I have a printer that needs a specific driver. The manufacturer provides only .deb and .rpm packages. How do I install this
Thanks in advance
Have you checked to see if the driver is available from the AUR?
Many AUR packages are built from .deb and .rpm archives. Epson printer drivers seem to use both
It might also help to check what drivers are recommended for your specific printer model at:
https://www.openprinting.org/printers
Looking it up on openprinting didn’t turn up anything. My printer is the Epson L385 if that helps
According to your model you need this driver from the AUR for printing:
pamac build epson-inkjet-printer-escpr
For scanning support install the imagesan
package:
sudo pacman -S imagescan
Gave me this error
Error: target not found: epson-inkjet-printer-escpr
edit:Oops, forgot sudo
Now it gives me a different error ‘Failed to add printer’
You don’t need sudo with pamac. I wonder why it worked with only sudo thought
Install system-config-printer
package and see Printing - Manjaro.
Just got around to doing it, it works perfectly. Thanks for your help.
Title edited to reflect real problem.
How to install .deb or .rpm printer drivers → Help with setting up Epson L385 Printer
