At my first days with Manjaro and this laptop, nearly 2 years ago, I think, I had some troubles with hibernation, that were solved. Some nvidia questions, if I don’t mistake. Also, I disabled hybrid-suspend, since it doesn’t work.
I was using very pleasantly suspend-then-hibernate, with different timings, depending if I’m at home or on travel, etc.
Last monthes I wasn’t using much my laptop out of home, so I just set it to only suspend. But this days I’m on travel for long time, and I set it again to hibernate if not used on a couple of hours.
And I realized that it’s not working. It seems to operate properly (suspends, and at the proper time wakes shortly to suspend, then stops). but when you boot, it doesn’t recover the previous state, but seems not to find or to be able to use the image and just boots like completely fresh booting. And gives the logical journal errors to be cleaned, from not having stoped properly, since it was hibernating.
Can’t find what has changed. Perhaps systemd. I was on systemd 252 for long time, since 253 disabled the time based suspend-then-hibernate, on behalf of a battery check system, that doesn’t work for me in my laptop. Battery status is not detected, it seems, so it continues on suspend till battery goes out.
When systemd 254 was released, that has both systems implemented, I upgraded. And I used it in the same time based way as before. I cannot say that without doubts, but I’m pretty sure I was working properly after the upgrade to 254, if I’m not mistaken, I was using it some time in that way, before the time not using hibernate.
Now it’s the same if I use suspend-then-hibernate or just hibernate (using sudo systemctl hibernate or the button on the deltop shell is the same), it always fail as explained. It behaves as saveing properly the image and goes into sleed properly. But on wake seems not to find or being able to use the image.
On jounal I cannot find nothing strange… So, perhaps some of you could find anything that helps me. Hibernation is no completely a must for me… but very very useful sometimes when doing certain works. So, I would really like to have it back.
My inxi:
Inxi
Kernel: 6.6.8-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=4d2d0e11-44f4-4f14-a6dc-d1f83f358998 rw quiet
cryptdevice=UUID=95fc649b-53b3-4137-813b-69f906456198:luks-95fc649b-53b3-4137-813b-69f906456198
root=/dev/mapper/luks-95fc649b-53b3-4137-813b-69f906456198 apparmor=1
security=apparmor
resume=/dev/mapper/luks-e4419e8b-5200-43f2-9f1f-8f886ee1616a
udev.log_priority=3 ibt=off mem_sleep_default=deep
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel, cairo-dock
wm: xfwm v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: LENOVO product: 82K1 v: IdeaPad Gaming 3 15IHU6
serial: Chassis: type: 10 v: IdeaPad Gaming 3 15IHU6
serial:
Mobo: LENOVO model: LNVNB161216 v: No DPK serial:
UEFI: LENOVO v: H4CN23WW(V1.08) date: 02/11/2022
ID-1: BAT1 charge: 26.4 Wh (59.6%) condition: 44.3/45.0 Wh (98.4%)
volts: 11.9 min: 11.5 model: SMP L20M3PC2 type: Li-ion serial:
status: not charging cycles: 41
Info: model: 11th Gen Intel Core i5-11320H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 2
microcode: 0x34
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 443 high: 751 min/max: 400/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 751 4: 400
5: 400 6: 400 7: 400 8: 400 bogomips: 51008
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-11; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 bus-ID: 0000:01:00.0
chip-ID: 10de:1f9d class-ID: 0302
Device-3: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2 chip-ID: 174f:244c
class-ID: 0e02 serial:
Display: x11 server: X.Org v: 21.1.10 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
gpu: i915 display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x09d2 built: 2020 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 15.05 GiB unified: yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.6.8-2-MANJARO status: kernel-api with: aoss
Server-2: JACK v: 1.9.22 status: off with: 1: a2jmidid status: off 2: nsmd
status: off tools: cadence,jack_control,jack_mixer
Server-3: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
IF: wlp0s20f3 state: up mac:
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 0000:02:00.0
IF: enp2s0 state: down mac:
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4 chip-ID: 8087:0026
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 194.5 GiB (40.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512GZL
lanes: 4 tech: SSD serial: fw-rev: C01C temp: 23.9 C scheme: GPT
ID-1: / raw-size: 459.68 GiB size: 451.4 GiB (98.20%)
used: 194.48 GiB (43.1%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-95fc649b-53b3-4137-813b-69f906456198
used: 14.4 MiB (4.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 16.95 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-e4419e8b-5200-43f2-9f1f-8f886ee1616a
System Temperatures: cpu: 36.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 282 Uptime: 5m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.41 GiB used: 1.83 GiB (11.9%) Init: systemd v: 254
Packages: 2102 pm: pacman pkgs: 2093 libs: 500
tools: octopi,pacaur,pamac,trizen,yay pm: flatpak pkgs: 9 Shell: Bash
v: 5.2.21 running-in: xfce4-terminal inxi: 3.3.31
The journalctl at hibernation order
Hibernating
dic 28 19:59:03 nacho-Lenovo kernel: wlp0s20f3: deauthenticating from 24:d3:f2:ed:1b:3c by local choice (Reason: 3=DEAUTH_LEAVING)
dic 28 19:59:04 nacho-Lenovo kernel: PM: Image not found (code -16)
dic 28 19:59:04 nacho-Lenovo kernel: PM: hibernation: hibernation entry
And journalctl from the booting after the hibernation
Wake from hibernate
dic 28 20:00:19 nacho-Lenovo kernel: microcode: updated early: 0x16 → 0x34, date = 2023-09-07
dic 28 20:00:19 nacho-Lenovo kernel: Linux version 6.6.8-2-MANJARO (builduser@fv-az913-981) (gcc (GCC) 13.2.1 20230801, GNU ld (GNU Binutils) 2.41.0) #1 SMP PREEMPT_DYNAMIC Thu Dec 21 16:21:45 UTC 2023
dic 28 20:00:19 nacho-Lenovo kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=4d2d0e11-44f4-4f14-a6dc-d1f83f358998 rw quiet cryptdevice=UUID=95fc649b-53b3-4137-813b-69f906456198:luks-95fc649b-53b3-4137-813b-69f906456198 root=/dev/mapper/luks-95fc649b-53b3-4137-813b-69f906456198 apparmor=1 security=apparmor resume=/dev/mapper/luks-e4419e8b-5200-43f2-9f1f-8f886ee1616a udev.log_priority=3 ibt=off mem_sleep_default=deep
dic 28 20:00:19 nacho-Lenovo kernel: x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
dic 28 20:00:19 nacho-Lenovo kernel: BIOS-provided physical RAM map:
dic 28 20:00:19 nacho-Lenovo kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
dic 28 20:00:19 nacho-Lenovo kernel: BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
dic 28 20:00:19 nacho-Lenovo kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000040d98fff] usable
dic 28 20:00:19 nacho-Lenovo kernel: BIOS-e820: [mem 0x0000000040d99000-0x0000000041698fff] reserved
dic 28 20:00:19 nacho-Lenovo kernel: BIOS-e820: [mem 0x0000000041699000-0x00000000434aefff] usable
dic 28 20:00:19 nacho-Lenovo kernel: BIOS-e820: [mem 0x00000000434af000-0x00000000452fefff] reserved
dic 28 20:00:19 nacho-Lenovo kernel: BIOS-e820: [mem 0x00000000452ff000-0x0000000045b2efff] ACPI NVS
dic 28 20:00:19 nacho-Lenovo kernel: BIOS-e820: [mem 0x0000000045b2f000-0x0000000045bfefff] ACPI data
dic 28 20:00:19 nacho-Lenovo kernel: BIOS-e820: [mem 0x0000000045bff000-0x0000000045bfffff] usable
dic 28 20:00:19 nacho-Lenovo kernel: BIOS-e820: [mem 0x0000000045c00000-0x0000000049ffffff] reserved
dic 28 20:00:19 nacho-Lenovo kernel: BIOS-e820: [mem 0x000000004a200000-0x000000004a3fffff] reserved
dic 28 20:00:19 nacho-Lenovo kernel: BIOS-e820: [mem 0x000000004b000000-0x00000000503fffff] reserved
dic 28 20:00:19 nacho-Lenovo kernel: BIOS-e820: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
dic 28 20:00:19 nacho-Lenovo kernel: BIOS-e820: [mem 0x00000000fe010000-0x00000000fe010fff] reserved
dic 28 20:00:19 nacho-Lenovo kernel: BIOS-e820: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
dic 28 20:00:19 nacho-Lenovo kernel: BIOS-e820: [mem 0x00000000ff200000-0x00000000ffffffff] reserved
dic 28 20:00:19 nacho-Lenovo kernel: BIOS-e820: [mem 0x0000000100000000-0x00000004afbfffff] usable
dic 28 20:00:19 nacho-Lenovo kernel: NX (Execute Disable) protection: active
dic 28 20:00:19 nacho-Lenovo kernel: APIC: Static calls initialized
dic 28 20:00:19 nacho-Lenovo kernel: e820: update [mem 0x3c832018-0x3c841057] usable ==> usable
dic 28 20:00:19 nacho-Lenovo kernel: extended physical RAM map:
dic 28 20:00:19 nacho-Lenovo kernel: reserve setup_data: [mem 0x0000000000000000-0x000000000009efff] usable
dic 28 20:00:19 nacho-Lenovo kernel: reserve setup_data: [mem 0x000000000009f000-0x00000000000fffff] reserved
dic 28 20:00:19 nacho-Lenovo kernel: reserve setup_data: [mem 0x0000000000100000-0x000000003c832017] usable
dic 28 20:00:19 nacho-Lenovo kernel: reserve setup_data: [mem 0x000000003c832018-0x000000003c841057] usable
dic 28 20:00:19 nacho-Lenovo kernel: reserve setup_data: [mem 0x000000003c841058-0x0000000040d98fff] usable
dic 28 20:00:19 nacho-Lenovo kernel: reserve setup_data: [mem 0x0000000040d99000-0x0000000041698fff] reserved
dic 28 20:00:19 nacho-Lenovo kernel: reserve setup_data: [mem 0x0000000041699000-0x00000000434aefff] usable
dic 28 20:00:19 nacho-Lenovo kernel: reserve setup_data: [mem 0x00000000434af000-0x00000000452fefff] reserved
dic 28 20:00:19 nacho-Lenovo kernel: reserve setup_data: [mem 0x00000000452ff000-0x0000000045b2efff] ACPI NVS
dic 28 20:00:19 nacho-Lenovo kernel: reserve setup_data: [mem 0x0000000045b2f000-0x0000000045bfefff] ACPI data
dic 28 20:00:19 nacho-Lenovo kernel: reserve setup_data: [mem 0x0000000045bff000-0x0000000045bfffff] usable
dic 28 20:00:19 nacho-Lenovo kernel: reserve setup_data: [mem 0x0000000045c00000-0x0000000049ffffff] reserved
dic 28 20:00:19 nacho-Lenovo kernel: reserve setup_data: [mem 0x000000004a200000-0x000000004a3fffff] reserved
dic 28 20:00:19 nacho-Lenovo kernel: reserve setup_data: [mem 0x000000004b000000-0x00000000503fffff] reserved
dic 28 20:00:19 nacho-Lenovo kernel: reserve setup_data: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
dic 28 20:00:19 nacho-Lenovo kernel: reserve setup_data: [mem 0x00000000fe010000-0x00000000fe010fff] reserved
dic 28 20:00:19 nacho-Lenovo kernel: reserve setup_data: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
dic 28 20:00:19 nacho-Lenovo kernel: reserve setup_data: [mem 0x00000000ff200000-0x00000000ffffffff] reserved
dic 28 20:00:19 nacho-Lenovo kernel: reserve setup_data: [mem 0x0000000100000000-0x00000004afbfffff] usable
dic 28 20:00:19 nacho-Lenovo kernel: efi: EFI v2.7 by INSYDE Corp.
dic 28 20:00:19 nacho-Lenovo kernel: efi: ACPI=0x45bfe000 ACPI 2.0=0x45bfe014 TPMFinalLog=0x45ac5000 SMBIOS=0x439e0000 SMBIOS 3.0=0x439de000 MEMATTR=0x3cb06018 ESRT=0x3cb0a018 INITRD=0x3cb07c18 RNG=0x45b70018 TPMEventLog=0x3caf1018
dic 28 20:00:19 nacho-Lenovo kernel: random: crng init done
dic 28 20:00:19 nacho-Lenovo kernel: efi: Remove mem77: MMIO range=[0xc0000000-0xcfffffff] (256MB) from e820 map
dic 28 20:00:19 nacho-Lenovo kernel: e820: remove [mem 0xc0000000-0xcfffffff] reserved
dic 28 20:00:19 nacho-Lenovo kernel: efi: Not removing mem78: MMIO range=[0xfe010000-0xfe010fff] (4KB) from e820 map
dic 28 20:00:19 nacho-Lenovo kernel: efi: Remove mem80: MMIO range=[0xff200000-0xffffffff] (14MB) from e820 map
dic 28 20:00:19 nacho-Lenovo kernel: e820: remove [mem 0xff200000-0xffffffff] reserved
dic 28 20:00:19 nacho-Lenovo kernel: SMBIOS 3.3.0 present.
dic 28 20:00:19 nacho-Lenovo kernel: DMI: LENOVO 82K1/LNVNB161216, BIOS H4CN23WW(V1.08) 02/11/2022
dic 28 20:00:19 nacho-Lenovo kernel: tsc: Detected 3200.000 MHz processor
dic 28 20:00:19 nacho-Lenovo kernel: tsc: Detected 3187.200 MHz TSC
dic 28 20:00:19 nacho-Lenovo kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
dic 28 20:00:19 nacho-Lenovo kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
dic 28 20:00:19 nacho-Lenovo kernel: last_pfn = 0x4afc00 max_arch_pfn = 0x400000000
dic 28 20:00:19 nacho-Lenovo kernel: MTRR map: 5 entries (3 fixed + 2 variable; max 23), built from 10 variable MTRRs
dic 28 20:00:19 nacho-Lenovo kernel: x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
dic 28 20:00:19 nacho-Lenovo kernel: last_pfn = 0x45c00 max_arch_pfn = 0x400000000
dic 28 20:00:19 nacho-Lenovo kernel: esrt: Reserving ESRT space from 0x000000003cb0a018 to 0x000000003cb0a118.
