nvidia-xrun-git 0.3.83.g270b6c0-1
lscpi
01:00.0 3D controller: NVIDIA Corporation GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M] (rev a1)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller (rev 06)
00:02.0 VGA compatible controller: Intel Corporation 4th Gen Core Processor Integrated Graphics Controller (rev 06)
optirun glxgears -info
GL_RENDERER = GeForce GT 820M/PCIe/SSE2
GL_VERSION = 4.6.0 NVIDIA 390.157
GL_VENDOR = NVIDIA Corporation
GL_EXTENSIONS = GL_AMD_multi_draw_indirect GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_compute_shader GL_ARB_compute_variable_group_size GL_ARB_conditional_render_inverted GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_derivative_control GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_indirect GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_ES3_1_compatibility GL_ARB_ES3_2_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_gl_spirv GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_gpu_shader_int64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_indirect_parameters GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_parallel_shader_compile GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_polygon_offset_clamp GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_query_buffer_object GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counter_ops GL_ARB_shader_atomic_counters GL_ARB_shader_bit_encoding GL_ARB_shader_draw_parameters GL_ARB_shader_group_vote GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_image_samples GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_sparse_buffer GL_ARB_sparse_texture GL_ARB_spirv_extensions GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_barrier GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_filter_anisotropic GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transform_feedback_overflow_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset_clamp GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_image_load_store GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_EXT_window_rectangles GL_EXT_x11_sync_object GL_EXT_import_sync_object GL_NV_robustness_video_memory_purge GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_context_flush_control GL_KHR_debug GL_KHR_parallel_shader_compile GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_KTX_buffer_region GL_NV_alpha_to_coverage_dither_control GL_NV_bindless_multi_draw_indirect GL_NV_bindless_multi_draw_indirect_count GL_NV_blend_equation_advanced GL_NV_blend_square GL_NV_command_list GL_NV_compute_program5 GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_draw_texture GL_NV_ES1_1_compatibility GL_NV_ES3_1_compatibility GL_NV_explicit_multisample GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_internalformat_sample_query GL_NV_gpu_program4_1 GL_NV_gpu_program5 GL_NV_gpu_program5_mem_extended GL_NV_gpu_program_fp64 GL_NV_gpu_shader5 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_query_resource GL_NV_query_resource_tag GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_atomic_counters GL_NV_shader_atomic_float GL_NV_shader_buffer_load GL_NV_shader_storage_buffer_object GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_rectangle_compressed GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_uniform_buffer_unified_memory GL_NV_vdpau_interop GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_attrib_integer_64bit GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_NV_shader_thread_group GL_KHR_blend_equation_advanced GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum
VisualID 1008, 0x3f0
298 frames in 5.0 seconds = 59.412 FPS
300 frames in 5.0 seconds = 59.976 FPS
300 frames in 5.0 seconds = 59.970 FPS
X connection to :0 broken (explicit kill or server shutdown).
primus: warning: dropping a frame to avoid deadlock
primus: warning: timeout waiting for display worker
/etc/X11/xorg.conf.d/30-nvidia.conf
Section "Device"
Identifier "nvidia"
Driver "nvidia"
BusID "PCI:1:0:0"
