Hello everyone,
I have been trying to get docker to run on my computer but I think I must have done something incorrect in setting it up, and have caused my computer to not recognize any nearby wifi networks. I am using Bluetooth tethering right now. Based on previous forums, I have run the following commands and below is their output. Thank you in advance for assisting me.
[Mod note: Screenshots removed; please post text outputs]
BG405
21 December 2024 19:44
2
Hello and welcome to the Manjaro Community.
Tip: Please don’t post screenshots as it makes it hard for us to read.
Please instead copy and paste the terminal output, highlight (select) it in the reply window and click the </> button at the top of the reply window for each output.
Thanks!
Sorry about that! here are the commands I have run:
[pablo-mpgh410trident3 ~]# nmcli g
STATE CONNECTIVITY WIFI-HW WIFI WWAN-HW WWAN METERED
connected full missing enabled missing enabled yes (guessed)
[pablo-mpgh410trident3 ~]# nmcli n
enabled
[pablo-mpgh410trident3 ~]# nmcli r
[pablo-mpgh410trident3 ~]# nmcli d
DEVICE TYPE STATE CONNECTION
BC:32:B2:23:2E:E8 bt connected Pablo's S23+ Network
lo loopback connected (externally) lo
docker0 bridge connected (externally) docker0
eno1 ethernet unavailable --
sudo inxi -Farz
Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 14.2.1 clocksource: tsc avail: hpet,acpi_pm
root=UUID=e9c7b1cf-3bbc-456e-b415-70fd4483f6cb rw quiet
splash udev.log_priority=3
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A wm: kwin_x11
with: Docker dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: Micro-Star model: MS-B9321 v: 1.0
serial: <filter> part-nu: B932.8
uuid: 7d7c99dd-717a-ea40-8fb1-2e9eb7913f5e
UEFI: American Megatrends v: 8.10 date: 05/26/2020
Info: model: Intel Core i5-10400F socket: U3E1 bits: 64
type: MT MCP arch: Comet Lake gen: core 10 level: v3 note: check
built: 2020 process: Intel 14nm family: 6 model-id: 0xA5 (165)
stepping: 5 microcode: 0xFC
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12
tpc: 2 smt: enabled cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3818 min/max: 800/4300 base/boost: 2871/8300
scaling: driver: intel_pstate governor: powersave volts: 0.9 V
ext-clock: 100 MHz cores: 1: 3818 2: 3818 3: 3818 4: 3818
5: 3818 6: 3818 7: 3818 8: 3818 9: 3818 10: 3818 11: 3818
12: 3818 bogomips: 69629
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2
ssse3 vmx
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT
vulnerable
Type: retbleed mitigation: Enhanced IBRS
Type: spec_store_bypass mitigation: Speculative Store Bypass
disabled via prctl
Type: spectre_v1 mitigation: usercopy/swapgs barriers and
__user pointer sanitization
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW
loop, KVM: SW loop
Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER]
vendor: Micro-Star MSI driver: nouveau v: kernel
non-free: 550.xx+ status: current (as of 2024-09;
EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: HDMI-A-1
empty: DP-1,DVI-D-1 bus-ID: 01:00.0 chip-ID: 10de:21c4
class-ID: 0300
Display: unspecified server: X.Org v: 21.1.14 with: Xwayland
v: 24.1.4 compositor: kwin_x11 driver: X: loaded: modesetting
alternate: fbdev,vesa dri: nouveau gpu: nouveau display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96
s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Acer SB230
serial: <filter> built: 2020 res: 1920x1080 hz: 75 dpi: 96
gamma: 1.2 size: 509x286mm (20.04x11.26") diag: 584mm (23")
ratio: 16:9 modes: max: 1920x1080 min: 720x400
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0
drv: nouveau device: 1 drv: swrast gbm: drv: nouveau
surfaceless: drv: nouveau x11: drv: nouveau inactive: wayland
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa
v: 24.2.8-arch1.1 glx-v: 1.4 direct-render: yes renderer: NV168
device-ID: 10de:21c4 memory: 5.85 GiB unified: no
API: Vulkan v: 1.4.303 layers: N/A device: 0
type: discrete-gpu name: NVIDIA GeForce GTX 1660 SUPER (NVK
TU116) driver: N/A device-ID: 10de:21c4 surfaces: xcb,xlib
Device-1: Intel Comet Lake PCH-V cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel
alternate: snd_soc_avs,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:a3f0 class-ID: 0403
Device-2: NVIDIA TU116 High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
bus-ID: 01:00.1 chip-ID: 10de:1aeb class-ID: 0403
API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: n/a (root, process) with:
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI
driver: e1000e v: kernel port: N/A bus-ID: 00:1f.6
chip-ID: 8086:0d55 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: N/A modules: iwlwifi
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0
chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: docker0 state: down mac: <filter>
IF-ID-2: enp0s20f0u9 state: unknown speed: N/A duplex: N/A
mac: <filter>
Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:5
Report: rfkill ID: hci0 rfk-id: 0 state: up
address: see --recommends
Local Storage: total: 1.55 TiB used: 46.08 GiB (2.9%)
SMART Message: Required tool smartctl not installed. Check
--recommends
model: PC SN530 SDBPNPZ-512G-1032 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
tech: SSD serial: <filter> fw-rev: 21111000 temp: 25.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate
model: ST1000LM049-2GH172 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: SDM1 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Generic
model: MassStorageClass size: 58.94 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 2958 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung
model: Flash Drive size: 119.51 GiB block-size: physical: 512 B
logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1
mode: 2.0 tech: SSD serial: <filter> fw-rev: 1100 scheme: MBR
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 46.08 GiB (9.8%) fs: ext4 block-size: 4096 B
dev: /dev/nvme0n1p2 maj-min: 259:2
used: 288 KiB (0.1%) fs: vfat block-size: 512 B
dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 33.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1466 libs: 361 tools: pamac
pm: flatpak pkgs: 0
1: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
2: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
3: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
4: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://mirror.23m.com/manjaro/stable/$repo/$arch
6: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
8: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
9: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
10: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
11: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
12: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
13: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
14: https://mirror.funami.tech/manjaro/stable/$repo/$arch
15: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
