Hibernation blackens the screen disabling any interaction except forced turn off, and on turn on the previous session is lost.
uname -a:
Linux silviu-omenbyhplaptop17cb0xxx 6.12.21-4-MANJARO #1 SMP PREEMPT_DYNAMIC Tue, 01 Apr 2025 18:45:30 +0000 x86_64 GNU/Linux
I’ve put resume
in the /etc/mkinitcpio.conf. Now the computer shuts down when selecting Hibernate, but the session is still lost.
$ sudo journalctl -u systemd-hibernate.service
apr 07 00:29:18 silviu-omenbyhplaptop17cb0xxx systemd[1]: Starting System Hibernate...
apr 07 00:29:18 silviu-omenbyhplaptop17cb0xxx systemd-sleep[34878]: Successfully froze unit 'user.slice'.
apr 07 00:29:18 silviu-omenbyhplaptop17cb0xxx systemd-sleep[34878]: Performing sleep operation 'hibernate'...
-- Boot f6d23ccc908f4aa7b43771b636865084 --
apr 18 17:01:45 silviu-omenbyhplaptop17cb0xxx systemd[1]: Starting System Hibernate...
apr 18 17:01:45 silviu-omenbyhplaptop17cb0xxx systemd-sleep[51765]: Successfully froze unit 'user.slice'.
apr 18 17:01:45 silviu-omenbyhplaptop17cb0xxx systemd-sleep[51765]: Performing sleep operation 'hibernate'...
apr 18 17:02:01 silviu-omenbyhplaptop17cb0xxx systemd[1]: systemd-hibernate.service: Main process exited, code=exited, status=1/FAILURE
apr 18 17:02:01 silviu-omenbyhplaptop17cb0xxx systemd[1]: systemd-hibernate.service: Failed with result 'exit-code'.
apr 18 17:02:01 silviu-omenbyhplaptop17cb0xxx systemd[1]: Failed to start System Hibernate.
apr 18 17:02:01 silviu-omenbyhplaptop17cb0xxx systemd[1]: systemd-hibernate.service: Consumed 6.564s CPU time, 1.8M memory peak, 916K memory swap peak.
-- Boot 337c62a822274541933ef3ece4014d92 --
apr 26 14:22:46 silviu-omenbyhplaptop17cb0xxx systemd[1]: Starting System Hibernate...
apr 26 14:22:46 silviu-omenbyhplaptop17cb0xxx systemd-sleep[1294137]: Successfully froze unit 'user.slice'.
apr 26 14:22:46 silviu-omenbyhplaptop17cb0xxx systemd-sleep[1294137]: Performing sleep operation 'hibernate'...
-- Boot ee386c62f7114ec68e956334d8f28b59 --
apr 26 14:23:59 silviu-omenbyhplaptop17cb0xxx systemd[1]: Starting System Hibernate...
apr 26 14:23:59 silviu-omenbyhplaptop17cb0xxx systemd-sleep[2078]: Successfully froze unit 'user.slice'.
apr 26 14:23:59 silviu-omenbyhplaptop17cb0xxx systemd-sleep[2078]: Performing sleep operation 'hibernate'...
$ cat /sys/power/mem_sleep
s2idle [deep]
swapon:
NAME TYPE SIZE USED PRIO
/dev/nvme0n1p7 partition 19,5G 0B -2
/etc/mkinitcpio.conf as installed by Manjaro Installer and added resume option:
HOOKS=(base udev autodetect microcode kms modconf block keyboard keymap consolefont plymouth filesystems fsck resume)
/etc/default/grub
# GRUB boot loader configuration
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR='Manjaro'
GRUB_CMDLINE_LINUX_DEFAULT='quiet splash udev.log_priority=3'
GRUB_CMDLINE_LINUX=""
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'menu' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE=hidden
