Rebooted.
My wifi settings is no longer showing up.
When I search for it in settings, it shows but disappears afterwards.
good morning to both of you
just in case it helps…
you can install it by activating the AUR
firmware
sudo cp ./rtl8188fu/firmware/rtl8188fufw.bin /lib/firmware/rtlwifi/
Do this:
Because I’m terribly sorry, but I have to be off now.
It’s in the AUR yes:
$ pamac search rtlwifi 1 ↵
rtw88-dkms-git r1.029812e-2 AUR
Newest Realtek rtlwifi codes
So can e installed using:
pamac build rtw88-dkms-git
Thank you very much for our time. Very much appreciated.
Good morning.
Its afternoon here in Ghana, tho.
[sudo] password for nuestman:
cp: cannot stat './rtl8188fu/firmware/rtl8188fufw.bin': No such file or directory
See:
pamac build rtw88-dkms-git 1 ✘ 5s
Preparing...
Checking rtw88-dkms-git dependencies...
Resolving dependencies...
Checking inter-conflicts...
To build (1):
Edit build files : [e]
Apply transaction ? [e/y/N] y
Cloning rtw88-dkms-git build files...
Generating rtw88-dkms-git information...
Building rtw88-dkms-git...
==> Making package: rtw88-dkms-git r1.029812e-2 (Sat 12 Mar 2022 02:37:40 PM GMT)
==> Retrieving sources...
-> Cloning rtw88 git repo...
Cloning into bare repository '/var/tmp/pamac-build-nuestman/rtw88-dkms-git/rtw88'...
remote: Enumerating objects: 679, done.
remote: Counting objects: 100% (679/679), done.
remote: Compressing objects: 100% (439/439), done.
remote: Total 679 (delta 475), reused 434 (delta 240), pack-reused 0
Receiving objects: 100% (679/679), 1.21 MiB | 885.00 KiB/s, done.
Resolving deltas: 100% (475/475), done.
rtw88 ... Skipped
==> Extracting sources...
-> Creating working copy of rtw88 git repo...
Cloning into 'rtw88'...
done.
==> Starting pkgver()...
==> Updated version: rtw88-dkms-git r124.e8d5abf-1
==> Entering fakeroot environment...
==> Starting package()...
==> Tidying install...
-> Removing libtool files...
-> Purging unwanted files...
-> Removing static library files...
-> Stripping unneeded symbols from binaries and libraries...
-> Compressing man and info pages...
==> Checking for packaging issues...
==> Creating package "rtw88-dkms-git"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Adding install file...
-> Generating .MTREE file...
-> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: rtw88-dkms-git r124.e8d5abf-1 (Sat 12 Mar 2022 02:37:45 PM GMT)
==> Cleaning up...
Checking keyring... [1/1]
Checking integrity... [1/1]
Loading packages files... [1/1]
Checking file conflicts... [1/1]
Checking available disk space... [1/1]
Installing rtw88-dkms-git (r124.e8d5abf-1)... [1/1]
Creating symlink /var/lib/dkms/rtw88/r124.e8d5abf/source -> /usr/src/rtw88-r124.e8d5abf
Building module:
cleaning build area...(bad exit status: 2)
make -j4 KERNELRELEASE=5.15.25-1-MANJARO -C /usr/lib/modules/5.15.25-1-MANJARO/build M=/var/lib/dkms/rtw88/r124.e8d5abf/build.........
rtw_pci.ko.xz:
Running module version sanity check.
- Original module
- No original module exists within this kernel
- Installation
- Installing to /usr/lib/modules/5.15.25-1-MANJARO/updates/dkms/
rtw_8723de.ko.xz:
- Original module
- Installation
rtw_8723d.ko.xz:
- Original module
- Installation
rtw_8822be.ko.xz:
- Original module
- Installation
rtw_8822b.ko.xz:
- Original module
- Installation
rtw_8822ce.ko.xz:
- Original module
- Installation
rtw_8822c.ko.xz:
- Original module
- Installation
rtw_8821ce.ko.xz:
- Original module
- Installation
rtw_8821c.ko.xz:
- Original module
- Installation
rtw_core.ko.xz:
- Original module
- Installation
depmod.......
Arming ConditionNeedsUpdate... [1/2]
Install DKMS modules [2/2]
==> dkms install --no-depmod rtw88/r124.e8d5abf -k 5.15.25-1-MANJARO
==> depmod 5.15.25-1-MANJARO
Rebooted. No luck.
I’m going to do a clean reinstall and see if I have any luck with that.
Thanks everyone. I appreciate it.
Will revert when I’m able to do that.
i think the problem is that the driver for that usb dongle is not updated to kernel 5.15. i also have same usb dongle wifi (Realtek RTL8188FTV) which is also bugged.
Edit:
Somehow i have successfully fixed my wifi, the problem is when you install the driver from AUR your system still use the old wifi driver in my case (and also probably your based the output you gave earlier) is still using the “r8188eu”.
what i did is to remove and blacklist that r8188eu using modprobe
modprobe -r r8188eu
and adding configuration file in /etc/modprobe.d/r8188eu.conf
blacklist r8188eu
proceed to install this driver from AUR (dont forget to install your linux header dkms first)
https://github.com/kelebek333/rtl8188fu
and then restart,
i noticed now my wifi could find and connect to access point
hope it work
Hi. I’m also having these problems. i’m trying these fixes but no luck.
Where do I find these? Please help.
