Hi yes it’s me, well this is the original error I wanted to show(only I didn’t know how to take screenshot) but well here I show the images. if you could help me it would be amazing as I have been trying to deal with it for quite some time but I don’t know what to do… so please if anyone knows the answer it would be very helpful.
Check OpenGL Version. 3.0 is needed at least:
glxinfo -B
I did it and I got this in the Terminal:
name of display: :0
display: :0 screen: 0
direct rendering: Yes
Extended renderer info (GLX_MESA_query_renderer):
Vendor: Intel (0x8086)
Device: Mesa Intel(R) HD Graphics 620 (KBL GT2) (0x5916)
Version: 23.0.3
Accelerated: yes
Video memory: 7831MB
Unified memory: yes
Preferred profile: core (0x1)
Max core profile version: 4.6
Max compat profile version: 4.6
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 3.2
OpenGL vendor string: Intel
OpenGL renderer string: Mesa Intel(R) HD Graphics 620 (KBL GT2)
OpenGL core profile version string: 4.6 (Core Profile) Mesa 23.0.3
OpenGL core profile shading language version string: 4.60
OpenGL core profile profile mask: core profile
OpenGL version string: 4.6 (Compatibility Profile) Mesa 23.0.3
OpenGL shading language version string: 4.60
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 23.0.3
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