dic 28 20:00:19 nacho-Lenovo kernel: e820: update [mem 0x3cb0a000-0x3cb0afff] usable ==> reserved
dic 28 20:00:19 nacho-Lenovo kernel: Using GB pages for direct mapping
dic 28 20:00:19 nacho-Lenovo kernel: Secure boot disabled
dic 28 20:00:19 nacho-Lenovo kernel: RAMDISK: [mem 0x38657000-0x3b258fff]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Early table checksum verification disabled
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: RSDP 0x0000000045BFE014 000024 (v02 LENOVO)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: XSDT 0x0000000045BD7188 00012C (v01 LENOVO CB-01 00000001 01000013)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: FACP 0x0000000045BD9000 000114 (v06 LENOVO CB-01 00000001 ACPI 00040000)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: DSDT 0x0000000045B7F000 056C0C (v02 LENOVO CB-01 00000001 ACPI 00040000)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: FACS 0x0000000045AA4000 000040
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: UEFI 0x0000000045B2E000 000236 (v01 LENOVO CB-01 00000001 ACPI 00040000)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: SSDT 0x0000000045BFA000 00255C (v02 LENOVO CB-01 00000001 INTL 20160422)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: SSDT 0x0000000045BF6000 003586 (v02 LENOVO CB-01 00000001 INTL 20160422)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: SSDT 0x0000000045BF5000 000106 (v02 LENOVO CB-01 00000001 INTL 20160422)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: SSDT 0x0000000045BEF000 005A4E (v02 LENOVO CB-01 00000001 INTL 20160422)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: SSDT 0x0000000045BEB000 003DC4 (v02 LENOVO CB-01 00000001 INTL 20160422)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: SSDT 0x0000000045BE7000 003300 (v02 LENOVO CB-01 00000001 INTL 20160422)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: SSDT 0x0000000045BE6000 00081F (v02 LENOVO CB-01 00000001 INTL 20160422)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: SSDT 0x0000000045BE5000 000033 (v02 LENOVO CB-01 00000001 INTL 20160422)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: SSDT 0x0000000045BE4000 00077B (v02 LENOVO CB-01 00000001 INTL 20160422)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: TPM2 0x0000000045BE3000 00004C (v04 LENOVO CB-01 00000001 ACPI 00040000)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: NHLT 0x0000000045BE0000 00189E (v00 LENOVO CB-01 00000001 ACPI 00040000)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: LPIT 0x0000000045BDF000 0000CC (v01 LENOVO CB-01 00000001 ACPI 00040000)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: WSMT 0x0000000045BDE000 000028 (v01 LENOVO CB-01 00000001 ACPI 00040000)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: SSDT 0x0000000045BDD000 000B70 (v02 LENOVO CB-01 00000001 INTL 20160422)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: SSDT 0x0000000045BDC000 00012A (v02 LENOVO CB-01 00000001 INTL 20160422)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: DBGP 0x0000000045BDB000 000034 (v01 LENOVO CB-01 00000001 ACPI 00040000)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: DBG2 0x0000000045BDA000 000054 (v00 LENOVO CB-01 00000001 ACPI 00040000)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: HPET 0x0000000045BD8000 000038 (v01 LENOVO CB-01 00000001 ACPI 00040000)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: APIC 0x0000000045BFD000 00012C (v04 LENOVO CB-01 00000001 ACPI 00040000)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: MCFG 0x0000000045BD6000 00003C (v01 LENOVO CB-01 00000001 ACPI 00040000)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: SSDT 0x0000000045B7A000 0042BB (v02 LENOVO CB-01 00000001 01000013)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: SSDT 0x0000000045B79000 000CF6 (v02 LENOVO CB-01 00000001 01000013)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: DMAR 0x0000000045B78000 000088 (v02 LENOVO CB-01 00000001 ACPI 00040000)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: SSDT 0x0000000045B76000 001F3D (v01 LENOVO CB-01 00000001 INTL 20160422)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: UEFI 0x0000000045A5D000 00063A (v01 LENOVO CB-01 00000001 ACPI 00040000)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: UEFI 0x0000000045A5C000 00005C (v01 LENOVO CB-01 00000001 ACPI 00040000)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: SSDT 0x0000000045B75000 000DB8 (v02 LENOVO CB-01 00000001 INTL 20160422)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: SSDT 0x0000000045B74000 0000F8 (v01 LENOVO CB-01 00000001 INTL 20160422)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: FPDT 0x0000000045B73000 000044 (v01 LENOVO CB-01 00000001 ACPI 00040000)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: BGRT 0x0000000045B72000 000038 (v01 LENOVO CB-01 00000001 ACPI 00040000)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: PTDT 0x0000000045B71000 000CFE (v00 LENOVO CB-01 00000001 ACPI 00040000)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving FACP table memory at [mem 0x45bd9000-0x45bd9113]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving DSDT table memory at [mem 0x45b7f000-0x45bd5c0b]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving FACS table memory at [mem 0x45aa4000-0x45aa403f]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving UEFI table memory at [mem 0x45b2e000-0x45b2e235]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving SSDT table memory at [mem 0x45bfa000-0x45bfc55b]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving SSDT table memory at [mem 0x45bf6000-0x45bf9585]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving SSDT table memory at [mem 0x45bf5000-0x45bf5105]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving SSDT table memory at [mem 0x45bef000-0x45bf4a4d]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving SSDT table memory at [mem 0x45beb000-0x45beedc3]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving SSDT table memory at [mem 0x45be7000-0x45bea2ff]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving SSDT table memory at [mem 0x45be6000-0x45be681e]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving SSDT table memory at [mem 0x45be5000-0x45be5032]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving SSDT table memory at [mem 0x45be4000-0x45be477a]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving TPM2 table memory at [mem 0x45be3000-0x45be304b]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving NHLT table memory at [mem 0x45be0000-0x45be189d]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving LPIT table memory at [mem 0x45bdf000-0x45bdf0cb]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving WSMT table memory at [mem 0x45bde000-0x45bde027]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving SSDT table memory at [mem 0x45bdd000-0x45bddb6f]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving SSDT table memory at [mem 0x45bdc000-0x45bdc129]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving DBGP table memory at [mem 0x45bdb000-0x45bdb033]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving DBG2 table memory at [mem 0x45bda000-0x45bda053]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving HPET table memory at [mem 0x45bd8000-0x45bd8037]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving APIC table memory at [mem 0x45bfd000-0x45bfd12b]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving MCFG table memory at [mem 0x45bd6000-0x45bd603b]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving SSDT table memory at [mem 0x45b7a000-0x45b7e2ba]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving SSDT table memory at [mem 0x45b79000-0x45b79cf5]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving DMAR table memory at [mem 0x45b78000-0x45b78087]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving SSDT table memory at [mem 0x45b76000-0x45b77f3c]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving UEFI table memory at [mem 0x45a5d000-0x45a5d639]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving UEFI table memory at [mem 0x45a5c000-0x45a5c05b]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving SSDT table memory at [mem 0x45b75000-0x45b75db7]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving SSDT table memory at [mem 0x45b74000-0x45b740f7]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving FPDT table memory at [mem 0x45b73000-0x45b73043]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving BGRT table memory at [mem 0x45b72000-0x45b72037]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Reserving PTDT table memory at [mem 0x45b71000-0x45b71cfd]
dic 28 20:00:19 nacho-Lenovo kernel: No NUMA configuration found
dic 28 20:00:19 nacho-Lenovo kernel: Faking a node at [mem 0x0000000000000000-0x00000004afbfffff]
dic 28 20:00:19 nacho-Lenovo kernel: NODE_DATA(0) allocated [mem 0x4afbfb000-0x4afbfffff]
dic 28 20:00:19 nacho-Lenovo kernel: Zone ranges:
dic 28 20:00:19 nacho-Lenovo kernel: DMA [mem 0x0000000000001000-0x0000000000ffffff]
dic 28 20:00:19 nacho-Lenovo kernel: DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
dic 28 20:00:19 nacho-Lenovo kernel: Normal [mem 0x0000000100000000-0x00000004afbfffff]
dic 28 20:00:19 nacho-Lenovo kernel: Device empty
dic 28 20:00:19 nacho-Lenovo kernel: Movable zone start for each node
dic 28 20:00:19 nacho-Lenovo kernel: Early memory node ranges
dic 28 20:00:19 nacho-Lenovo kernel: node 0: [mem 0x0000000000001000-0x000000000009efff]
dic 28 20:00:19 nacho-Lenovo kernel: node 0: [mem 0x0000000000100000-0x0000000040d98fff]
dic 28 20:00:19 nacho-Lenovo kernel: node 0: [mem 0x0000000041699000-0x00000000434aefff]
dic 28 20:00:19 nacho-Lenovo kernel: node 0: [mem 0x0000000045bff000-0x0000000045bfffff]
dic 28 20:00:19 nacho-Lenovo kernel: node 0: [mem 0x0000000100000000-0x00000004afbfffff]
dic 28 20:00:19 nacho-Lenovo kernel: Initmem setup node 0 [mem 0x0000000000001000-0x00000004afbfffff]
dic 28 20:00:19 nacho-Lenovo kernel: On node 0, zone DMA: 1 pages in unavailable ranges
dic 28 20:00:19 nacho-Lenovo kernel: On node 0, zone DMA: 97 pages in unavailable ranges
dic 28 20:00:19 nacho-Lenovo kernel: On node 0, zone DMA32: 2304 pages in unavailable ranges
dic 28 20:00:19 nacho-Lenovo kernel: On node 0, zone DMA32: 10064 pages in unavailable ranges
dic 28 20:00:19 nacho-Lenovo kernel: On node 0, zone Normal: 9216 pages in unavailable ranges
dic 28 20:00:19 nacho-Lenovo kernel: On node 0, zone Normal: 1024 pages in unavailable ranges
dic 28 20:00:19 nacho-Lenovo kernel: Reserving Intel graphics memory at [mem 0x4c800000-0x503fffff]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: PM-Timer IO Port: 0x1808
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
dic 28 20:00:19 nacho-Lenovo kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Using ACPI (MADT) for SMP configuration information
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: HPET id: 0x8086a201 base: 0xfed00000
dic 28 20:00:19 nacho-Lenovo kernel: e820: update [mem 0x3cb0e000-0x3cc1cfff] usable ==> reserved
dic 28 20:00:19 nacho-Lenovo kernel: TSC deadline timer available
dic 28 20:00:19 nacho-Lenovo kernel: smpboot: Allowing 8 CPUs, 0 hotplug CPUs
dic 28 20:00:19 nacho-Lenovo kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
dic 28 20:00:19 nacho-Lenovo kernel: PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
dic 28 20:00:19 nacho-Lenovo kernel: PM: hibernation: Registered nosave memory: [mem 0x3c832000-0x3c832fff]
dic 28 20:00:19 nacho-Lenovo kernel: PM: hibernation: Registered nosave memory: [mem 0x3c841000-0x3c841fff]
dic 28 20:00:19 nacho-Lenovo kernel: PM: hibernation: Registered nosave memory: [mem 0x3cb0a000-0x3cb0afff]
dic 28 20:00:19 nacho-Lenovo kernel: PM: hibernation: Registered nosave memory: [mem 0x3cb0e000-0x3cc1cfff]
dic 28 20:00:19 nacho-Lenovo kernel: PM: hibernation: Registered nosave memory: [mem 0x40d99000-0x41698fff]
dic 28 20:00:19 nacho-Lenovo kernel: PM: hibernation: Registered nosave memory: [mem 0x434af000-0x452fefff]
dic 28 20:00:19 nacho-Lenovo kernel: PM: hibernation: Registered nosave memory: [mem 0x452ff000-0x45b2efff]
dic 28 20:00:19 nacho-Lenovo kernel: PM: hibernation: Registered nosave memory: [mem 0x45b2f000-0x45bfefff]
dic 28 20:00:19 nacho-Lenovo kernel: PM: hibernation: Registered nosave memory: [mem 0x45c00000-0x49ffffff]
dic 28 20:00:19 nacho-Lenovo kernel: PM: hibernation: Registered nosave memory: [mem 0x4a000000-0x4a1fffff]
dic 28 20:00:19 nacho-Lenovo kernel: PM: hibernation: Registered nosave memory: [mem 0x4a200000-0x4a3fffff]
dic 28 20:00:19 nacho-Lenovo kernel: PM: hibernation: Registered nosave memory: [mem 0x4a400000-0x4affffff]
dic 28 20:00:19 nacho-Lenovo kernel: PM: hibernation: Registered nosave memory: [mem 0x4b000000-0x503fffff]
dic 28 20:00:19 nacho-Lenovo kernel: PM: hibernation: Registered nosave memory: [mem 0x50400000-0xfe00ffff]
dic 28 20:00:19 nacho-Lenovo kernel: PM: hibernation: Registered nosave memory: [mem 0xfe010000-0xfe010fff]
dic 28 20:00:19 nacho-Lenovo kernel: PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfed1ffff]
dic 28 20:00:19 nacho-Lenovo kernel: PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfed7ffff]
dic 28 20:00:19 nacho-Lenovo kernel: PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xffffffff]
dic 28 20:00:19 nacho-Lenovo kernel: [mem 0x50400000-0xfe00ffff] available for PCI devices
dic 28 20:00:19 nacho-Lenovo kernel: Booting paravirtualized kernel on bare hardware
dic 28 20:00:19 nacho-Lenovo kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
dic 28 20:00:19 nacho-Lenovo kernel: setup_percpu: NR_CPUS:320 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
dic 28 20:00:19 nacho-Lenovo kernel: percpu: Embedded 64 pages/cpu s225280 r8192 d28672 u262144
dic 28 20:00:19 nacho-Lenovo kernel: pcpu-alloc: s225280 r8192 d28672 u262144 alloc=1*2097152
dic 28 20:00:19 nacho-Lenovo kernel: pcpu-alloc: [0] 0 1 2 3 4 5 6 7
dic 28 20:00:19 nacho-Lenovo kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=4d2d0e11-44f4-4f14-a6dc-d1f83f358998 rw quiet cryptdevice=UUID=95fc649b-53b3-4137-813b-69f906456198:luks-95fc649b-53b3-4137-813b-69f906456198 root=/dev/mapper/luks-95fc649b-53b3-4137-813b-69f906456198 apparmor=1 security=apparmor resume=/dev/mapper/luks-e4419e8b-5200-43f2-9f1f-8f886ee1616a udev.log_priority=3 ibt=off mem_sleep_default=deep
dic 28 20:00:19 nacho-Lenovo kernel: Unknown kernel command line parameters “BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 cryptdevice=UUID=95fc649b-53b3-4137-813b-69f906456198:luks-95fc649b-53b3-4137-813b-69f906456198”, will be passed to user space.
dic 28 20:00:19 nacho-Lenovo kernel: Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
dic 28 20:00:19 nacho-Lenovo kernel: Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
dic 28 20:00:19 nacho-Lenovo kernel: Fallback order for Node 0: 0
dic 28 20:00:19 nacho-Lenovo kernel: Built 1 zonelists, mobility grouping on. Total pages: 4074001
dic 28 20:00:19 nacho-Lenovo kernel: Policy zone: Normal
dic 28 20:00:19 nacho-Lenovo kernel: mem auto-init: stack:all(zero), heap alloc:on, heap free:off
dic 28 20:00:19 nacho-Lenovo kernel: software IO TLB: area num 8.
dic 28 20:00:19 nacho-Lenovo kernel: Memory: 16014396K/16555320K available (16384K kernel code, 2150K rwdata, 13148K rodata, 3424K init, 3784K bss, 540668K reserved, 0K cma-reserved)
dic 28 20:00:19 nacho-Lenovo kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
dic 28 20:00:19 nacho-Lenovo kernel: ftrace: allocating 49001 entries in 192 pages
dic 28 20:00:19 nacho-Lenovo kernel: ftrace: allocated 192 pages with 2 groups
dic 28 20:00:19 nacho-Lenovo kernel: Dynamic Preempt: full
dic 28 20:00:19 nacho-Lenovo kernel: rcu: Preemptible hierarchical RCU implementation.
dic 28 20:00:19 nacho-Lenovo kernel: rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=8.
dic 28 20:00:19 nacho-Lenovo kernel: rcu: RCU priority boosting: priority 1 delay 500 ms.
