Help with kscreen and several monitors
Hello!
I have 4 monitors that are always connected to my nvidia graphics card and would like two configurations (that can be swapped between).
Desired configurations:
  1. monitors A, B, C
    • regular, non-mirrored configuration
    • A is primary
    • monitor D is disabled
  2. monitors A, D
    • D is mirrored to A
    • D is primary
    • monitors B, C are disabled
Is there a good way to handle swapping between these configurations using kscreen when all monitors are always connected?
There is seemingly no end-user documentation for kscreen, KDE’s git repository for kscreen is not helpful, and I cannot find an obvious way via System Settings/Display Configuration.
Is it best to do this with a script using xrandr or nvidia-settings's metamodes? If so, which of these are preferred? xrandr seems to wipe options (such as ForceCompositionPipeline) applied by nvidia-settings.
Thank you,
cat
Hi, my answer will probably only tangently answer yours. Anyway: I have lost hope in using kscreen to handle monitors. I have only two monitors but kscreen seems to always forget the correct settings for single monitors and extended configuration.
So in my case I decided to use xrandr. Can’t actually answer your question about the better solution between xrandr or nvidia-settings.
One small thing: I downloaded yad and created a mini interface to create an alternate meta+p menu to handle my custom configurations.
return=$(yad --list --height=450 --width=600 --no-headers --undecorated --no-buttons --center --on-top --skip-taskbar --close-on-unfocus --separator= --title "Choose Layout" --text-align=center --column="Option" --column=@font@ Acer 30 Samsung 30 "Doule 4 Steam" 30 Extend 30 "NONE" 30 " - Display Settings - " 30 " - Arandr - " 30)
if [[ "$return" == Acer ]]; then
    bash  $( dirname "$0" )/AcerScreen.sh
elif [[ "$return" == Samsung ]]; then
    bash $( dirname "$0" )/SamsungScreen.sh
elif [[ "$return" == "Doule 4 Steam" ]]; then
    bash $( dirname "$0" )/doubleScreen4Steam.sh
elif [[ "$return" == Extend ]]; then
    bash $( dirname "$0" )/doubleScreen.sh
elif [[ "$return" == " - Display Settings - " ]]; then
    kcmshell5 kcm_kscreen
elif [[ "$return" == " - Arandr - " ]]; then
    arandr
fi
Each *.sh file is a configuration setted by the xrandr command. The last two simply open the kde display setting gui or the arandr gui.
you basically just need to write 2 scripts, one for every setup and using xrandr to set the screens as you desire.
something like that:
1.
xrandr --output DP-1 --mode 1920x1080 --pos 0x0 --rotate normal --output DP-2 --mode 1920x1080 --pos 1920x0 --rotate normal --output DP-3 --mode 1920x1080 --pos 3860x0 --rotate normal --output DP-4 --off
xrandr --output DP-1 --mode 1920x1080 --pos 0x0 --rotate normal --output DP-2 --off --output DP-3 --off --output DP-4 --mode 1920x1080 --pos 1920x0 --rotate normal --same-as DP-1
and then just run one of the scripts.
I’ve come up with some scripts using primarily nvidia-settings (as I think the syntax is a little easier to understand) and a single xrandr command to set the primary monitor.
monitor-conf-regular.sh
#!/bin/sh
# monitor-conf-regular.sh
# cat - 2022-05-09
# Activates monitors: lg_ultrawide, asus_left, asus_right; disables other monitors.
# xrandr outputs
output_asus_left=USB-C-0.2
output_asus_right=USB-C-0.3
output_lg_ultrawide=DP-2
# nvidia metamodes
metamode_asus_left="$output_asus_left: 1920x1080_60_0 +0+0 \
	{Rotation=90, ForceCompositionPipeline=On}"
metamode_asus_right="$output_asus_right: 1920x1080_60_0 +1080+0 \
metamode_lg_ultrawide="$output_lg_ultrawide: 3440x1440_60 +2160+480 \
	{ForceCompositionPipeline=On}"
nvidia-settings --assign "CurrentMetaMode"="$metamode_asus_left, $metamode_asus_right, $metamode_lg_ultrawide"
xrandr --output $output_lg_ultrawide --primary
monitor-conf-w-tv.sh
#!/bin/sh
# monitor-conf-w-tv.sh
# cat - 2022-05-09
# Activates monitors: lg_tv, lg_ultrawide; disables other monitors.
# Configures lg_tv as the source of a mirror (tranformed to fit) to lg_ultrawide.
# xrandr outputs
output_lg_tv=HDMI-0
# nvidia metamodes
metamode_lg_tv="$output_lg_tv: 3840x2160_60 +0+0 \
metamode_lg_ultrawide="$output_lg_ultrawide: 3440x1440_60 +0+0 \
	{Transform=(1.116272,0,0, 0,1.5,0, 0,0,1), ForceCompositionPipeline=On}"
nvidia-settings --assign "CurrentMetaMode"="$metamode_lg_tv, $metamode_lg_ultrawide"
xrandr --output $output_lg_tv --primary
Instead of manually computing the transform, I got it by running this to apply the initial transform:
  • xrandr --output [monitor] --mode [base-resolution] --scale-from [desired-resolution]
then ran:
  • nvidia-settings -q CurrentMetaMode
which reflected the transform and I used that in the script.
I still need to mess around with disabling kscreen and seeing if that messes anything up, but for now I’m content.
Thanks all!
I am not sure about whats ā€˜easier’ in those scripts of you.
The xrandr codes i wrote are bassically everything you need just put in the correct output IDs (you get them by running xrandr) and the correct monitor position and thats it.
It happened this way because I was already doing research on how to use nvidia-settings's metamodes. I’m pretty sure I need to use it if I want ForceCompositionPipeline set, because xrandr seems to clear that (and any other nvidia-specific information) when it sets the mode of a monitor. I basically decided ā€œI’m already using metamodes, so I’ll do as much as I can with themā€.
Thanks again,
cat
