Since yesterday I have 1,9 GB of updates on my manjaro.
But there’s this warning error:
não foi possível satisfazer as dependências:
- a remoção de pulseaudio quebra a dependência ‘pulseaudio=16.1-1’ requerida por pulseaudio-jack
Translating:
could not satisfy dependencies:
- removing pulseaudio breaks the ‘pulseaudio=16.1-1’ dependency required by pulseaudio-jack
I tried to search for pulseaudio on the update list, but hes not listed there.
sudo pacman -R pulseaudio-jack
run update again
Still the same message.
Should I reboot?
I tried using sudo pacman -Syyu:
Iniciando atualização completa do sistema...
:: Substituir wxgtk-common por extra/wxwidgets-common? [S/n] s
:: Substituir wxgtk3 por extra/wxwidgets-gtk3? [S/n] s
resolvendo dependências...
procurando pacotes conflitantes...
:: pipewire-pulse e pulseaudio estão em conflito. Remover pulseaudio? [s/N] s
:: pipewire-pulse e pulseaudio-bluetooth estão em conflito. Remover pulseaudio-bluetooth? [s/N] s
:: pipewire-pulse e manjaro-pulse estão em conflito. Remover manjaro-pulse? [s/N] s
erro: falha ao preparar a transação (não foi possível satisfazer as dependências)
:: a remoção de pulseaudio quebra a dependência "pulseaudio=16.1-1" necessária por pulseaudio-lirc
:: a remoção de pulseaudio quebra a dependência "pulseaudio=16.1-1" necessária por pulseaudio-rtp
:: a remoção de pulseaudio quebra a dependência "pulseaudio=16.1-1" necessária por pulseaudio-zeroconf
translated:
:: Starting full system update...
:: Replace wxgtk-common with extra/wxwidgets-common? [Y/n] y
:: Replace wxgtk3 with extra/wxwidgets-gtk3? [Y/n] y
resolving dependencies...
:: pipewire-pulse and pulseaudio are in conflict. Remove pulseaudio? [y/n]
:: pipewire-pulse and pulseaudio-bluetooth are in conflict. Remove pulseaudio-bluetooth? [y/n]
:: pipewire-pulse and manjaro-pulse are in conflict. Remove manjaro-pulse? [y/n]
error: Failed to prepare transaction (unable to satisfy dependencies)
:: removing pulseaudio breaks the "pulseaudio=16.1-1" dependency needed by pulseaudio-lirc
:: removing pulseaudio breaks the "pulseaudio=16.1-1" dependency needed by pulseaudio-rtp
:: removing pulseaudio breaks the "pulseaudio=16.1-1" dependency needed by pulseaudio-zeroconf
sudo pacman -R pulseaudio-lirc pulseaudio-rtp pulseaudio-zeroconf
run update again
checking dependencies...
:: removing pulseaudio-zeroconf breaks the "pulseaudio-zeroconf" dependency needed by manjaro-pulse
sudo pacman -R manjaro-pulse pulseaudio-lirc pulseaudio-rtp pulseaudio-zeroconf
then run update
