Help needed on Sound Setup / Issues with Youtube while usage of USB Jabra Speaker
Hi everybody, and thanks for reading.
I’m on Testing branch, GNOME, X11, nvidia
When playing youtube videos and playback sound via USB jabra speaker the video stops after 3-4 seconds. It is even not starting smoothly and soft.
As soon as I switch to internal audio, the video and audio playback is fine without any issues.
If I than switch back to USB audio, the video- and audio playback is fine as well…
This is … odd at least.
On Kernel 613 as well as on 612
And I have no clue where to look at and how to solve this and highly appreciate any help.
inxi -Fazy
  Kernel: 6.12.15-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=90a8387b-5c49-4561-b393-f7989aa5cc29 rw apparmor=1
    resume=UUID=62fb2270-d61f-4bad-8915-ef32e2451b02 nmi_watchdog=0 nowatchdog
  Desktop: GNOME v: 47.4 tk: GTK v: 3.24.48 wm: gnome-shell
    tools: gsd-screensaver-proxy avail: cinnamon-screensaver dm: 1: GDM v: 47.0
    2: LightDM v: 1.32.0 note: stopped Distro: Manjaro base: Arch Linux
  Type: Laptop System: Alienware product: Alienware Area-51m v: 1.28.0
  Mobo: Alienware model: Alienware Area-51m v: A00
    serial: <superuser required> part-nu: 08C4 uuid: <superuser required>
    UEFI: Alienware v: 1.28.0 date: 11/03/2023
  ID-1: BAT1 charge: 72.8 Wh (100.0%) condition: 72.8/90.0 Wh (80.9%)
    volts: 12.7 min: 11.4 model: COMPAL PABAS0241231 type: Li-ion
    serial: <filter> status: full
  Info: model: Intel Core i7-9700 bits: 64 type: MCP arch: Coffee Lake
    gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xD (13) microcode: 0x102
  Topology: cpus: 1x dies: 1 clusters: 8 cores: 8 smt: <unsupported> cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 12 MiB
    desc: 1x12 MiB
  Speed (MHz): avg: 4509 min/max: 800/4700 scaling: driver: intel_pstate
    governor: powersave cores: 1: 4509 2: 4509 3: 4509 4: 4509 5: 4509 6: 4509
    7: 4509 8: 4509 bogomips: 48016
  Type: gather_data_sampling mitigation: Microcode (locked)
  Type: retbleed mitigation: Enhanced IBRS
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Dell driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: none empty: DP-2, DP-3, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
    chip-ID: 8086:3e98 class-ID: 0380
  Device-2: NVIDIA TU106M [GeForce RTX 2070 Mobile] vendor: Dell
    driver: nvidia v: 550.144.03 alternate: nouveau,nvidia_drm
    non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx)
    arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
    gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 ports: active: none
    off: HDMI-A-1,eDP-1 empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:1f10
    class-ID: 0300
  Device-3: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.4.1:20
    chip-ID: 046d:08e5 class-ID: 0102 serial: <filter>
  Device-4: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:4 chip-ID: 0bda:5538
  Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.5
    compositor: gnome-shell driver: X: loaded: N/A failed: nvidia
    gpu: nvidia,nvidia-nvswitch note: X driver n/a, try sudo/root
    display-ID: :1 screens: 1
  Screen-1: 0 s-res: 3840x1408 s-dpi: 96 s-size: 1016x373mm (40.00x14.69")
    s-diag: 1082mm (42.61")
  Monitor-1: DP-0 pos: primary,bottom-l res: mode: 1920x1080 hz: 144
    scale: 100% (1) dpi: 128 size: 381x214mm (15x8.43") diag: 437mm (17.2")
    modes: N/A
  Monitor-2: HDMI-0 pos: top-right res: 1920x1080
    size: 527x296mm (20.75x11.65") modes: N/A
    drv: nvidia device: 1 drv: iris gbm: drv: iris surfaceless: drv: nvidia x11:
    drv: nvidia inactive: wayland
  API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: nvidia mesa v: 550.144.03
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2070/PCIe/SSE2
    memory: 7.81 GiB
  Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
