kde != os:)
ok, good luck.
I’ll try to solve the problem myself, and thank you very much for your help
kde != os:)
ok, good luck.
Thank you, unclear with what but thank you. xD
To point you in the correct direction.
Uninstall your Nvidia drivers (you installed from the web page) with the uninstall script that came with the installation (or there will be a ton of files leftover creating problems for you).
Then use mhwd
to install the correct nvidia drivers.
You can type mhwd -l
to see what drivers the system recommends you to install.
I already solved the language with folders
This topic was automatically closed 3 hours after the last reply. New replies are no longer allowed.
“Help please” is not a valid topic title. I’ve edited it.
Please see:
Also note that we have a Pусский section of our forum if you prefer to speak in Russian. However, since this is primarily an English forum, you did well providing English and Russian text in your post.
