Help with Graphic Card and Driver
Hi guys, i’m new on linux and manjaro, can we have an help on the graphic card settings ? I have some problem with KDE (glitches, desktop effects doesn’t start automatically on startup), and for example when i launch Supertuxracing the entire system freeze.I think there is a problem with graphic card driver or not ???
This is the result of inxi -Fuzy:
> System:
>   Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.19.5
>   Distro: Manjaro Linux
> Machine:
>   Type: Desktop System: LENOVO product: 30AH001GIX v: ThinkStation P300
>   serial: <filter>
>   Mobo: LENOVO model: SHARKBAY v: SDK0E50510 PRO serial: <filter> BIOS: LENOVO
>   v: FBKTB0AUS date: 03/26/2015
> CPU:
>   Topology: Quad Core model: Intel Core i7-4790 bits: 64 type: MT MCP
>   L2 cache: 8192 KiB
>   Speed: 3508 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 3593 2: 3592
>   3: 3592 4: 3592 5: 3593 6: 3593 7: 3593 8: 3592
> Graphics:
>   Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
>   driver: i915 v: kernel
>   Display: x11 server: X.Org 1.20.8 driver: intel unloaded: modesetting
>   resolution: 1: 1360x768~60Hz 2: 1920x1080~60Hz
>   OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
>   v: 4.5 Mesa 20.1.7
Ah, sorry for my english and thanks :slight_smile: :slight_smile:
Hello,
Have you tried this?
Hello, how do i check if my laptop is using dedicated GPU all the time and not the one integrated in CPU? In manjaro settings manager under nvidia drivers(4.55xx) i have seen some video-linux , video-modesetting, and video-vesa. What does it means?