dic 28 20:00:19 nacho-Lenovo kernel: Trampoline variant of Tasks RCU enabled.
dic 28 20:00:19 nacho-Lenovo kernel: Rude variant of Tasks RCU enabled.
dic 28 20:00:19 nacho-Lenovo kernel: Tracing variant of Tasks RCU enabled.
dic 28 20:00:19 nacho-Lenovo kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
dic 28 20:00:19 nacho-Lenovo kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
dic 28 20:00:19 nacho-Lenovo kernel: NR_IRQS: 20736, nr_irqs: 2048, preallocated irqs: 16
dic 28 20:00:19 nacho-Lenovo kernel: rcu: srcu_init: Setting srcu_struct sizes based on contention.
dic 28 20:00:19 nacho-Lenovo kernel: kfence: initialized - using 2097152 bytes for 255 objects at 0x(ptrval)-0x(ptrval)
dic 28 20:00:19 nacho-Lenovo kernel: Console: colour dummy device 80x25
dic 28 20:00:19 nacho-Lenovo kernel: printk: console [tty0] enabled
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Core revision 20230628
dic 28 20:00:19 nacho-Lenovo kernel: hpet: HPET dysfunctional in PC10. Force disabled.
dic 28 20:00:19 nacho-Lenovo kernel: APIC: Switch to symmetric I/O mode setup
dic 28 20:00:19 nacho-Lenovo kernel: DMAR: Host address width 39
dic 28 20:00:19 nacho-Lenovo kernel: DMAR: DRHD base: 0x000000fed90000 flags: 0x0
dic 28 20:00:19 nacho-Lenovo kernel: DMAR: dmar0: reg_base_addr fed90000 ver 4:0 cap 1c0000c40660462 ecap 29a00f0505e
dic 28 20:00:19 nacho-Lenovo kernel: DMAR: DRHD base: 0x000000fed91000 flags: 0x1
dic 28 20:00:19 nacho-Lenovo kernel: DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
dic 28 20:00:19 nacho-Lenovo kernel: DMAR: RMRR base: 0x0000004c000000 end: 0x000000503fffff
dic 28 20:00:19 nacho-Lenovo kernel: DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 1
dic 28 20:00:19 nacho-Lenovo kernel: DMAR-IR: HPET id 0 under DRHD base 0xfed91000
dic 28 20:00:19 nacho-Lenovo kernel: DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
dic 28 20:00:19 nacho-Lenovo kernel: DMAR-IR: Enabled IRQ remapping in x2apic mode
dic 28 20:00:19 nacho-Lenovo kernel: x2apic enabled
dic 28 20:00:19 nacho-Lenovo kernel: APIC: Switched APIC routing to: cluster x2apic
dic 28 20:00:19 nacho-Lenovo kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2df10e7656b, max_idle_ns: 440795364873 ns
dic 28 20:00:19 nacho-Lenovo kernel: Calibrating delay loop (skipped), value calculated using timer frequency… 6376.00 BogoMIPS (lpj=10624000)
dic 28 20:00:19 nacho-Lenovo kernel: CPU0: Thermal monitoring enabled (TM1)
dic 28 20:00:19 nacho-Lenovo kernel: x86/cpu: User Mode Instruction Prevention (UMIP) activated
dic 28 20:00:19 nacho-Lenovo kernel: process: using mwait in idle threads
dic 28 20:00:19 nacho-Lenovo kernel: Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
dic 28 20:00:19 nacho-Lenovo kernel: Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
dic 28 20:00:19 nacho-Lenovo kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and user pointer sanitization
dic 28 20:00:19 nacho-Lenovo kernel: Spectre V2 : Mitigation: Enhanced / Automatic IBRS
dic 28 20:00:19 nacho-Lenovo kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
dic 28 20:00:19 nacho-Lenovo kernel: Spectre V2 : Spectre v2 / PBRSB-eIBRS: Retire a single CALL on VMEXIT
dic 28 20:00:19 nacho-Lenovo kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
dic 28 20:00:19 nacho-Lenovo kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
dic 28 20:00:19 nacho-Lenovo kernel: GDS: Mitigation: Microcode
dic 28 20:00:19 nacho-Lenovo kernel: x86/fpu: Supporting XSAVE feature 0x001: ‘x87 floating point registers’
dic 28 20:00:19 nacho-Lenovo kernel: x86/fpu: Supporting XSAVE feature 0x002: ‘SSE registers’
dic 28 20:00:19 nacho-Lenovo kernel: x86/fpu: Supporting XSAVE feature 0x004: ‘AVX registers’
dic 28 20:00:19 nacho-Lenovo kernel: x86/fpu: Supporting XSAVE feature 0x020: ‘AVX-512 opmask’
dic 28 20:00:19 nacho-Lenovo kernel: x86/fpu: Supporting XSAVE feature 0x040: ‘AVX-512 Hi256’
dic 28 20:00:19 nacho-Lenovo kernel: x86/fpu: Supporting XSAVE feature 0x080: ‘AVX-512 ZMM_Hi256’
dic 28 20:00:19 nacho-Lenovo kernel: x86/fpu: Supporting XSAVE feature 0x200: ‘Protection Keys User registers’
dic 28 20:00:19 nacho-Lenovo kernel: x86/fpu: Supporting XSAVE feature 0x800: ‘Control-flow User registers’
dic 28 20:00:19 nacho-Lenovo kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
dic 28 20:00:19 nacho-Lenovo kernel: x86/fpu: xstate_offset[5]: 832, xstate_sizes[5]: 64
dic 28 20:00:19 nacho-Lenovo kernel: x86/fpu: xstate_offset[6]: 896, xstate_sizes[6]: 512
dic 28 20:00:19 nacho-Lenovo kernel: x86/fpu: xstate_offset[7]: 1408, xstate_sizes[7]: 1024
dic 28 20:00:19 nacho-Lenovo kernel: x86/fpu: xstate_offset[9]: 2432, xstate_sizes[9]: 8
dic 28 20:00:19 nacho-Lenovo kernel: x86/fpu: xstate_offset[11]: 2440, xstate_sizes[11]: 16
dic 28 20:00:19 nacho-Lenovo kernel: x86/fpu: Enabled xstate features 0xae7, context size is 2456 bytes, using ‘compacted’ format.
dic 28 20:00:19 nacho-Lenovo kernel: Freeing SMP alternatives memory: 40K
dic 28 20:00:19 nacho-Lenovo kernel: pid_max: default: 32768 minimum: 301
dic 28 20:00:19 nacho-Lenovo kernel: LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,apparmor,integrity
dic 28 20:00:19 nacho-Lenovo kernel: landlock: Up and running.
dic 28 20:00:19 nacho-Lenovo kernel: Yama: becoming mindful.
dic 28 20:00:19 nacho-Lenovo kernel: LSM support for eBPF active
dic 28 20:00:19 nacho-Lenovo kernel: AppArmor: AppArmor initialized
dic 28 20:00:19 nacho-Lenovo kernel: Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
dic 28 20:00:19 nacho-Lenovo kernel: Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
dic 28 20:00:19 nacho-Lenovo kernel: smpboot: CPU0: 11th Gen Intel(R) Core™ i5-11320H @ 3.20GHz (family: 0x6, model: 0x8c, stepping: 0x2)
dic 28 20:00:19 nacho-Lenovo kernel: RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
dic 28 20:00:19 nacho-Lenovo kernel: RCU Tasks Rude: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
dic 28 20:00:19 nacho-Lenovo kernel: RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
dic 28 20:00:19 nacho-Lenovo kernel: Performance Events: PEBS fmt4±baseline, AnyThread deprecated, Icelake events, 32-deep LBR, full-width counters, Intel PMU driver.
dic 28 20:00:19 nacho-Lenovo kernel: … version: 5
dic 28 20:00:19 nacho-Lenovo kernel: … bit width: 48
dic 28 20:00:19 nacho-Lenovo kernel: … generic registers: 8
dic 28 20:00:19 nacho-Lenovo kernel: … value mask: 0000ffffffffffff
dic 28 20:00:19 nacho-Lenovo kernel: … max period: 00007fffffffffff
dic 28 20:00:19 nacho-Lenovo kernel: … fixed-purpose events: 4
dic 28 20:00:19 nacho-Lenovo kernel: … event mask: 0001000f000000ff
dic 28 20:00:19 nacho-Lenovo kernel: signal: max sigframe size: 3632
dic 28 20:00:19 nacho-Lenovo kernel: Estimated ratio of average max frequency by base frequency (times 1024): 1376
dic 28 20:00:19 nacho-Lenovo kernel: rcu: Hierarchical SRCU implementation.
dic 28 20:00:19 nacho-Lenovo kernel: rcu: Max phase no-delay instances is 1000.
dic 28 20:00:19 nacho-Lenovo kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
dic 28 20:00:19 nacho-Lenovo kernel: smp: Bringing up secondary CPUs …
dic 28 20:00:19 nacho-Lenovo kernel: smpboot: x86: Booting SMP configuration:
dic 28 20:00:19 nacho-Lenovo kernel: … node #0, CPUs: #1 #2 #3 #4 #5 #6 #7
dic 28 20:00:19 nacho-Lenovo kernel: smp: Brought up 1 node, 8 CPUs
dic 28 20:00:19 nacho-Lenovo kernel: smpboot: Max logical packages: 1
dic 28 20:00:19 nacho-Lenovo kernel: smpboot: Total of 8 processors activated (51015.00 BogoMIPS)
dic 28 20:00:19 nacho-Lenovo kernel: devtmpfs: initialized
dic 28 20:00:19 nacho-Lenovo kernel: x86/mm: Memory block size: 128MB
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: PM: Registering ACPI NVS region [mem 0x452ff000-0x45b2efff] (8585216 bytes)
dic 28 20:00:19 nacho-Lenovo kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
dic 28 20:00:19 nacho-Lenovo kernel: futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
dic 28 20:00:19 nacho-Lenovo kernel: pinctrl core: initialized pinctrl subsystem
dic 28 20:00:19 nacho-Lenovo kernel: PM: RTC time: 19:00:11, date: 2023-12-28
dic 28 20:00:19 nacho-Lenovo kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
dic 28 20:00:19 nacho-Lenovo kernel: DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
dic 28 20:00:19 nacho-Lenovo kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
dic 28 20:00:19 nacho-Lenovo kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
dic 28 20:00:19 nacho-Lenovo kernel: audit: initializing netlink subsys (disabled)
dic 28 20:00:19 nacho-Lenovo kernel: audit: type=2000 audit(1703790011.006:1): state=initialized audit_enabled=0 res=1
dic 28 20:00:19 nacho-Lenovo kernel: thermal_sys: Registered thermal governor ‘fair_share’
dic 28 20:00:19 nacho-Lenovo kernel: thermal_sys: Registered thermal governor ‘bang_bang’
dic 28 20:00:19 nacho-Lenovo kernel: thermal_sys: Registered thermal governor ‘step_wise’
dic 28 20:00:19 nacho-Lenovo kernel: thermal_sys: Registered thermal governor ‘user_space’
dic 28 20:00:19 nacho-Lenovo kernel: thermal_sys: Registered thermal governor ‘power_allocator’
dic 28 20:00:19 nacho-Lenovo kernel: cpuidle: using governor ladder
dic 28 20:00:19 nacho-Lenovo kernel: cpuidle: using governor menu
dic 28 20:00:19 nacho-Lenovo kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
dic 28 20:00:19 nacho-Lenovo kernel: PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xc0000000-0xcfffffff] (base 0xc0000000)
dic 28 20:00:19 nacho-Lenovo kernel: PCI: not using MMCONFIG
dic 28 20:00:19 nacho-Lenovo kernel: PCI: Using configuration type 1 for base access
dic 28 20:00:19 nacho-Lenovo kernel: ENERGY_PERF_BIAS: Set to ‘normal’, was ‘performance’
dic 28 20:00:19 nacho-Lenovo kernel: kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
dic 28 20:00:19 nacho-Lenovo kernel: HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
dic 28 20:00:19 nacho-Lenovo kernel: HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
dic 28 20:00:19 nacho-Lenovo kernel: HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
dic 28 20:00:19 nacho-Lenovo kernel: HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Added OSI(Module Device)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Added OSI(Processor Device)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Added OSI(3.0 SCP Extensions)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Added OSI(Processor Aggregator Device)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI BIOS Error (bug): Could not resolve symbol [_SB.PC00.I2C0.TPD0], AE_NOT_FOUND (20230628/dswload2-162)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20230628/psobject-220)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Skipping parse of AML opcode: Scope (0x0010)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI BIOS Error (bug): Could not resolve symbol [_SB.PC00.I2C0.TPL1], AE_NOT_FOUND (20230628/dswload2-162)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: 17 ACPI AML tables successfully acquired and loaded
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Dynamic OEM Table Load:
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: SSDT 0xFFFF888100F60C00 000386 (v02 PmRef Cpu0Cst 00003001 INTL 20160422)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: SSDT 0xFFFF888100F55800 0006CB (v02 PmRef Cpu0Ist 00003000 INTL 20160422)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: SSDT 0xFFFF888101A1A400 0001C6 (v02 PmRef Cpu0Psd 00003000 INTL 20160422)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: SSDT 0xFFFF888100F66C00 00028B (v02 PmRef Cpu0Hwp 00003000 INTL 20160422)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: SSDT 0xFFFF888100F58000 0008E7 (v02 PmRef ApIst 00003000 INTL 20160422)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: SSDT 0xFFFF888100F54800 00048A (v02 PmRef ApHwp 00003000 INTL 20160422)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: SSDT 0xFFFF888100F57800 0004D4 (v02 PmRef ApPsd 00003000 INTL 20160422)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: SSDT 0xFFFF888100F53800 00048A (v02 PmRef ApCst 00003000 INTL 20160422)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: OSC evaluated successfully for all CPUs
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: EC: EC started
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: EC: interrupt blocked
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB.PC00.LPCB.EC0: Boot DSDT EC used to handle transactions
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Interpreter enabled
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: PM: (supports S0 S3 S4 S5)
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Using IOAPIC for interrupt routing
dic 28 20:00:19 nacho-Lenovo kernel: PCI: MMCONFIG at [mem 0xc0000000-0xcfffffff] reserved as ACPI motherboard resource
dic 28 20:00:19 nacho-Lenovo kernel: PCI: Using host bridge windows from ACPI; if necessary, use “pci=nocrs” and report a bug
dic 28 20:00:19 nacho-Lenovo kernel: PCI: Using E820 reservations for host bridge windows
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: Enabled 7 GPEs in block 00 to 7F
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB.PC00.XHCI.RHUB.HS10.BTRT: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB.PC00.PAUD: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB.PC00.RP05.PCRP: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB.PC00.SAT0.VOL0.V0PR: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB.PC00.SAT0.VOL1.V1PR: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB.PC00.SAT0.VOL2.V2PR: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB_.PC00.I2C0.PXTC: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB_.PC00.I2C0.PTPL: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB_.PC00.CNVW.WRST: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB_.PC00.VMD0.RP09.NVPR: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB_.PC00.VMD0.PRT0.NVPR: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB_.PC00.VMD0.PRT1.NVPR: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB_.PC00.VMD0.PRT2.NVPR: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB_.PC00.VMD0.PRT3.NVPR: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB_.PC00.VMD0.PRT4.NVPR: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB_.PC00.VMD0.PRT5.NVPR: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB_.PC00.VMD0.PRT6.NVPR: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB_.PC00.VMD0.PRT7.NVPR: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB_.PC00.VMD0.VOL0.V0PR: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB_.PC00.VMD0.VOL1.V1PR: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB_.PC00.VMD0.VOL2.V2PR: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB_.PC00.VMD0.VOL3.V3PR: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _TZ_.FN00: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _TZ_.FN01: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _TZ_.FN02: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _TZ_.FN03: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _TZ_.FN04: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: \PIN_: New power resource
