My system randomly freezes and leaves my no choice but to switch off the power of desktop. I have waited for like an half hour to see if it get responsive but no.
Please help when i was on manjaro lxqt & lubuntu this issue was not there and now i installed gnome it happens 2 out of three times i boot my system.
Please Help Me I love gnome and i dont want to switch to another desktop environment.
Here is my inxi -Fazy
Kernel: 5.4.118-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=8d682308-c48b-4c51-b984-5cc50a54c311 rw quiet
resume=UUID=b6d06ca8-16fe-46e6-9189-4ec73fd991b1 udev.log_priority=3
Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
Type: Desktop Mobo: ASRock model: G31M-S serial: <filter>
BIOS: American Megatrends v: P1.60 date: 04/02/2009
Info: Dual Core model: Pentium E5300 bits: 64 type: MCP arch: Penryn
family: 6 model-id: 17 (23) stepping: A (10) microcode: A0B cache: L2: 2 MiB
flags: lm nx pae sse sse2 sse3 ssse3 bogomips: 10378
Speed: 1495 MHz min/max: 1203/2603 MHz Core speeds (MHz): 1: 1495 2: 1202
Vulnerabilities: Type: itlb_multihit status: KVM: Vulnerable
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2
mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Device-1: NVIDIA GK208 [GeForce GT 710] driver: nvidia v: 390.143
alternate: nouveau,nvidia_drm bus-ID: 04:00.0 chip-ID: 10de:1281
class-ID: 0300
Display: x11 server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: GeForce GT 710/PCIe/SSE2 v: 4.6.0 NVIDIA 390.143
direct render: Yes
Device-1: Intel NM10/ICH7 Family High Definition Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:27d8
class-ID: 0403
Device-2: NVIDIA GF119 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 04:00.1 chip-ID: 10de:0e08 class-ID: 0403
Device-3: Generalplus USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:2 chip-ID: 1b3f:2008
class-ID: 0300
Sound Server-1: ALSA v: k5.4.118-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASRock
driver: r8169 v: kernel port: d800 bus-ID: 01:00.0 chip-ID: 10ec:8136
class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u
bus-ID: 1-4:5 chip-ID: 148f:7601 class-ID: 0000 serial: <filter>
IF: wlp0s29f7u4 state: up mac: <filter>
Local Storage: total: 232.89 GiB used: 20.54 GiB (8.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3250318AS
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: <unknown>
rotation: 7200 rpm serial: <filter> rev: CC44 scheme: MBR
ID-1: / raw-size: 225.51 GiB size: 220.91 GiB (97.96%)
used: 20.54 GiB (9.3%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
Kernel: swappiness: 21 (default 60) cache-pressure: 50 (default 100)
ID-1: swap-1 type: partition size: 7.38 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 51.0 C mobo: N/A gpu: nvidia temp: 55 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 40%
Processes: 166 Uptime: 12m wakeups: 0 Memory: 3.35 GiB
used: 1.76 GiB (52.6%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 Packages: pacman: 993 lib: 284 Shell: Zsh v: 5.8
running-in: gnome-terminal inxi: 3.3.04
