Thanks to the Manjaro Team for this update! Since I have seen during the update checking which packages need to be rebuilt: foreign orage, foreign zotero, I have launched:
checkrebuild -v
foreign orage
foreign zotero
ldd /usr/lib/zotero/plugin-container
libxul.so => not found
ldd /usr/lib/zotero/libxul.so
libmozsandbox.so => not found
liblgpllibs.so => not found
libmozsqlite3.so => not found
libmozgtk.so => not found
ldd /usr/lib/zotero/libsoftokn3.so
ldd /usr/lib/zotero/libmozavcodec.so
libmozavutil.so => not found
ldd /usr/lib/xfce4/panel/plugins/liborageclock.so
libxfce4panel-1.0.so.4 => not found
Thanks @Mirdarthos! I have not tested sudo pamac build orage since pamac rebuild is apparently to be used only for AUR packages which is not the case of orage (you probably made a typo writing orange instead of it). Does someone have another idea?
Thanks again!
Orage is not part of Xfce anymore. v4.16 dropped it so it’s not even a dependency. You can safely remove it and replace it with another calendar software, in case you need it.
Thanks @pgomezase , @phush0 and @Mirdarthos for your help! As @pgomezase rightly wrote, I have removed it by launching sudo pacman -Rsu orage and do not have it listed in checkrebuild any more! Thanks
Thank for the tip for the favorites in the whisker menu @moana ! Since it has also worked for @vvoss and @Armag67, I have wrote this line and save it the ~/.config/xfce4/panel/whiskermenu-8.rc file. After that nothing appears when I open the whisker menu. So I have rebooted my computer and nothing appears. I wrote it and second time and made sure that the file was saved. I rebooted once more and my favorites are still absent when I open the whisker menu. So I reopened the ~/.config/xfce4/panel/whiskermenu-8.rc file, and the favorites= line is empty after the equal sign… Does anyone have an idea how to solve it or why the favorites lines somehow “deletes itself”.
Thanks for your attention!
