Hey, I don’t quite know where to ask but here, I’m trying to run Marvel Rivals through Steam, and both Proton-ge-custom-bin 9.22-1 and Proton Experimental doesn’t work, all I get is a Unreal crash error. My specs are below, and ideas on how I can fix it? I’ve tried doing SteamDeck=1 %command% like protondb suggests, for which it also crashes. Have a Proton log for it, but I don’t know what information is needed, so please let me know if possible
OS: Manjaro Linux x86_64
Kernel: 6.11.11-1-MANJARO
DE: Plasma 6.2.4
CPU: 12th Gen Intel i7-12700K (20) @ 4.900GHz
GPU: AMD ATI Radeon RX 7900 XT/7900 XTX/7900 GRE/7900M
GPU: Intel AlderLake-S GT1
Please show
inxi -Farz
mhwd -li -l
Kernel: 6.11.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
root=UUID=7b19a2a8-949f-40ff-948c-bcba9b4daa1d rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Desktop System: Gigabyte product: B760I AORUS PRO v: -CF
serial: <superuser required>
Mobo: Gigabyte model: B760I AORUS PRO v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F2
date: 03/30/2023
Info: model: 12th Gen Intel Core i7-12700K bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 2
microcode: 0x37
Topology: cpus: 1x dies: 1 clusters: 9 cores: 12 threads: 20 mt: 8 tpc: 2
st: 4 smt: enabled cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32
KiB, 4x64 KiB L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB
desc: 1x25 MiB
Speed (MHz): avg: 800 min/max: 800/4900:5000:3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 bogomips: 144440
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel AlderLake-S GT1 vendor: Gigabyte driver: i915 v: kernel
alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
active: none empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:4680 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900
XT/7900 XTX/7900 GRE/7900M] vendor: XFX driver: amdgpu v: kernel
arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2,DP-4,HDMI-A-3
empty: DP-3,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:744c class-ID: 0300
Device-3: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:5
chip-ID: 046d:08e5 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: amdgpu,modesetting unloaded: radeon
alternate: fbdev,vesa dri: radeonsi,iris gpu: amdgpu display-ID: :0
screens: 1
Screen-1: 0 s-res: 4864x1080 s-dpi: 96 s-size: 1283x285mm (50.51x11.22")
s-diag: 1314mm (51.74")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,top-left
model: BenQ EX240N serial: <filter> built: 2022 res: mode: 1920x1080 hz: 60
scale: 100% (1) dpi: 93 gamma: 1.2 size: 526x296mm (20.71x11.65")
diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: DP-4 mapped: DisplayPort-3 pos: top-center model: BenQ GW2480
serial: <filter> built: 2019 res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 604mm (23.8")
Monitor-3: HDMI-A-3 mapped: HDMI-A-2 pos: bottom-r model: Acer AL1511
serial: <filter> built: 2004 res: mode: 1024x768 hz: 75 scale: 100% (1)
dpi: 86 gamma: 1.2 size: 304x228mm (11.97x8.98") diag: 380mm (15")
ratio: 4:3 modes: max: 640x350 min: 720x400
API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
drv: iris device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: iris
surfaceless: drv: iris x11: drv: radeonsi inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XT (radeonsi
navi31 LLVM 18.1.8 DRM 3.59 6.11.11-1-MANJARO) device-ID: 1002:744c
memory: 19.53 GiB unified: no
API: Vulkan v: 1.4.303 layers: 4 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XT (RADV NAVI31) driver: N/A device-ID: 1002:744c
surfaces: xcb,xlib device: 1 type: integrated-gpu name: Intel UHD
Graphics 770 (ADL-S GT1) driver: N/A device-ID: 8086:4680
surfaces: xcb,xlib
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Raptor Lake High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:7a50 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
Device-3: Kingston Hyperx Cloud Flight wireless headset
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-4.2:4 chip-ID: 0951:16c4 class-ID: 0300
Device-4: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.11.11-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Intel Raptor Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:7a70 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0
chip-ID: 8086:15f3 class-ID: 0200
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:12 chip-ID: 8087:0033
class-ID: e001
Local Storage: total: 5.49 TiB used: 2.93 TiB (53.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD BLACK
SN850X HS 1000GB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 620311WD temp: 43.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B4QFXO7 temp: 34.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: A-Data model: USB Flash Drive
size: 28.91 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 146.48 GiB size: 143.13 GiB (97.71%)
used: 78.44 GiB (54.8%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 585.94 GiB size: 575.67 GiB (98.25%)
used: 391.44 GiB (68.0%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
System Temperatures: cpu: 36.0 C mobo: 34.0 C gpu: amdgpu temp: 41.0 C
mem: 50.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Packages: 1554 pm: pacman pkgs: 1528 libs: 389 tools: pamac,yay pm: flatpak
pkgs: 26
1: https://manjaro.kurdy.org/stable/$repo/$arch
2: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
3: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
4: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
5: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
6: http://manjaro.grena.ge/stable/$repo/$arch
7: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
8: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
Memory: total: 32 GiB note: est. available: 31.12 GiB used: 6.54 GiB (21.0%)
Processes: 485 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.42 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.37 running-in: konsole inxi: 3.3.37
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-linux 2024.05.06 true PCI
> 0000:03:00.0 (0300:1002:744c) Display controller ATI Technologies Inc:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:00:02.0 (0300:8086:4680) Display controller Intel Corporation:
First off I’d mention your dual gfx …
Which would mean you would want to use DRI_PRIME=1 or similar to use the amdgpu.
In the case of steam games the launch options
DRI_PRIME=1 %command%
PS
You can also check that prime is working as it should with something like
glxinfo | grep 'renderer string'
DRI_PRIME=1 glxinfo | grep 'renderer string'
According to ProtonDB, this game also needs extra Launch Options in Steam (game Properties) in order to start https://www.protondb.com/app/2767030
//EDIT: also here is the Proton GitHub page for this game Marvel Rivals (2767030) · Issue #8300 · ValveSoftware/Proton · GitHub
Also note that use of
SteamDeck=1even if only launched once using it permanently enables silent launching of the game until game files are verified in Steam, so if you were confused as to why the launcher stops popping up after using this, that’s why.
Both protondb and that environment variable were mentioned in the opening post.
6.11 is EOL, I recommend to use Kernel 6.6 LTS or 6.12 LTS.
I also recommend to disable your iGPU in Bios, if you don’t need it you have a cleaner experience around Linux with a single active GPU.
Creating a Swap Partition can’t hurt also.
Your memory looks a little bid hot btw. did you created this logs right after gaming?
You can also switch to Wayland bottom left, at your login screen (SDDM), when X11 shows problems.
In addition, a fresh Proton Experimental update was released yesterday that fixed Marvel Rivals crashing on non-Steam devices after a recent game update.
You can give it another go and see how it behaves now.
Update: added link to the changelog
