Helvum is crashing immediately after startup.
I have pipweire installed - and working.
- AUR package pipewire-dropin-replacement.
lib check:
❯ ldd /usr/bin/helvum
linux-vdso.so.1 (0x00007ffc8e77f000)
libpipewire-0.3.so.0 => /usr/lib/libpipewire-0.3.so.0 (0x00007f6b31ae4000)
system:
❯ uname -a
Linux dwarf 5.15.2-2-MANJARO #1 SMP PREEMPT Sat Nov 13 19:25:38 UTC 2021 x86_64 GNU/Linux
Crash:
❯ helvum
(process:2470): Gtk-WARNING **: 08:31:16.475: Unknown key gtk-button-images in /home/pavels/.config/gtk-4.0/settings.ini
(process:2470): Gtk-WARNING **: 08:31:16.475: Unknown key gtk-menu-images in /home/pavels/.config/gtk-4.0/settings.ini
(process:2470): Gtk-WARNING **: 08:31:16.475: Unknown key gtk-toolbar-style in /home/pavels/.config/gtk-4.0/settings.ini
[xcb] Unknown sequence number while processing queue
[xcb] Most likely this is a multi-threaded client and XInitThreads has not been called
[xcb] Aborting, sorry about that.
helvum: xcb_io.c:269: poll_for_event: Předpoklad „!xcb_xlib_threads_sequence_lost“ nesplněn.
[1] 2470 abort (core dumped) helvum
Hello @pprchal and welcome
I cannot find this package on the AUR, thus I assume it has been removed.
- hevlum is in standard repos
sudo pacman -S helvum
- removed pipewire-dropin-replacement(AUR)
- continuing to remove pipewire as is unusable for me now (ardour,…) rolling back to jack
But I don’t think that crash is OK
ha,journalctl -f > helvum.log
-- Journal begins at Tue 2021-12-14 22:35:03 CET. --
pro 15 17:00:50 dwarf audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@4-2825-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
pro 15 17:00:50 dwarf kernel: audit: type=1131 audit(1639584050.170:178): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@4-2825-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
pro 15 17:00:50 dwarf audit: BPF prog-id=0 op=UNLOAD
pro 15 17:00:50 dwarf kernel: audit: type=1334 audit(1639584050.253:179): prog-id=0 op=UNLOAD
pro 15 17:00:50 dwarf kernel: audit: type=1334 audit(1639584050.253:180): prog-id=0 op=UNLOAD
pro 15 17:00:50 dwarf kernel: audit: type=1334 audit(1639584050.253:181): prog-id=0 op=UNLOAD
pro 15 17:01:02 dwarf CROND[2839]: (root) CMD (run-parts /etc/cron.hourly)
pro 15 17:01:02 dwarf CROND[2838]: (root) CMDEND (run-parts /etc/cron.hourly)
pro 15 17:01:11 dwarf kwin_x11[1037]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4308, resource id: 81788934, major code: 18 (ChangeProperty), minor code: 0
pro 15 17:01:15 dwarf audit[2868]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=2868 comm="helvum" exe="/usr/bin/helvum" sig=6 res=1
pro 15 17:01:15 dwarf kernel: audit: type=1701 audit(1639584075.485:182): auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=2868 comm="helvum" exe="/usr/bin/helvum" sig=6 res=1
pro 15 17:01:15 dwarf audit: BPF prog-id=44 op=LOAD
pro 15 17:01:15 dwarf audit: BPF prog-id=45 op=LOAD
pro 15 17:01:15 dwarf kernel: audit: type=1334 audit(1639584075.502:183): prog-id=44 op=LOAD
pro 15 17:01:15 dwarf kernel: audit: type=1334 audit(1639584075.502:184): prog-id=45 op=LOAD
pro 15 17:01:15 dwarf audit: BPF prog-id=46 op=LOAD
pro 15 17:01:15 dwarf systemd[1]: Started Process Core Dump (PID 2881/UID 0).
pro 15 17:01:15 dwarf audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@5-2881-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
pro 15 17:01:15 dwarf kernel: audit: type=1334 audit(1639584075.502:185): prog-id=46 op=LOAD
pro 15 17:01:15 dwarf kernel: audit: type=1130 audit(1639584075.505:186): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@5-2881-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
pro 15 17:01:16 dwarf systemd-coredump[2882]: Process 2868 (helvum) of user 1000 dumped core.
