Arial
2 October 2021 13:31
1
Hey, I am using the latest stable branch of manjaro linux with zsh shell and KDE plasma desktop enviroment. I have input lag with my keyboard, which is integrated into my latop. (a Razerblade 2020 edition) It is always noticeable, but mostly when typing fast in applications such as google docs or VSCode. I tried fixes listed in some other posts, but none seem to work.
(The lag is minimal btw, but as someone who just switched from windows, it is pretty annoying)
Thanks in advance!
Arial
4 October 2021 14:36
3
Hey man thanks for the reply! So in the âtest your keyboard hereâ field I do not see the delay that I might in other programs. The layout also seems to be correct. Actually, the delay seems to happen mostly in browsers, (I have tested LibreWolf, Firefox, and Chrome)
I am thinking that perhaps it could do with my laptop being on battery, and being slower or somethin?
I am not sure, I will keep working on it
Fabby
5 October 2021 07:54
4
An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you further. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text .
Arial
5 October 2021 15:07
5
Alright, here it is. BTW, please let me know if there is any ID that wasnt filtered.
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=1e3d8a53-62a5-4f1a-83dc-7012ceca5a90 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Razer
product: Blade 15 Advanced Model (Early 2021) - RZ09-036 v: 6.04
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Razer model: CH560 v: 4 serial: <filter> UEFI: Razer v: 1.03
date: 03/05/2021
ID-1: BAT0 charge: 68.3 Wh (80.2%) condition: 85.2/80.2 Wh (106.2%)
volts: 16.1 min: 15.4 model: Razer Blade type: Unknown serial: <filter>
status: Discharging
RAM: total: 15.49 GiB used: 3.66 GiB (23.6%)
Info: 8-Core model: Intel Core i7-10875H bits: 64 type: MT MCP
arch: Comet Lake family: 6 model-id: A5 (165) stepping: 2 microcode: EA
cache: L2: 16 MiB bogomips: 73625
Speed: 800 MHz min/max: 800/5100 MHz Core speeds (MHz): 1: 800 2: 827 3: 900
4: 895 5: 816 6: 800 7: 800 8: 800 9: 800 10: 812 11: 800 12: 800 13: 800
14: 800 15: 800 16: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Razer USA
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: Razer USA
driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:24dd class-ID: 0300
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-7:3 chip-ID: 13d3:56d5 class-ID: 0e02 serial: <filter>
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
s-diag: 777mm (30.6")
Monitor-1: eDP-1 res: 2560x1440 hz: 240 dpi: 189 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.2
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Razer USA driver: snd_hda_intel
chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: Razer USA
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:228b
class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
port: 3000 bus-ID: 03:00.0 chip-ID: 8086:2725 class-ID: 0280
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-5:2
chip-ID: 8087:0032 class-ID: e001
Local Storage: total: 953.87 GiB used: 37.77 GiB (4.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB1T0HBLR-00A00
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: EXF7201Q temp: 38.9 C scheme: GPT
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 37.72 GiB (38.5%)
fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: 1e3d8a53-62a5-4f1a-83dc-7012ceca5a90
used: 48.4 MiB (50.4%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
label: SYSTEM uuid: B21B-D6A7
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 17.09 GiB fs: ntfs label: Recovery
uuid: 382C1A222C19DBA6
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 835.69 GiB fs: ntfs
label: Blade 15 uuid: A416653F16651418
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 1000 MiB fs: ntfs label: Winre
uuid: A6601D16601CEEB5
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-5:2 info: Intel AX210 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0032
class-ID: e001
Device-2: 1-7:3 info: IMC Networks Integrated Camera type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-3: 1-8:4 info: Razer USA Razer Blade type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1532:026d class-ID: 0300
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 40.0 C mobo: N/A
Processes: 378 Uptime: 1m wakeups: 1 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1265 pacman: 1256 lib: 334
flatpak: 0 snap: 9 Shell: Zsh v: 5.8 default: Bash v: 5.1.8
running-in: yakuake inxi: 3.3.06```
Fabby
5 October 2021 15:26
6
Arial:
5.13.19-2-MANJARO
Kernel 5.13 is EOL so please install both 5.4 and 5.10 LTS (Long Term Support) and see which one of the two troubles you least.
If that doesnât solve the issue, weâll take it from thereâŚ
Arial
6 October 2021 13:27
7
Thanks man! Unfortunatly, LTS does not work on this laptop, it does not detect my graphics card or my networking card. So I will just deal with the lag I gues, I am getting used to it already.
I really apreciate the help tho!
Fabby
6 October 2021 17:34
8
Please read this:
Difficulty: âââââ
Remember when you installed your very first Windows, added bells and whistles and then couldnât see the wood for the trees any more and had to re-install?
Well, youâre in the same situation now: Youâre a N00b again! Embrace it!
I know right now youâre thinking:
Why is this so much more difficult than Windows? [image]
Whereas in 6 months time, youâll be like:
Why can't I make Windows jump through fiery hoops like I do with Linux??? <a class="lightbox&quâŚ
Especially the Linux has multiple kernels section, then try the latest Stable kernel and remember youâre on the fast development channel and you should upgrade your kernel often!
Arial
6 October 2021 23:06
9
Will do! Also, that is basicly me, I was a windows power user who recently switched. Thanks man, you have been a huge help! The good karma is all coming your way lol
Fabby
7 October 2021 09:19
10
So did that work?
If yes, please donât forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
so that the next person that has the exact same problem you just had will benefit from your post as well as your question will now be in the âsolvedâ status.
system
Closed
9 October 2021 23:19
11
