Hibernation blinks power light, then immediately Resumes
Hello! Fresh install of Manjaro KDE Plasma on a Thinkpad P1 Gen5, using Nvidia Quadro.
  • S0ix works flawlessly OOTB. Suspends for days and resumes perfectly.
  • Using swapfile at /swapfile (on a LUKS partition)
  • Added “resume” hook to mkinitcpio after encrypt
  • Standard Manjaro installer’s LUKS encrypted EXT4 as root
Rebooted and when clicking Hibernate, the machine/display powers off for 4 seconds, which blinks the power light quickly like 8 times, and then immediately resumes. I went back in and added the optional Kernel parameters (even though i was trying to use the systemd EFI variable):
  • Added resume and resume_offset according to ArchLinux hibernation instructions
That did not change anything.
Below is the captured (large) dmesg from the moment i click Hibernate, and then I truncate it just after it resumes.
Note the timestamps of when it freezes and resumes.
[  386.599498] wlp0s20f3: deauthenticating from f0:9f:c2:66:59:0d by local choice (Reason: 3=DEAUTH_LEAVING)
[  389.472130] PM: hibernation: hibernation entry
[  389.484335] Filesystems sync: 0.009 seconds
[  389.485412] Freezing user space processes
[  389.487999] Freezing user space processes completed (elapsed 0.002 seconds)
[  389.488010] OOM killer disabled.
[  389.488886] PM: hibernation: Marking nosave pages: [mem 0x00000000-0x00000fff]
[  389.488894] PM: hibernation: Marking nosave pages: [mem 0x0009f000-0x000fffff]
[  389.488900] PM: hibernation: Marking nosave pages: [mem 0x663f9000-0x66639fff]
[  389.488922] PM: hibernation: Marking nosave pages: [mem 0x675a7000-0x675a7fff]
[  389.488925] PM: hibernation: Marking nosave pages: [mem 0x6bb6f000-0x717fefff]
[  389.489642] PM: hibernation: Marking nosave pages: [mem 0x71800000-0xffffffff]
[  389.496860] PM: hibernation: Basic memory bitmaps created
[  389.498408] PM: hibernation: Preallocating image memory
[  390.643957] PM: hibernation: Allocated 1863310 pages for snapshot
[  390.643959] PM: hibernation: Allocated 7453240 kbytes in 1.14 seconds (6537.92 MB/s)
[  390.643961] Freezing remaining freezable tasks
[  390.645363] Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
[  390.729460] printk: Suspending console(s) (use no_console_suspend to debug)
[  392.374918] pcieport 0000:00:1d.0: pciehp: Slot(8): Card present
[  392.374932] pcieport 0000:00:1d.0: pciehp: Slot(8): Link Up
[  392.505987] pci 0000:20:00.0: [8086:1136] type 01 class 0x060400 PCIe Switch Upstream Port
[  392.506062] pci 0000:20:00.0: PCI bridge to [bus 00]
[  392.506084] pci 0000:20:00.0:   bridge window [io  0x0000-0x0fff]
[  392.506094] pci 0000:20:00.0:   bridge window [mem 0x00000000-0x000fffff]
[  392.506123] pci 0000:20:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[  392.506155] pci 0000:20:00.0: enabling Extended Tags
[  392.506437] pci 0000:20:00.0: supports D1 D2
[  392.506441] pci 0000:20:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[  392.506655] pci 0000:20:00.0: PTM enabled, 4ns granularity
[  392.506735] pci 0000:20:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0000:00:1d.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[  392.507178] pci 0000:20:00.0: PM: parent 0000:00:1d.0 should not be sleeping
[  392.507230] pci 0000:20:00.0: Adding to iommu group 18
[  392.507447] pcieport 0000:00:1d.0: ASPM: current common clock configuration is inconsistent, reconfiguring
[  392.535939] pci 0000:20:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[  392.536634] pci 0000:21:00.0: [8086:1136] type 01 class 0x060400 PCIe Switch Downstream Port
[  392.536722] pci 0000:21:00.0: PCI bridge to [bus 00]
[  392.536752] pci 0000:21:00.0:   bridge window [io  0x0000-0x0fff]
[  392.536769] pci 0000:21:00.0:   bridge window [mem 0x00000000-0x000fffff]