# Option "DPI" "96 x 96"
EndSection
/etc/default/nvidia-xrun
# When enabled, nvidia-xrun will turn the card on before attempting to load the
# modules and running the command, and turn it off after the commands exits and
# the modules gets unloaded. If order for this to work, CONTROLLER_BUS_ID and
# DEVICE_BUS_ID must be set correctly. IDs can be found by by inspecting the
# output of lshw.
ENABLE_PM=1
# When PM is enabled, remove the card from the system after the command exists
# and modules unload: the card will be readded in the next nvidia-xrun
# execution before loading the nvidia module again. This is recommended as Xorg
# and some other programs tend to load the nvidia module if they detect a
# nvidia card in the system, and when the module is loaded the card can't save
# power.
REMOVE_DEVICE=1
# Bus ID of the PCI express controller
CONTROLLER_BUS_ID=0000:00:01.0
# Bus ID of the graphic card
DEVICE_BUS_ID=0000:01:00.0
# Seconds to wait before turning on the card after PCI devices rescan
BUS_RESCAN_WAIT_SEC=1
# Ordered list of modules to load before running the command
MODULES_LOAD=(nvidia nvidia_uvm nvidia_modeset "nvidia_drm modeset=1")
# Ordered list of modules to unload after the command exits
MODULES_UNLOAD=(nvidia_drm nvidia_modeset nvidia_uvm nvidia)
/home/ataq/.config/X11/nvidia-xinitrc
if [ $# -gt 0 ]; then
else
# startkde
openbox-session
fi
in tty execute “nvidia-xrun”
/home/ataq/.local/share/xorg/Xorg.1.log
[ 63.139]
X.Org X Server 1.21.1.7
[ 63.139] Current Operating System: Linux ataq 6.1.19-1-MANJARO #1 SMP PREEMPT_DYNAMIC Mon Mar 13 12:59:35 UTC 2023 x86_64
[ 63.139] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64 root=UUID=4645d5de-f720-4fd5-8938-9b5d42dbc7d2 rw rootflags=subvol=@ udev.log_priority=3 loglevel=3
[ 63.139]
[ 63.139] Current version of pixman: 0.42.2
[ 63.139] Before reporting problems, check http://wiki.x.org
[ 63.139] Markers: (--) probed, (**) from config file, (==) default setting,
[ 63.140] (==) Log file: "/home/ataq/.local/share/xorg/Xorg.1.log", Time: Sat Mar 25 19:38:04 2023
[ 63.140] (++) Using config file: "/etc/X11/nvidia-xorg.conf"
[ 63.140] (EE) Unable to locate/open config directory: "nvidia-xorg.conf.d"
[ 63.140] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 63.140] (==) ServerLayout "layout"
[ 63.140] (**) |-->Screen "nvidia" (1)
[ 63.140] (**) | |-->Monitor "<default monitor>"
[ 63.140] (**) | |-->Device "nvidia"
[ 63.140] (==) No monitor specified for screen "nvidia".
[ 63.140] (**) |-->Inactive Device "intel"
[ 63.140] (==) Automatically adding devices
[ 63.140] (==) Automatically enabling devices
[ 63.140] (==) Automatically adding GPU devices
[ 63.140] (==) Automatically binding GPU devices
[ 63.140] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 63.140] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 63.140] Entry deleted from font path.
[ 63.140] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 63.140] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 63.140] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 63.140] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 63.140] (**) ModulePath set to "/usr/lib/nvidia,/usr/lib32/nvidia,/usr/lib32/nvidia/xorg/modules,/usr/lib32/xorg/modules,/usr/lib64/nvidia/xorg/modules,/usr/lib64/nvidia/xorg,/usr/lib64/xorg/modules"
[ 63.140] (II) The server relies on udev to provide the list of input devices.
[ 63.140] (II) Module ABI versions:
[ 63.140] X.Org ANSI C Emulation: 0.4
[ 63.140] X.Org Video Driver: 25.2
[ 63.140] X.Org XInput driver : 24.4
[ 63.140] X.Org Server Extension : 10.0
[ 63.141] (++) using VT number 5
[ 63.141] (--) controlling tty is VT number 5, auto-enabling KeepTty
[ 63.143] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_34
[ 63.144] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 63.144] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card1
[ 63.145] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 13 paused 0
[ 63.145] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 63.145] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[ 63.146] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 14 paused 0
[ 63.147] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia,/usr/lib32/nvidia,/usr/lib32/nvidia/xorg/modules,/usr/lib32/xorg/modules,/usr/lib64/nvidia/xorg/modules,/usr/lib64/nvidia/xorg,/usr/lib64/xorg/modules"
[ 63.147] (**) OutputClass "nvidia" setting /dev/dri/card1 as PrimaryGPU
