Please help me , how to reset default theme on manjaro gnome,i was install theme on terminal from github , but not according to ekpectation
You might need to be a bit more verbose … what exactly did you do?
Similarly … what desktop is it? You tagged multiple.
Welcome to the forum!
Sorry, but your post is …
Please help us help you. See:
If you run Gnome (as given in your profile data) then open a terminal and run
dconf reset -f /org/gnome/
Afterwards, reboot.
Whoah, that’s a bit extreme. We don’t even know what exactly happened yet.
Pliss , can you help me how to reset default , because thme is so bad , i was install on terminal , i found that theme form github
Read what others posted and answer their questions? Otherwise we can’t help you.
Thnkyou bro solved
@Riss Since you did not even bother telling us what you actually did, a random guess from a helpful volunteer accidently solved the issue. Effectively, you used a sledgehammer when all you needed were tweezers.