  Device-2: NVIDIA TU106 High Definition Audio vendor: Dell
    driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max:
    lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
  Device-3: GN Netcom Jabra Speak2 75 driver: jabra,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.3.1:18
    chip-ID: 0b0e:24f1 class-ID: 0300 serial: <filter>
  Device-4: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.12.15-1-MANJARO status: kernel-api with: aoss
  Server-1: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Realtek Killer E3000 2.5GbE vendor: Dell driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 45:00.0
    chip-ID: 10ec:3000 class-ID: 0200
  IF: enp69s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak]
    vendor: Rivet Networks driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s
    lanes: 1 bus-ID: 46:00.0 chip-ID: 8086:2526 class-ID: 0280
  IF: wlp70s0 state: up mac: <filter>
  Info: services: httpd, NetworkManager, sshd, systemd-timesyncd,
    wpa_supplicant
  Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:11
    chip-ID: 8087:0025 class-ID: e001
  Local Storage: total: 1.16 TiB used: 623.55 GiB (52.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: PM981a NVMe 256GB
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 15305029 temp: 49.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 PRO 1TB
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
  ID-1: / raw-size: 64.57 GiB size: 62.5 GiB (96.80%) used: 27.97 GiB (44.7%)
    fs: ext4 dev: /dev/sda5 maj-min: 8:5
  ID-2: /boot/efi raw-size: 1.05 GiB size: 1.05 GiB (99.80%)
    used: 5.5 MiB (0.5%) fs: vfat dev: /dev/sda3 maj-min: 8:3
  ID-3: /home raw-size: 477.58 GiB size: 469.01 GiB (98.21%)
    used: 329.35 GiB (70.2%) fs: ext4 dev: /dev/sda7 maj-min: 8:7
  Kernel: swappiness: 20 (default 60) cache-pressure: 100 (default) zswap: no
  ID-1: swap-1 type: partition size: 45.26 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda6 maj-min: 8:6
  System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 61 C
  Fan Speeds (rpm): N/A
  Memory: total: 32 GiB note: est. available: 31.03 GiB used: 5.84 GiB (18.8%)
  Processes: 340 Power: uptime: 13m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.35 GiB services: gsd-power,
    power-profiles-daemon, thermald, upowerd Init: systemd v: 257
  Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1673 libs: 410
    tools: gnome-software,pamac,yay pm: flatpak pkgs: 0 Compilers: clang: 19.1.7
    gcc: 14.2.1 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.37
What else as input do you need?
Thanks
Hello @Zauberer-Merlin :wink:
Please check:
sudo tlp-stat --usb
Your Jabra USB device should be set to on instead of auto. I believe it is a problem of powersaveing.
Hi megavolt,
thanks for your reply!
I do not use tlp but power-profiles-daemon, and I understood that tlp AND ppd do not work together quite well.
Any idea how to check USB powersaving in this environment?
power-profiles-daemon is only for CPU throttling, nothing more, but yes, both dont’t work together.
Without TLP you would need to write udev rule, like:
File: /etc/udev/rules.d/99-usb-autosuspend.rules
ACTION=="add", SUBSYSTEM=="usb", ATTR{idVendor}=="0b0e", ATTR{idProduct}=="24f1", ATTR{power/control}="on"
Then apply:
sudo udevadm control --reload &&  sudo udevadm trigger
Anyway, it is much easier with TLP and provides the same as power-profiles-daemon & more.
Hi megavolt,
you did rule it … thanks.
My notebook is primarily running on AC so there was no need for me so far to use TLP.
Installed it yesterday, and
a) notebook life on battery dramatically extended in comparison to power-profile-daemon
b) the audio playback on the jabra usb device is working fine at least this morning
Marked as solved, and thanks for the help!
Best from
themagicianwhogothelpfromaguru
