These are my frequently used desktops on laptops, but I always find the drawback
that there is no default software to help us with the touchpad configuration, beyond enable, disable.
I have used this program without problems on lxde, lxqt and xfce desktops (other desktops have default settings)
- the program requires packages: xinput (xorg-xinput), zenity, xmessage (optionally).
- the program is designed not to run completely if these packages are missing from the computer, xmessage (optionally).
- the program detects the desktops: lxde, lxqt, xfce and sends input to the program settings window to the menu, configures the autorun when starting session.
- to completely clean the program files run:
rm ~/.config/autostart/xinput-touchpad-estado-al-inicio.desktop - to completely clean the program files run:
rm ~/.local/share/applications/xin-touchpad-conf.desktop
it is very easy to manually translate the program by any user, (feel free to do it if necessary)
the program can be given any name, it should be able to run without any problems. (in my case:
xin-touchpad.sh) -
the program has three ways of being called:
xin-touchpad.sh --conf(launch the settings window)
xin-touchpad.sh --auto(load the configuration at login)
xin-touchpad.sh(switch state on > off and off > on, assign a keyboard shortcut to run the program)
My language is Spanish, so it is very likely that my English and Russian translations are wrong.
#!/usr/bin/bash
#dependencias: xinput -o xorg-xinput, xmessage, zenity
#configurcion rapida
dispositivo='Device'
atras='Back'
estado_al_inicio='Status en startup'
estado1='Enabled'
estado0='Disabled'
mas_opciones='More options'
columna_opciones='Options'
mas_ajustes='More settings'
velocidad='Speed'
abrir_hoja_datos='Open data sheet'
metodo_desplazamiento='Displacement method'
metodo_desplazamiento1='two fingers'
metodo_desplazamiento2='edge'
metodo_desplazamiento3='button'
desplazamiento_natural='Natural displacement'
desplazamiento_horizontal='Horizontal displacement'
click_al_tocar='Click when touch'
desactivado_al_escribir='Off when typing'
si='YES'
no='NO'
modo_zurdo_para='Left handed mode for'
refrescar='Refresh'
salir='Leave'
aceptar='Agree'
dispositivo_vacio='empty device'
timeout='0.8s'
#TRADUCIR CON CUIDADO
xin_touchpad_conf='xin touchpad conf'
conf='--conf'
xin_touchpad_auto='xin touchpad auto'
auto_start='--auto'
#modo auto inicio aplica la configuracion en bucle para todos los dispositivos listados
#siempre imprimir en hoja con linea blanca de seguridad hacia arriba"
znt=$(which 'zenity')
xin=$(which 'xinput')
if [[ "$znt" != '' ]] ; then
v1=+1
else
v1=+0
fi
if [[ "$xin" != '' ]] ; then
v2=+1
else
v2=+0
fi
if [ $(($v1 $v2)) == 2 ] ; then
demo=\
"$estado_al_inicio:$estado1
$velocidad:0.40
$metodo_desplazamiento:$metodo_desplazamiento1
$click_al_tocar:$si
$desactivado_al_escribir:$si
$desplazamiento_horizontal:$si
$desplazamiento_natural:$si"
ruta=$(dirname "$0")/.xin-conf.txt
if [ ! -e "$ruta" ] ; then
touch "$ruta"
#DESEKTOP ENTRY > menu
escritorio=$(echo $XDG_CURRENT_DESKTOP)
ok=$(grep -io "lxde\|lxqt\|xfce" <<< $escritorio)
if [[ "$ok" != '' ]] ; then
ok=1
fi
if [[ "$ok" == 1 ]] ; then
echo "escritorio $escritorio detectado"