Found module linux-vdso.so.1 with build-id: fc0932250ec82a533fb89adf1ab0c5e4209ea233
Found module libpipewire-module-session-manager.so with build-id: 4361a561425fecd86e0264485fd2367e76ae2598
Found module libpipewire-module-metadata.so with build-id: 69b538ed883934653341a3f265b12ca3387524a1
Found module libpipewire-module-adapter.so with build-id: 9a0c292402586330eda7f7d59c4d5d981af0324f
Found module libpipewire-module-client-device.so with build-id: d33667d8681ba893f76dc2ebfad48cc39bb66a64
Found module libpipewire-module-client-node.so with build-id: 824c6fdefd4f19c229f2b59f5ee9204a2b14a638
Found module libpipewire-module-protocol-native.so with build-id: 7ecab4978ec8dfeeb972000292d373daca90ed9c
Found module libdbus-1.so.3 with build-id: 74f2ab9c60512f3a93c932c3f627564d42e0b11e
Found module libspa-dbus.so with build-id: 8d000da179e54a4c1cc0ef1da9f461a260d5319e
Found module libgvfscommon.so with build-id: 90d1858292300e4e1ee3fbe84ab06079af840ec6
Found module libgvfsdbus.so with build-id: dcb9d652f2e5c65154517fe6934215ec6bd1c29c
Found module libgpg-error.so.0 with build-id: 3801187d42c4955bd93c605451430cdf1b164e63
Found module libgcrypt.so.20 with build-id: db45f5d5e0f7af1e77324fea1885f974619ad268
Found module libcap.so.2 with build-id: 7ab63cdf1c7435ae6910ccd518a92dc4f6a9b5b6
Found module liblz4.so.1 with build-id: e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Found module libsystemd.so.0 with build-id: 65e1ee509d2099c477c39e7af6a539f1a5c1072d
Found module libspa-journal.so with build-id: b326235d0d3cdf7960d81c85c255ceb1a7e9f536
Found module libspa-support.so with build-id: 1eb6638aeb61fb72f244ef0cc3442e2aa22998f9
Found module libpciaccess.so.0 with build-id: 9dd24e76ebc38465541313b36446ffb4af842c12
Found module libdrm_nouveau.so.2 with build-id: ee16fa6a4d0bd08f5448cfc046ccb76b49aaa8a3
Found module libdrm_radeon.so.1 with build-id: 5d1615e0467d0a34a5a82cbd4ebc84851e116307
Found module libdrm_intel.so.1 with build-id: d160331e9c642c1d36669e2ffd875689f9186ea9
Found module i965_dri.so with build-id: 15c4dbf09c19372a24ffa131302a738dfda732e1
Found module libXxf86vm.so.1 with build-id: 01e8243d0c6c971fa9e743e6e53d606b1cb76f6e
Found module libxcb-glx.so.0 with build-id: 8ad115382ad874165523dc5b4488c99d73bbc3c4
Found module libGLX_mesa.so.0 with build-id: bb74869736f072e29ec6a9709f74c0c77ec58233
Found module libGLX.so.0 with build-id: 0f40ceaa036edc65147e9559b94e0219472493fc
Found module libGL.so.1 with build-id: 8b3028bab286029945569a0dfcf695f0f61d9c3b
Found module libnss_files.so.2 with build-id: 1a36dfc01d3a1010b2ee79766a24a8090a3266d5
Found module libxshmfence.so.1 with build-id: 8876d9ccf620858795724ca24b9e567585a77cec
Found module libxcb-sync.so.1 with build-id: dda14591103b01b1311906053bf1ca9e82ade35c
Found module libxcb-present.so.0 with build-id: 68f5465258750e2397b1333b3ffc01ee33caa4e1
Found module libxcb-dri3.so.0 with build-id: 9407a2480e09dc5a1dd9d9a0652fa8d32b328c91
Found module libwayland-server.so.0 with build-id: 7156897eafc4b7562f2b214e6ad8ca6c85c57e47