[  392.536813] pci 0000:21:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[  392.536865] pci 0000:21:00.0: enabling Extended Tags
[  392.537191] pci 0000:21:00.0: supports D1 D2
[  392.537197] pci 0000:21:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[  392.537942] pci 0000:21:00.0: Adding to iommu group 19
[  392.538409] pci 0000:21:01.0: [8086:1136] type 01 class 0x060400 PCIe Switch Downstream Port
[  392.538492] pci 0000:21:01.0: PCI bridge to [bus 00]
[  392.538523] pci 0000:21:01.0:   bridge window [io  0x0000-0x0fff]
[  392.538544] pci 0000:21:01.0:   bridge window [mem 0x00000000-0x000fffff]
[  392.538579] pci 0000:21:01.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[  392.538631] pci 0000:21:01.0: enabling Extended Tags
[  392.538947] pci 0000:21:01.0: supports D1 D2
[  392.538952] pci 0000:21:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[  392.539638] pci 0000:21:01.0: Adding to iommu group 20
[  392.540070] pci 0000:21:02.0: [8086:1136] type 01 class 0x060400 PCIe Switch Downstream Port
[  392.540149] pci 0000:21:02.0: PCI bridge to [bus 00]
[  392.540172] pci 0000:21:02.0:   bridge window [io  0x0000-0x0fff]
[  392.540193] pci 0000:21:02.0:   bridge window [mem 0x00000000-0x000fffff]
[  392.540227] pci 0000:21:02.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[  392.540270] pci 0000:21:02.0: enabling Extended Tags
[  392.540557] pci 0000:21:02.0: supports D1 D2
[  392.540562] pci 0000:21:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[  392.540855] pci 0000:21:02.0: Adding to iommu group 21
[  392.540964] pci 0000:21:03.0: [8086:1136] type 01 class 0x060400 PCIe Switch Downstream Port
[  392.541010] pci 0000:21:03.0: PCI bridge to [bus 00]
[  392.541021] pci 0000:21:03.0:   bridge window [io  0x0000-0x0fff]
[  392.541026] pci 0000:21:03.0:   bridge window [mem 0x00000000-0x000fffff]
[  392.541045] pci 0000:21:03.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[  392.541070] pci 0000:21:03.0: enabling Extended Tags
[  392.541265] pci 0000:21:03.0: supports D1 D2
[  392.541266] pci 0000:21:03.0: PME# supported from D0 D1 D2 D3hot D3cold
[  392.541567] pci 0000:21:03.0: Adding to iommu group 22
[  392.541682] pci 0000:20:00.0: PCI bridge to [bus 21-89]
[  392.541706] pci 0000:21:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[  392.541717] pci 0000:21:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[  392.541728] pci 0000:21:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[  392.541739] pci 0000:21:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[  392.541890] pci 0000:22:00.0: [8086:1137] type 00 class 0x0c0340 PCIe Endpoint
[  392.541926] pci 0000:22:00.0: BAR 0 [mem 0x00000000-0x0003ffff 64bit pref]
[  392.541948] pci 0000:22:00.0: BAR 2 [mem 0x00000000-0x00000fff 64bit pref]
[  392.541996] pci 0000:22:00.0: enabling Extended Tags
[  392.542177] pci 0000:22:00.0: supports D1 D2
[  392.542178] pci 0000:22:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[  392.542475] pci 0000:22:00.0: Adding to iommu group 23
[  392.542587] pci 0000:21:00.0: PCI bridge to [bus 22-89]
[  392.542609] pci_bus 0000:22: busn_res: [bus 22-89] end is updated to 22
[  392.542694] pci 0000:21:01.0: PCI bridge to [bus 23-89]
[  392.542714] pci_bus 0000:23: busn_res: [bus 23-89] end is updated to 56
[  392.542846] pci 0000:57:00.0: [8086:1138] type 00 class 0x0c0330 PCIe Endpoint
[  392.542878] pci 0000:57:00.0: BAR 0 [mem 0x00000000-0x0000ffff 64bit]
[  392.542945] pci 0000:57:00.0: enabling Extended Tags
[  392.543063] pci 0000:57:00.0: PME# supported from D3hot D3cold
[  392.543116] pci 0000:57:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0000:00:1d.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[  392.543194] pci 0000:57:00.0: Adding to iommu group 24
