Hibernate does not work
Hibernation (suspend to disk) does NOT work.
Sleep (suspend to ram) mostly works fine.
On hibernating, either of the following 2 happens:
  1. The system starts as if it was shutdown. No applications resume.
  2. During boot, the system is stuck at a blank screen. No peripherals working (keyboard seems disabled, since capslock & mute lights are not working)
System Info (inxi --admin --verbosity=7 --filter --width) :
  Kernel: 5.15.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    root=UUID=3558045c-dcc4-487c-a376-25b936741642 rw apparmor=1
    security=apparmor resume=UUID=8b6a5170-152d-42c1-b5d1-6e4016b529c4
    udev.log_priority=3
  Console: pty pts/1 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
    base: Arch Linux
  Type: Laptop System: HP product: HP Pavilion Laptop 14-ce1xxx
    v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: HP model: 84BC v: 15.32 serial: <filter> UEFI: Insyde v: F.24
    date: 09/10/2021
  ID-1: BAT0 charge: 21.5 Wh (77.3%) condition: 27.8/27.8 Wh (100.0%)
    volts: 11.5 min: 11.6 model: HP Primary type: Li-ion serial: N/A
    status: discharging
  RAM: total: 7.65 GiB used: 3.33 GiB (43.5%)
  Array-1: capacity: 16 GiB slots: 1 EC: None max-module-size: 16 GiB
    note: est.
  Device-1: Bottom type: DDR4 detail: synchronous size: 8 GiB
    speed: 2400 MT/s volts: curr: 1.2 width (bits): data: 64 total: 64
    manufacturer: SK Hynix part-no: HMA81GS6AFR8N-UH serial: <filter>
  Info: model: Intel Core i5-8265U socket: BGA1528 (U3E1) note: check bits: 64
    type: MT MCP arch: Whiskey Lake family: 6 model-id: 0x8E (142)
    stepping: 0xB (11) microcode: 0xF0
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 679 high: 700 min/max: 400/3900 base/boost: 1485/8300
    scaling: driver: intel_pstate governor: powersave volts: 0.6 V
    ext-clock: 100 MHz cores: 1: 625 2: 610 3: 700 4: 700 5: 700 6: 700 7: 700
    8: 700 bogomips: 28808
    arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
    cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
    epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
    ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
    nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
    pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep
    ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
  Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Hewlett-Packard
    driver: i915 v: kernel ports: active: HDMI-A-1,eDP-1 empty: none
    bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
  Device-2: NVIDIA GP108M [GeForce MX150] vendor: Hewlett-Packard
    driver: nvidia v: 510.73.05 alternate: nouveau,nvidia_drm non-free: 515.xx+
    status: current (as of 2022-05) arch: Maxwell pcie: gen: 1 speed: 2.5 GT/s
    lanes: 4 link-max: gen: 3 speed: 8 GT/s bus-ID: 02:00.0 chip-ID: 10de:1d10
    class-ID: 0302
  Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
    Integrated Webcam
    type: USB driver: uvcvideo bus-ID: 1-3:2 chip-ID: 05c8:03bc class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
    loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: i915
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1921x2160 s-dpi: 96 s-size: 506x570mm (19.92x22.44")
    s-diag: 762mm (30.01")
  Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: top-right model: HP 24y
    serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
    size: 528x297mm (20.79x11.69") diag: 606mm (23.9") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  Monitor-2: eDP-1 pos: primary,bottom-l model: LG Display 0x060f
    built: 2018 res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2
    size: 309x174mm (12.17x6.85") diag: 355mm (14") ratio: 16:9
    modes: 1920x1080
  OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 22.0.4
    direct render: Yes
  Device-1: Intel Cannon Point-LP High Definition Audio
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
    alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
    chip-ID: 8086:9dc8 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.41-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.51 running: yes
  Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
    vendor: Hewlett-Packard driver: r8169 v: kernel pcie: speed: Unknown
    lanes: 63 link-max: gen: 6 speed: 64 GT/s port: 3000 bus-ID: 04:00.0
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
    driver: btusb v: 0.8 bus-ID: 1-10:4 chip-ID: 8087:0aaa class-ID: e001
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
    v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
  Local Storage: total: 1.36 TiB used: 437.81 GiB (31.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
    family: Mobile HDD size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 5400
    serial: <filter> rev: RSM7 temp: 33 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 331d 22h cycles: 5825
    Pre-Fail: attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WDS500G2B0B-00YS70 family: WD Blue / Red / Green SSDs
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B sata: 3.3
    speed: 6.0 Gb/s type: SSD serial: <filter> rev: 20WD temp: 40 C
    scheme: GPT
  SMART: yes state: enabled health: PASSED on: 147d 10h cycles: 2271
  ID-1: / raw-size: 58.59 GiB size: 57.37 GiB (97.92%) used: 36.3 GiB (63.3%)
    fs: ext4 block-size: 4096 B dev: /dev/sdb7 maj-min: 8:23 label: N/A
    uuid: 3558045c-dcc4-487c-a376-25b936741642
  ID-2: /boot/efi raw-size: 99 MiB size: 95 MiB (95.96%)
    used: 65 MiB (68.4%) fs: vfat block-size: 512 B dev: /dev/sdb2 maj-min: 8:18
    label: N/A uuid: D0BA-8DA9
  ID-3: /mnt/DATA raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
    used: 340.51 GiB (36.6%) fs: ntfs block-size: 4096 B dev: /dev/sda1
    maj-min: 8:1 label: DATA uuid: E6229D50229D2699
  ID-4: /mnt/extra raw-size: 90 GiB size: 88.28 GiB (98.09%)
    used: 60.94 GiB (69.0%) fs: ext4 block-size: 4096 B dev: /dev/sdb8
    maj-min: 8:24 label: extra uuid: 1860a152-1859-43ce-8e9e-9a147664f87c
  ID-1: swap-1 type: partition size: 20.51 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sdb6 maj-min: 8:22 label: N/A
    uuid: 8b6a5170-152d-42c1-b5d1-6e4016b529c4
  ID-1: /dev/sdb1 maj-min: 8:17 size: 529 MiB fs: ntfs label: Recovery
    uuid: 6C7EB8CA7EB88DF8
  ID-2: /dev/sdb3 maj-min: 8:19 size: 16 MiB fs: N/A label: N/A uuid: N/A
  ID-3: /dev/sdb4 maj-min: 8:20 size: 295.28 GiB fs: ntfs label: Windows
    uuid: 58CCBD3ACCBD12EC
  ID-4: /dev/sdb5 maj-min: 8:21 size: 762 MiB fs: ntfs label: N/A
    uuid: 1EA0E006A0DFE277
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-1:5 info: Lenovo Wireless Mouse type: Mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 98mA
    chip-ID: 17ef:60d1 class-ID: 0301
  Device-2: 1-3:2 info: Cheng Uei Precision Industry (Foxlink) HP Wide
    Vision HD Integrated Webcam
    type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
    power: 500mA chip-ID: 05c8:03bc class-ID: 0e02
  Device-3: 1-10:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
    type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 8087:0aaa class-ID: e001
  Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 50.0 C pch: 47.0 C mobo: N/A
  Processes: 258 Uptime: 50m wakeups: 8 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1425 pacman: 1419 lib: 373
  flatpak: 0 snap: 6 Shell: Bash (sudo) v: 5.1.16 running-in: konsole
  inxi: 3.3.16
Boot logs: journalctl -b 0 -x -p 3
Jun 04 17:02:06 BatBook kernel: x86/cpu: SGX disabled by BIOS.
