Which codec in Youtube > Stats for nerds proves that hardware acceleration is enabled. Is it vp09 or av01? Thank you.
I believe it’s this one.
@Yochanan sir this happens in firefox also
I don’t think you check hardware acceleration is enabled by the codec used.
This might be more informative:
https://wiki.archlinux.org/title/Hardware_video_acceleration
There is codec information at the bottom of the page.
If you actually click on the link you’ll see how to check if hardware acceleration is in use.
