philm
1
Currently our developers team is testing our latest ISOs built on yesterday’s Stable Update. You can grab your copy from here: Release 202402220315 · manjaro/release-review · GitHub
Key features:
- update to Calamares 3.3.1
- newer Mesa
- newer Kernels
- latest upstream packages as of Thu Feb 15 00:49:14 CET 2024
See also the user feedback of the current stable update here: [Stable Update] 2024-02-21 - Kernels, KDE, VirtualBox, Calamares, ROCm, Firefox, Thunderbird
To ease downloading and verifying the ISO you can use our utilities
philm
5
Which version of the installer?
Calamares 3.3.1 and 3.3.2 is both affected - albeit not to the same degree
Selected hibernate using ext4 and encryption with 3.3.1 - OK.
Selected hibernate using ext4 and encryption with 3.3.2 - only swap partition is encrypted.
Selecting encryption - using a swapfile and btrfs - does not create an encrypted installation - both versions affected.
Calamares 3.3.2
Installing in VirtualBox using btrfs - swap with hibernate - encryption
- initrd fails to load /@/boot/amd-ucode.img but fails
$ tree -L 1 /boot
/boot
├── amd-ucode.img
├── grub
├── initramfs-6.6-x86_64-fallback.img
├── initramfs-6.6-x86_64.img
├── linux66-x86_64.kver
├── memtest86+
└── vmlinuz-6.6-x86_64
GRUB_CMDLINE_LINUX_DEFAULT='quiet splash resume=/dev/mapper/luks-25c5600c-7ca2-4da8- 938b-069bbe4f58a5 udev.log_priority=3'
$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 32G 0 disk
├─sda1 8:1 0 23,6G 0 part /var/cache
│ /var/log
│ /home
└─sda2 8:2 0 8,4G 0 part
└─luks-25c5600c-7ca2-4da8-938b-069bbe4f58a5 254:0 0 8,4G 0 crypt [SWAP]
