Help rising D: how to change the gnome activities color with no extensions
i want to change the color of this:
Captura de pantalla de 2020-08-21 15-59-35
also the windows on the rigth have green color, i want to change them too :c
they are green. i want to make them pink, but i have no idea how.
on i3wm i usually go to a doc and them just pick a new color, can i do the same on gnome to change that green thing and make it and the windows selector pink?
Hello and welcome,
What you try to do, will seem difficult once you read this tutorial
But you should be able to get what you are looking for.