[  392.543301] pci 0000:21:02.0: PCI bridge to [bus 57-89]
[  392.543322] pci_bus 0000:57: busn_res: [bus 57-89] end is updated to 57
[  392.543405] pci 0000:21:03.0: PCI bridge to [bus 58-89]
[  392.543425] pci_bus 0000:58: busn_res: [bus 58-89] end is updated to 89
[  392.543430] pci_bus 0000:21: busn_res: [bus 21-89] end is updated to 89
[  392.543437] pci 0000:21:01.0: bridge window [mem 0x00100000-0x001fffff 64bit pref] to [bus 23-56] add_size 100000 add_align 100000
[  392.543439] pci 0000:21:01.0: bridge window [mem 0x00100000-0x001fffff] to [bus 23-56] add_size 100000 add_align 100000
[  392.543440] pci 0000:21:03.0: bridge window [mem 0x00100000-0x001fffff 64bit pref] to [bus 58-89] add_size 100000 add_align 100000
[  392.543442] pci 0000:21:03.0: bridge window [mem 0x00100000-0x001fffff] to [bus 58-89] add_size 100000 add_align 100000
[  392.543444] pci 0000:20:00.0: bridge window [mem 0x00100000-0x004fffff 64bit pref] to [bus 21-89] add_size 200000 add_align 100000
[  392.543445] pci 0000:20:00.0: bridge window [mem 0x00100000-0x004fffff] to [bus 21-89] add_size 200000 add_align 100000
[  392.543450] pci 0000:20:00.0: bridge window [mem 0x84000000-0xb20fffff]: assigned
[  392.543451] pci 0000:20:00.0: bridge window [mem 0x6410000000-0x645a0fffff 64bit pref]: assigned
[  392.543452] pci 0000:20:00.0: bridge window [io  size 0x4000]: can't assign; no space
[  392.543454] pci 0000:20:00.0: bridge window [io  size 0x4000]: failed to assign
[  392.543456] pci 0000:21:00.0: bridge window [mem 0x84000000-0x840fffff]: assigned
[  392.543457] pci 0000:21:00.0: bridge window [mem 0x6410000000-0x64100fffff 64bit pref]: assigned
[  392.543458] pci 0000:21:01.0: bridge window [mem 0x84100000-0x9affffff]: assigned
[  392.543459] pci 0000:21:01.0: bridge window [mem 0x6410100000-0x6434ffffff 64bit pref]: assigned
[  392.543460] pci 0000:21:02.0: bridge window [mem 0x9b000000-0x9b0fffff]: assigned
[  392.543461] pci 0000:21:02.0: bridge window [mem 0x6435000000-0x64350fffff 64bit pref]: assigned
[  392.543462] pci 0000:21:03.0: bridge window [mem 0x9b100000-0xb1ffffff]: assigned
[  392.543462] pci 0000:21:03.0: bridge window [mem 0x6435100000-0x6459ffffff 64bit pref]: assigned
[  392.543463] pci 0000:21:00.0: bridge window [io  size 0x1000]: can't assign; no space
[  392.543464] pci 0000:21:00.0: bridge window [io  size 0x1000]: failed to assign
[  392.543465] pci 0000:21:01.0: bridge window [io  size 0x1000]: can't assign; no space
[  392.543465] pci 0000:21:01.0: bridge window [io  size 0x1000]: failed to assign
[  392.543466] pci 0000:21:02.0: bridge window [io  size 0x1000]: can't assign; no space
[  392.543467] pci 0000:21:02.0: bridge window [io  size 0x1000]: failed to assign
[  392.543468] pci 0000:21:03.0: bridge window [io  size 0x1000]: can't assign; no space
[  392.543468] pci 0000:21:03.0: bridge window [io  size 0x1000]: failed to assign
[  392.543470] pci 0000:22:00.0: BAR 0 [mem 0x6410000000-0x641003ffff 64bit pref]: assigned
[  392.543488] pci 0000:22:00.0: BAR 2 [mem 0x6410040000-0x6410040fff 64bit pref]: assigned
[  392.543505] pci 0000:21:00.0: PCI bridge to [bus 22]
[  392.543513] pci 0000:21:00.0:   bridge window [mem 0x84000000-0x840fffff]
[  392.543518] pci 0000:21:00.0:   bridge window [mem 0x6410000000-0x64100fffff 64bit pref]
[  392.543527] pci 0000:21:01.0: PCI bridge to [bus 23-56]
[  392.543533] pci 0000:21:01.0:   bridge window [mem 0x84100000-0x9affffff]
[  392.543538] pci 0000:21:01.0:   bridge window [mem 0x6410100000-0x6434ffffff 64bit pref]
[  392.543548] pci 0000:57:00.0: BAR 0 [mem 0x9b000000-0x9b00ffff 64bit]: assigned
[  392.543565] pci 0000:21:02.0: PCI bridge to [bus 57]
[  392.543572] pci 0000:21:02.0:   bridge window [mem 0x9b000000-0x9b0fffff]