[ 63.148] (--) PCI: (0@0:2:0) 8086:0416:17aa:3808 rev 6, Mem @ 0xd1000000/4194304, 0xc0000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[ 63.148] (--) PCI:*(1@0:0:0) 10de:1140:17aa:380e rev 161, Mem @ 0xd0000000/16777216, 0xa0000000/268435456, 0xb0000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/524288
[ 63.148] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 63.148] (II) LoadModule: "glx"
[ 63.148] (II) Loading /usr/lib/nvidia/xorg/libglx.so
[ 63.255] (II) Module glx: vendor="NVIDIA Corporation"
[ 63.255] compiled for 4.0.2, module version = 1.0.0
[ 63.255] Module class: X.Org Server Extension
[ 63.255] (II) NVIDIA GLX Module 390.157 Wed Oct 12 09:19:15 UTC 2022
[ 63.264] (II) LoadModule: "nvidia"
[ 63.264] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 63.264] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 63.264] compiled for 4.0.2, module version = 1.0.0
[ 63.264] Module class: X.Org Video Driver
[ 63.264] (II) LoadModule: "modesetting"
[ 63.265] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 63.268] (II) Module modesetting: vendor="X.Org Foundation"
[ 63.268] compiled for 1.21.1.7, module version = 1.21.1
[ 63.268] Module class: X.Org Video Driver
[ 63.268] ABI class: X.Org Video Driver, version 25.2
[ 63.268] (II) NVIDIA dlloader X Driver 390.157 Wed Oct 12 09:21:41 UTC 2022
[ 63.268] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 63.268] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 63.268] xf86EnableIO: failed to enable I/O ports 0000-03ff (Operation not permitted)
[ 63.268] (II) systemd-logind: releasing fd for 226:1
[ 63.269] (II) Loading sub module "fb"
[ 63.269] (II) LoadModule: "fb"
[ 63.269] (II) Module "fb" already built-in
[ 63.269] (II) Loading sub module "wfb"
[ 63.269] (II) LoadModule: "wfb"
[ 63.269] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 63.269] (II) Module wfb: vendor="X.Org Foundation"
[ 63.269] compiled for 1.21.1.7, module version = 1.0.0
[ 63.269] ABI class: X.Org ANSI C Emulation, version 0.4
[ 63.269] (II) Loading sub module "ramdac"
[ 63.269] (II) LoadModule: "ramdac"
[ 63.269] (II) Module "ramdac" already built-in
[ 63.269] (WW) Falling back to old probe method for modesetting
[ 63.269] (II) modeset(G0): using drv /dev/dri/card0
[ 63.269] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 63.270] (II) NVIDIA(0): Creating default Display subsection in Screen section
"nvidia" for depth/fbbpp 24/32
[ 63.270] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 63.270] (==) NVIDIA(0): RGB weight 888
[ 63.270] (==) NVIDIA(0): Default visual is TrueColor
[ 63.270] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 63.270] (II) Applying OutputClass "nvidia" options to /dev/dri/card1
[ 63.270] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 63.270] (**) NVIDIA(0): Enabling 2D acceleration
[ 63.273] (II) NVIDIA(0): NVIDIA GPU GeForce GT 820M (GF117) at PCI:1:0:0 (GPU-0)
[ 63.273] (--) NVIDIA(0): Memory: 2097152 kBytes
[ 63.273] (--) NVIDIA(0): VideoBIOS: 75.17.84.00.ff
[ 63.273] (II) NVIDIA(0): Detected PCI Express Link width: 8X
[ 63.273] (II) NVIDIA(0): Validated MetaModes:
[ 63.273] (II) NVIDIA(0): "NULL"
[ 63.273] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[ 63.273] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[ 63.273] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 63.273] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[ 63.273] (**) modeset(G0): Option "AccelMethod" "none"
[ 63.273] (==) modeset(G0): RGB weight 888
[ 63.273] (==) modeset(G0): Default visual is TrueColor
[ 63.273] (**) modeset(G0): glamor disabled
[ 63.273] (II) modeset(G0): ShadowFB: preferred YES, enabled YES
[ 63.273] (II) modeset(G0): Double-buffered shadow updates: off
[ 63.276] (II) modeset(G0): Output eDP-1-1 has no monitor section
[ 63.277] (II) modeset(G0): Output VGA-1-1 has no monitor section
[ 63.305] (II) modeset(G0): Output HDMI-1-1 has no monitor section
[ 63.308] (II) modeset(G0): EDID for output eDP-1-1
[ 63.308] (II) modeset(G0): Manufacturer: CMN Model: 1740 Serial#: 0
[ 63.308] (II) modeset(G0): Year: 2014 Week: 38
[ 63.308] (II) modeset(G0): EDID Version: 1.4
[ 63.308] (II) modeset(G0): Digital Display Input
[ 63.308] (II) modeset(G0): 6 bits per channel
[ 63.308] (II) modeset(G0): Digital interface is undefined
[ 63.308] (II) modeset(G0): Max Image Size [cm]: horiz.: 38 vert.: 21
[ 63.308] (II) modeset(G0): Gamma: 2.20
[ 63.308] (II) modeset(G0): No DPMS capabilities specified
[ 63.308] (II) modeset(G0): Supported color encodings: RGB 4:4:4