Found module libdrm.so.2 with build-id: 457a1a1bd25f1d5541a10d3f16c5dc1440d77c7d
Found module libxcb-xfixes.so.0 with build-id: a6b197ace5b9b59f913f5969eb419a88d1194f47
Found module libxcb-dri2.so.0 with build-id: 2dd6e65129a809dab828a1d26215a3f7a363fcc8
Found module libX11-xcb.so.1 with build-id: 0db4f94d8ae31b8dc9a83f825a9171656f1e532c
Found module libglapi.so.0 with build-id: 57828fb70af7c1f2aa70b096d748851a1fd39a9c
Found module libgbm.so.1 with build-id: 42e129ba16de8ff426f740e7686a1f02a738abf9
Found module libEGL_mesa.so.0 with build-id: fb943970628f1b739095eb6e3a22e90b402ecd0a
Found module libGLdispatch.so.0 with build-id: 195b34c1bb271f3b1162c897cfbcfb859e656b93
Found module libEGL.so.1 with build-id: 473944aea0e3dbc5d595dee647702a3cdc0aed78
Found module libbrotlicommon.so.1 with build-id: f68934f94312f770550ebc6c5acfd6359b098b07
Found module libstdc++.so.6 with build-id: 8ab0e57054dd1dcba681f217016afc6a4e639783
Found module libicudata.so.70 with build-id: e1dcc2a88cfaafed882d09c90c668af0eed4efed
Found module libblkid.so.1 with build-id: f03a24e92c9852272bd0049b5bcb7ed6cf0e664f
Found module libXdmcp.so.6 with build-id: 8ca0792d23c8b8b4c0864297512349292bea5955
Found module libXau.so.6 with build-id: 1c67764663e07bec24d8951e5fd93f4d165979ff
Found module libbrotlidec.so.1 with build-id: f871e6f204ab8d48099915126ba01be989a8000f
Found module libbz2.so.1.0 with build-id: 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Found module liblzma.so.5 with build-id: 8b615460aa230708c5183f16bede67aa0437d95e
Found module libzstd.so.1 with build-id: 4b10444c1560ebc574af4d5f488b7408b22d450e
Found module libdatrie.so.1 with build-id: 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Found module liblzo2.so.2 with build-id: ed8e33ba505954ca344aea58d10c7b8a37fd2f39
Found module libxml2.so.2 with build-id: 6e67981c9b7528a3502824bf183423a0a02e1075
Found module libjson-glib-1.0.so.0 with build-id: 5865be5fcc01b48a0a113e0145ec45529bff89a6
Found module libsqlite3.so.0 with build-id: 6514739218fd9adab53e2e53a63a7364f9e544b3
Found module libicui18n.so.70 with build-id: 95af755fca990df26753a7d720b8e3ae24270e42
Found module libicuuc.so.70 with build-id: 2e245c2bf12f95fd8ab79b3a4be99524677cbd70
Found module libstemmer.so.0 with build-id: aa44a40dfb223020ed8e49cd2d28fc3887128463
Found module libexpat.so.1 with build-id: 8850138eae6d9d4d43c5c4b2ac48393bc4279037
Found module libgraphite2.so.3 with build-id: 47761dc11e553f519cde97ed9ee985be12ccdae2
Found module libpcre.so.1 with build-id: 845483dd0acba86de9f0313102bebbaf3ce52767
Found module libresolv.so.2 with build-id: c915c72668282861a813f7ea3c0780f37b681dc0
Found module libmount.so.1 with build-id: ff9a1d99d35cf640d0bfdaba294854372672c29b
Found module libpixman-1.so.0 with build-id: 341f793dcada3a48a306a793d265a517e3f2e7d6
Found module libxcb-shm.so.0 with build-id: fb797f299a446f559a95afcc168227482cc800d1
Found module libxcb-render.so.0 with build-id: a37bdb37744b508be9dd29fd9ccb9bb0170d43e5
Found module libxcb.so.1 with build-id: 0d1ef11740a5daad2ee331e812a51aa6574af222