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
GRUB_DISABLE_OS_PROBER=false
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
/etc/systemd/sleep.conf
# This file is part of systemd.
# systemd is free software; you can redistribute it and/or modify it under the
# terms of the GNU Lesser General Public License as published by the Free
# Software Foundation; either version 2.1 of the License, or (at your option)
# any later version.
# Entries in this file show the compile time defaults. Local configuration
# should be created by either modifying this file (or a copy of it placed in
# /etc/ if the original file is shipped in /usr/), or by creating "drop-ins" in
# the /etc/systemd/sleep.conf.d/ directory. The latter is generally
# recommended. Defaults can be restored by simply deleting the main
# configuration file and all drop-ins located in /etc/.
# Use 'systemd-analyze cat-config systemd/sleep.conf' to display the full config.
# See systemd-sleep.conf(5) for details.
[Sleep]
#AllowSuspend=yes
#AllowHibernation=yes
#AllowSuspendThenHibernate=yes
#AllowHybridSleep=yes
#SuspendState=mem standby freeze
#HibernateMode=platform shutdown
#MemorySleepMode=
#HibernateDelaySec=
#HibernateOnACPower=yes
#SuspendEstimationSec=60min
inxy -Fazy:
Kernel: 6.12.21-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=5c4cde37-dac8-41e3-95c6-7b79465ca0fe rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Laptop System: HP product: OMEN by HP Laptop 17-cb0xxx v: N/A
Mobo: HP model: 8603 v: 45.40 serial: <superuser required>
part-nu: 8RT96EA#AKE uuid: <superuser required> UEFI: AMI v: F.23
date: 02/18/2020
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse B330/M330/M331
status: discharging
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62431
vulnerable
Device-1: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Hewlett-Packard
driver: nouveau v: kernel non-free: 550-570.xx+ status: current (as of
2025-04; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:1f11 class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
Integrated Webcam driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-5:4 chip-ID: 05c8:03bc class-ID: 0e02
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: nouveau gpu: nouveau display-ID: :0 screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1774 built: 2020 res: 1920x1080
dpi: 128 gamma: 1.2 size: 381x214mm (15x8.43") diag: 437mm (17.2")
ratio: 16:9 modes: max: 1920x1080 min: 640x350
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau x11:
drv: nouveau inactive: wayland
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 25.0.3-arch1.1 glx-v: 1.4
direct-render: yes renderer: NV166 device-ID: 10de:1f11 memory: 5.85 GiB
unified: no
API: Vulkan v: 1.4.309 layers: N/A device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 2060 (NVK TU106) driver: mesa nvk v: 25.0.3-arch1.1
device-ID: 10de:1f11 surfaces: xcb,xlib
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_avs,
snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0401
Device-2: NVIDIA TU106 High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f9
class-ID: 0403
API: ALSA v: k6.12.21-4-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 3c:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp60s0 state: down mac: <filter>
Info: services: httpd, NetworkManager, systemd-timesyncd, wpa_supplicant
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 5020 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.95 TiB used: 37.87 GiB (1.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB1T0HBLR-000H1
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: HPS0NEXF temp: 41.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: PSSD T7 Touch
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Kingston model: DT microDuo 3C
size: 115.5 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: PMAP scheme: MBR
ID-1: / raw-size: 194.82 GiB size: 190.71 GiB (97.89%)
used: 37.87 GiB (19.9%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p9 maj-min: 259:9
ID-1: swap-1 type: partition size: 19.53 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:7
System Temperatures: cpu: 48.0 C pch: 47.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0 fan-2: 0
Memory: total: 16 GiB note: est. available: 15.49 GiB used: 5.93 GiB (38.3%)
Processes: 320 Power: uptime: 19m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.17 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: 1478 pm: pacman pkgs: 1471 libs: 383 tools: pamac pm: flatpak
pkgs: 7 Compilers: gcc: 14.2.1 Shell: fish v: 4.0.1 default: Bash v: 5.2.37
running-in: tmux: inxi: 3.3.38
The installation of Manjaro is not older than 2 weeks.