[ 63.308] (II) modeset(G0): First detailed timing is preferred mode
[ 63.308] (II) modeset(G0): Preferred mode is native pixel format and refresh rate
[ 63.308] (II) modeset(G0): redX: 0.627 redY: 0.337 greenX: 0.317 greenY: 0.578
[ 63.308] (II) modeset(G0): blueX: 0.156 blueY: 0.074 whiteX: 0.313 whiteY: 0.329
[ 63.308] (II) modeset(G0): Manufacturer's mask: 0
[ 63.308] (II) modeset(G0): Supported detailed timing:
[ 63.308] (II) modeset(G0): clock: 107.8 MHz Image Size: 382 x 214 mm
[ 63.308] (II) modeset(G0): h_active: 1600 h_sync: 1648 h_sync_end 1680 h_blank_end 1940 h_border: 0
[ 63.308] (II) modeset(G0): v_active: 900 v_sync: 903 v_sync_end 908 v_blanking: 926 v_border: 0
[ 63.308] (II) modeset(G0): clock: 71.9 MHz Image Size: 382 x 214 mm
[ 63.308] (II) modeset(G0): Unknown vendor-specific block 2
[ 63.308] (II) modeset(G0): EDID (in hex):
[ 63.308] (II) modeset(G0): 00ffffffffffff000dae401700000000
[ 63.308] (II) modeset(G0): 2618010490261578029405a056519428
[ 63.308] (II) modeset(G0): 13505400000001010101010101010101
[ 63.308] (II) modeset(G0): 0101010101011c2a405461841a303020
[ 63.308] (II) modeset(G0): 35007ed61000001a121c405461841a30
[ 63.308] (II) modeset(G0): 302035007ed61000001a000000000000
[ 63.308] (II) modeset(G0): 00000000000000000000000000000002
[ 63.308] (II) modeset(G0): 000c3add0d3c6e17192e7e0000000051
[ 63.308] (II) modeset(G0): Printing probed modes for output eDP-1-1
[ 63.308] (II) modeset(G0): Modeline "1600x900"x60.0 107.80 1600 1648 1680 1940 900 903 908 926 +hsync -vsync (55.6 kHz eP)
[ 63.308] (II) modeset(G0): Modeline "1600x900"x120.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 63.308] (II) modeset(G0): Modeline "1600x900"x119.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 63.308] (II) modeset(G0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 63.308] (II) modeset(G0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 63.308] (II) modeset(G0): Modeline "1600x900"x40.0 71.86 1600 1648 1680 1940 900 903 908 926 +hsync -vsync (37.0 kHz e)
[ 63.308] (II) modeset(G0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 63.308] (II) modeset(G0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 63.308] (II) modeset(G0): Modeline "1440x810"x120.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 63.308] (II) modeset(G0): Modeline "1440x810"x119.9 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 63.308] (II) modeset(G0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 63.308] (II) modeset(G0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 63.308] (II) modeset(G0): Modeline "1280x800"x120.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 63.308] (II) modeset(G0): Modeline "1280x800"x119.9 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 63.308] (II) modeset(G0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 63.308] (II) modeset(G0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 63.308] (II) modeset(G0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 63.308] (II) modeset(G0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 63.308] (II) modeset(G0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 63.308] (II) modeset(G0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 63.308] (II) modeset(G0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 63.308] (II) modeset(G0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 63.308] (II) modeset(G0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 63.308] (II) modeset(G0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 63.308] (II) modeset(G0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 63.308] (II) modeset(G0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 63.308] (II) modeset(G0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 63.308] (II) modeset(G0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 63.308] (II) modeset(G0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 63.308] (II) modeset(G0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 63.308] (II) modeset(G0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 63.308] (II) modeset(G0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 63.308] (II) modeset(G0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 63.308] (II) modeset(G0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 63.308] (II) modeset(G0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 63.308] (II) modeset(G0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 63.308] (II) modeset(G0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 