16: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
17: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
18: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
19: https://mirror.easyname.at/manjaro/stable/$repo/$arch
20: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
21: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
22: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
23: https://mirrors2.manjaro.org/stable/$repo/$arch
24: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
25: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
26: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
27: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
28: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
29: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
30: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
31: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
32: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
33: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
34: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
35: https://mirrors.manjaro.org/repo/stable/$repo/$arch
36: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
37: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
38: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
39: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
40: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
41: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
42: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
43: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
44: https://manjaro.kurdy.org/stable/$repo/$arch
45: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
46: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
47: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
48: http://mirror.fcix.net/manjaro/stable/$repo/$arch
49: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
50: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
51: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
52: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
53: https://mirror.init7.net/manjaro/stable/$repo/$arch
54: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
55: https://mirror.koddos.net/manjaro/stable/$repo/$arch
56: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
57: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
58: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
59: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
60: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
61: https://mirror.zetup.net/manjaro/stable/$repo/$arch
62: https://muug.ca/mirror/manjaro/stable/$repo/$arch
63: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
64: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
65: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
66: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
67: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
68: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
69: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
70: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
71: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
72: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
73: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
74: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
75: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
76: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
77: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
78: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
79: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
80: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
81: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
82: https://manjaro.ynh.ovh/stable/$repo/$arch
Memory: total: 16 GiB available: 15.54 GiB
used: 4.55 GiB (29.2%)
Processes: 303 Power: uptime: 53m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 0 hibernate: platform
avail: shutdown, reboot, suspend, test_resume image: 6.19 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd
Init: systemd v: 256 default: graphical tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 alt: 13
Shell: Sudo (sudo) v: 1.9.16p2 default: Bash v: 5.2.37
running-in: konsole inxi: 3.3.36
[pablo-mpgh410trident3 ~]# ^C
[pablo-mpgh410trident3 ~]# sudo mhwd --list
> 0000:01:00.0 (0300:10de:21c4) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2024.05.03 false PCI
video-nvidia-470xx 2023.03.23 false PCI
video-linux 2024.05.06 true PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
[pablo-mpgh410trident3 ~]# ip address
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: eno1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether 2c:f0:5d:6e:40:20 brd ff:ff:ff:ff:ff:ff
altname enp0s31f6
3: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
link/ether 02:42:1f:a1:de:f6 brd ff:ff:ff:ff:ff:ff
inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
4: enp0s20f0u9: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN group default qlen 1000
link/ether e0:d4:e8:51:13:36 brd ff:ff:ff:ff:ff:ff
inet 192.168.44.54/24 brd 192.168.44.255 scope global dynamic noprefixroute enp0s20f0u9
valid_lft 2531sec preferred_lft 2531sec
inet6 fe80::9217:ba7c:b7b0:3a1f/64 scope link noprefixroute
[pablo-mpgh410trident3 ~]# rfkill list all
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
cscs
21 December 2024 19:58
4
The last time this card wasnt working for another user it was simply because windoze was not fully shut down.
And this was on a machine where windoze was not even still installed!
Please advise if you are dual-booting, windoze was previously installed, and/or are familiar with whether ‘Fast Startup’ was disabled and/or it was fully shut down.
( In that case the user succeeded by fully removing all power supply for some minutes )
I wondered if this was some sort of dual-boot with windoze issue.
But your output would suggest this is the sole system on the machine.
Sadly … that does not discount the possibility that windoze was not fully shutdown and has held the card hostage. This related arch thread solution included re-installing windoze!
( In order to disable ‘fast-startup’ - a cmd to properly shut down could also suffice )
https://bbs.archlinux.org/viewtopic.php?id=290632
Hello! Thank you for pointing me in the right direction. I used to have Widows before moving to Manjaro. I am not familiar with Fast Startup - only Fast Boot - I recall having some issues with booting up my computer and changing the boot order. I will try to remove the power supply for a bit, if this fails I will continue reading into the threads you have linked, particularly the arch forum’s recommendation to try and reset the card. I strongly suspect that perhaps I did not properly shut down windows.
system
Closed
24 December 2024 20:25
6
