PLZ HOW DO I FIX DIS I’m using Manjaro budgie
@aaaaaaaa
Sorry for the question, but did you try first to check if the right click works with another computer? And did you try another mouse with the computer where it didn’t work?
Maybe it could be that the mouse or the port are broken.
This is how not to get help with this problem..
This is..
I’m on a Asus vivobook 12 2in1 and I don’t know why it doesn’t work
@aaaaaaaa
try this:
Thanks
$ gsettings set org.gnome.desktop.peripherals.touchpad click-method areas
this worrks on me from the terminal
This topic was automatically closed 3 hours after the last reply. New replies are no longer allowed.
