Hello people, I was wondering where to start to fix (if needed) these errors I am getting from doing
sudo journalctl -p 3 -xb
sep 05 11:00:25 Geriel-Manjaro kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT4._GTF due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
sep 05 11:00:25 Geriel-Manjaro kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT0._GTF.DSSP], AE_NOT_FOUND (20190816/psargs-330)
sep 05 11:00:25 Geriel-Manjaro kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT0._GTF due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
sep 05 11:00:25 Geriel-Manjaro kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT3._GTF.DSSP], AE_NOT_FOUND (20190816/psargs-330)
sep 05 11:00:25 Geriel-Manjaro kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT3._GTF due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
sep 05 11:00:25 Geriel-Manjaro kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT1._GTF.DSSP], AE_NOT_FOUND (20190816/psargs-330)
sep 05 11:00:25 Geriel-Manjaro kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT1._GTF due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
sep 05 11:00:25 Geriel-Manjaro kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT4._GTF.DSSP], AE_NOT_FOUND (20190816/psargs-330)
sep 05 11:00:25 Geriel-Manjaro kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT5._GTF.DSSP], AE_NOT_FOUND (20190816/psargs-330)
sep 05 11:00:25 Geriel-Manjaro kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT5._GTF due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
sep 05 11:00:25 Geriel-Manjaro kernel: kobject_add_internal failed for PNP0C14:00-DEADBEEF-4001-0000-00A0-C90629100000 with -EEXIST, don't try to register things with the same name in the same directory.
sep 05 11:00:25 Geriel-Manjaro kernel: wmi_bus wmi_bus-PNP0C14:00: failed to register DEADBEEF-4001-0000-00A0-C90629100000
sep 05 11:00:25 Geriel-Manjaro kernel: wmi: Failed to parse WDG method
sep 05 11:00:25 Geriel-Manjaro kernel: really_probe: driver_sysfs_add(PNP0C14:00-05901221-D566-11D1-B2F0-00A0C9062910) failed
sep 05 11:00:27 Geriel-Manjaro wpa_supplicant[805]: ioctl[SIOCSIWAP]: Operation not permitted
sep 05 11:00:27 Geriel-Manjaro wpa_supplicant[805]: ioctl[SIOCSIWENCODEEXT]: Invalid argument
sep 05 11:00:28 Geriel-Manjaro wpa_supplicant[805]: Failed to add supported operating classes IE
sep 05 11:00:28 Geriel-Manjaro wpa_supplicant[805]: bgscan simple: Failed to enable signal strength monitoring
sep 05 11:00:33 Geriel-Manjaro colord-sane[1019]: io/hpmud/pp.c 627: unable to read device-id ret=-1
sep 05 11:00:34 Geriel-Manjaro gdm-password][1043]: gkr-pam: unable to locate daemon control file
Honestly I am kind of lost about what some of those errors means, if they are important or not, and how should I handle them, can someone please give me a hint to clear my paranoia about them?
EDIT: Oh I’m sorry I forgot to put the System info, I copied it and didn’t pasted it here, my bad:
OS: Manjaro Linux x86_64
Host: Z370M DS3H
Kernel: 5.4.60-2-MANJARO
Shell: bash 5.0.18
Resolution: 1920x1080 @ 60.00Hz
DE: GNOME 3.36.5
BTW, after that I installed Lightdm (and obviously disabled GDM), so if anything is GDM related I think I can skip it since I am loving LightDM a lot more