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: PCI Root Bridge [PC00] (domain 0000 [bus 00-e0])
dic 28 20:00:19 nacho-Lenovo kernel: acpi PNP0A08:00: OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
dic 28 20:00:19 nacho-Lenovo kernel: acpi PNP0A08:00: OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
dic 28 20:00:19 nacho-Lenovo kernel: PCI host bridge to bus 0000:00
dic 28 20:00:19 nacho-Lenovo kernel: pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
dic 28 20:00:19 nacho-Lenovo kernel: pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
dic 28 20:00:19 nacho-Lenovo kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
dic 28 20:00:19 nacho-Lenovo kernel: pci_bus 0000:00: root bus resource [mem 0x50400000-0xbfffffff window]
dic 28 20:00:19 nacho-Lenovo kernel: pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
dic 28 20:00:19 nacho-Lenovo kernel: pci_bus 0000:00: root bus resource [bus 00-e0]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:00.0: [8086:9a14] type 00 class 0x060000
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:02.0: [8086:9a49] type 00 class 0x030000
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:02.0: reg 0x10: [mem 0x6014000000-0x6014ffffff 64bit]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:02.0: reg 0x18: [mem 0x4000000000-0x400fffffff 64bit pref]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:02.0: reg 0x20: [io 0x5000-0x503f]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:02.0: BAR 2: assigned to efifb
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:02.0: DMAR: Skip IOMMU disabling for graphics
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:02.0: reg 0x344: [mem 0x00000000-0x00ffffff 64bit]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:02.0: VF(n) BAR0 space: [mem 0x00000000-0x06ffffff 64bit] (contains BAR0 for 7 VFs)
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:02.0: reg 0x34c: [mem 0x00000000-0x1fffffff 64bit pref]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:02.0: VF(n) BAR2 space: [mem 0x00000000-0xdfffffff 64bit pref] (contains BAR2 for 7 VFs)
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:04.0: [8086:9a03] type 00 class 0x118000
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:04.0: reg 0x10: [mem 0x6015200000-0x601521ffff 64bit]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:08.0: [8086:9a11] type 00 class 0x088000
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:08.0: reg 0x10: [mem 0x6015238000-0x6015238fff 64bit]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:0a.0: [8086:9a0d] type 00 class 0x118000
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:0a.0: reg 0x10: [mem 0x6015220000-0x6015227fff 64bit]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:0a.0: enabling Extended Tags
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:0e.0: [8086:9a0b] type 00 class 0x010400
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:0e.0: reg 0x10: [mem 0x6012000000-0x6013ffffff 64bit]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:0e.0: reg 0x18: [mem 0x52000000-0x53ffffff]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:0e.0: reg 0x20: [mem 0x6015100000-0x60151fffff 64bit]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:14.0: [8086:a0ed] type 00 class 0x0c0330
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:14.0: reg 0x10: [mem 0x55180000-0x5518ffff 64bit]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:14.2: [8086:a0ef] type 00 class 0x050000
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:14.2: reg 0x10: [mem 0x6015230000-0x6015233fff 64bit]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:14.2: reg 0x18: [mem 0x6015237000-0x6015237fff 64bit]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:14.3: [8086:a0f0] type 00 class 0x028000
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:14.3: reg 0x10: [mem 0x601522c000-0x601522ffff 64bit]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:15.0: [8086:a0e8] type 00 class 0x0c8000
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:16.0: [8086:a0e0] type 00 class 0x078000
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:16.0: reg 0x10: [mem 0x6015235000-0x6015235fff 64bit]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:16.0: PME# supported from D3hot
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:17.0: [8086:09ab] type 00 class 0x088000
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1c.0: [8086:a0bc] type 01 class 0x060400
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1c.0: PTM enabled (root), 4ns granularity
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1d.0: [8086:09ab] type 00 class 0x088000
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1d.3: [8086:a0b3] type 01 class 0x060400
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1d.3: PME# supported from D0 D3hot D3cold
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1d.3: PTM enabled (root), 4ns granularity
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1f.0: [8086:a082] type 00 class 0x060100
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1f.3: [8086:a0c8] type 00 class 0x040100
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1f.3: reg 0x10: [mem 0x6015228000-0x601522bfff 64bit]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1f.3: reg 0x20: [mem 0x6015000000-0x60150fffff 64bit]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1f.3: PME# supported from D3hot D3cold
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1f.4: [8086:a0a3] type 00 class 0x0c0500
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1f.4: reg 0x10: [mem 0x6015234000-0x60152340ff 64bit]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1f.4: reg 0x20: [io 0xefa0-0xefbf]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1f.5: [8086:a0a4] type 00 class 0x0c8000
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:01:00.0: [10de:1f9d] type 00 class 0x030200
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:01:00.0: reg 0x10: [mem 0x54000000-0x54ffffff]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:01:00.0: reg 0x14: [mem 0x6000000000-0x600fffffff 64bit pref]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:01:00.0: reg 0x1c: [mem 0x6010000000-0x6011ffffff 64bit pref]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:01:00.0: reg 0x24: [io 0x4000-0x407f]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:01:00.0: reg 0x30: [mem 0xfff80000-0xffffffff pref]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:01:00.0: 31.504 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x4 link at 0000:00:1c.0 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1c.0: PCI bridge to [bus 01]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1c.0: bridge window [io 0x4000-0x4fff]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1c.0: bridge window [mem 0x54000000-0x54ffffff]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1c.0: bridge window [mem 0x6000000000-0x6011ffffff 64bit pref]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:02:00.0: reg 0x10: [io 0x3000-0x30ff]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:02:00.0: reg 0x18: [mem 0x55004000-0x55004fff 64bit]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:02:00.0: reg 0x20: [mem 0x55000000-0x55003fff 64bit]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:02:00.0: supports D1 D2
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1d.3: PCI bridge to [bus 02]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1d.3: bridge window [io 0x3000-0x3fff]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1d.3: bridge window [mem 0x55000000-0x550fffff]
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: EC: interrupt unblocked
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: EC: event unblocked
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: EC: GPE=0x6e
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB.PC00.LPCB.EC0: Boot DSDT EC initialization complete
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB_.PC00.LPCB.EC0_: EC: Used to handle transactions and events
dic 28 20:00:19 nacho-Lenovo kernel: iommu: Default domain type: Translated
dic 28 20:00:19 nacho-Lenovo kernel: iommu: DMA domain TLB invalidation policy: lazy mode
dic 28 20:00:19 nacho-Lenovo kernel: SCSI subsystem initialized
dic 28 20:00:19 nacho-Lenovo kernel: libata version 3.00 loaded.
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: bus type USB registered
dic 28 20:00:19 nacho-Lenovo kernel: usbcore: registered new interface driver usbfs
dic 28 20:00:19 nacho-Lenovo kernel: usbcore: registered new interface driver hub
dic 28 20:00:19 nacho-Lenovo kernel: usbcore: registered new device driver usb
dic 28 20:00:19 nacho-Lenovo kernel: pps_core: LinuxPPS API ver. 1 registered
dic 28 20:00:19 nacho-Lenovo kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
dic 28 20:00:19 nacho-Lenovo kernel: PTP clock support registered
dic 28 20:00:19 nacho-Lenovo kernel: EDAC MC: Ver: 3.0.0
dic 28 20:00:19 nacho-Lenovo kernel: efivars: Registered efivars operations
dic 28 20:00:19 nacho-Lenovo kernel: NetLabel: Initializing
dic 28 20:00:19 nacho-Lenovo kernel: NetLabel: domain hash size = 128
dic 28 20:00:19 nacho-Lenovo kernel: NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
dic 28 20:00:19 nacho-Lenovo kernel: NetLabel: unlabeled traffic allowed by default
dic 28 20:00:19 nacho-Lenovo kernel: mctp: management component transport protocol core
dic 28 20:00:19 nacho-Lenovo kernel: NET: Registered PF_MCTP protocol family
dic 28 20:00:19 nacho-Lenovo kernel: PCI: Using ACPI for IRQ routing
dic 28 20:00:19 nacho-Lenovo kernel: PCI: pci_cache_line_size set to 64 bytes
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1f.5: can’t claim BAR 0 [mem 0xfe010000-0xfe010fff]: no compatible bridge window
dic 28 20:00:19 nacho-Lenovo kernel: e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
dic 28 20:00:19 nacho-Lenovo kernel: e820: reserve RAM buffer [mem 0x3c832018-0x3fffffff]
dic 28 20:00:19 nacho-Lenovo kernel: e820: reserve RAM buffer [mem 0x3cb0a000-0x3fffffff]
dic 28 20:00:19 nacho-Lenovo kernel: e820: reserve RAM buffer [mem 0x3cb0e000-0x3fffffff]
dic 28 20:00:19 nacho-Lenovo kernel: e820: reserve RAM buffer [mem 0x40d99000-0x43ffffff]
dic 28 20:00:19 nacho-Lenovo kernel: e820: reserve RAM buffer [mem 0x434af000-0x43ffffff]
dic 28 20:00:19 nacho-Lenovo kernel: e820: reserve RAM buffer [mem 0x45c00000-0x47ffffff]
dic 28 20:00:19 nacho-Lenovo kernel: e820: reserve RAM buffer [mem 0x4afc00000-0x4afffffff]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:02.0: vgaarb: setting as boot VGA device
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:02.0: vgaarb: bridge control possible
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
dic 28 20:00:19 nacho-Lenovo kernel: vgaarb: loaded
dic 28 20:00:19 nacho-Lenovo kernel: clocksource: Switched to clocksource tsc-early
dic 28 20:00:19 nacho-Lenovo kernel: VFS: Disk quotas dquot_6.6.0
dic 28 20:00:19 nacho-Lenovo kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
dic 28 20:00:19 nacho-Lenovo kernel: AppArmor: AppArmor Filesystem Enabled
dic 28 20:00:19 nacho-Lenovo kernel: pnp: PnP ACPI init
dic 28 20:00:19 nacho-Lenovo kernel: system 00:00: [io 0x0680-0x069f] has been reserved
dic 28 20:00:19 nacho-Lenovo kernel: system 00:00: [io 0x164e-0x164f] has been reserved
dic 28 20:00:19 nacho-Lenovo kernel: system 00:00: [io 0xfd60-0xfd63] has been reserved
dic 28 20:00:19 nacho-Lenovo kernel: system 00:02: [io 0x1854-0x1857] has been reserved
dic 28 20:00:19 nacho-Lenovo kernel: pnp 00:04: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
dic 28 20:00:19 nacho-Lenovo kernel: system 00:04: [mem 0xfedc0000-0xfedc7fff] has been reserved
dic 28 20:00:19 nacho-Lenovo kernel: system 00:04: [mem 0xfeda0000-0xfeda0fff] has been reserved
dic 28 20:00:19 nacho-Lenovo kernel: system 00:04: [mem 0xfeda1000-0xfeda1fff] has been reserved
dic 28 20:00:19 nacho-Lenovo kernel: system 00:04: [mem 0xfed20000-0xfed7ffff] could not be reserved
dic 28 20:00:19 nacho-Lenovo kernel: system 00:04: [mem 0xfed90000-0xfed93fff] could not be reserved
dic 28 20:00:19 nacho-Lenovo kernel: system 00:04: [mem 0xfed45000-0xfed8ffff] could not be reserved
dic 28 20:00:19 nacho-Lenovo kernel: system 00:04: [mem 0xfee00000-0xfeefffff] has been reserved
dic 28 20:00:19 nacho-Lenovo kernel: system 00:05: [io 0x1800-0x18fe] could not be reserved
dic 28 20:00:19 nacho-Lenovo kernel: system 00:05: [mem 0xfe000000-0xfe01ffff] could not be reserved
dic 28 20:00:19 nacho-Lenovo kernel: system 00:05: [mem 0xfe04c000-0xfe04ffff] has been reserved
dic 28 20:00:19 nacho-Lenovo kernel: system 00:05: [mem 0xfe050000-0xfe0affff] has been reserved
dic 28 20:00:19 nacho-Lenovo kernel: system 00:05: [mem 0xfe0d0000-0xfe0fffff] has been reserved
dic 28 20:00:19 nacho-Lenovo kernel: system 00:05: [mem 0xfe200000-0xfe7fffff] has been reserved
dic 28 20:00:19 nacho-Lenovo kernel: system 00:05: [mem 0xff000000-0xffffffff] has been reserved
dic 28 20:00:19 nacho-Lenovo kernel: system 00:05: [mem 0xfd000000-0xfd68ffff] has been reserved
dic 28 20:00:19 nacho-Lenovo kernel: system 00:05: [mem 0xfd6b0000-0xfd6cffff] has been reserved
dic 28 20:00:19 nacho-Lenovo kernel: system 00:05: [mem 0xfd6f0000-0xfdffffff] has been reserved
dic 28 20:00:19 nacho-Lenovo kernel: system 00:06: [io 0x2000-0x20fe] has been reserved
dic 28 20:00:19 nacho-Lenovo kernel: pnp: PnP ACPI: found 8 devices
dic 28 20:00:19 nacho-Lenovo kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
dic 28 20:00:19 nacho-Lenovo kernel: NET: Registered PF_INET protocol family
dic 28 20:00:19 nacho-Lenovo kernel: IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
dic 28 20:00:19 nacho-Lenovo kernel: tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
dic 28 20:00:19 nacho-Lenovo kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
dic 28 20:00:19 nacho-Lenovo kernel: TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
dic 28 20:00:19 nacho-Lenovo kernel: TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
dic 28 20:00:19 nacho-Lenovo kernel: TCP: Hash tables configured (established 131072 bind 65536)
