I use vim3pro with manjaro arm gnome wayland. Just wanted to know if i can add custom resolution support in wayland session by editing extlinux.conf and adding something like below (bold text):
I saw this from a web link for adding custom resolution using grub.cfg however as vim3 is efi based, so not sure how or where to add this command.
I need to add this custom resolution because i use an old TV with vim3 which does not report proper edid and resolutions to display manager and the available resolutions in wayland all look a bit wrong.
bro it worked for wayland session in gnome and should work in plasma as well. you can try it as well. add any resolution in extlinux.conf and it will appear as selectable in display settings.
@Strit
this thread can be closed, thanks for support you all.