Found module libXrender.so.1 with build-id: 97e0b9ab6ba96ebc86527cc2b3c3078aad8616b3
Found module libfreetype.so.6 with build-id: 26c5f833068ff72660d1975cbc2074c3eb47fad8
Found module libz.so.1 with build-id: 81bf6e728a6d6f5b105b0f8b25f6c614ce10452a
Found module libtiff.so.5 with build-id: e8d89a0fb0847641ddb75c5f03fa89d68155a75d
Found module libjpeg.so.8 with build-id: 879ca18a2f58c25d77ba881db3a44a5676ef6c7d
Found module libpng16.so.16 with build-id: 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Found module libthai.so.0 with build-id: 3fdce1a7db2b94d9168eea540dbf5ff5caa3b8ad
Found module libcairo-script-interpreter.so.2 with build-id: a3dad249e313cbbadf1212802a04bca6bf4a0b91
Found module libXinerama.so.1 with build-id: dbb6adece34ea2766d3efcd628af8f9757344dd6
Found module libXrandr.so.2 with build-id: d4e869b5c72541e1de8f96b456248987ea52d51b
Found module libXfixes.so.3 with build-id: 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Found module libXdamage.so.1 with build-id: a1d867e093c16944b2c0083be98050ef35c9e5c2
Found module libXcursor.so.1 with build-id: eb6315bcd7526aaf51b0a1307efdc587cea0a152
Found module libXext.so.6 with build-id: d70f24beb4fad748d6becffdcc13e51be0a2ebfa
Found module libwayland-egl.so.1 with build-id: 791e39283cdcc5a08cfd091b8cd4c59869a11278
Found module libwayland-client.so.0 with build-id: d274361e7aa57c9b63504a039e063322450cbb9c
Found module libxkbcommon.so.0 with build-id: 1f1bc7527e57c886c3df5803068122e1971d4724
Found module librt.so.1 with build-id: 75484da2d6f1515189eefa076e0a40328834cd16
Found module libtracker-sparql-3.0.so.0 with build-id: b0eee5a9b660fed5221ea15139e9608282320503
Found module libcloudproviders.so.0 with build-id: ed1d9c9e60be4e858ad148484767249be1edf95f
Found module libX11.so.6 with build-id: e9192497aa39fab51358826d1a1b5fb77edc5081
Found module libXi.so.6 with build-id: 16603be937a02a7e61b0b0395d064be7efd86f49
Found module libpangoft2-1.0.so.0 with build-id: 0a64cffe87210d8b7864a3a4fdaa92a120d20bee
Found module libepoxy.so.0 with build-id: b6357fc6b748c512f90339433d74502b9d0621dc
Found module libfontconfig.so.1 with build-id: 1103a641395c7d3b42e49b793d3a9ea927c77bf6
Found module libfribidi.so.0 with build-id: 79124bad061c2aab4ec89f25d067363d5b781114
Found module libharfbuzz.so.0 with build-id: 5d9b408e95d3c98a95333fdd413b8b64a7757631
Found module libpangocairo-1.0.so.0 with build-id: 820de243a3ad1d1d9e12ebc2b6073b19d620d744
Found module libgmodule-2.0.so.0 with build-id: 34cabbd12d9baf397a0255f174e4c96165bc329b
Found module libffi.so.8 with build-id: f90d8b734f6de9b25faedb8cbfab7054dafc0a42
Found module ld-linux-x86-64.so.2 with build-id: 040cc3dd10461562f177df39e3be2f3704258c3c
Found module libc.so.6 with build-id: 4b406737057708c0e4c642345a703c47a61c73dc
Found module libdl.so.2 with build-id: 5abc547e7b0949f89f3c0e21ab0c8331a7440a8a
Found module libm.so.6 with build-id: 2b8fd1f869ecab4e0b55e92f2f151897f6818acf
Found module libpthread.so.0 with build-id: 07c8f95b4f3251d08550217ad8a1f31066229996
Found module libgcc_s.so.1 with build-id: 7f8508bb914546ada778809b64b99d234337d835