RUTA_ARCHIVO_desktop_entry=~/.local/share/applications/xin-touchpad-conf.desktop
TEXTO_desktop_entry=\
"[Desktop Entry]
Exec=\"$(readlink -f "$0")\" $conf
Type=Application
Name=$xin_touchpad_conf
Terminal=false
Icon=
Categories=Settings;
StartupNotify=true" # Exec=si se usa rutas cortas del tipo ~/ la accion personalizada no se ejecuta correctamente. desactivar: NotShowIn=LXDE;
if [ ! -e "${RUTA_ARCHIVO_desktop_entry%/*}" ] ; then
mkdir -p "${RUTA_ARCHIVO_desktop_entry%/*}"
fi
if [[ "$TEXTO_desktop_entry" != "$(cat "$RUTA_ARCHIVO_desktop_entry")" ]] ; then
cat <<< "$TEXTO_desktop_entry" > $RUTA_ARCHIVO_desktop_entry
fi
else
cat <<< "$TEXTO_desktop_entry" > "$(dirname "$0")/xin-touchpad-conf.desktop"
fi
ok=1
fi
RUTA_ARCHIVO_desktop_entry=~/.config/autostart/xinput-touchpad-estado-al-inicio.desktop
"[Desktop Entry]
Exec=\"$(readlink -f "$0")\" $auto_start
Name=$xin_touchpad_auto
Type=Application
Version=1.0" # Exec=si se usa rutas cortas del tipo ~/ la accion personalizada no se ejecuta correctamente. desactivar: NotShowIn=LXDE;
fi
fi
else
cat <<< "$TEXTO_desktop_entry" > "$(dirname "$0")/xin-touchpad-auto.desktop"
fi
fi
if [ $(wc -w < "$ruta") == 0 ] ; then
cat <<< "$demo" > "$ruta" # el achivo no se escribe si no existe primero (touch)
fi
if [[ "$0 $1" == "$0 $conf" ]] ; then
#motor
prm=true
while $prm ; do
dat=$(cat "$ruta")
dat_clean=$(grep -v "^$" <<< $dat)
if [[ "$dat" != "$dat_clean" ]] ; then
cat <<< "$dat_clean" > "$ruta"
fi
dat="$dat_clean"
ls_disp=$(xinput list --name-only | tr '\n' '|' | sed 's/|$//g')
ls_disp_dat=$(grep "^$dispositivo:" <<< $dat | sed 's/^'"$dispositivo"'://g')
out=$(zenity --forms --separator=$'\n' --extra-button="$refrescar" --cancel-label="$salir" --ok-label="$aceptar" --add-combo="$estado_al_inicio" --combo-values="|$estado1|$estado0" --add-combo="$dispositivo" --combo-values="|$ls_disp" --add-combo="$modo_zurdo_para" --combo-values="|$ls_disp" --add-combo="$mas_opciones" --combo-values="|$mas_ajustes|$velocidad|$abrir_hoja_datos" --text=\
"$dat")
res=$?
if [ $res == 0 ] ; then
est=$(sed -n 1p <<< $out)
dsp=$(sed -n 2p <<< $out)
mdz=$(sed -n 3p <<< $out)
mop=$(sed -n 4p <<< $out)
if [ $(wc -w <<< $est) != 0 ] ; then
if [[ "$est" == "$estado1" ]] ; then
sed -i "s/^$estado_al_inicio:.*/$estado_al_inicio:$est/g" "$ruta"
elif [[ "$est" == "$estado0" ]] ; then
fi
fi
if [ $(wc -w <<< $dsp) != 0 ] ; then
disp_dat=$(grep "^$dispositivo" <<< $dat)
name=$(sed 's/.*://g' <<< $disp_dat)
if [[ "$dsp" == "$name" ]] ; then
sed -i '/^'"$dispositivo"'.*/d' "$ruta"
else
if [ $(tail -n1 < "$ruta" | wc -w) == 0 ] ; then
cat <<< \
"$dispositivo:$dsp" >> "$ruta"
else
cat <<< \
fi
fi
fi
if [ $(wc -w <<< $mdz) != 0 ] ; then
disp_dat=$(grep "^$modo_zurdo_para:$mdz" <<< $dat)
est_act=$(sed 's/.* > //g' <<< $disp_dat)
code_x=$(xinput list-props "$mdz" | grep "libinput Left Handed Enabled (" | grep -o "([0-9]*" | sed 's/^(//g')
#mdz2=$(sed 's/[[:punct:]]/./g' <<< $mdz)
if [[ "$disp_dat" == "" ]] ; then
xinput set-prop "$mdz" "$code_x" 1
cat <<< \
"$modo_zurdo_para:$mdz" >> "$ruta"
else
cat <<< \
fi
else
xinput set-prop "$mdz" "$code_x" 0
sed -i "/^$modo_zurdo_para.*/d" "$ruta"
fi
fi
if [ $(wc -w <<< $mop) != 0 ] ; then
