Could some kind soul please walk me through getting my system back.
System boots fine but X server fails to start.
Graphics card: nVidia G92 [GeForce 8800 GTS 512]
Kernel: x86_64 Linux 5.4.85-1-MANJARO
$ cat /var/log/Xorg.0.log
[ 40.515] (--) Log file renamed from "/var/log/Xorg.pid-815.log" to "/var/log/Xorg.0.log"
[ 40.516]
X.Org X Server 1.20.10
[ 40.516] Build Operating System: Linux Manjaro Linux
[ 40.516] Current Operating System: Linux rigsby-manjaro 4.19.163-1-MANJARO #1 SMP Fri Dec 11 17:21:11 UTC 2020 x86_64
[ 40.516] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=3788d943-583e-4f9f-82f2-6b84d1ed636b rw quiet udev.log_priority=3 resume=UUID=dc86afd5-a6e8-4876-9e1c-c9ada34e014e
[ 40.516] Build Date: 16 December 2020 10:33:32PM
[ 40.516]
[ 40.516] Current version of pixman: 0.40.0
[ 40.516] Before reporting problems, check http://wiki.x.org
[ 40.516] Markers: (--) probed, (**) from config file, (==) default setting,
[ 40.516] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Jan 8 19:19:21 2021
[ 40.516] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 40.516] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 40.516] (==) ServerLayout "Layout0"
[ 40.516] (**) |-->Screen "Screen0" (0)
[ 40.516] (**) | |-->Monitor "Monitor0"
[ 40.516] (**) | |-->Device "Device0"
[ 40.516] (**) |-->Input Device "Keyboard0"
[ 40.516] (**) |-->Input Device "Mouse0"
[ 40.516] (==) Automatically adding devices
[ 40.516] (==) Automatically enabling devices
[ 40.516] (==) Automatically adding GPU devices
[ 40.517] (==) Automatically binding GPU devices
[ 40.517] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 40.517] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 40.517] Entry deleted from font path.
[ 40.517] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 40.517] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 40.517] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 40.517] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 40.517] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 40.517] (**) Extension "Composite" is enabled
[ 40.517] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 40.517] (WW) Disabling Keyboard0
[ 40.517] (WW) Disabling Mouse0
[ 40.517] (II) Module ABI versions:
[ 40.517] X.Org ANSI C Emulation: 0.4
[ 40.517] X.Org Video Driver: 24.1
[ 40.517] X.Org XInput driver : 24.1
[ 40.517] X.Org Server Extension : 10.0
[ 40.517] (++) using VT number 1
[ 40.517] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 40.518] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 40.521] (--) PCI:*(1@0:0:0) 10de:0600:10de:0502 rev 162, Mem @ 0xe6000000/16777216, 0xd0000000/268435456, 0xe4000000/33554432, I/O @ 0x00009000/128, BIOS @ 0x????????/131072
[ 40.521] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 40.521] (II) LoadModule: "glx"
[ 40.521] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 40.523] (II) Module glx: vendor="X.Org Foundation"
[ 40.523] compiled for 1.20.10, module version = 1.0.0
[ 40.523] ABI class: X.Org Server Extension, version 10.0
[ 40.523] (II) LoadModule: "nvidia"
[ 40.523] (WW) Warning, couldn't open module nvidia
[ 40.523] (EE) Failed to load module "nvidia" (module does not exist, 0)
[ 40.523] (EE) No drivers available.
[ 40.523] (EE)
Fatal server error:
[ 40.523] (EE) no screens found(EE)
[ 40.523] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 40.523] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 40.523] (EE)
[ 40.523] (EE) Server terminated with error (1). Closing log file.
