Hi all,
I’ve been experimenting with theming today and I’m having an issue with Nautilus, I’m trying to replicate what is in the screenshot on the Nordic Polar theme github:
However my sidebar looks all squished, my top nav has quite a bit of padding (top and bottom), and when I select a file the text goes white and there is no background selection colour (making it difficult to read):
Simmilar thing in the settings for a lot of apps things look squished together:
Does anyone have any idea where I might go about tweaking these setting? is there are easy way to undo any Manjaro specific customisations that might be interfering?
I used the gnome tweaks/extensions apps to help change the theme, I’ve also tried uninstalling manjaro-gdm-branding
, manjaro-gnome-settings
, and manjaro-gnome-extensions-settings
. I’ve renamed the ~/.config/dconf
and ~/.gnome
to ~/.config/dconf.bak
and ~/.gnome.bak
but that didn’t help.
Not very experienced with theming so any help would be appreciated.
