Help needed for polkit
Hello,
Just to tell I have the same problem encountered by rob215x following the Manjaro 26.0 update: after its installation via pamac-manager (as I usually do, without any problem), authentication fails on the same way for pamac and pamac-manager.
At first, I’ve tried the polkit fix (although my setup was apparently good). Then I read carefully this whole thread to guess any clue, and the solution found for rob215x does not work for me: I’m already using linux 6.12 for several months!
I don’t see anything relevant in journalctl.
It may be a cat plot. :laughing:
Mod edit:- Please read:
@KittyCat
Always possible, I suppose; cats tend to be quietly subversive, in their feline way.
Please provide your system information as described (below) to help others identify any factors that might be contributing. I’m sure someone will help when they are able.
System Information
For Support purposes it’s better to ask your system directly.
Output of the inxi command will generate information useful for those wishing to help:
inxi -zv8 (short-form)
inxi man pages (manual)
Running `inxi` within a `chroot` environment
Your privacy is respected
  Kernel: 6.12.63-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/vmlinuz-6.12-x86_64 root=/dev/mapper/VG1-root rw
    quiet splash udev.log_priority=3 cpufreq.default_governor=ondemand
    nowatchdog
  Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.21.0
    wm: kwin_wayland with: krunner vt: 1 dm: SDDM Distro: Manjaro
    base: Arch Linux
  Type: Desktop System: ASUS product: N/A v: N/A serial: N/A
  Mobo: ASUSTeK model: PRIME B550M-K v: Rev X.0x serial: <filter>
    part-nu: SKU uuid: 67a7bf24-ab95-a784-66fc-581122bfd83b Firmware: UEFI
    vendor: American Megatrends v: 3902 date: 08/12/2025
  System RAM: total: 16 GiB available: 15.53 GiB used: 4.71 GiB (30.3%)
  Device-1: DIMM_A1 type: no module installed
  Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 8 GiB speed: 3600 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
    width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMK16GX4M2D3600C16 serial: N/A
  Device-3: DIMM_B1 type: no module installed
  Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Slot: 0 type: PCIe status: in use length: long volts: 3.3 bus-ID: 00:03.1
    children: 1: 0b:00.0 class-ID: 0300 type: display 2: 0b:00.1 class-ID: 0403
    type: audio
  Slot: 1 type: PCIe status: available length: short volts: 3.3
    bus-ID: 00:1f.7
  Slot: 2 type: PCIe status: available length: short volts: 3.3
    bus-ID: 00:1f.7
  Info: model: AMD Ryzen 5 5600X socket: AM4 bits: 64 type: MT MCP
    arch: Zen 3+ gen: 3 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
    family: 0x19 (25) model-id: 0x21 (33) stepping: 2 microcode: 0xA201213
    desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 550 min/max: 550/4875 boost: enabled
    base/boost: 3700/4650 scaling: driver: amd-pstate-epp governor: powersave
    volts: 1.1 V ext-clock: 100 MHz cores: 1: 550 2: 550 3: 550 4: 550 5: 550
    6: 550 7: 550 8: 550 9: 550 10: 550 11: 550 12: 550 bogomips: 88833
    xsaves xtopology
    affected
  Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate] vendor: Gigabyte
    driver: nvidia v: 590.48.01 alternate: nouveau,nvidia_drm
    non-free: 550-580.xx+ status: current (as of 2025-11; EOL~2026-12-xx)
    arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1
    empty: DP-2,HDMI-A-1,HDMI-A-2 bus-ID: 0b:00.0 chip-ID: 10de:2489
    class-ID: 0300
    compositor: kwin_wayland driver: X: loaded: nvidia
    gpu: nv_platform,nvidia,nvidia-nvswitch display-ID: 0
  Monitor-1: DP-1 model: PA24A serial: <filter> built: 2020 res:
    mode: 1920x1200 hz: 60 scale: 100% (1) dpi: 94 gamma: 1.2 chroma: red:
    x: 0.655 y: 0.337 green: x: 0.306 y: 0.627 blue: x: 0.145 y: 0.051 white:
    x: 0.314 y: 0.329 size: 518x324mm (20.39x12.76") diag: 611mm (24.1")
    ratio: 16:10 modes: 1920x1200, 1920x1080, 1600x1200, 1680x1050,
    1280x1024, 1440x900, 1280x960, 1366x768, 1152x864, 1280x720, 1024x768,
    800x600, 720x576, 720x480, 640x480
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
    x11: drv: nvidia inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 25.3.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
    memory: 7.81 GiB display-ID: :1.0
  API: Vulkan v: 1.4.335 layers: 2 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 3060 Ti driver: nvidia v: 590.48.01 device-ID: 10de:2489
    surfaces: N/A
  Device-1: NVIDIA GA104 High Definition Audio vendor: Gigabyte
    bus-ID: 0b:00.1 chip-ID: 10de:228b class-ID: 0403
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.12.63-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.9 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Server-3: PulseAudio v: 17.0-98-gb096 status: active (root, process)
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
    vendor: ASUSTeK RTL8111H driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 0a:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: VG: VG1 type: LVM2 size: 931.26 GiB free: 393.76 GiB