[  392.543577] pci 0000:21:02.0:   bridge window [mem 0x6435000000-0x64350fffff 64bit pref]
[  392.543586] pci 0000:21:03.0: PCI bridge to [bus 58-89]
[  392.543593] pci 0000:21:03.0:   bridge window [mem 0x9b100000-0xb1ffffff]
[  392.543598] pci 0000:21:03.0:   bridge window [mem 0x6435100000-0x6459ffffff 64bit pref]
[  392.543607] pci 0000:20:00.0: PCI bridge to [bus 21-89]
[  392.543613] pci 0000:20:00.0:   bridge window [mem 0x84000000-0xb20fffff]
[  392.543618] pci 0000:20:00.0:   bridge window [mem 0x6410000000-0x645a0fffff 64bit pref]
[  392.543627] pcieport 0000:00:1d.0: PCI bridge to [bus 20-89]
[  392.543629] pcieport 0000:00:1d.0:   bridge window [io  0x5000-0x7fff]
[  392.543632] pcieport 0000:00:1d.0:   bridge window [mem 0x84000000-0xb20fffff]
[  392.543635] pcieport 0000:00:1d.0:   bridge window [mem 0x6410000000-0x645a0fffff 64bit pref]
[  392.543639] PCI: No. 2 try to assign unassigned res
[  392.543641] pcieport 0000:00:1d.0: resource 13 [io  0x5000-0x7fff] released
[  392.543642] pcieport 0000:00:1d.0: PCI bridge to [bus 20-89]
[  392.543651] pcieport 0000:00:1d.0: bridge window [io  0x5000-0x8fff]: assigned
[  392.543652] pci 0000:20:00.0: bridge window [io  0x5000-0x8fff]: assigned
[  392.543653] pci 0000:21:00.0: bridge window [io  0x5000-0x5fff]: assigned
[  392.543654] pci 0000:21:01.0: bridge window [io  0x6000-0x6fff]: assigned
[  392.543655] pci 0000:21:02.0: bridge window [io  0x7000-0x7fff]: assigned
[  392.543656] pci 0000:21:03.0: bridge window [io  0x8000-0x8fff]: assigned
[  392.543657] pci 0000:21:00.0: PCI bridge to [bus 22]
[  392.543665] pci 0000:21:00.0:   bridge window [io  0x5000-0x5fff]
[  392.543672] pci 0000:21:00.0:   bridge window [mem 0x84000000-0x840fffff]
[  392.543677] pci 0000:21:00.0:   bridge window [mem 0x6410000000-0x64100fffff 64bit pref]
[  392.543686] pci 0000:21:01.0: PCI bridge to [bus 23-56]
[  392.543689] pci 0000:21:01.0:   bridge window [io  0x6000-0x6fff]
[  392.543695] pci 0000:21:01.0:   bridge window [mem 0x84100000-0x9affffff]
[  392.543700] pci 0000:21:01.0:   bridge window [mem 0x6410100000-0x6434ffffff 64bit pref]
[  392.543709] pci 0000:21:02.0: PCI bridge to [bus 57]
[  392.543712] pci 0000:21:02.0:   bridge window [io  0x7000-0x7fff]
[  392.543718] pci 0000:21:02.0:   bridge window [mem 0x9b000000-0x9b0fffff]
[  392.543723] pci 0000:21:02.0:   bridge window [mem 0x6435000000-0x64350fffff 64bit pref]
[  392.543732] pci 0000:21:03.0: PCI bridge to [bus 58-89]
[  392.543735] pci 0000:21:03.0:   bridge window [io  0x8000-0x8fff]
[  392.543742] pci 0000:21:03.0:   bridge window [mem 0x9b100000-0xb1ffffff]
[  392.543746] pci 0000:21:03.0:   bridge window [mem 0x6435100000-0x6459ffffff 64bit pref]
[  392.543755] pci 0000:20:00.0: PCI bridge to [bus 21-89]
[  392.543758] pci 0000:20:00.0:   bridge window [io  0x5000-0x8fff]
[  392.543765] pci 0000:20:00.0:   bridge window [mem 0x84000000-0xb20fffff]
[  392.543769] pci 0000:20:00.0:   bridge window [mem 0x6410000000-0x645a0fffff 64bit pref]
[  392.543778] pcieport 0000:00:1d.0: PCI bridge to [bus 20-89]
[  392.543779] pcieport 0000:00:1d.0:   bridge window [io  0x5000-0x8fff]
[  392.543783] pcieport 0000:00:1d.0:   bridge window [mem 0x84000000-0xb20fffff]
[  392.543786] pcieport 0000:00:1d.0:   bridge window [mem 0x6410000000-0x645a0fffff 64bit pref]
[  392.543836] pci 0000:20:00.0: enabling device (0000 -> 0003)
[  392.543939] pci 0000:21:02.0: enabling device (0000 -> 0003)
[  392.544018] pci 0000:57:00.0: enabling device (0000 -> 0002)
[  392.550440] ACPI: EC: interrupt blocked
[  392.554369] ACPI: PM: Preparing to enter system sleep state S4
[  392.687339] ACPI: EC: event blocked
[  392.687341] ACPI: EC: EC stopped
[  392.687341] ACPI: PM: Saving platform NVS memory
[  392.691045] Disabling non-boot CPUs ...