dic 28 20:00:19 nacho-Lenovo kernel: MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
dic 28 20:00:19 nacho-Lenovo kernel: UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
dic 28 20:00:19 nacho-Lenovo kernel: UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
dic 28 20:00:19 nacho-Lenovo kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
dic 28 20:00:19 nacho-Lenovo kernel: NET: Registered PF_XDP protocol family
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:01:00.0: can’t claim BAR 6 [mem 0xfff80000-0xffffffff pref]: no compatible bridge window
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:02.0: BAR 9: assigned [mem 0x4020000000-0x40ffffffff 64bit pref]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:02.0: BAR 7: assigned [mem 0x4010000000-0x4016ffffff 64bit]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:15.0: BAR 0: assigned [mem 0x4017000000-0x4017000fff 64bit]
dic 28 20:00:19 nacho-Lenovo kernel: resource: avoiding allocation from e820 entry [mem 0x0009f000-0x000fffff]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:00:1f.5: BAR 0: assigned [mem 0x50400000-0x50400fff]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:01:00.0: BAR 6: no space for [mem size 0x00080000 pref]
dic 28 20:00:19 nacho-Lenovo kernel: pci 0000:01:00.0: BAR 6: failed to assign [mem size 0x00080000 pref]
dic 28 20:00:19 nacho-Lenovo kernel: pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
dic 28 20:00:19 nacho-Lenovo kernel: pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
dic 28 20:00:19 nacho-Lenovo kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
dic 28 20:00:19 nacho-Lenovo kernel: pci_bus 0000:00: resource 7 [mem 0x50400000-0xbfffffff window]
dic 28 20:00:19 nacho-Lenovo kernel: pci_bus 0000:00: resource 8 [mem 0x4000000000-0x7fffffffff window]
dic 28 20:00:19 nacho-Lenovo kernel: pci_bus 0000:01: resource 0 [io 0x4000-0x4fff]
dic 28 20:00:19 nacho-Lenovo kernel: pci_bus 0000:01: resource 1 [mem 0x54000000-0x54ffffff]
dic 28 20:00:19 nacho-Lenovo kernel: pci_bus 0000:01: resource 2 [mem 0x6000000000-0x6011ffffff 64bit pref]
dic 28 20:00:19 nacho-Lenovo kernel: pci_bus 0000:02: resource 0 [io 0x3000-0x3fff]
dic 28 20:00:19 nacho-Lenovo kernel: pci_bus 0000:02: resource 1 [mem 0x55000000-0x550fffff]
dic 28 20:00:19 nacho-Lenovo kernel: PCI: CLS 64 bytes, default 64
dic 28 20:00:19 nacho-Lenovo kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
dic 28 20:00:19 nacho-Lenovo kernel: software IO TLB: mapped [mem 0x0000000034657000-0x0000000038657000] (64MB)
dic 28 20:00:19 nacho-Lenovo kernel: Trying to unpack rootfs image as initramfs…
dic 28 20:00:19 nacho-Lenovo kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2df10e7656b, max_idle_ns: 440795364873 ns
dic 28 20:00:19 nacho-Lenovo kernel: Initialise system trusted keyrings
dic 28 20:00:19 nacho-Lenovo kernel: Key type blacklist registered
dic 28 20:00:19 nacho-Lenovo kernel: workingset: timestamp_bits=41 max_order=22 bucket_order=0
dic 28 20:00:19 nacho-Lenovo kernel: zbud: loaded
dic 28 20:00:19 nacho-Lenovo kernel: integrity: Platform Keyring initialized
dic 28 20:00:19 nacho-Lenovo kernel: integrity: Machine keyring initialized
dic 28 20:00:19 nacho-Lenovo kernel: Key type asymmetric registered
dic 28 20:00:19 nacho-Lenovo kernel: Asymmetric key parser ‘x509’ registered
dic 28 20:00:19 nacho-Lenovo kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
dic 28 20:00:19 nacho-Lenovo kernel: io scheduler mq-deadline registered
dic 28 20:00:19 nacho-Lenovo kernel: io scheduler kyber registered
dic 28 20:00:19 nacho-Lenovo kernel: io scheduler bfq registered
dic 28 20:00:19 nacho-Lenovo kernel: pcieport 0000:00:1c.0: PME: Signaling with IRQ 122
dic 28 20:00:19 nacho-Lenovo kernel: pcieport 0000:00:1c.0: AER: enabled with IRQ 122
dic 28 20:00:19 nacho-Lenovo kernel: pcieport 0000:00:1c.0: DPC: enabled with IRQ 122
dic 28 20:00:19 nacho-Lenovo kernel: pcieport 0000:00:1c.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
dic 28 20:00:19 nacho-Lenovo kernel: pcieport 0000:00:1d.3: PME: Signaling with IRQ 123
dic 28 20:00:19 nacho-Lenovo kernel: pcieport 0000:00:1d.3: AER: enabled with IRQ 123
dic 28 20:00:19 nacho-Lenovo kernel: pcieport 0000:00:1d.3: DPC: enabled with IRQ 123
dic 28 20:00:19 nacho-Lenovo kernel: pcieport 0000:00:1d.3: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
dic 28 20:00:19 nacho-Lenovo kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
dic 28 20:00:19 nacho-Lenovo kernel: Monitor-Mwait will be used to enter C-1 state
dic 28 20:00:19 nacho-Lenovo kernel: Monitor-Mwait will be used to enter C-2 state
dic 28 20:00:19 nacho-Lenovo kernel: Monitor-Mwait will be used to enter C-3 state
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: _SB_.PR00: Found 3 idle states
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: AC: AC Adapter [ACAD] (on-line)
dic 28 20:00:19 nacho-Lenovo kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1a/PNP0C0D:00/input/input0
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: button: Lid Switch [LID0]
dic 28 20:00:19 nacho-Lenovo kernel: input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: button: Sleep Button [SLPB]
dic 28 20:00:19 nacho-Lenovo kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: button: Power Button [PWRB]
dic 28 20:00:19 nacho-Lenovo kernel: thermal LNXTHERM:00: registered as thermal_zone0
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: thermal: Thermal Zone [TZ00] (54 C)
dic 28 20:00:19 nacho-Lenovo kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
dic 28 20:00:19 nacho-Lenovo kernel: hpet_acpi_add: no address or irqs in _CRS
dic 28 20:00:19 nacho-Lenovo kernel: Non-volatile memory driver v1.3
dic 28 20:00:19 nacho-Lenovo kernel: Linux agpgart interface v0.103
dic 28 20:00:19 nacho-Lenovo kernel: tpm tpm0: tpm_read_log_acpi: Failed to map ACPI memory
dic 28 20:00:19 nacho-Lenovo kernel: AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: bus type drm_connector registered
dic 28 20:00:19 nacho-Lenovo kernel: [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
dic 28 20:00:19 nacho-Lenovo kernel: fbcon: Deferring console take-over
dic 28 20:00:19 nacho-Lenovo kernel: simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
dic 28 20:00:19 nacho-Lenovo kernel: usbcore: registered new interface driver usbserial_generic
dic 28 20:00:19 nacho-Lenovo kernel: usbserial: USB Serial support registered for generic
dic 28 20:00:19 nacho-Lenovo kernel: rtc_cmos 00:01: RTC can wake from S4
dic 28 20:00:19 nacho-Lenovo kernel: rtc_cmos 00:01: registered as rtc0
dic 28 20:00:19 nacho-Lenovo kernel: rtc_cmos 00:01: setting system clock to 2023-12-28T19:00:11 UTC (1703790011)
dic 28 20:00:19 nacho-Lenovo kernel: rtc_cmos 00:01: alarms up to one month, y3k, 242 bytes nvram
dic 28 20:00:19 nacho-Lenovo kernel: intel_pstate: Intel P-state driver initializing
dic 28 20:00:19 nacho-Lenovo kernel: intel_pstate: HWP enabled
dic 28 20:00:19 nacho-Lenovo kernel: ledtrig-cpu: registered to indicate activity on CPUs
dic 28 20:00:19 nacho-Lenovo kernel: hid: raw HID events driver (C) Jiri Kosina
dic 28 20:00:19 nacho-Lenovo kernel: intel_pmc_core INT33A1:00: initialized
dic 28 20:00:19 nacho-Lenovo kernel: drop_monitor: Initializing network drop monitor service
dic 28 20:00:19 nacho-Lenovo kernel: Initializing XFRM netlink socket
dic 28 20:00:19 nacho-Lenovo kernel: NET: Registered PF_INET6 protocol family
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: battery: Slot [BAT1] (battery present)
dic 28 20:00:19 nacho-Lenovo kernel: Freeing initrd memory: 45064K
dic 28 20:00:19 nacho-Lenovo kernel: Segment Routing with IPv6
dic 28 20:00:19 nacho-Lenovo kernel: RPL Segment Routing with IPv6
dic 28 20:00:19 nacho-Lenovo kernel: In-situ OAM (IOAM) with IPv6
dic 28 20:00:19 nacho-Lenovo kernel: NET: Registered PF_PACKET protocol family
dic 28 20:00:19 nacho-Lenovo kernel: microcode: Microcode Update Driver: v2.2.
dic 28 20:00:19 nacho-Lenovo kernel: resctrl: L2 allocation detected
dic 28 20:00:19 nacho-Lenovo kernel: IPI shorthand broadcast: enabled
dic 28 20:00:19 nacho-Lenovo kernel: sched_clock: Marking stable (568222034, 6512204)->(602309005, -27574767)
dic 28 20:00:19 nacho-Lenovo kernel: registered taskstats version 1
dic 28 20:00:19 nacho-Lenovo kernel: Loading compiled-in X.509 certificates
dic 28 20:00:19 nacho-Lenovo kernel: Loaded X.509 cert ‘Build time autogenerated kernel key: c071c707c9e3d2bdd78e51c4cdaf418758e4072a’
dic 28 20:00:19 nacho-Lenovo kernel: zswap: loaded using pool zstd/zsmalloc
dic 28 20:00:19 nacho-Lenovo kernel: Key type .fscrypt registered
dic 28 20:00:19 nacho-Lenovo kernel: Key type fscrypt-provisioning registered
dic 28 20:00:19 nacho-Lenovo kernel: AppArmor: AppArmor sha1 policy hashing enabled
dic 28 20:00:19 nacho-Lenovo kernel: PM: Magic number: 3:121:42
dic 28 20:00:19 nacho-Lenovo kernel: memory memory78: hash matches
dic 28 20:00:19 nacho-Lenovo kernel: RAS: Correctable Errors collector initialized.
dic 28 20:00:19 nacho-Lenovo kernel: clk: Disabling unused clocks
dic 28 20:00:19 nacho-Lenovo kernel: Freeing unused decrypted memory: 2028K
dic 28 20:00:19 nacho-Lenovo kernel: Freeing unused kernel image (initmem) memory: 3424K
dic 28 20:00:19 nacho-Lenovo kernel: Write protecting the kernel read-only data: 30720k
dic 28 20:00:19 nacho-Lenovo kernel: Freeing unused kernel image (rodata/data gap) memory: 1188K
dic 28 20:00:19 nacho-Lenovo kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
dic 28 20:00:19 nacho-Lenovo kernel: rodata_test: all tests were successful
dic 28 20:00:19 nacho-Lenovo kernel: Run /init as init process
dic 28 20:00:19 nacho-Lenovo kernel: with arguments:
dic 28 20:00:19 nacho-Lenovo kernel: /init
dic 28 20:00:19 nacho-Lenovo kernel: with environment:
dic 28 20:00:19 nacho-Lenovo kernel: HOME=/
dic 28 20:00:19 nacho-Lenovo kernel: TERM=linux
dic 28 20:00:19 nacho-Lenovo kernel: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64
dic 28 20:00:19 nacho-Lenovo kernel: cryptdevice=UUID=95fc649b-53b3-4137-813b-69f906456198:luks-95fc649b-53b3-4137-813b-69f906456198
dic 28 20:00:19 nacho-Lenovo kernel: wmi_bus wmi_bus-PNP0C14:02: [Firmware Info]: B7F3CA0A-ACDC-42D2-9217-77C6C628FBD2 has zero instances
dic 28 20:00:19 nacho-Lenovo kernel: wmi_bus wmi_bus-PNP0C14:02: WQAE data block query control method not found
dic 28 20:00:19 nacho-Lenovo kernel: i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
dic 28 20:00:19 nacho-Lenovo kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
dic 28 20:00:19 nacho-Lenovo kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
dic 28 20:00:19 nacho-Lenovo kernel: vmd 0000:00:0e.0: PCI host bridge to bus 10000:e0
dic 28 20:00:19 nacho-Lenovo kernel: pci_bus 10000:e0: root bus resource [bus e0-ff]
dic 28 20:00:19 nacho-Lenovo kernel: pci_bus 10000:e0: root bus resource [mem 0x52000000-0x53ffffff]
dic 28 20:00:19 nacho-Lenovo kernel: pci_bus 10000:e0: root bus resource [mem 0x6015102000-0x60151fffff 64bit]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:17.0: [8086:a0d3] type 00 class 0x010601
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:17.0: reg 0x10: [mem 0x00000000-0x00001fff]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:17.0: reg 0x14: [mem 0x00000000-0x000000ff]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:17.0: reg 0x18: [io 0x0000-0x0007]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:17.0: reg 0x1c: [io 0x0000-0x0003]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:17.0: reg 0x20: [io 0x0000-0x001f]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:17.0: reg 0x24: [mem 0x52000000-0x520007ff]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:17.0: PME# supported from D3hot
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:1d.0: [8086:a0b0] type 01 class 0x060400
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:1d.0: PME# supported from D0 D3hot D3cold
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:1d.0: PTM enabled (root), 4ns granularity
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:1d.0: Primary bus is hard wired to 0
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e1:00.0: [8086:f1aa] type 00 class 0x010802
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e1:00.0: reg 0x10: [mem 0x52100000-0x52103fff 64bit]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e1:00.0: reg 0x1ac: [mem 0x00000000-0x00003fff 64bit]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e1:00.0: VF(n) BAR0 space: [mem 0x00000000-0x0001ffff 64bit] (contains BAR0 for 8 VFs)
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e1:00.0: 15.752 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x2 link at 10000:e0:1d.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:1d.0: PCI bridge to [bus e1]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:1d.0: bridge window [io 0x0000-0x0fff]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:1d.0: bridge window [mem 0x52100000-0x521fffff]
dic 28 20:00:19 nacho-Lenovo kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
dic 28 20:00:19 nacho-Lenovo kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
dic 28 20:00:19 nacho-Lenovo kernel: xhci_hcd 0000:00:14.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000200009810
dic 28 20:00:19 nacho-Lenovo kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
dic 28 20:00:19 nacho-Lenovo kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
dic 28 20:00:19 nacho-Lenovo kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
dic 28 20:00:19 nacho-Lenovo kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
dic 28 20:00:19 nacho-Lenovo kernel: usb usb1: Product: xHCI Host Controller
dic 28 20:00:19 nacho-Lenovo kernel: usb usb1: Manufacturer: Linux 6.6.8-2-MANJARO xhci-hcd
dic 28 20:00:19 nacho-Lenovo kernel: usb usb1: SerialNumber: 0000:00:14.0
dic 28 20:00:19 nacho-Lenovo kernel: hub 1-0:1.0: USB hub found
dic 28 20:00:19 nacho-Lenovo kernel: hub 1-0:1.0: 12 ports detected
dic 28 20:00:19 nacho-Lenovo kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
dic 28 20:00:19 nacho-Lenovo kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
dic 28 20:00:19 nacho-Lenovo kernel: usb usb2: Product: xHCI Host Controller
dic 28 20:00:19 nacho-Lenovo kernel: usb usb2: Manufacturer: Linux 6.6.8-2-MANJARO xhci-hcd
dic 28 20:00:19 nacho-Lenovo kernel: usb usb2: SerialNumber: 0000:00:14.0
dic 28 20:00:19 nacho-Lenovo kernel: hub 2-0:1.0: USB hub found
dic 28 20:00:19 nacho-Lenovo kernel: hub 2-0:1.0: 4 ports detected
dic 28 20:00:19 nacho-Lenovo kernel: cryptd: max_cpu_qlen set to 1000
dic 28 20:00:19 nacho-Lenovo kernel: AVX2 version of gcm_enc/dec engaged.