  LV-1: boot maj-min: 254:0 type: linear dm: dm-0 size: 512 MiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 931.26 GiB
  LV-2: home maj-min: 254:5 type: linear dm: dm-5 size: 500 GiB
  Components:
  LV-3: log maj-min: 254:3 type: linear dm: dm-3 size: 1024 MiB
  Components:
  LV-4: root maj-min: 254:4 type: linear dm: dm-4 size: 20 GiB
  Components:
  LV-5: swap maj-min: 254:1 type: linear dm: dm-1 size: 4 GiB
  Components:
  LV-6: var maj-min: 254:2 type: linear dm: dm-2 size: 12 GiB
  Components:
  Local Storage: total: 2.73 TiB lvm-free: 393.76 GiB used: 1.2 TiB (44.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 35.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 23d 19h cycles: 1,151
    read-units: 22,491,030 [11.5 TB] written-units: 15,930,089 [8.15 TB]
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD20EZBX-00AYRA0 family: Blue (SMR) size: 1.82 TiB block-size:
    physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD
    rpm: 7200 serial: <filter> fw-rev: 1A01 temp: 29 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 209d 16h cycles: 1151
  ID-1: / raw-size: 20 GiB size: 19.52 GiB (97.59%) used: 12.41 GiB (63.6%)
    fs: ext4 block-size: 4096 B dev: /dev/dm-4 maj-min: 254:4 mapped: VG1-root
    label: N/A uuid: N/A
  ID-2: /boot raw-size: 512 MiB size: 487.2 MiB (95.16%)
    used: 47.5 MiB (9.8%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
    maj-min: 254:0 mapped: VG1-boot label: N/A uuid: N/A
  ID-3: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%)
    used: 370 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: EFI uuid: 88D1-F720
  ID-4: /home raw-size: 500 GiB size: 491.08 GiB (98.22%)
    used: 283.63 GiB (57.8%) fs: ext4 block-size: 4096 B dev: /dev/dm-5
    maj-min: 254:5 mapped: VG1-home label: N/A uuid: N/A
  ID-5: /home/<filter>/Torrents/seed raw-size: N/A size: 213 GiB
    used: 77.08 GiB (36.2%) fs: fuse.sshfs
    remote: transmission@esteban.lan.kittycat.fr:seed
  ID-6: /home/<filter>/Torrents/tasks raw-size: N/A size: 213 GiB
    remote: transmission@esteban.lan.kittycat.fr:tasks
  ID-7: /mnt/data raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 926.66 GiB (50.6%) fs: ext4 block-size: 4096 B dev: /dev/sda1
    maj-min: 8:1 label: data uuid: 27588577-926e-4d50-8615-c08884f7bb5a
  ID-8: /var raw-size: 12 GiB size: 11.74 GiB (97.83%)
    used: 6.78 GiB (57.8%) fs: ext4 block-size: 4096 B dev: /dev/dm-2
    maj-min: 254:2 mapped: VG1-var label: N/A uuid: N/A
  ID-9: /var/log raw-size: 1024 MiB size: 973.4 MiB (95.06%)
    used: 101.7 MiB (10.4%) fs: ext4 block-size: 4096 B dev: /dev/dm-3
    maj-min: 254:3 mapped: VG1-log label: N/A uuid: N/A
  Kernel: swappiness: 50 (default 60) cache-pressure: 100 (default) zswap: no
  ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: 1
    dev: /dev/dm-1 maj-min: 254:1 mapped: VG1-swap label: swap
    uuid: f22e425c-4869-459f-b778-03b714410112
  Device-1: 3-1:2 info: AVerMedia AVerTV Volar Green HD (A835B)
    type: <vendor specific> driver: dvb_usb_af9035,it913x interfaces: 1 rev: 2.0
    chip-ID: 07ca:3835 class-ID: 0000 serial: <filter>
  Device-2: 3-3:3 info: Acer Peripherals (now BenQ ) ZOWIE Gaming Mouse
    type: mouse,keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 1.1
    chip-ID: 04a5:8002 class-ID: 0300
  Device-3: 3-4:4 info: Logitech UltraX Keyboard (Y-BL49) type: keyboard,HID
    chip-ID: 046d:c30e class-ID: 0300
  System Temperatures: cpu: 43.8 C mobo: 39.5 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1455 libs: 449 tools: pamac
    1: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    2: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    3: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    4: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    5: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    6: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    7: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 354
  1: cpu: 2.7% command: firefox pid: 2001 mem: 715.1 MiB (4.4%)
  2: cpu: 1.6% command: kwin_wayland pid: 942 mem: 351.4 MiB (2.2%)
  3: cpu: 0.7% command: steam pid: 2785 mem: 194.5 MiB (1.2%)
  4: cpu: 0.5% command: ./steamwebhelper pid: 2953 mem: 408.4 MiB (2.5%)
  5: cpu: 0.5% command: steamwebhelper pid: 3024 mem: 489.3 MiB (3.0%)
  Memory top: 5 of 354
  1: mem: 715.1 MiB (4.4%) command: firefox pid: 2001 cpu: 2.7%
  2: mem: 582.4 MiB (3.6%) command: thunderbird pid: 1622 cpu: 0.2%
  3: mem: 489.3 MiB (3.0%) command: steamwebhelper pid: 3024 cpu: 0.5%
  4: mem: 468.8 MiB (2.9%) command: plasmashell pid: 1099 cpu: 0.1%
  5: mem: 463.6 MiB (2.9%) command: firefox pid: 2453 cpu: 0.2%
  Processes: 354 Power: uptime: 1h 3m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,upowerd
    Init: systemd v: 258 default: graphical tool: systemctl
  Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Bash (su) v: 5.3.9
    running-in: konsole inxi: 3.3.40
Hello,
Looking at the logs again, it seems a line escaped my attention the first time.