if [[ "$mop" == "$mas_ajustes" ]] ; then
#bucle 2
prm2=true
while $prm2 ; do
dat=$(cat "$ruta")
act_vl=$(grep "^$velocidad" <<< $dat | grep -o "[0-9]\.[0-9]*")
act_md=$(grep "^$metodo_desplazamiento:" <<< $dat | sed "s/^$metodo_desplazamiento://g")
act_dn=$(grep "^$desplazamiento_natural:" <<< $dat | sed "s/^$desplazamiento_natural://g")
act_dh=$(grep "^$desplazamiento_horizontal:" <<< $dat | sed "s/^$desplazamiento_horizontal://g")
act_ct=$(grep "^$click_al_tocar:" <<< $dat | sed "s/^$click_al_tocar://g")
act_de=$(grep "^$desactivado_al_escribir:" <<< $dat | sed "s/^$desactivado_al_escribir://g")
#aplicar cambios nivel sistema
#metodo desp
if [[ "$act_md" == "$metodo_desplazamiento1" ]] ; then
code_x=$(xinput list-props "$ls_disp_dat" | grep "libinput Scroll Method Enabled (" | grep -o "([0-9]*" | sed 's/^(//g')
xinput set-prop "$ls_disp_dat" "$code_x" 1, 0, 0
elif [[ "$act_md" == "$metodo_desplazamiento2" ]] ; then
xinput set-prop "$ls_disp_dat" "$code_x" 0, 1, 0
elif [[ "$act_md" == "$metodo_desplazamiento3" ]] ; then
xinput set-prop "$ls_disp_dat" "$code_x" 0, 0, 1
fi
#velocidad
if [[ "$act_vl" == "" ]] ; then
act_vl=0.40
fi
accel_speed=$(xinput list-props "$ls_disp_dat" | grep "libinput Accel Speed (" | grep -o "([0-9]*" | sed 's/^(//g')
xinput set-prop "$ls_disp_dat" "$accel_speed" $act_vl
#desp natural
if [[ "$act_dn" == "$si" ]] ; then
code_x=$(xinput list-props "$ls_disp_dat" | grep "libinput Natural Scrolling Enabled (" | grep -o "([0-9]*" | sed 's/^(//g')
elif [[ "$act_dn" == "$no" ]] ; then
fi
#desp horizontal
if [[ "$act_dh" == "$si" ]] ; then
code_x=$(xinput list-props "$ls_disp_dat" | grep "libinput Horizontal Scroll Enabled (" | grep -o "([0-9]*" | sed 's/^(//g')
elif [[ "$act_dh" == "$no" ]] ; then
fi
#click al tocar
if [[ "$act_ct" == "$si" ]] ; then
code_x=$(xinput list-props "$ls_disp_dat" | grep "libinput Tapping Enabled (" | grep -o "([0-9]*" | sed 's/^(//g')
elif [[ "$act_ct" == "$no" ]] ; then
fi
#desac al escribir
if [[ "$act_de" == "$si" ]] ; then
code_x=$(xinput list-props "$ls_disp_dat" | grep "libinput Disable While Typing Enabled (" | grep -o "([0-9]*" | sed 's/^(//g')
elif [[ "$act_de" == "$no" ]] ; then
fi
out2=$(zenity --cancel-label="$atras" --ok-label="$aceptar" --list --width=600 --height=250 --column="$columna_opciones" "$metodo_desplazamiento > $act_md" "$desplazamiento_natural > $act_dn" "$desplazamiento_horizontal > $act_dh" "$click_al_tocar > $act_ct" "$desactivado_al_escribir > $act_de")
if [ $? == 0 ] ; then
out2_a=$(sed 's/ > .*$//g' <<< $out2)
if [[ "$out2_a" == "$metodo_desplazamiento" ]] ; then
#modo desplazamiento
md1=$(grep "^$metodo_desplazamiento:$metodo_desplazamiento1" <<< "$dat")
md2=$(grep "^$metodo_desplazamiento:$metodo_desplazamiento2" <<< "$dat")
md3=$(grep "^$metodo_desplazamiento:$metodo_desplazamiento3" <<< "$dat")
md=$(
if [[ "$md1" != '' ]] ; then
cat <<< \
"TRUE
else
cat <<< \
"FALSE
fi
if [[ "$md2" != '' ]] ; then
cat <<< \
"TRUE
else
cat <<< \
"FALSE
fi
if [[ "$md3" != '' ]] ; then
cat <<< \
"TRUE
else
cat <<< \
"FALSE
fi
out3=$(IFS=$'\n' ; zenity --cancel-label="$atras" --ok-label="$aceptar" --list --radiolist --column='X' --column="$metodo_desplazamiento" $md)
res3=$?