Found module libglib-2.0.so.0 with build-id: d4aa102e545015a506c3ee06398676b70f65bcbc
Found module libgio-2.0.so.0 with build-id: b3348994e4d526d182becc32821aa3dbe9797149
Found module libgraphene-1.0.so.0 with build-id: 3a967a1f87378940d58d44a233dec7239760884d
Found module libcairo.so.2 with build-id: 06820af9cf79c2deb207d9533a61caf04e67a8ad
Found module libcairo-gobject.so.2 with build-id: abbf5a8a182ea1b8b7d68540df5c2e25c0bdae0c
Found module libgdk_pixbuf-2.0.so.0 with build-id: ca4beb15a30de8d8767f7bca8222038c61b58b36
Found module libpango-1.0.so.0 with build-id: 0036caf67265c11b1de7a50321d9bee619248118
Found module libgtk-4.so.1 with build-id: fade43c4a4c2eddfc91d3258c0ab4b9e24f4f895
Found module libgobject-2.0.so.0 with build-id: 3e451709a0a5772b9550d3a4c28dcb37a87028fa
Found module libpipewire-0.3.so.0 with build-id: 2ef062f025e19926ef385bda58e4174130126737
Found module helvum with build-id: 172e15b7c17a8c320c545d9fa701f1a99ce6a01d
Stack trace of thread 2868:
#0 0x00007f4898253d22 raise (libc.so.6 + 0x3cd22)
#1 0x00007f489823d862 abort (libc.so.6 + 0x26862)
#2 0x00007f489823d747 __assert_fail_base.cold (libc.so.6 + 0x26747)
#3 0x00007f489824c616 __assert_fail (libc.so.6 + 0x35616)
#4 0x00007f4897e47d2d n/a (libX11.so.6 + 0x40d2d)
#5 0x00007f4897e47dc8 n/a (libX11.so.6 + 0x40dc8)
#6 0x00007f4897e48182 _XEventsQueued (libX11.so.6 + 0x41182)
#7 0x00007f4897e4b176 _XGetRequest (libX11.so.6 + 0x44176)
#8 0x00007f4897e24b28 XChangeProperty (libX11.so.6 + 0x1db28)
#9 0x00007f4898e3de7f n/a (libgtk-4.so.1 + 0x3e6e7f)
#10 0x00007f4898e3df10 n/a (libgtk-4.so.1 + 0x3e6f10)
#11 0x00007f4898e44be9 n/a (libgtk-4.so.1 + 0x3edbe9)
#12 0x00007f4899216fdf n/a (libgobject-2.0.so.0 + 0x20fdf)
#13 0x00007f4899219199 g_object_set_valist (libgobject-2.0.so.0 + 0x23199)
#14 0x00007f4899219455 g_object_set (libgobject-2.0.so.0 + 0x23455)
#15 0x00007f4898d28c73 n/a (libgtk-4.so.1 + 0x2d1c73)
#16 0x00007f4898b0ae93 n/a (libgtk-4.so.1 + 0xb3e93)
#17 0x00007f48992261c0 g_signal_emit_valist (libgobject-2.0.so.0 + 0x301c0)
#18 0x00007f4899226330 g_signal_emit (libgobject-2.0.so.0 + 0x30330)
#19 0x00007f4898d11b48 gtk_widget_realize (libgtk-4.so.1 + 0x2bab48)
#20 0x00007f4898d24ba9 n/a (libgtk-4.so.1 + 0x2cdba9)
#21 0x00007f48992261c0 g_signal_emit_valist (libgobject-2.0.so.0 + 0x301c0)
#22 0x00007f4899226330 g_signal_emit (libgobject-2.0.so.0 + 0x30330)
#23 0x00007f4898d0bddf gtk_widget_show (libgtk-4.so.1 + 0x2b4ddf)
#24 0x0000557bad15fb5b n/a (helvum + 0x34b5b)
#25 0x0000557bad157fb2 n/a (helvum + 0x2cfb2)
#26 0x00007f48992261c0 g_signal_emit_valist (libgobject-2.0.so.0 + 0x301c0)
#27 0x00007f4899226330 g_signal_emit (libgobject-2.0.so.0 + 0x30330)
#28 0x00007f489876e739 n/a (libgio-2.0.so.0 + 0xcc739)
#29 0x0000557bad158527 n/a (helvum + 0x2d527)
#30 0x00007f489877928a g_application_run (libgio-2.0.so.0 + 0xd728a)
#31 0x0000557bad169452 n/a (helvum + 0x3e452)
#32 0x0000557bad1566b3 n/a (helvum + 0x2b6b3)
#33 0x0000557bad168c83 n/a (helvum + 0x3dc83)
#34 0x0000557bad168cad n/a (helvum + 0x3dcad)
#35 0x0000557bad2165aa n/a (helvum + 0xeb5aa)