dic 28 20:00:19 nacho-Lenovo kernel: AES CTR mode by8 optimization enabled
dic 28 20:00:19 nacho-Lenovo kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:1d.0: bridge window [mem 0x00100000-0x001fffff] to [bus e1] add_size 100000 add_align 100000
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:1d.0: BAR 14: assigned [mem 0x52000000-0x521fffff]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:17.0: BAR 0: assigned [mem 0x52200000-0x52201fff]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:1d.0: BAR 13: no space for [io size 0x1000]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:1d.0: BAR 13: failed to assign [io size 0x1000]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:17.0: BAR 5: assigned [mem 0x52202000-0x522027ff]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:17.0: BAR 1: assigned [mem 0x52202800-0x522028ff]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:17.0: BAR 4: no space for [io size 0x0020]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:17.0: BAR 4: failed to assign [io size 0x0020]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:17.0: BAR 2: no space for [io size 0x0008]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:17.0: BAR 2: failed to assign [io size 0x0008]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:17.0: BAR 3: no space for [io size 0x0004]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:17.0: BAR 3: failed to assign [io size 0x0004]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e1:00.0: BAR 0: assigned [mem 0x52000000-0x52003fff 64bit]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e1:00.0: BAR 7: assigned [mem 0x52004000-0x52023fff 64bit]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e0:1d.0: bridge window [mem 0x52000000-0x521fffff]
dic 28 20:00:19 nacho-Lenovo kernel: pci 10000:e1:00.0: VMD: Default LTR value set by driver
dic 28 20:00:19 nacho-Lenovo kernel: ahci 10000:e0:17.0: version 3.0
dic 28 20:00:19 nacho-Lenovo kernel: ahci 10000:e0:17.0: can’t derive routing for PCI INT A
dic 28 20:00:19 nacho-Lenovo kernel: ahci 10000:e0:17.0: PCI INT A: no GSI
dic 28 20:00:19 nacho-Lenovo kernel: ahci 10000:e0:17.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
dic 28 20:00:19 nacho-Lenovo kernel: ahci 10000:e0:17.0: flags: 64bit ncq sntf pm clo only pio slum part deso sadm sds
dic 28 20:00:19 nacho-Lenovo kernel: scsi host0: ahci
dic 28 20:00:19 nacho-Lenovo kernel: ata1: SATA max UDMA/133 abar m2048@0x52202000 port 0x52202100 irq 144
dic 28 20:00:19 nacho-Lenovo kernel: pcieport 10000:e0:1d.0: can’t derive routing for PCI INT A
dic 28 20:00:19 nacho-Lenovo kernel: pcieport 10000:e0:1d.0: PCI INT A: no GSI
dic 28 20:00:19 nacho-Lenovo kernel: pcieport 10000:e0:1d.0: PME: Signaling with IRQ 145
dic 28 20:00:19 nacho-Lenovo kernel: pcieport 10000:e0:1d.0: AER: enabled with IRQ 145
dic 28 20:00:19 nacho-Lenovo kernel: pcieport 10000:e0:1d.0: DPC: enabled with IRQ 145
dic 28 20:00:19 nacho-Lenovo kernel: pcieport 10000:e0:1d.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
dic 28 20:00:19 nacho-Lenovo kernel: vmd 0000:00:0e.0: Bound to PCI domain 10000
dic 28 20:00:19 nacho-Lenovo kernel: usb 1-6: new high-speed USB device number 2 using xhci_hcd
dic 28 20:00:19 nacho-Lenovo kernel: i915 0000:00:02.0: vgaarb: deactivate vga console
dic 28 20:00:19 nacho-Lenovo kernel: i915 0000:00:02.0: [drm] Using Transparent Hugepages
dic 28 20:00:19 nacho-Lenovo kernel: i915 0000:00:02.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=io+mem:owns=io+mem
dic 28 20:00:19 nacho-Lenovo kernel: i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/tgl_dmc_ver2_12.bin (v2.12)
dic 28 20:00:19 nacho-Lenovo kernel: ------------[ cut here ]------------
dic 28 20:00:19 nacho-Lenovo kernel: i915 0000:00:02.0: drm_WARN_ON(val == 0xffffffff)
dic 28 20:00:19 nacho-Lenovo kernel: WARNING: CPU: 7 PID: 133 at drivers/gpu/drm/i915/display/intel_tc.c:702 tgl_tc_phy_init+0xd6/0x100 [i915]
dic 28 20:00:19 nacho-Lenovo kernel: Modules linked in: i915(+) crct10dif_pclmul crc32_pclmul crc32c_intel polyval_clmulni polyval_generic gf128mul ghash_clmulni_intel sha512_ssse3 serio_raw sha256_ssse3 atkbd sha1_ssse3 i2c_algo_bit libps2 drm_buddy aesni_intel vivaldi_fmap ttm intel_gtt crypto_simd spi_intel_pci cryptd drm_display_helper spi_intel xhci_pci cec xhci_pci_renesas vmd i8042 video serio wmi
dic 28 20:00:19 nacho-Lenovo kernel: CPU: 7 PID: 133 Comm: (udev-worker) Not tainted 6.6.8-2-MANJARO #1 146dce4c0b8863ad44f28ec2edb37ecbadc944c7
dic 28 20:00:19 nacho-Lenovo kernel: Hardware name: LENOVO 82K1/LNVNB161216, BIOS H4CN23WW(V1.08) 02/11/2022
dic 28 20:00:19 nacho-Lenovo kernel: RIP: 0010:tgl_tc_phy_init+0xd6/0x100 [i915]
dic 28 20:00:19 nacho-Lenovo kernel: Code: 48 8b 6f 50 48 85 ed 75 03 48 8b 2f e8 63 0a 35 e5 48 c7 c1 c0 e0 7b c0 48 89 ea 48 c7 c7 11 fa 7d c0 48 89 c6 e8 ea 35 ae e4 <0f> 0b 48 8b 03 8b 70 7c 48 8b 38 e8 aa 91 fa ff 89 c1 89 c5 c1 e9
dic 28 20:00:19 nacho-Lenovo kernel: RSP: 0018:ffffc900023e78e8 EFLAGS: 00010286
dic 28 20:00:19 nacho-Lenovo kernel: RAX: 0000000000000000 RBX: ffff888110504400 RCX: c0000000ffffefff
dic 28 20:00:19 nacho-Lenovo kernel: RDX: 0000000000000000 RSI: 00000000ffffefff RDI: 0000000000000001
dic 28 20:00:19 nacho-Lenovo kernel: RBP: ffff888101ee7600 R08: 0000000000000000 R09: ffffc900023e7770
dic 28 20:00:19 nacho-Lenovo kernel: R10: 0000000000000003 R11: ffffffffa6eca428 R12: ffff88810f050000
dic 28 20:00:19 nacho-Lenovo kernel: R13: 0000000000000000 R14: 0000000fffffffe0 R15: ffff88810f050000
dic 28 20:00:19 nacho-Lenovo kernel: FS: 00007fba15d4b480(0000) GS:ffff88849fbc0000(0000) knlGS:0000000000000000
dic 28 20:00:19 nacho-Lenovo kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
dic 28 20:00:19 nacho-Lenovo kernel: CR2: 00005647de2730d8 CR3: 0000000100e98003 CR4: 0000000000f70ee0
dic 28 20:00:19 nacho-Lenovo kernel: PKRU: 55555554
dic 28 20:00:19 nacho-Lenovo kernel: Call Trace:
dic 28 20:00:19 nacho-Lenovo kernel: ? tgl_tc_phy_init+0xd6/0x100 [i915 e8929fddc263aa6e315f45b230af5f50a5562637]
dic 28 20:00:19 nacho-Lenovo kernel: ? __warn+0x81/0x130
dic 28 20:00:19 nacho-Lenovo kernel: ? report_bug+0x171/0x1a0
dic 28 20:00:19 nacho-Lenovo kernel: ? prb_read_valid+0x1b/0x30
dic 28 20:00:19 nacho-Lenovo kernel: ? handle_bug+0x3c/0x80
dic 28 20:00:19 nacho-Lenovo kernel: ? exc_invalid_op+0x17/0x70
dic 28 20:00:19 nacho-Lenovo kernel: ? asm_exc_invalid_op+0x1a/0x20
dic 28 20:00:19 nacho-Lenovo kernel: intel_tc_port_init+0x185/0x230 [i915 e8929fddc263aa6e315f45b230af5f50a5562637]
dic 28 20:00:19 nacho-Lenovo kernel: intel_ddi_init+0x942/0x1000 [i915 e8929fddc263aa6e315f45b230af5f50a5562637]
dic 28 20:00:19 nacho-Lenovo kernel: ? __pfx_intel_ddi_init+0x10/0x10 [i915 e8929fddc263aa6e315f45b230af5f50a5562637]
dic 28 20:00:19 nacho-Lenovo kernel: intel_bios_for_each_encoder+0x35/0x50 [i915 e8929fddc263aa6e315f45b230af5f50a5562637]
dic 28 20:00:19 nacho-Lenovo kernel: intel_setup_outputs+0x380/0x8b0 [i915 e8929fddc263aa6e315f45b230af5f50a5562637]
dic 28 20:00:19 nacho-Lenovo kernel: intel_display_driver_probe_nogem+0x14c/0x210 [i915 e8929fddc263aa6e315f45b230af5f50a5562637]
dic 28 20:00:19 nacho-Lenovo kernel: i915_driver_probe+0x6d2/0xb90 [i915 e8929fddc263aa6e315f45b230af5f50a5562637]
dic 28 20:00:19 nacho-Lenovo kernel: local_pci_probe+0x42/0xa0
dic 28 20:00:19 nacho-Lenovo kernel: pci_device_probe+0xc1/0x260
dic 28 20:00:19 nacho-Lenovo kernel: ? sysfs_do_create_link_sd+0x6e/0xe0
dic 28 20:00:19 nacho-Lenovo kernel: really_probe+0x19b/0x3e0
dic 28 20:00:19 nacho-Lenovo kernel: ? __pfx___driver_attach+0x10/0x10
dic 28 20:00:19 nacho-Lenovo kernel: __driver_probe_device+0x78/0x160
dic 28 20:00:19 nacho-Lenovo kernel: driver_probe_device+0x1f/0x90
dic 28 20:00:19 nacho-Lenovo kernel: __driver_attach+0xd2/0x1c0
dic 28 20:00:19 nacho-Lenovo kernel: bus_for_each_dev+0x85/0xd0
dic 28 20:00:19 nacho-Lenovo kernel: bus_add_driver+0x116/0x220
dic 28 20:00:19 nacho-Lenovo kernel: driver_register+0x59/0x100
dic 28 20:00:19 nacho-Lenovo kernel: i915_init+0x22/0xc0 [i915 e8929fddc263aa6e315f45b230af5f50a5562637]
dic 28 20:00:19 nacho-Lenovo kernel: ? __pfx_i915_init+0x10/0x10 [i915 e8929fddc263aa6e315f45b230af5f50a5562637]
dic 28 20:00:19 nacho-Lenovo kernel: do_one_initcall+0x5a/0x320
dic 28 20:00:19 nacho-Lenovo kernel: do_init_module+0x60/0x240
dic 28 20:00:19 nacho-Lenovo kernel: init_module_from_file+0x89/0xe0
dic 28 20:00:19 nacho-Lenovo kernel: ? generic_update_time+0x4e/0x60
dic 28 20:00:19 nacho-Lenovo kernel: idempotent_init_module+0x120/0x2b0
dic 28 20:00:19 nacho-Lenovo kernel: __x64_sys_finit_module+0x5e/0xb0
dic 28 20:00:19 nacho-Lenovo kernel: do_syscall_64+0x5d/0x90
dic 28 20:00:19 nacho-Lenovo kernel: ? ksys_read+0x6f/0xf0
dic 28 20:00:19 nacho-Lenovo kernel: ? syscall_exit_to_user_mode+0x2b/0x40
dic 28 20:00:19 nacho-Lenovo kernel: ? do_syscall_64+0x6c/0x90
dic 28 20:00:19 nacho-Lenovo kernel: ? exc_page_fault+0x7f/0x180
dic 28 20:00:19 nacho-Lenovo kernel: entry_SYSCALL_64_after_hwframe+0x6e/0xd8
dic 28 20:00:19 nacho-Lenovo kernel: RIP: 0033:0x7fba1683473d
dic 28 20:00:19 nacho-Lenovo kernel: Code: ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d c3 95 0c 00 f7 d8 64 89 01 48
dic 28 20:00:19 nacho-Lenovo kernel: RSP: 002b:00007ffeabc51708 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
dic 28 20:00:19 nacho-Lenovo kernel: RAX: ffffffffffffffda RBX: 00005647de26ff60 RCX: 00007fba1683473d
dic 28 20:00:19 nacho-Lenovo kernel: RDX: 0000000000000000 RSI: 00007fba16941376 RDI: 0000000000000011
dic 28 20:00:19 nacho-Lenovo kernel: RBP: 00007fba16941376 R08: 0000000000000070 R09: fffffffffffffe90
dic 28 20:00:19 nacho-Lenovo kernel: R10: 0000000000000050 R11: 0000000000000246 R12: 0000000000020000
dic 28 20:00:19 nacho-Lenovo kernel: R13: 00005647de26d140 R14: 0000000000000000 R15: 00005647de26b200
dic 28 20:00:19 nacho-Lenovo kernel: —[ end trace 0000000000000000 ]—
dic 28 20:00:19 nacho-Lenovo kernel: CPU: 7 PID: 133 Comm: (udev-worker) Tainted: G W 6.6.8-2-MANJARO #1 146dce4c0b8863ad44f28ec2edb37ecbadc944c7
dic 28 20:00:19 nacho-Lenovo kernel: RAX: 0000000000000000 RBX: ffff888110505600 RCX: c0000000ffffefff
dic 28 20:00:19 nacho-Lenovo kernel: i915 0000:00:02.0: [drm] Protected Xe Path (PXP) protected content support initialized
dic 28 20:00:19 nacho-Lenovo kernel: usb 1-6: New USB device found, idVendor=174f, idProduct=244c, bcdDevice= 0.14
dic 28 20:00:19 nacho-Lenovo kernel: usb 1-6: New USB device strings: Mfr=3, Product=1, SerialNumber=2
dic 28 20:00:19 nacho-Lenovo kernel: usb 1-6: Product: Integrated Camera
dic 28 20:00:19 nacho-Lenovo kernel: usb 1-6: Manufacturer: Generic
dic 28 20:00:19 nacho-Lenovo kernel: usb 1-6: SerialNumber: 0001
dic 28 20:00:19 nacho-Lenovo kernel: ata1: SATA link down (SStatus 0 SControl 300)
dic 28 20:00:19 nacho-Lenovo kernel: nvme nvme0: pci function 10000:e1:00.0
dic 28 20:00:19 nacho-Lenovo kernel: nvme 10000:e1:00.0: PCI INT A: not connected
dic 28 20:00:19 nacho-Lenovo kernel: nvme nvme0: 8/0/0 default/read/poll queues
dic 28 20:00:19 nacho-Lenovo kernel: nvme0n1: p1 p2 p3
dic 28 20:00:19 nacho-Lenovo kernel: usb 1-8: new full-speed USB device number 3 using xhci_hcd
dic 28 20:00:19 nacho-Lenovo kernel: usb 1-8: New USB device found, idVendor=048d, idProduct=c966, bcdDevice=14.00
dic 28 20:00:19 nacho-Lenovo kernel: usb 1-8: New USB device strings: Mfr=1, Product=2, SerialNumber=0
dic 28 20:00:19 nacho-Lenovo kernel: usb 1-8: Product: ITE Device(8176)
dic 28 20:00:19 nacho-Lenovo kernel: usb 1-8: Manufacturer: ITE Tech. Inc.