if [ $res3 == 0 ] ; then
xinput --enable "$ls_disp_dat"
if [[ "$out3" == "$metodo_desplazamiento1" ]] ; then
sed -i "s/^$metodo_desplazamiento:.*/$metodo_desplazamiento:$out3/g" "$ruta"
elif [[ "$out3" == "$metodo_desplazamiento2" ]] ; then
elif [[ "$out3" == "$metodo_desplazamiento3" ]] ; then
fi
elif [ $? == 1 ] ; then
prm3=false
fi
#desp natural
elif [[ "$out2_a" == "$desplazamiento_natural" ]] ; then
sed -i "s/^$desplazamiento_natural:.*/$desplazamiento_natural:$no/g" "$ruta"
sed -i "s/^$desplazamiento_natural:.*/$desplazamiento_natural:$si/g" "$ruta"
fi
#desp horizontal
elif [[ "$out2_a" == "$desplazamiento_horizontal" ]] ; then
sed -i "s/^$desplazamiento_horizontal:.*/$desplazamiento_horizontal:$no/g" "$ruta"
sed -i "s/^$desplazamiento_horizontal:.*/$desplazamiento_horizontal:$si/g" "$ruta"
fi
#click al tocar
elif [[ "$out2_a" == "$click_al_tocar" ]] ; then
sed -i "s/^$click_al_tocar:.*/$click_al_tocar:$no/g" "$ruta"
sed -i "s/^$click_al_tocar:.*/$click_al_tocar:$si/g" "$ruta"
fi
#desac mientras escribe
elif [[ "$out2_a" == "$desactivado_al_escribir" ]] ; then
sed -i "s/^$desactivado_al_escribir:.*/$desactivado_al_escribir:$no/g" "$ruta"
sed -i "s/^$desactivado_al_escribir:.*/$desactivado_al_escribir:$si/g" "$ruta"
fi
fi
prm2=false
fi
done #bulce 2
elif [[ "$mop" == "$velocidad" ]] ; then
#bucle 4
prm4=true
while $prm4 ; do
dat=$(cat "$ruta")
vel=$(grep "^$velocidad" <<< $dat | grep -o "[0-9]\.[0-9]*")
if [[ "$vel" == "" ]] ; then
vel=0
else
vel=$(
if [[ "$vel" == '1.00' ]] ; then
cat <<< "100"
else
global=$(grep -o "[0-9]" <<< $vel)
n1=$(sed -n 1p <<< $global)
n2=$(sed -n 2p <<< $global)
n3=$(sed -n 3p <<< $global)
cat <<< "$n2$n3"
fi)
fi
out_vel=$(zenity --scale --step='10' --cancel-label="$atras" --ok-label="$aceptar" --value="$vel")
res2=$?