63.308] (II) modeset(G0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 63.308] (II) modeset(G0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 63.308] (II) modeset(G0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 63.308] (II) modeset(G0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 63.308] (II) modeset(G0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 63.308] (II) modeset(G0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 63.308] (II) modeset(G0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 63.308] (II) modeset(G0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 63.308] (II) modeset(G0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 63.308] (II) modeset(G0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 63.308] (II) modeset(G0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 63.308] (II) modeset(G0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 63.308] (II) modeset(G0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 63.308] (II) modeset(G0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 63.308] (II) modeset(G0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 63.308] (II) modeset(G0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 63.308] (II) modeset(G0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 63.308] (II) modeset(G0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 63.308] (II) modeset(G0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 63.308] (II) modeset(G0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 63.308] (II) modeset(G0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 63.308] (II) modeset(G0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 63.308] (II) modeset(G0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 63.308] (II) modeset(G0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 63.308] (II) modeset(G0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 63.308] (II) modeset(G0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 63.308] (II) modeset(G0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 63.308] (II) modeset(G0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 63.308] (II) modeset(G0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 63.308] (II) modeset(G0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 63.308] (II) modeset(G0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 63.308] (II) modeset(G0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 63.308] (II) modeset(G0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 63.308] (II) modeset(G0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 63.309] (II) modeset(G0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 63.309] (II) modeset(G0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 63.309] (II) modeset(G0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 63.310] (II) modeset(G0): EDID for output VGA-1-1
[ 63.338] (II) modeset(G0): EDID for output HDMI-1-1
[ 63.338] (II) modeset(G0): Manufacturer: VSC Model: f634 Serial#: 16843009
[ 63.338] (II) modeset(G0): Year: 2019 Week: 18
[ 63.338] (II) modeset(G0): EDID Version: 1.3
[ 63.338] (II) modeset(G0): Digital Display Input
[ 63.338] (II) modeset(G0): Max Image Size [cm]: horiz.: 70 vert.: 39
[ 63.338] (II) modeset(G0): Gamma: 2.20
[ 63.338] (II) modeset(G0): DPMS capabilities: Off
[ 63.338] (II) modeset(G0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 63.338] (II) modeset(G0): Default color space is primary color space
[ 63.338] (II) modeset(G0): First detailed timing is preferred mode
[ 63.338] (II) modeset(G0): redX: 0.672 redY: 0.311 greenX: 0.256 greenY: 0.654
[ 63.338] (II) modeset(G0): blueX: 0.081 blueY: 0.055 whiteX: 0.313 whiteY: 0.329
[ 63.338] (II) modeset(G0): Supported established timings:
[ 63.338] (II) modeset(G0): 720x400@70Hz
[ 63.338] (II) modeset(G0): 640x480@60Hz
[ 63.338] (II) modeset(G0): 640x480@67Hz
[ 63.338] (II) modeset(G0): 640x480@72Hz
[ 63.338] (II) modeset(G0): 640x480@75Hz
[ 63.338] (II) modeset(G0): 800x600@56Hz
[ 63.338] (II) modeset(G0): 800x600@60Hz
[ 63.338] (II) modeset(G0): 800x600@72Hz
[ 63.338] (II) modeset(G0): 800x600@75Hz
[ 63.338] (II) modeset(G0): 832x624@75Hz
[ 63.338] (II) modeset(G0): 1024x768@60Hz
[ 63.338] (II) modeset(G0): 1024x768@70Hz
[ 63.338] (II) modeset(G0): 1024x768@75Hz
[ 63.338] (II) modeset(G0): 1280x1024@75Hz
[ 63.338] (II) modeset(G0): 1152x864@75Hz
[ 63.338] (II) modeset(G0): Manufacturer's mask: 0
[ 63.338] (II) modeset(G0): Supported standard timings:
[ 63.338] (II) modeset(G0): #0: hsize: 1920 vsize 1200 refresh: 60 vid: 209
[ 63.338] (II) modeset(G0): #1: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 63.338] (II) modeset(G0): #2: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 63.338] (II) modeset(G0): #3: hsize: 1600 vsize 900 refresh: 60 vid: 49321
[ 63.338] (II) modeset(G0): #4: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 63.338] (II) modeset(G0): #5: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 63.338] (II) modeset(G0): #6: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 63.338] (II) modeset(G0): #7: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 63.338] (II) modeset(G0): Supported detailed timing:
[ 63.338] (II) modeset(G0): clock: 241.5 MHz Image Size: 698 x 392 mm
[ 63.338] (II) modeset(G0): h_active: 2560 h_sync: 2608 h_sync_end 2640 h_blank_end 2720 h_border: 0
[ 63.339] (II) modeset(G0): v_active: 1440 v_sync: 1443 v_sync_end 1448 v_blanking: 1481 v_border: 0
[ 63.339] (II) modeset(G0): Serial No: V3G191820026
[ 63.339] (II) modeset(G0): Ranges: V min: 24 V max: 75 Hz, H min: 24 H max: 99 kHz, PixClock max 255 MHz
[ 63.339] (II) modeset(G0): Monitor name: VX3211-2K
[ 63.339] (II) modeset(G0): Supported detailed timing:
[ 63.339] (II) modeset(G0): clock: 148.5 MHz Image Size: 698 x 392 mm
[ 63.339] (II) modeset(G0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 63.339] (II) modeset(G0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 63.339] (II) modeset(G0): clock: 74.2 MHz Image Size: 698 x 392 mm
[ 63.339] (II) modeset(G0): v_active: 540 v_sync: 542 v_sync_end 547 v_blanking: 562 v_border: 0
[ 63.339] (II) modeset(G0): h_active: 1920 h_sync: 2448 h_sync_end 2492 h_blank_end 2640 h_border: 0
[ 63.339] (II) modeset(G0): h_active: 1280 h_sync: 1390 h_sync_end 1430 h_blank_end 1650 h_border: 0
[ 63.339] (II) modeset(G0): v_active: 720 v_sync: 725 v_sync_end 730 v_blanking: 750 v_border: 0
[ 63.339] (II) modeset(G0): Number of EDID sections to follow: 1
[ 63.339] (II) modeset(G0): EDID (in hex):
[ 63.339] (II) modeset(G0): 00ffffffffffff005a6334f601010101
[ 63.339] (II) modeset(G0): 121d0103804627782e2ac5ac4f41a714
[ 63.339] (II) modeset(G0): 0e5054bfef80d100d1c0b300a9c09500
[ 63.339] (II) modeset(G0): 8180810081c0565e00a0a0a029503020
[ 63.339] (II) modeset(G0): 3500ba882100001a000000ff00563347
[ 63.339] (II) modeset(G0): 3139313832303032360a000000fd0018
[ 63.339] (II) modeset(G0): 4b186319000a202020202020000000fc
[ 63.339] (II) modeset(G0): 005658333231312d324b0a20202001c0
[ 63.339] (II) modeset(G0): 02032bf156010203040506070e0f9011
[ 63.339] (II) modeset(G0): 12131409161d1e1f22212023097f0783
[ 63.339] (II) modeset(G0): 01000067030c0010003832023a801871
[ 63.339] (II) modeset(G0): 382d40582c4500ba882100001e011d80
[ 63.339] (II) modeset(G0): 18711c1620582c2500ba882100009e02
[ 63.339] (II) modeset(G0): 3a80d072382d40102c4580ba88210000
[ 63.339] (II) modeset(G0): 1e011d007251d01e206e285500ba8821
[ 63.339] (II) modeset(G0): 00001e0000000000000000000000009d
[ 63.339] (--) modeset(G0): HDMI max TMDS frequency 250000KHz
[ 63.339] (II) modeset(G0): Printing probed modes for output HDMI-1-1
[ 63.339] (II) modeset(G0): Modeline "2560x1440"x60.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz eP)
[ 63.339] (II) modeset(G0): Modeline "1920x1200"x60.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1920x1080i"x60.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1920x1080i"x50.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1920x1080"x30.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1920x1080"x25.0 74.25 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (28.1 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1920x1080"x24.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1920x1080i"x59.9 74.18 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1920x1080"x30.0 74.18 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.7 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1920x1080"x24.0 74.18 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1600x900"x60.0 108.00 1600 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1440x576"x50.0 54.00 1440 1464 1592 1728 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1440x480"x60.0 54.05 1440 1472 1596 1716 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 63.339] (II) modeset(G0): Modeline "1440x480"x59.9 54.00 1440 1472 1596 1716 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 63.339] (II) modeset(G0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 