Jun 04 17:02:06 BatBook kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.IPPF._STA.POS1], AE_NOT_FOUND (20210730/psargs-330)
Jun 04 17:02:06 BatBook kernel: ACPI Error: Aborting method \_SB.IPPF._STA due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Jun 04 17:02:06 BatBook kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
Jun 04 17:02:06 BatBook kernel: ACPI Error: Aborting method \_SB.PR01._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Jun 04 17:02:06 BatBook kernel: ACPI Error: Aborting method \_SB.PR02._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Jun 04 17:02:06 BatBook kernel: ACPI Error: Aborting method \_SB.PR03._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Jun 04 17:02:06 BatBook kernel: ACPI Error: Aborting method \_SB.PR04._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Jun 04 17:02:06 BatBook kernel: ACPI Error: Aborting method \_SB.PR05._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Jun 04 17:02:06 BatBook kernel: ACPI Error: Aborting method \_SB.PR06._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Jun 04 17:02:06 BatBook kernel: ACPI Error: Aborting method \_SB.PR07._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Jun 04 17:02:07 BatBook kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.IPPF._STA.POS1], AE_NOT_FOUND (20210730/psargs-330)
Jun 04 17:02:07 BatBook kernel: ACPI Error: Aborting method \_SB.IPPF._STA due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Jun 04 17:02:08 BatBook kernel:
Jun 04 17:02:09 BatBook kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.IPPF._STA.POS1], AE_NOT_FOUND (20210730/psargs-330)
Jun 04 17:02:09 BatBook kernel: ACPI Error: Aborting method \_SB.IPPF._STA due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Jun 04 17:02:10 BatBook kernel: Bluetooth: hci0: Failed to send firmware data (-38)
Jun 04 17:02:10 BatBook kernel: Bluetooth: hci0: sending frame failed (-19)
Jun 04 17:02:13 BatBook kernel: Bluetooth: hci0: command 0xfc1e tx timeout
Jun 04 17:02:13 BatBook kernel: Bluetooth: hci0: Failed to read MSFT supported features (-110)
Jun 04 17:02:28 BatBook kwin_x11[1204]: kwin_xkbcommon: XKB: couldn't find a Compose file for locale "en_IN" (mapped to "en_IN.ISO8859-1")
Jun 04 17:02:29 BatBook kded5[1201]: org.kde.plasma.dataengine.geolocation: error:  "Unknown host location.services.mozilla.com: Host not found"
Jun 04 17:04:59 BatBook sudo[2436]:  samarth : a password is required ; TTY=pts/1 ; PWD=/home/samarth ; USER=root ; COMMAND=/sbin/file -s /dev/sdb3
Previous boot logs : journalctl -b -1 -x -p 3
Jun 04 11:29:26 BatBook kernel: x86/cpu: SGX disabled by BIOS.
Jun 04 11:29:26 BatBook kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.IPPF._STA.POS1], AE_NOT_FOUND (20210730/psargs-330)
Jun 04 11:29:26 BatBook kernel: ACPI Error: Aborting method \_SB.IPPF._STA due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Jun 04 11:29:26 BatBook kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
Jun 04 11:29:26 BatBook kernel: ACPI Error: Aborting method \_SB.PR01._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Jun 04 11:29:26 BatBook kernel: ACPI Error: Aborting method \_SB.PR02._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Jun 04 11:29:26 BatBook kernel: ACPI Error: Aborting method \_SB.PR03._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Jun 04 11:29:26 BatBook kernel: ACPI Error: Aborting method \_SB.PR04._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Jun 04 11:29:26 BatBook kernel: ACPI Error: Aborting method \_SB.PR05._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Jun 04 11:29:26 BatBook kernel: ACPI Error: Aborting method \_SB.PR06._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Jun 04 11:29:26 BatBook kernel: ACPI Error: Aborting method \_SB.PR07._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Jun 04 11:29:26 BatBook kernel: Hibernate inconsistent memory map detected!
Jun 04 11:29:26 BatBook kernel: PM: hibernation: Image mismatch: architecture specific data
Jun 04 11:29:26 BatBook kernel: PM: hibernation: Failed to load image, recovering.
Jun 04 11:29:27 BatBook kernel:
Jun 04 11:29:28 BatBook kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.IPPF._STA.POS1], AE_NOT_FOUND (20210730/psargs-330)
Jun 04 11:29:28 BatBook kernel: ACPI Error: Aborting method \_SB.IPPF._STA due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Jun 04 11:29:48 BatBook kwin_x11[1140]: kwin_xkbcommon: XKB: couldn't find a Compose file for locale "en_IN" (mapped to "en_IN.ISO8859-1")
Jun 04 11:29:49 BatBook kded5[1137]: org.kde.plasma.dataengine.geolocation: error:  "Unknown host location.services.mozilla.com: Host not found"
Jun 04 11:29:50 BatBook bluetoothd[748]: Failed to set mode: Blocked through rfkill (0x12)
Jun 04 12:00:05 BatBook bluetoothd[748]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
Jun 04 12:00:52 BatBook bluetoothd[748]: profiles/audio/avctp.c:avctp_control_confirm() Control: Refusing unexpected connect
Jun 04 12:00:53 BatBook pulseaudio[1225]: org.freedesktop.DBus.Properties.Get /org/bluez/hci0/dev_FC_58_FA_58_0E_32/sep1/fd0 Volume failed: org.freedesktop.DBus.Error.InvalidArgs>
Jun 04 12:54:36 BatBook bluetoothd[748]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected
Things I have ensured (consulted forum and Arch wiki):
  • /etc/mkinitcpio.conf contains the resume hook
HOOKS="base udev autodetect modconf block keyboard keymap resume filesystems fsck"
  • /etc/default/grub also has Swap device UUID specified
GRUB_CMDLINE_LINUX_DEFAULT="apparmor=1 security=apparmor resume=UUID=8b6a5170-152d-42c1-b5d1-6e4016b529c4 udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
  • Swap partition is also 20.5G, which is more than double the RAM (8G)
Happy to provide any more info to debug/fix this issue.