if [ $res2 == 0 ] ; then
out_vel2=$(
if [ $out_vel == 100 ] ; then
cat <<< "1.00"
else
cat <<< "0.$out_vel"
fi)
sed -i "s/^$estado_al_inicio.*/$estado_al_inicio:$estado1/g" "$ruta"
xinput set-prop "$ls_disp_dat" "$accel_speed" "$out_vel2"
sed -i "s/^$velocidad:.*/$velocidad:$out_vel2/g" "$ruta"
#timeout 0.8s xmessage -center -bg green "$estado1"
elif [ $res2 == 1 ] ; then
prm4=false
fi
done #bucle
elif [[ "$mop" == "$abrir_hoja_datos" ]] ; then
xdg-open "$ruta"
fi
fi
elif [[ "$out" == "$refrescar" ]] ; then
echo "$refrescar"
elif [ $res == 1 ] ; then
prm=false
fi
done #bucle
######################################################## auto start
elif [[ "$0 $1" == "$0 $auto_start" ]] ; then
echo 'auto start'
dat=$(cat "$ruta")
if [[ "$ls_disp_dat" == "" ]] ; then
echo "$dispositivo_vacio"
else
act_ei=$(grep "^$estado_al_inicio" <<< $dat | sed "s/$estado_al_inicio://g")
act_md=$(grep "^$metodo_desplazamiento" <<< $dat | sed "s/$metodo_desplazamiento://g")
act_dn=$(grep "^$desplazamiento_natural" <<< $dat | sed "s/$desplazamiento_natural://g")
act_dh=$(grep "^$desplazamiento_horizontal" <<< $dat | sed "s/$desplazamiento_horizontal://g")
act_ct=$(grep "^$click_al_tocar" <<< $dat | sed "s/$click_al_tocar://g")
act_de=$(grep "^$desactivado_al_escribir" <<< $dat | sed "s/$desactivado_al_escribir://g")
#estado
if [[ "$act_ei" == "$estado1" ]] ; then
elif [[ "$act_ei" == "$estado0" ]] ; then
xinput --disable "$ls_disp_dat"
fi
#metodo desp
fi
#velocidad
act_vl=0.40
fi
#desp natural
fi
#desp horizontal
fi
#click al tocar
fi
#desac al escribir
fi
fi #puerta dispositivo vacio
######################################################## toggle
elif [[ "$0" == "$0" ]] ; then
dat=$(cat "$ruta")
else
if [[ "$timeout" == "" ]] ; then
timeout='0.8s'
fi
act_est=$(xinput list-props "$ls_disp_dat" | grep "Device Enabled (" | awk '{print $NF}')
#estado
if [ $act_est == 0 ] ; then
timeout "$timeout" xmessage -center -bg green "$estado1"
#parametros
#metodo desp
fi
#velocidad
act_vl=0.40
fi
#desp natural
fi
#desp horizontal
fi
#click al tocar
fi
#desac al escribir
fi
elif [ $act_est == 1 ] ; then
timeout "$timeout" xmessage -center -bg grey "$estado0"
fi
fi
fi
exit
español
dispositivo='Dispositivo'
atras='Atras'
estado_al_inicio='Estado al inicio'
estado1='Activado'
estado0='Desactivado'
mas_opciones='Mas opciones'
columna_opciones='Opciones'
mas_ajustes='Mas ajustes'
velocidad='Velocidad'
abrir_hoja_datos='Abrir hoja datos'
metodo_desplazamiento='Metodo de desplazamiento'
metodo_desplazamiento1='dos dedos'
metodo_desplazamiento2='borde'
metodo_desplazamiento3='boton'
desplazamiento_natural='Desplazamiento natural'
desplazamiento_horizontal='Desplazamiento horizontal'
click_al_tocar='Click al tocar'
desactivado_al_escribir='Desactivado al escribir'
si='SI'
no='NO'
modo_zurdo_para='Modo zurdo para'
refrescar='Refrescar'
salir='Salir'
aceptar='Aceptar'
dispositivo_vacio='dispositivo vacio'
русский
dispositivo='Устройство'
atras='Позади'
estado_al_inicio='Состояние в начале'
estado1='Активирован'
estado0='Недопустимый'
mas_opciones='Больше опций'
columna_opciones='Опции'
mas_ajustes='Больше настроек'
velocidad='Скорость'
abrir_hoja_datos='Открыть лист данных'
metodo_desplazamiento='Вытесняющий метод'
metodo_desplazamiento1='два пальца'
metodo_desplazamiento2='край'
metodo_desplazamiento3='кнопка'
desplazamiento_natural='Естественное смещение'
desplazamiento_horizontal='Горизонтальное смещение'
click_al_tocar='Нажмите на сенсорный'
desactivado_al_escribir='Выключается при наборе текста'
si='ДА'
no='НЕТ'
modo_zurdo_para='Режим левой руки для'
refrescar='Обновить'
salir='Выход'
aceptar='Принять'
dispositivo_vacio='пустое устройство'
To disable xmessage notification, add # to the beginning of the lines:
This program is the replacement of this publication:
you can find useful instructions right there