dic 28 20:00:19 nacho-Lenovo kernel: input: ITE Tech. Inc. ITE Device(8176) Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:048D:C966.0001/input/input4
dic 28 20:00:19 nacho-Lenovo kernel: input: ITE Tech. Inc. ITE Device(8176) Wireless Radio Control as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:048D:C966.0001/input/input5
dic 28 20:00:19 nacho-Lenovo kernel: hid-generic 0003:048D:C966.0001: input,hiddev96,hidraw0: USB HID v1.10 Keyboard [ITE Tech. Inc. ITE Device(8176)] on usb-0000:00:14.0-8/input0
dic 28 20:00:19 nacho-Lenovo kernel: usbcore: registered new interface driver usbhid
dic 28 20:00:19 nacho-Lenovo kernel: usbhid: USB HID core driver
dic 28 20:00:19 nacho-Lenovo kernel: usb 1-10: new full-speed USB device number 4 using xhci_hcd
dic 28 20:00:19 nacho-Lenovo kernel: usb 1-10: New USB device found, idVendor=8087, idProduct=0026, bcdDevice= 0.02
dic 28 20:00:19 nacho-Lenovo kernel: usb 1-10: New USB device strings: Mfr=0, Product=0, SerialNumber=0
dic 28 20:00:19 nacho-Lenovo kernel: [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 1
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: video: Video Device [GFX0] (multi-head: yes rom: no post: no)
dic 28 20:00:19 nacho-Lenovo kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input6
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: video: [Firmware Bug]: ACPI(PXSX) defines _DOD but not _DOS
dic 28 20:00:19 nacho-Lenovo kernel: ACPI: video: Video Device [PXSX] (multi-head: yes rom: no post: no)
dic 28 20:00:19 nacho-Lenovo kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:46/LNXVIDEO:01/input/input7
dic 28 20:00:19 nacho-Lenovo kernel: fbcon: i915drmfb (fb0) is primary device
dic 28 20:00:19 nacho-Lenovo kernel: i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
dic 28 20:00:19 nacho-Lenovo kernel: device-mapper: uevent: version 1.0.3
dic 28 20:00:19 nacho-Lenovo kernel: device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
dic 28 20:00:19 nacho-Lenovo kernel: Key type trusted registered
dic 28 20:00:19 nacho-Lenovo kernel: Key type encrypted registered
dic 28 20:00:19 nacho-Lenovo kernel: fbcon: Taking over console
dic 28 20:00:19 nacho-Lenovo kernel: Console: switching to colour frame buffer device 240x67
dic 28 20:00:19 nacho-Lenovo kernel: EXT4-fs (dm-0): mounted filesystem 4d2d0e11-44f4-4f14-a6dc-d1f83f358998 r/w with ordered data mode. Quota mode: none.
dic 28 20:00:19 nacho-Lenovo systemd[1]: systemd 254.7-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
dic 28 20:00:19 nacho-Lenovo systemd[1]: Detected architecture x86-64.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Hostname set to .
dic 28 20:00:19 nacho-Lenovo systemd[1]: bpf-lsm: LSM BPF program attached
dic 28 20:00:19 nacho-Lenovo systemd[1]: /usr/lib/systemd/system/avahi-daemon.socket:22: ListenStream= references a path below legacy directory /var/run/, updating /var/run/avahi-daemon/socket → /run/avahi-daemon/socket; please update the unit file accordingly.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Queued start job for default target Graphical Interface.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Created slice Slice /system/getty.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Created slice Slice /system/modprobe.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Created slice Encrypted Volume Units Service Slice.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Created slice Slice /system/systemd-fsck.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Created slice User and Session Slice.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Started Forward Password Requests to Wall Directory Watch.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Reached target Login Prompts.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Reached target Local Integrity Protected Volumes.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Reached target Remote File Systems.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Reached target Slice Units.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Reached target Mounting snaps.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Reached target Mounted snaps.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Reached target Local Verity Protected Volumes.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Listening on Device-mapper event daemon FIFOs.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Listening on LVM2 poll daemon socket.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Listening on Process Core Dump Socket.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Listening on Journal Socket (/dev/log).
dic 28 20:00:19 nacho-Lenovo systemd[1]: Listening on Journal Socket.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Listening on udev Control Socket.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Listening on udev Kernel Socket.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Mounting Huge Pages File System…
dic 28 20:00:19 nacho-Lenovo systemd[1]: Mounting POSIX Message Queue File System…
dic 28 20:00:19 nacho-Lenovo systemd[1]: Mounting Kernel Debug File System…
dic 28 20:00:19 nacho-Lenovo systemd[1]: Mounting Kernel Trace File System…
dic 28 20:00:19 nacho-Lenovo systemd[1]: Starting Load AppArmor profiles…
dic 28 20:00:19 nacho-Lenovo systemd[1]: Starting Create List of Static Device Nodes…
dic 28 20:00:19 nacho-Lenovo systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
dic 28 20:00:19 nacho-Lenovo systemd[1]: Starting Load Kernel Module configfs…
dic 28 20:00:19 nacho-Lenovo systemd[1]: Starting Load Kernel Module dm_mod…
dic 28 20:00:19 nacho-Lenovo systemd[1]: Starting Load Kernel Module drm…
dic 28 20:00:19 nacho-Lenovo systemd[1]: Starting Load Kernel Module fuse…
dic 28 20:00:19 nacho-Lenovo systemd[1]: Starting Load Kernel Module loop…
dic 28 20:00:19 nacho-Lenovo systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
dic 28 20:00:19 nacho-Lenovo systemd[1]: Starting Load Kernel Modules…
dic 28 20:00:19 nacho-Lenovo systemd[1]: TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/StubPcrKernelImage-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
dic 28 20:00:19 nacho-Lenovo systemd[1]: Starting Remount Root and Kernel File Systems…
dic 28 20:00:19 nacho-Lenovo systemd[1]: Starting Coldplug All udev Devices…
dic 28 20:00:19 nacho-Lenovo systemd[1]: Mounted Huge Pages File System.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Mounted POSIX Message Queue File System.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Mounted Kernel Debug File System.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Mounted Kernel Trace File System.
dic 28 20:00:19 nacho-Lenovo kernel: loop: module loaded
dic 28 20:00:19 nacho-Lenovo kernel: fuse: init (API version 7.39)
dic 28 20:00:19 nacho-Lenovo kernel: acpi_call: loading out-of-tree module taints kernel.
dic 28 20:00:19 nacho-Lenovo kernel: acpi_call: module verification failed: signature and/or required key missing - tainting kernel
dic 28 20:00:19 nacho-Lenovo systemd[1]: Finished Create List of Static Device Nodes.
dic 28 20:00:19 nacho-Lenovo systemd[1]: modprobe@configfs.service: Deactivated successfully.
dic 28 20:00:19 nacho-Lenovo kernel: EXT4-fs (dm-0): re-mounted 4d2d0e11-44f4-4f14-a6dc-d1f83f358998 r/w. Quota mode: none.
dic 28 20:00:19 nacho-Lenovo kernel: audit: type=1400 audit(1703790018.549:2): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“lsb_release” pid=289 comm=“apparmor_parser”
dic 28 20:00:19 nacho-Lenovo kernel: audit: type=1400 audit(1703790018.549:3): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe” pid=290 comm=“apparmor_parser”
dic 28 20:00:19 nacho-Lenovo kernel: audit: type=1400 audit(1703790018.549:4): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe//kmod” pid=290 comm=“apparmor_parser”
dic 28 20:00:19 nacho-Lenovo systemd[1]: Finished Load Kernel Module configfs.
dic 28 20:00:19 nacho-Lenovo systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
dic 28 20:00:19 nacho-Lenovo kernel: audit: type=1400 audit(1703790018.556:5): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“samba-rpcd” pid=294 comm=“apparmor_parser”
dic 28 20:00:19 nacho-Lenovo kernel: audit: type=1400 audit(1703790018.563:6): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“ping” pid=287 comm=“apparmor_parser”
dic 28 20:00:19 nacho-Lenovo kernel: audit: type=1400 audit(1703790018.569:7): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“samba-bgqd” pid=292 comm=“apparmor_parser”
dic 28 20:00:19 nacho-Lenovo kernel: audit: type=1400 audit(1703790018.569:8): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“php-fpm” pid=291 comm=“apparmor_parser”
dic 28 20:00:19 nacho-Lenovo kernel: audit: type=1400 audit(1703790018.573:9): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“samba-dcerpcd” pid=293 comm=“apparmor_parser”
dic 28 20:00:19 nacho-Lenovo kernel: audit: type=1400 audit(1703790018.579:10): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“klogd” pid=297 comm=“apparmor_parser”
dic 28 20:00:19 nacho-Lenovo kernel: audit: type=1400 audit(1703790018.583:11): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“/usr/lib/lightdm/lightdm-guest-session” pid=288 comm=“apparmor_parser”
dic 28 20:00:19 nacho-Lenovo systemd[1]: Finished Load Kernel Module dm_mod.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
dic 28 20:00:19 nacho-Lenovo systemd[1]: modprobe@drm.service: Deactivated successfully.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Finished Load Kernel Module drm.
dic 28 20:00:19 nacho-Lenovo systemd[1]: modprobe@fuse.service: Deactivated successfully.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Finished Load Kernel Module fuse.
dic 28 20:00:19 nacho-Lenovo systemd[1]: modprobe@loop.service: Deactivated successfully.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Finished Load Kernel Module loop.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Finished Remount Root and Kernel File Systems.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Finished Load AppArmor profiles.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Finished Coldplug All udev Devices.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Mounting FUSE Control File System…
dic 28 20:00:19 nacho-Lenovo systemd[1]: Mounting Kernel Configuration File System…
dic 28 20:00:19 nacho-Lenovo systemd[1]: Starting Load AppArmor profiles managed internally by snapd…
dic 28 20:00:19 nacho-Lenovo systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
dic 28 20:00:19 nacho-Lenovo systemd[1]: Starting Load/Save OS Random Seed…
dic 28 20:00:19 nacho-Lenovo systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Starting Create Static Device Nodes in /dev gracefully…
dic 28 20:00:19 nacho-Lenovo systemd[1]: Mounted FUSE Control File System.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Mounted Kernel Configuration File System.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Finished Load/Save OS Random Seed.
dic 28 20:00:19 nacho-Lenovo systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 342 (snapd-apparmor)
dic 28 20:00:19 nacho-Lenovo systemd[1]: Mounting Arbitrary Executable File Formats File System…
dic 28 20:00:19 nacho-Lenovo systemd[1]: Mounted Arbitrary Executable File Formats File System.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Finished Load AppArmor profiles managed internally by snapd.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Create System Users was skipped because no trigger condition checks were met.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Starting Create Static Device Nodes in /dev…
dic 28 20:00:19 nacho-Lenovo systemd[1]: Finished Create Static Device Nodes in /dev.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Reached target Preparation for Local File Systems.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/machines.raw).
dic 28 20:00:19 nacho-Lenovo systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
dic 28 20:00:19 nacho-Lenovo systemd[1]: Starting Journal Service…
dic 28 20:00:19 nacho-Lenovo systemd[1]: Starting Rule-based Manager for Device Events and Files…
dic 28 20:00:19 nacho-Lenovo systemd-journald[354]: Collecting audit messages is disabled.
dic 28 20:00:19 nacho-Lenovo systemd[1]: Started Journal Service.
dic 28 20:00:19 nacho-Lenovo systemd-journald[354]: Received client request to flush runtime journal.
dic 28 20:00:19 nacho-Lenovo systemd-journald[354]: File /var/log/journal/86da4ca7c2a047e88e3c5f7785911172/system.journal corrupted or uncleanly shut down, renaming and replacing.
dic 28 20:00:19 nacho-Lenovo kernel: Consider using thermal netlink events interface
dic 28 20:00:19 nacho-Lenovo kernel: input: Intel HID events as /devices/platform/INTC1051:00/input/input8
dic 28 20:00:19 nacho-Lenovo kernel: intel-hid INTC1051:00: platform supports 5 button array
dic 28 20:00:19 nacho-Lenovo kernel: input: Intel HID 5 button array as /devices/platform/INTC1051:00/input/input9
dic 28 20:00:19 nacho-Lenovo kernel: ideapad_acpi VPC2004:00: Unknown keyboard type: 1
dic 28 20:00:19 nacho-Lenovo kernel: input: Ideapad extra buttons as /devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/input/input10
dic 28 20:00:19 nacho-Lenovo kernel: ideapad_acpi VPC2004:00: Keyboard backlight control not available
dic 28 20:00:19 nacho-Lenovo kernel: EDAC igen6: v2.5.1
dic 28 20:00:19 nacho-Lenovo kernel: i801_smbus 0000:00:1f.4: SPD Write Disable is set
dic 28 20:00:19 nacho-Lenovo kernel: i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
dic 28 20:00:19 nacho-Lenovo kernel: resource: resource sanity check: requesting [mem 0x00000000fedc0000-0x00000000fedcdfff], which spans more than pnp 00:04 [mem 0xfedc0000-0xfedc7fff]
dic 28 20:00:19 nacho-Lenovo kernel: caller __uncore_imc_init_box+0xfa/0x150 [intel_uncore] mapping multiple BARs
dic 28 20:00:19 nacho-Lenovo kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
dic 28 20:00:19 nacho-Lenovo kernel: input: PC Speaker as /devices/platform/pcspkr/input/input11
dic 28 20:00:19 nacho-Lenovo kernel: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
dic 28 20:00:19 nacho-Lenovo kernel: mei_me 0000:00:16.0: enabling device (0000 → 0002)
dic 28 20:00:19 nacho-Lenovo kernel: i2c i2c-13: 2/2 memory slots populated (from DMI)
dic 28 20:00:19 nacho-Lenovo kernel: i2c i2c-13: Successfully instantiated SPD at 0x50
dic 28 20:00:19 nacho-Lenovo kernel: ideapad_acpi VPC2004:00: DYTC interface is not available
dic 28 20:00:19 nacho-Lenovo kernel: spi-nor spi0.0: s25fl064k (8192 Kbytes)
dic 28 20:00:19 nacho-Lenovo kernel: Creating 1 MTD partitions on “0000:00:1f.5”:
dic 28 20:00:19 nacho-Lenovo kernel: 0x000000000000-0x000001800000 : “BIOS”
dic 28 20:00:19 nacho-Lenovo kernel: mtd: partition “BIOS” extends beyond the end of device “0000:00:1f.5” – size truncated to 0x800000
dic 28 20:00:19 nacho-Lenovo kernel: intel_rapl_msr: PL4 support detected.
