Hello,
I tried to install tutanota-desktop from AUR (en) - tutanota-desktop
To do this, I added the ‘aarch64’ parameter to PKGBUILD and executed the following commands:
git clone https://aur.archlinux.org/tutanota-desktop.git
cd tutanota-desktop/
makepkg -Asrcif
But fatal error occurred as a result of the building:
<--- JS stacktrace --->
FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
1: 0xb712ac node::Abort() [node]
2: 0xa93f08 [node]
3: 0xd3bb10 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [node]
4: 0xd3bce0 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [node]
5: 0xf1a26c [node]
6: 0xf2c20c v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [node]
7: 0xf08380 v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [node]
8: 0xf09358 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [node]
9: 0xeebfe8 v8::internal::Factory::NewFillerObject(int, v8::internal::AllocationAlignment, v8::internal::AllocationType, v8::internal::AllocationOrigin) [node]
10: 0x12925c4 v8::internal::Runtime_AllocateInYoungGeneration(int, unsigned long*, v8::internal::Isolate*) [node]
11: 0x167712c [node]
/home/user/tutanota-desktop/PKGBUILD: line 34: 7374 Emergency stop (The memory image has been reset to disk) node desktop --custom-desktop-release --unpacked
==> ERROR: There was a failure in build().
Interruption...
How can this problem be solved?
