Hello manjaro community,
I am using manjaro for a long time now…and I am enjoying it.
For quite some time I ignored the long booting up of my machine, I usually do not turn off my laptop, I put it into sleep mode. but I think it’s time now I explore the boot processes and optimise them for better use. This will be a learning curve for me.
I usually try to do it myself, but the system is running well, so I don’t want to mess up anything without expert guidance. so here we go…
I am putting some output here from my console…if any more information requires I will provide it in a jiffy…
[sonal@sonal-80e5 ~]$ systemd-analyze
Startup finished in 4.036s (firmware) + 2.001s (loader) + 3.941s (kernel) + 1min 20.179s (userspace) = 1min 30.158s
graphical.target reached after 1min 19.235s in userspace
[sonal@sonal-80e5 ~]$ systemd-analyze blame
1min 1.426s systemd-swap.service
12.301s udisks2.service
9.095s lvm2-monitor.service
6.555s dev-sda3.device
5.989s polkit.service
3.685s bluetooth.service
3.684s avahi-daemon.service
3.680s NetworkManager.service
3.554s systemd-logind.service
2.825s systemd-journal-flush.service
2.763s systemd-udevd.service
2.708s ModemManager.service
2.449s cups.service
2.399s ufw.service
2.398s systemd-fsck@dev-disk-by\x2duuid-28CB\x2d1A14.service
2.044s upower.service
2.044s apparmor.service
1.310s var-lib-snapd-snap-core18-2066.mount
1.094s var-lib-snapd-snap-core18-1997.mount
1.068s var-lib-snapd-snap-gnome\x2d3\x2d28\x2d1804-145.mount
1.044s systemd-backlight@backlight:intel_backlight.service
1.029s var-lib-snapd-snap-gtk\x2dcommon\x2dthemes-1515.mount
1.015s wpa_supplicant.service
lines 1-23
[sonal@sonal-80e5 ~]$ systemd-analyze critical-chain
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
graphical.target @1min 19.235s
└─multi-user.target @1min 19.235s
└─systemd-swap.service @17.809s +1min 1.426s
└─basic.target @17.673s
└─sockets.target @17.673s
└─dbus.socket @17.673s
└─sysinit.target @17.640s
└─systemd-update-utmp.service @17.601s +37ms
└─systemd-tmpfiles-setup.service @17.078s +505ms
└─local-fs.target @17.077s
└─boot-efi.mount @16.777s +300ms
└─systemd-fsck@dev-disk-by\x2duuid-28CB\x2d1A14.service @14.337s +2.398s
└─local-fs-pre.target @14.199s
└─lvm2-monitor.service @5.104s +9.095s
└─systemd-journald.socket @5.022s
└─system.slice @4.870s
└─-.slice @4.870s
Also, I am using systemd-swap with zswap.
thank you in advance
