I am just starting out with Manjaro, and I downloaded the minimal installation for raspberry pi 4.
Everything is working ok for now, however I would like to have the user I created autologin on boot.
I searched around, but everything I found is related to one of the desktop environments, and I have the minimal version which is just console and none of those tools.
How can I go about achieving the auto login?
As 2 extra “bonus” items, something else I want and need to do is:
How can I prevent the user from being asked the password every time I issue a sudo command?
Is there a way to change the small graphic (manjaro logo) that appears at boot and shutdown?
I managed to get the login investigating meanwhile, and also the passwordless sudo, although it did not work adding to the sudoers file, rather adding to a new file in sudoers.d like you mention, but with a different syntax of !authenticate.
I know normally this is a security risk , but this is towards building an emulation image to boot up a retro computer, so not really concerned about it.
Regarding the logo, it’s what appears as soon as it starts booting. Did you not see it ever? It’s like this:
It only appears for a very short while. Not sure if it resembles a theme but if that even applies to this minimal desktop-less build?
Now I am researching a new thing and it’s to run a script on bootup, after the autologin. I tired as seen elsewhere to create an /etc/rc.local file but that did not work/
Edit: did not let me upload image. It’s like this:
https: // i. ytimg. com/vi/GQL06AwHG44/maxresdefault.jpg
So I found the theme, and I replaced the logo.png file for a different one.
I see it display as shutdown, but it seems at startup it uses a different file. Any chance the very first image I see is not even a plymouth theme yet?
