Hello (agian) wonderful manjaro forum, I just checked journalctl
and found that there are repeated infos shown below. I wonder if anyone knows what is this means and anything that I need to take care of? I enabled the systemd-swap
before, not sure if it is related.
May 26 11:44:41 cz kernel: audit: type=1130 audit(1653583481.773:9022): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=netdata comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? >
May 26 11:44:41 cz kernel: audit: type=1131 audit(1653583481.783:9023): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=netdata comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? >
May 26 11:44:41 cz audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=netdata comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 26 11:44:41 cz audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=netdata comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 26 11:44:41 cz audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=netdata comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
May 26 11:44:41 cz systemd[1]: Stopped Real time performance monitoring.
May 26 11:44:41 cz [268159]: Cannot change directory to '/var/cache/netdata'
May 26 11:44:41 cz systemd[1]: Starting Real time performance monitoring...
May 26 11:44:41 cz [268159]: EXIT: netdata prepares to exit with code 1...
May 26 11:44:41 cz systemd[1]: Started Real time performance monitoring.
May 26 11:44:41 cz [268159]: EXIT: cleaning up the database...
May 26 11:44:41 cz systemd[1]: netdata.service: Main process exited, code=exited, status=1/FAILURE
May 26 11:44:41 cz [268159]: Cleaning up database [0 hosts(s)]...
May 26 11:44:41 cz systemd[1]: netdata.service: Failed with result 'exit-code'.
May 26 11:44:41 cz [268159]: EXIT: removing netdata PID file '/opt/netdata/var/run/netdata/netdata.pid'...
May 26 11:44:41 cz [268159]: EXIT: cannot unlink pidfile '/opt/netdata/var/run/netdata/netdata.pid'.
May 26 11:44:41 cz [268159]: EXIT: all done - netdata is now exiting - bye bye...
May 26 11:44:41 cz netdata[268159]: 2022-05-26 11:44:41: netdata FATAL : MAIN : Cannot change directory to '/var/cache/netdata' # : Invalid argument
May 26 11:44:41 cz netdata[268159]: 2022-05-26 11:44:41: netdata INFO : MAIN : EXIT: netdata prepares to exit with code 1...
May 26 11:44:41 cz netdata[268159]: 2022-05-26 11:44:41: netdata INFO : MAIN : EXIT: cleaning up the database...
May 26 11:44:41 cz netdata[268159]: 2022-05-26 11:44:41: netdata INFO : MAIN : Cleaning up database [0 hosts(s)]...
May 26 11:44:41 cz netdata[268159]: 2022-05-26 11:44:41: netdata INFO : MAIN : EXIT: removing netdata PID file '/opt/netdata/var/run/netdata/netdata.pid'...
May 26 11:44:41 cz netdata[268159]: 2022-05-26 11:44:41: netdata ERROR : MAIN : EXIT: cannot unlink pidfile '/opt/netdata/var/run/netdata/netdata.pid'. (errno 2, No such file or directory)
May 26 11:44:41 cz netdata[268159]: 2022-05-26 11:44:41: netdata INFO : MAIN : EXIT: all done - netdata is now exiting - bye bye...
May 26 11:45:12 cz systemd[1]: netdata.service: Scheduled restart job, restart counter is at 2097.
May 26 11:45:12 cz kernel: audit: type=1130 audit(1653583512.000:9024): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=netdata comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? >
May 26 11:45:12 cz kernel: audit: type=1131 audit(1653583512.000:9025): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=netdata comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? >
inxi -Fxxz
Kernel: 5.17.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 wm: xfwm dm: LightDM
Type: Laptop System: Razer product: Blade 15 (2022) - RZ09-0421 v: 8.04
Mobo: Razer model: CH580 v: 4 serial: <superuser required> UEFI: Razer
v: 1.09 date: 02/22/2022
ID-1: BAT0 charge: 83.1 Wh (100.0%) condition: 83.1/80.2 Wh (103.6%)
volts: 17.4 min: 15.4 model: Razer Blade serial: <filter> status: full
ID-2: hidpp_battery_0 charge: 29% condition: N/A volts: 3.8 min: N/A
model: Logitech G903 LIGHTSPEED Wireless Gaming Mouse w/ HERO
serial: <filter> status: discharging
Info: 14-core (6-mt/8-st) model: 12th Gen Intel Core i7-12800H bits: 64
type: MST AMCP arch: Alder Lake rev: 3 cache: L1: 1.2 MiB L2: 11.5 MiB
L3: 24 MiB
Speed (MHz): avg: 1614 high: 2407 min/max: 400/2400:1800 cores: 1: 1919
2: 2303 3: 458 4: 2300 5: 2400 6: 2400 7: 2400 8: 2407 9: 2275 10: 2308
11: 1276 12: 1910 13: 1212 14: 1107 15: 754 16: 1395 17: 761 18: 743
19: 839 20: 1117 bogomips: 112160
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Razer USA
driver: i915 v: kernel ports: active: eDP-1 empty: none bus-ID: 00:02.0
chip-ID: 8086:46a6
Device-2: NVIDIA GA103M [GeForce RTX 3080 Ti Laptop GPU]
vendor: Razer USA driver: nvidia v: 510.73.05 arch: Ampere pcie:
speed: 2.5 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 10de:2460
Device-3: IMC Networks Integrated RGB Camera type: USB driver: uvcvideo
bus-ID: 1-2:2 chip-ID: 13d3:5279
Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 4608x1985 s-dpi: 96
Monitor-1: HDMI-1-0 pos: primary,top-right res: 2560x1440 dpi: 108
diag: 690mm (27.15")
Monitor-2: eDP-1 pos: bottom-l res: 2048x1152 dpi: 151
diag: 395mm (15.55")
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Razer USA
driver: sof-audio-pci-intel-tgl bus-ID: 00:1f.3 chip-ID: 8086:51c8
Device-2: NVIDIA vendor: Razer USA driver: N/A pcie: speed: 2.5 GT/s
lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:2288
Sound Server-1: ALSA v: k5.17.9-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Intel Alder Lake-P PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:51f0
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-10:6
chip-ID: 8087:0033
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 953.87 GiB used: 167.17 GiB (17.5%)
ID-1: /dev/nvme0n1 model: NVMe CA6-8D1024 size: 953.87 GiB
speed: 63.2 Gb/s lanes: 4 serial: <filter> temp: 37.9 C
ID-1: / size: 661.15 GiB used: 73.94 GiB (11.2%) fs: ext4
dev: /dev/nvme0n1p5
ID-2: /boot/efi size: 96 MiB used: 50.7 MiB (52.8%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 447 Uptime: 17h 53m Memory: 31.04 GiB used: 4.93 GiB (15.9%)
Init: systemd v: 250 Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1425
pacman: 1408 flatpak: 8 snap: 9 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.16