[  392.691046] Wakeup pending. Abort CPU freeze
[  392.691047] Non-boot CPUs are not disabled
[  392.691047] ACPI: EC: EC started
[  392.692038] ACPI: PM: Waking up from system sleep state S4
[  398.308374] ACPI: EC: interrupt unblocked
[  398.464344] ACPI: EC: event unblocked
[  398.464484] usb usb1: root hub lost power or was reset
[  398.464486] usb usb2: root hub lost power or was reset
[  398.464936] pcieport 0000:00:1d.0: pciehp: Slot(8): Card not present
[  398.465098] pci_bus 0000:22: busn_res: [bus 22] is released
[  398.465175] pci_bus 0000:23: busn_res: [bus 23-56] is released
[  398.465386] pci_bus 0000:57: busn_res: [bus 57] is released
[  398.465552] pci_bus 0000:58: busn_res: [bus 58-89] is released
[  398.465688] pci_bus 0000:21: busn_res: [bus 21-89] is released
[  398.478796] i915 0000:00:02.0: [drm] GT0: GuC firmware i915/adlp_guc_70.bin version 70.29.2
[  398.478800] i915 0000:00:02.0: [drm] GT0: HuC firmware i915/tgl_huc.bin version 7.9.3
[  398.480463] iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
[  398.480923] nvme nvme0: D3 entry latency set to 8 seconds
[  398.493096] i915 0000:00:02.0: [drm] GT0: HuC: authenticated for all workloads
[  398.493983] i915 0000:00:02.0: [drm] GT0: GUC: submission enabled
[  398.493984] i915 0000:00:02.0: [drm] GT0: GUC: SLPC enabled
[  398.494661] i915 0000:00:02.0: [drm] GT0: GUC: RC enabled
[  398.499301] nvme nvme0: 14/0/0 default/read/poll queues
[  398.636156] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x20
[  398.636205] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[  398.636255] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
[  398.636268] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[  398.637490] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
[  398.749657] usb 1-5: reset full-speed USB device number 2 using xhci_hcd
[  399.012932] usb 1-8: reset high-speed USB device number 4 using xhci_hcd
[  399.276254] usb 1-7: reset full-speed USB device number 3 using xhci_hcd
[  399.542903] usb 1-10: reset full-speed USB device number 5 using xhci_hcd
[  399.690287] PM: hibernation: Basic memory bitmaps freed
Any help would be appreciated!! :slight_smile:
Please see → [Stable Update] 2024-09-02 - Kernels, Pipewire, Systemd, LibreOffice, OGUI, Inputplumber, Firefox - #2 by philm
Thank you. However, I did read and investigated the github issue and none of that applies to my reported issue. The v256 issue is around sleep and “Freezing user space processes failed after…” errors. Searching several boot messages, I have never logged such an error. So the reported issues do not apply.
Also as I reported, S0ix (suspend) works fine for my 6.10 kernel and nvidia proprietary drivers without any of those workarounds - mainly because of the newer 6.10.6 kernel. I was previously on 6.9.x and had some issues with suspend But 6.10.6 is fine for several days now.
My issue seems to be around a hook or config that is triggering Hibernation to wake up immediately: pure hibernation, not suspend or sleep as reported. Following the Arch instructions multiple times on multiple installs has not yielded to Hibernation working.
This is the same as S2Idle according to Power management/Suspend and hibernate - ArchWiki.
You are using Hibernation and if it is not the freeze user sessions that is causing this - I don’t know.
The flashing 8 times seems to be indicative of something - I am guessing the resumed stated cannot be applied fully - but without knowning what the flashes really mean that is a guess.
