I recently installed Manjaro KDE on a new SSD. I put the old HDD in a caddy in place of the optical drive (removed the optical drive) to use as storage. I formatted the drive but now I am unable to do anything on this drive. I can’t create new folders not paste any files.
What am I doing wrong? On my Win 10 rig I have a SSD for the OS and applications and a 2TB HDD for storage. I want to replicate the same setup. I assumed it would be simple but isn’t. How do I go about doing that?
i’m reading that how to geek and yes i find it easier then the other posted link,got to Mounting the file systems section and got this.the Hdd is not formated.
sudo mount /dev/sda /mnt/scsi
mount: /mnt/scsi: wrong fs type, bad option, bad superblock on /dev/sda, missing codepage or help
er program, or other error.
hey sorry for the long time since i replied joys of real life,yeah i forgot to format it .tried to update manjaro the old version to many conflicts so gave up and installed the latest version.
though i did have one issue with sudo gedit /etc/fstab which I had to web search and found out it only works on Gnome based Linux,as I’m using KDE based Linux you have to use kate /etc/fstab
other then that all working great and thanks for the help
