Dareku
February 19, 2023, 5:32pm
1
Hi i am very noob. Need to autostart a script like wakeonlan -i IP xx.xx.xx.xx mac xx:xx:xx:xx.
the script .sh work fine but only AFTER login (i put him in autostart)
Also i try to put him on /etc/X11/xinit/xinitrc.d/ but also run after login…
Can you help?
Thx!
TriMoon
February 19, 2023, 6:36pm
2
You should create a system service that starts with your computer in that case.
See the results of a search-engine for more details about systemd-services:
Dareku
February 19, 2023, 9:03pm
3
ok, read guideline but not working
first created monitoron.script on /etc/systemd/system - command on konsole work good
monitoron.script:
[Unit]
Description=Wake-on-LAN
Requires=network.target
After=network.target
[Service]
ExecStart=/home/cesare/.local/bin/wakeonlan -i IP XX.XX.XX.XX MAC XX:XX:XX:XX
Type=oneshot
[Install]
WantedBy=multi-user.target
Last enabled script
systemctl enable monitoron.service
What is wrong?
thx
? monitoron.service
file and not monitoron.script
systemctl enable
service is ok only after reboot …
We can test service by sudo systemctl start monitoron
(and we can read result in journalctl)
Dareku
February 19, 2023, 9:32pm
5
service tested, powered off monitor and launched test systemctl “start monitoron.service”, work.
it work as a test, but when reboot or power off/on won’t work
journal
|19/02/23 22:39|kernel|audit: type=1131 audit(1676842796.473:134): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=monitoron comm=systemd exe=/usr/lib/systemd/systemd hostname=? addr=? terminal=? res=success'|```
Edit i get somepoint...
journal after startup fail but adding "Restart=on-failure & RestartSec=3" willl work!
``` |19/02/23 23:17|systemd|monitoron.service: Main process exited, code=exited, status=1/FAILURE|
|19/02/23 23:17|systemd|monitoron.service: Failed with result 'exit-code'.|
|19/02/23 23:17|audit|SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=monitoron comm=systemd exe=/usr/lib/systemd/systemd hostname=? addr=? terminal=? res=failed'|
|19/02/23 23:17|systemd|monitoron.service: Scheduled restart job, restart counter is at 1.|
|19/02/23 23:17|audit|SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=monitoron comm=systemd exe=/usr/lib/systemd/systemd hostname=? addr=? terminal=? res=success'|
|19/02/23 23:17|audit|SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=monitoron comm=systemd exe=/usr/lib/systemd/systemd hostname=? addr=? terminal=? res=success'|
|19/02/23 23:17|systemd|monitoron.service: Scheduled restart job, restart counter is at 2.|
|19/02/23 23:17|kernel|audit: type=1130 audit(1676845042.526:70): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=monitoron comm=systemd exe=/usr/lib/systemd/systemd hostname=? addr=? terminal=? res=success'|
|19/02/23 23:17|kernel|audit: type=1131 audit(1676845042.526:71): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=monitoron comm=systemd exe=/usr/lib/systemd/systemd hostname=? addr=? terminal=? res=success'|
|19/02/23 23:17|systemd|monitoron.service: Deactivated successfully.|
|19/02/23 23:17|kernel|audit: type=1130 audit(1676845042.553:72): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=monitoron comm=systemd exe=/usr/lib/systemd/systemd hostname=? addr=? terminal=? res=success'|
|19/02/23 23:17|kernel|audit: type=1131 audit(1676845042.553:73): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=monitoron comm=systemd exe=/usr/lib/systemd/systemd hostname=? addr=? terminal=? res=success'| ```
TriMoon
February 20, 2023, 7:46am
6
Dareku:
You probably need network-online.target
see: systemd.special
PS: To check logs for the unit you can use one of the below or both:
systemctl status monitoron
journalctl -u monitoron
Please edit your post with output so the log outputs are placed between codeblocks as:```
text
Those are backticks normally found on the left of the 1 on your keyboard…
Dareku
February 20, 2023, 8:23pm
7
Solved! now monitor power on at login!!!
using this service:
[Unit]
Requires=network-online.target
After=network-online.target
[Service]
ExecStart=/home/userxxx/.local/bin/wakeonlan -i XXX.XXX.X.XX(IP) XX:XX:XX:XX:XX:XX(MAC)
Type=oneshot
[Install]
WantedBy=network-online.target
Now i try to make a service turning off monitor when system suspend:
[Unit]
Description=off screen before suspend
Before=network-online.target
Before=suspend.target sleep.target
[Service]
ExecStartPre=/bin/sleep 5
ExecStart=/usr/bin/lgtv MyTv off ssl
Type=oneshot
[Install]
WantedBy=suspend.target sleep.target
This script WORK if i test him, but suspending manjaro make lan disconnected IMMEDIATLY (red X on lan icon) i use sleep 5 to see what’s happening while service running:
click suspend
lan disconnect immediatly
remote command error beaucause lan is disconnected
5 seconds pass
system will suspend
My question: there is a way to tell at service “don’t stop ethernet when suspend?” Or configure lan to NOT disable when suspend system? Modify suspend rules?
Thx
TriMoon
February 21, 2023, 9:25am
9
In your monitoron
service:
This is wrong, because that is used for services that setup your network config for your own machine…
So you should disable your service again, then remove that line and re-enable the service again.
(If not done this way the link will not be removed)
With respect to your second problem/question about suspend/resume, it is better to create a new thread about that to keep this thread clean for the Title it has for other readers in future…
Because That is a totally different topic which has completely different stuff involved…
Dareku
February 21, 2023, 9:38am
10
Ok, solved! WantedBy=network-online.target is wrong but it work. I removed the line and now the script it’s better Thx!!!