Thanks in advance! :slight_smile:
It is impossible to troubleshoot BIOS errors - that is an upstream kernel developer task.
I have similar messages on my system but as I rarely use hibernation I have only few ideas.
Try fiddling with the acpi daemon - perhaps add acpi settings to the kernel command line - search the arck wiki for acpi - see if there’s hints to what can be done.
Edit 2022-06-04T14:21:00Z
Perhaps your issue is related to your GPU - try searching the forum - I am fairly certain I have seen issues with hibernation using Nvidia GPU.
I also tested with the Manjaro lxqt-kwin ISO - bare metal install using Calamares → Erase disk → Swap+Hibernate option.
My bare-metal test is using Intel only.
Result is that hibernate works - the manual test is
systemctl hibernate
Yet another test
This time - I don’t have to install anything - it is functional laptop - with dual graphics - Intel Nvidia
$ inxi -M
  Type: Laptop System: LENOVO product: 20CKCTO1WW v: ThinkPad T550
    serial: <superuser required>
  Mobo: LENOVO model: 20CKCTO1WW v: SDK0E50512 STD
    serial: <superuser required> UEFI: LENOVO v: N11ET48W (1.24 )
    date: 03/20/2019
$ inxi -S
  Host: lion Kernel: 5.17.7-1-MANJARO arch: x86_64 bits: 64
    Desktop: KDE Plasma v: 5.24.5 Distro: Manjaro Linux
$ inxi -G
  Device-1: Intel HD Graphics 5500 driver: i915 v: kernel
  Device-2: NVIDIA GM108M [GeForce 940M] driver: nouveau v: kernel
  Device-3: Acer Integrated Camera type: USB driver: uvcvideo
  Display: x11 server: X.Org v: 21.1.3 driver: X: loaded: modesetting
    gpu: i915 resolution: 2880x1620~60Hz
  Message: Unable to show GL data. Required tool glxinfo missing.
I completely forgot I brought it to a meeting to show a client how far I am with their project - opened the lid and the system resumed from hibernation - just where I left it a fortnight ago - no issues.
While all this is not very helpful - it does tell us that it is an issue local to your system and configuration.
The resume settings on this system equals yours - but my system is using nouveau driver instead of Nvidia
[fh@lion ~]$ cat /etc/mkinitcpio.conf | grep HOOKS=\"
HOOKS="base udev autodetect modconf block keyboard keymap consolefont resume filesystems fsck"
[fh@lion ~]$ cat /etc/default/grub | grep GRUB_CMDLINE_LINUX_DEFAULT
GRUB_CMDLINE_LINUX_DEFAULT="quiet resume=UUID=d9c6ab8f-c338-4e7d-a4a4-3c07b6068b2e  udev.log_priority=3"
So I think you limit your troubleshooting to how you get the Nvidia driver to play nice with hibernation.
For these BIOS ACPI errors, I came across forum posts with similar errors. People advised that they are pretty common (vendors to blame), and generally do not matter. In my case, not so sure.
Okay, will try that. By the way, I did try stuff with KMS and modules in initramfs (Making sure you're not a bot!), but no luck.
Hmm seems possible. Will look around.
Yes I have tried this manual test. Always boots up like a normal shutdown.
Yeah seems like it. I’ll try switching the drivers.
Got it. Thanks a lot!