#36 0x0000557bad156a62 n/a (helvum + 0x2ba62)
#37 0x00007f489823eb25 __libc_start_main (libc.so.6 + 0x27b25)
#38 0x0000557bad14ca7e n/a (helvum + 0x21a7e)
Stack trace of thread 2872:
#0 0x00007f489830ab2f __poll (libc.so.6 + 0xf3b2f)
#1 0x00007f4898614729 n/a (libglib-2.0.so.0 + 0xa8729)
#2 0x00007f48985bdbc1 g_main_context_iteration (libglib-2.0.so.0 + 0x51bc1)
#3 0x00007f48985bdc12 n/a (libglib-2.0.so.0 + 0x51c12)
#4 0x00007f48985eece1 n/a (libglib-2.0.so.0 + 0x82ce1)
#5 0x00007f4898539259 start_thread (libpthread.so.0 + 0x9259)
#6 0x00007f48983155e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 2874:
#0 0x00007f489831592e epoll_wait (libc.so.6 + 0xfe92e)
#1 0x00007f488ff1e571 n/a (libspa-support.so + 0x13571)
#2 0x00007f488ff12234 n/a (libspa-support.so + 0x7234)
#3 0x00007f48992a45f5 pw_main_loop_run (libpipewire-0.3.so.0 + 0x545f5)
#4 0x0000557bad166f2d n/a (helvum + 0x3bf2d)
#5 0x0000557bad168c96 n/a (helvum + 0x3dc96)
#6 0x0000557bad15d7a3 n/a (helvum + 0x327a3)
#7 0x0000557bad2191b3 n/a (helvum + 0xee1b3)
#8 0x00007f4898539259 start_thread (libpthread.so.0 + 0x9259)
#9 0x00007f48983155e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 2876:
#3 0x00007f4899293590 n/a (libpipewire-0.3.so.0 + 0x43590)
#4 0x00007f4898539259 start_thread (libpthread.so.0 + 0x9259)
#5 0x00007f48983155e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 2873:
#0 0x00007f489831018d syscall (libc.so.6 + 0xf918d)
#1 0x00007f489860ebbb g_cond_wait_until (libglib-2.0.so.0 + 0xa2bbb)
#2 0x00007f489858f7d3 n/a (libglib-2.0.so.0 + 0x237d3)
#3 0x00007f489858f964 g_async_queue_timeout_pop (libglib-2.0.so.0 + 0x23964)
#4 0x00007f48985f196a n/a (libglib-2.0.so.0 + 0x8596a)
#5 0x00007f48985eece1 n/a (libglib-2.0.so.0 + 0x82ce1)
#6 0x00007f4898539259 start_thread (libpthread.so.0 + 0x9259)
#7 0x00007f48983155e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 2875:
#2 0x00007f48985bfa63 g_main_loop_run (libglib-2.0.so.0 + 0x53a63)
#3 0x00007f48987a5268 n/a (libgio-2.0.so.0 + 0x103268)
Stack trace of thread 2871:
#0 0x00007f48985458ca __futex_abstimed_wait_common64 (libpthread.so.0 + 0x158ca)
#1 0x00007f489853f270 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf270)
#2 0x00007f488de2232c n/a (i965_dri.so + 0x24032c)
#3 0x00007f488de21d88 n/a (i965_dri.so + 0x23fd88)
pro 15 17:01:16 dwarf systemd[1]: systemd-coredump@5-2881-0.service: Deactivated successfully.
pro 15 17:01:16 dwarf audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@5-2881-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
pro 15 17:01:16 dwarf kernel: audit: type=1131 audit(1639584076.412:187): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@5-2881-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
pro 15 17:01:16 dwarf audit: BPF prog-id=0 op=UNLOAD
pro 15 17:01:16 dwarf kernel: audit: type=1334 audit(1639584076.479:188): prog-id=0 op=UNLOAD
pro 15 17:01:16 dwarf kernel: audit: type=1334 audit(1639584076.479:189): prog-id=0 op=UNLOAD
pro 15 17:01:16 dwarf kernel: audit: type=1334 audit(1639584076.479:190): prog-id=0 op=UNLOAD