dic 28 20:00:19 nacho-Lenovo kernel: spi-nor spi0.1: w25q128 (16384 Kbytes)
dic 28 20:00:19 nacho-Lenovo kernel: intel_rapl_common: Found RAPL domain package
dic 28 20:00:19 nacho-Lenovo kernel: intel_rapl_common: Found RAPL domain core
dic 28 20:00:19 nacho-Lenovo kernel: intel_rapl_common: Found RAPL domain uncore
dic 28 20:00:19 nacho-Lenovo kernel: intel_rapl_common: Found RAPL domain psys
dic 28 20:00:19 nacho-Lenovo kernel: intel-lpss 0000:00:15.0: enabling device (0004 → 0006)
dic 28 20:00:19 nacho-Lenovo kernel: iTCO_vendor_support: vendor-support=0
dic 28 20:00:19 nacho-Lenovo kernel: idma64 idma64.0: Found Intel integrated DMA 64-bit
dic 28 20:00:19 nacho-Lenovo kernel: Intel(R) Wireless WiFi driver for Linux
dic 28 20:00:19 nacho-Lenovo kernel: ee1004 13-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
dic 28 20:00:19 nacho-Lenovo kernel: iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
dic 28 20:00:19 nacho-Lenovo kernel: iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
dic 28 20:00:19 nacho-Lenovo kernel: iwlwifi 0000:00:14.3: Detected crf-id 0x3617, cnv-id 0x20000302 wfpm id 0x80000000
dic 28 20:00:19 nacho-Lenovo kernel: iwlwifi 0000:00:14.3: PCI dev a0f0/0074, rev=0x351, rfid=0x10a100
dic 28 20:00:19 nacho-Lenovo kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
dic 28 20:00:19 nacho-Lenovo kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
dic 28 20:00:19 nacho-Lenovo kernel: iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
dic 28 20:00:19 nacho-Lenovo kernel: iwlwifi 0000:00:14.3: loaded firmware version 77.ad46c98b.0 QuZ-a0-hr-b0-77.ucode op_mode iwlmvm
dic 28 20:00:19 nacho-Lenovo kernel: mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915])
dic 28 20:00:19 nacho-Lenovo kernel: r8169 0000:02:00.0 eth0: RTL8168h/8111h, e4:a8:df:c7:bc:e3, XID 541, IRQ 168
dic 28 20:00:19 nacho-Lenovo kernel: r8169 0000:02:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
dic 28 20:00:19 nacho-Lenovo kernel: input: MSFT0001:01 06CB:CE78 Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-14/i2c-MSFT0001:01/0018:06CB:CE78.0002/input/input12
dic 28 20:00:19 nacho-Lenovo kernel: input: MSFT0001:01 06CB:CE78 Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-14/i2c-MSFT0001:01/0018:06CB:CE78.0002/input/input13
dic 28 20:00:19 nacho-Lenovo kernel: hid-generic 0018:06CB:CE78.0002: input,hidraw1: I2C HID v1.00 Mouse [MSFT0001:01 06CB:CE78] on i2c-MSFT0001:01
dic 28 20:00:19 nacho-Lenovo kernel: r8169 0000:02:00.0 enp2s0: renamed from eth0
dic 28 20:00:19 nacho-Lenovo kernel: RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
dic 28 20:00:19 nacho-Lenovo kernel: RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
dic 28 20:00:19 nacho-Lenovo kernel: RAPL PMU: hw unit of domain package 2^-14 Joules
dic 28 20:00:19 nacho-Lenovo kernel: RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
dic 28 20:00:19 nacho-Lenovo kernel: RAPL PMU: hw unit of domain psys 2^-14 Joules
dic 28 20:00:19 nacho-Lenovo kernel: snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
dic 28 20:00:19 nacho-Lenovo kernel: snd_hda_intel 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
dic 28 20:00:19 nacho-Lenovo kernel: nvidia: module license ‘NVIDIA’ taints kernel.
dic 28 20:00:19 nacho-Lenovo kernel: Disabling lock debugging due to kernel taint
dic 28 20:00:19 nacho-Lenovo kernel: nvidia: module license taints kernel.
dic 28 20:00:19 nacho-Lenovo kernel: iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x351
dic 28 20:00:19 nacho-Lenovo kernel: thermal thermal_zone8: failed to read out thermal zone (-61)
dic 28 20:00:19 nacho-Lenovo kernel: input: MSFT0001:01 06CB:CE78 Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-14/i2c-MSFT0001:01/0018:06CB:CE78.0002/input/input15
dic 28 20:00:19 nacho-Lenovo kernel: input: MSFT0001:01 06CB:CE78 Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-14/i2c-MSFT0001:01/0018:06CB:CE78.0002/input/input16
dic 28 20:00:19 nacho-Lenovo kernel: hid-multitouch 0018:06CB:CE78.0002: input,hidraw1: I2C HID v1.00 Mouse [MSFT0001:01 06CB:CE78] on i2c-MSFT0001:01
dic 28 20:00:19 nacho-Lenovo kernel: intel_tcc_cooling: TCC Offset locked
dic 28 20:00:19 nacho-Lenovo kernel: mousedev: PS/2 mouse device common for all mice
dic 28 20:00:19 nacho-Lenovo kernel: iwlwifi 0000:00:14.3: Detected RF HR B5, rfid=0x10a100
dic 28 20:00:19 nacho-Lenovo kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 509
dic 28 20:00:19 nacho-Lenovo kernel: nvidia 0000:01:00.0: enabling device (0006 → 0007)
dic 28 20:00:19 nacho-Lenovo kernel: iwlwifi 0000:00:14.3: base HW address: c4:75:ab:3d:0a:f4
dic 28 20:00:19 nacho-Lenovo kernel: iwlwifi 0000:00:14.3 wlp0s20f3: renamed from wlan0
dic 28 20:00:19 nacho-Lenovo kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 545.29.06 Thu Nov 16 01:59:08 UTC 2023
dic 28 20:00:19 nacho-Lenovo kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
dic 28 20:00:19 nacho-Lenovo kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
dic 28 20:00:19 nacho-Lenovo kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: enabling device (0000 → 0002)
dic 28 20:00:19 nacho-Lenovo kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040100
dic 28 20:00:19 nacho-Lenovo kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
dic 28 20:00:19 nacho-Lenovo kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: use msi interrupt mode
dic 28 20:00:19 nacho-Lenovo kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 545.29.06 Thu Nov 16 01:47:29 UTC 2023
dic 28 20:00:19 nacho-Lenovo kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: hda codecs found, mask 5
dic 28 20:00:19 nacho-Lenovo kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: using HDA machine driver skl_hda_dsp_generic now
dic 28 20:00:19 nacho-Lenovo kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: DMICs detected in NHLT tables: 2
dic 28 20:00:19 nacho-Lenovo kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 2:2:0-57864
dic 28 20:00:19 nacho-Lenovo kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:23:0
dic 28 20:00:19 nacho-Lenovo kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: unknown sof_ext_man header type 3 size 0x30
dic 28 20:00:19 nacho-Lenovo kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
dic 28 20:00:19 nacho-Lenovo kernel: [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
dic 28 20:00:20 nacho-Lenovo kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 2:2:0-57864
dic 28 20:00:20 nacho-Lenovo kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:23:0
dic 28 20:00:20 nacho-Lenovo kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: Topology: ABI 3:22:1 Kernel ABI 3:23:0
dic 28 20:00:20 nacho-Lenovo kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
dic 28 20:00:20 nacho-Lenovo kernel: snd_hda_codec_realtek ehdaudio0D0: autoconfig for ALC257: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
dic 28 20:00:20 nacho-Lenovo kernel: snd_hda_codec_realtek ehdaudio0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
dic 28 20:00:20 nacho-Lenovo kernel: snd_hda_codec_realtek ehdaudio0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
dic 28 20:00:20 nacho-Lenovo kernel: snd_hda_codec_realtek ehdaudio0D0: mono: mono_out=0x0
dic 28 20:00:20 nacho-Lenovo kernel: snd_hda_codec_realtek ehdaudio0D0: inputs:
dic 28 20:00:20 nacho-Lenovo kernel: snd_hda_codec_realtek ehdaudio0D0: Mic=0x19
dic 28 20:00:20 nacho-Lenovo kernel: snd_hda_codec_realtek ehdaudio0D0: ASoC: sink widget AIF1TX overwritten
dic 28 20:00:20 nacho-Lenovo kernel: snd_hda_codec_realtek ehdaudio0D0: ASoC: source widget AIF1RX overwritten
dic 28 20:00:20 nacho-Lenovo kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi3 overwritten
dic 28 20:00:20 nacho-Lenovo kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi2 overwritten
dic 28 20:00:20 nacho-Lenovo kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi1 overwritten
dic 28 20:00:20 nacho-Lenovo kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Codec Output Pin1 overwritten
dic 28 20:00:20 nacho-Lenovo kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Codec Input Pin1 overwritten
dic 28 20:00:20 nacho-Lenovo kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Analog Codec Playback overwritten
dic 28 20:00:20 nacho-Lenovo kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Digital Codec Playback overwritten
dic 28 20:00:20 nacho-Lenovo kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Alt Analog Codec Playback overwritten
dic 28 20:00:20 nacho-Lenovo kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Analog Codec Capture overwritten
dic 28 20:00:20 nacho-Lenovo kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Digital Codec Capture overwritten
dic 28 20:00:20 nacho-Lenovo kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Alt Analog Codec Capture overwritten
dic 28 20:00:20 nacho-Lenovo kernel: skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
dic 28 20:00:20 nacho-Lenovo kernel: input: sof-hda-dsp Mic as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input18
dic 28 20:00:20 nacho-Lenovo kernel: input: sof-hda-dsp Headphone as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input19
dic 28 20:00:20 nacho-Lenovo kernel: input: sof-hda-dsp HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input20
dic 28 20:00:20 nacho-Lenovo kernel: input: sof-hda-dsp HDMI/DP,pcm=4 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input21
dic 28 20:00:20 nacho-Lenovo kernel: input: sof-hda-dsp HDMI/DP,pcm=5 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input22
dic 28 20:00:20 nacho-Lenovo kernel: mc: Linux media interface: v0.10
dic 28 20:00:20 nacho-Lenovo kernel: Bluetooth: Core ver 2.22
dic 28 20:00:20 nacho-Lenovo kernel: NET: Registered PF_BLUETOOTH protocol family
dic 28 20:00:20 nacho-Lenovo kernel: Bluetooth: HCI device and connection manager initialized
dic 28 20:00:20 nacho-Lenovo kernel: Bluetooth: HCI socket layer initialized
dic 28 20:00:20 nacho-Lenovo kernel: Bluetooth: L2CAP socket layer initialized
dic 28 20:00:20 nacho-Lenovo kernel: Bluetooth: SCO socket layer initialized
dic 28 20:00:20 nacho-Lenovo kernel: videodev: Linux video capture interface: v2.00
dic 28 20:00:20 nacho-Lenovo kernel: usbcore: registered new interface driver btusb
dic 28 20:00:20 nacho-Lenovo kernel: usb 1-6: Found UVC 1.10 device Integrated Camera (174f:244c)
dic 28 20:00:20 nacho-Lenovo kernel: Bluetooth: hci0: Found device firmware: intel/ibt-19-0-4.sfi
dic 28 20:00:20 nacho-Lenovo kernel: Bluetooth: hci0: Boot Address: 0x24800
dic 28 20:00:20 nacho-Lenovo kernel: Bluetooth: hci0: Firmware Version: 249-27.23
dic 28 20:00:20 nacho-Lenovo kernel: Bluetooth: hci0: Firmware already loaded
dic 28 20:00:20 nacho-Lenovo kernel: Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
dic 28 20:00:20 nacho-Lenovo kernel: usbcore: registered new interface driver uvcvideo
dic 28 20:00:20 nacho-Lenovo kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
dic 28 20:00:20 nacho-Lenovo kernel: nvidia-uvm: Loaded the UVM driver, major device number 506.
dic 28 20:00:24 nacho-Lenovo kernel: Adding 17777232k swap on /dev/mapper/luks-e4419e8b-5200-43f2-9f1f-8f886ee1616a. Priority:-2 extents:1 across:17777232k SS
dic 28 20:00:24 nacho-Lenovo kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
dic 28 20:00:24 nacho-Lenovo kernel: Bluetooth: BNEP filters: protocol multicast
dic 28 20:00:24 nacho-Lenovo kernel: Bluetooth: BNEP socket layer initialized
dic 28 20:00:24 nacho-Lenovo kernel: Bluetooth: MGMT ver 1.22
dic 28 20:00:24 nacho-Lenovo kernel: NET: Registered PF_ALG protocol family
dic 28 20:00:24 nacho-Lenovo kernel: loop0: detected capacity change from 0 to 8
dic 28 20:00:24 nacho-Lenovo kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
dic 28 20:00:24 nacho-Lenovo kernel: kauditd_printk_skb: 58 callbacks suppressed
dic 28 20:00:24 nacho-Lenovo kernel: audit: type=1400 audit(1703790024.509:70): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“/usr/lib/snapd/snap-confine” pid=809 comm=“apparmor_parser”
dic 28 20:00:24 nacho-Lenovo kernel: audit: type=1400 audit(1703790024.536:71): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“/usr/lib/snapd/snap-confine//mount-namespace-capture-helper” pid=809 comm=“apparmor_parser”
dic 28 20:00:24 nacho-Lenovo kernel: Generic FE-GE Realtek PHY r8169-0-200:00: attached PHY driver (mii_bus:phy_addr=r8169-0-200:00, irq=MAC)
dic 28 20:00:24 nacho-Lenovo kernel: r8169 0000:02:00.0 enp2s0: Link is Down
dic 28 20:00:24 nacho-Lenovo kernel: iwlwifi 0000:00:14.3: Registered PHC clock: iwlwifi-PTP, with index: 0
dic 28 20:00:26 nacho-Lenovo kernel: ACPI Warning: _SB.NPCF._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230628/nsarguments-61)
dic 28 20:00:26 nacho-Lenovo kernel: ACPI Warning: _SB.PC00.RP05.PXSX._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230628/nsarguments-61)
dic 28 20:00:27 nacho-Lenovo kernel: Xorg[842]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
dic 28 20:00:28 nacho-Lenovo kernel: wlp0s20f3: authenticate with 24:d3:f2:ed:1b:3c
dic 28 20:00:28 nacho-Lenovo kernel: wlp0s20f3: send auth to 24:d3:f2:ed:1b:3c (try 1/3)
dic 28 20:00:28 nacho-Lenovo kernel: wlp0s20f3: authenticated
dic 28 20:00:28 nacho-Lenovo kernel: wlp0s20f3: associate with 24:d3:f2:ed:1b:3c (try 1/3)
dic 28 20:00:28 nacho-Lenovo kernel: wlp0s20f3: RX AssocResp from 24:d3:f2:ed:1b:3c (capab=0x511 status=0 aid=30)
dic 28 20:00:28 nacho-Lenovo kernel: wlp0s20f3: associated
dic 28 20:00:28 nacho-Lenovo kernel: wlp0s20f3: Limiting TX power to 23 (23 - 0) dBm as advertised by 24:d3:f2:ed:1b:3c
dic 28 20:00:32 nacho-Lenovo systemd-journald[354]: File /var/log/journal/86da4ca7c2a047e88e3c5f7785911172/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
dic 28 20:00:34 nacho-Lenovo kernel: Bluetooth: RFCOMM TTY layer initialized
dic 28 20:00:34 nacho-Lenovo kernel: Bluetooth: RFCOMM socket layer initialized
dic 28 20:00:34 nacho-Lenovo kernel: Bluetooth: RFCOMM ver 1.11
dic 28 20:00:34 nacho-Lenovo kernel: warning: `kdeconnectd’ uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Any ideas or help will be welcome.
Thanks, and ¡HAPPY NEW YEAR TO EVERYBODY!