63.339] (II) modeset(G0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 63.339] (II) modeset(G0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 63.339] (II) modeset(G0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 63.339] (II) modeset(G0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 63.339] (II) modeset(G0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 63.339] (II) modeset(G0): Modeline "720x576i"x50.0 13.50 720 732 795 864 576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[ 63.339] (II) modeset(G0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 63.339] (II) modeset(G0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 63.339] (II) modeset(G0): Modeline "720x480i"x60.0 13.51 720 739 801 858 480 488 494 525 interlace -hsync -vsync (15.8 kHz e)
[ 63.339] (II) modeset(G0): Modeline "720x480i"x59.9 13.50 720 739 801 858 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[ 63.339] (II) modeset(G0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 63.339] (II) modeset(G0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 63.339] (II) modeset(G0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 63.339] (II) modeset(G0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 63.339] (II) modeset(G0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 63.339] (II) modeset(G0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 63.339] (II) modeset(G0): Modeline "720x240"x60.1 13.51 720 739 801 858 240 244 247 262 -hsync -vsync (15.8 kHz e)
[ 63.339] (II) modeset(G0): Modeline "720x240"x60.1 13.50 720 739 801 858 240 244 247 262 -hsync -vsync (15.7 kHz e)
[ 63.339] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 63.339] (==) modeset(G0): DPI set to (96, 96)
[ 63.339] (II) Loading sub module "fb"
[ 63.339] (II) LoadModule: "fb"
[ 63.339] (II) Module "fb" already built-in
[ 63.339] (II) Loading sub module "shadow"
[ 63.339] (II) LoadModule: "shadow"
[ 63.339] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 63.344] (II) Module shadow: vendor="X.Org Foundation"
[ 63.344] compiled for 1.21.1.7, module version = 1.1.0
[ 63.344] ABI class: X.Org ANSI C Emulation, version 0.4
[ 63.345] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[ 63.345] (II) NVIDIA: access.
[ 63.348] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 63.348] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 63.348] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 63.348] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 63.348] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 63.348] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 63.348] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 63.348] (II) NVIDIA(0): Config Options in the README.
[ 63.381] (II) NVIDIA(0): Setting mode "NULL"
[ 63.385] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 63.385] (==) NVIDIA(0): Backing store enabled
[ 63.385] (==) NVIDIA(0): Silken mouse enabled
[ 63.385] (==) NVIDIA(0): DPMS enabled
[ 63.385] (WW) NVIDIA(0): Option "PrimaryGPU" is not used
[ 63.385] (II) Loading sub module "dri2"
[ 63.385] (II) LoadModule: "dri2"
[ 63.385] (II) Module "dri2" already built-in
[ 63.385] (II) NVIDIA(0): [DRI2] Setup complete
[ 63.385] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 63.385] (==) modeset(G0): Backing store enabled
[ 63.385] (==) modeset(G0): Silken mouse enabled
[ 63.579] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[ 63.579] (==) modeset(G0): DPMS enabled
[ 63.579] (EE)
[ 63.579] (EE) Backtrace:
[ 63.579] (EE) 0: /usr/lib/Xorg (dri3_send_open_reply+0xdd) [0x563f672359ed]
[ 63.580] (EE) 1: /usr/lib/libc.so.6 (__sigaction+0x50) [0x7f87071bdf50]
[ 63.580] (EE) 2: /usr/lib/Xorg (InitOutput+0x599) [0x563f67251349]
[ 63.580] (EE) 3: /usr/lib/Xorg (SProcXkbDispatch+0x17b7) [0x563f67117ed3]
[ 63.580] (EE) 4: /usr/lib/libc.so.6 (__libc_init_first+0x90) [0x7f87071a8790]
[ 63.581] (EE) 5: /usr/lib/libc.so.6 (__libc_start_main+0x8a) [0x7f87071a884a]
[ 63.581] (EE) 6: /usr/lib/Xorg (_start+0x25) [0x563f671192f5]
[ 63.581] (EE)
[ 63.581] (EE) Segmentation fault at address 0x10
[ 63.581] (EE)
Fatal server error:
[ 63.581] (EE) Caught signal 11 (Segmentation fault). Server aborting
[ 63.581] (EE)
[ 63.581] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 63.581] (EE) Please also check the log file at "/home/ataq/.local/share/xorg/Xorg.1.log" for additional information.
[ 63.581] (EE)
[ 63.598] (EE) Server terminated with error (1). Closing log file.
Please help.