The authentication failure reports this:
polkit-agent-helper-1[19317]: polkit-agent-helper-1: pam_authenticate failed: System error
Hope this can help, this is certainly not expected behavior.
The following is from Known issues and solutions in the most recent Stable Update notification threads; there are a few solutions listed that may help:
I’d advise to be very very careful with the last two commands - especially with the very last one.
Do not forget to revert that later - when it either did not have the desired effect
or even when it had that effect -
because that would permanently disable an important security feature.
stopping the service to troubleshoot is not a problem
a reboot will restore original function
masking it will be permanent across future reboots - and is not intuitive to revert
I spent time to dig the subject this morning.
By stopping the polkit-agent-helper.socket unit + restoring SUID to polkit-agent-helper-1, thus somehow “rolling back” to the previous 126 version, the authent is working.
I believe the problem is related to the new systemd unit template “polkit-agent-helper@.service”: its sandboxing directives may be the root cause. When looking at polkit upstream, there are some recent issues complaining about breakages related to this.
I tried to apply this recent commit via a drop-in for the unit, but it does not change anything.
I think I’m gonna try some changes to relax/adapt the sandboxing config, in order to see if I find something. On the other hand, I remain a bit skeptical: my setup is standard, I don’t see what could prevent PAM to access what it needs here.
@anon33601770 : I couldn’t agree more with your warning! It was not in my intention to mask the socket unit, it’s indeed the kind of config easily forgotten and thus never reverted. I don’t like this, it’s dangerous.
The problem is really tied to the sandboxing configuration of the systemd unit template.
By relaxing ProtectSystem=strict to ProtectSystem=full, the polkit authentication is working.
Current PAM config seems to require a write access on a part of the FS restricted by “strict” config.
At this point I don’t know if this is a Manjaro specific problem, or a more global one that should be reported as an issue to Polkit upstream.
I eventually found the culprit. :laughing:
Long time ago, I applied a customization to my PAM config, by following the advice found here: https://wiki.archlinux.org/title/Security#Lock_out_user_after_three_failed_login_attempts
By default, all user locks are lost after reboot. If your attacker can reboot the machine, it is more secure if locks persist. To make locks persist, change the dir parameter in /etc/security/faillock.conf to /var/lib/faillock
Obviously, /var/lib/faillock is readonly with the ProtectSystem=strict config.
So in order to make this functional without relaxing ProtectSystem=full (my 1st workaround), the proper way is to relax only this path with the setting:
ReadWritePaths=/var/lib/faillock
This point should be added in the Arch wiki article.
But that is the default already.
At least now.
Has this changed over time?
that section of the file looks like this right now:
# The directory where the user files with the failure records are kept.
# The default is /var/run/faillock.
# dir = /var/run/faillock
… you removed the # in front of the third line?
and now you reverted that?
This (above) is the default right now.
And everything works.
No change to that file.
/var/run is a symlink to /run, which is on a tmpfs. In other words, it does not persist across reboots.
@KittyCat proposes changing the path to /var/lib instead, which would indeed make it persist across reboots.
Whether such is desirable is another matter. Everyone gets Butterfinger Syndrome™ from time to time, even the legitimate owner of the machine. :wink:
It seems there was a bit of misunderstanding. I’ll rephrase that.
The default “dir” setting in /etc/security/faillock.conf is indeed “/var/run/faillock”.
With this default config, the polkit problem does not occur.
A weakness of this default is that the faillock state does NOT persist across reboots.
That’s the point of the Arch wiki article I quoted: to make the state persistent, it suggests to change the “dir” setting to “/var/lib/faillock”.
That’s what I’ve done some times ago, and it’s the generator of my polkit problem.
I do NOT propose here to change the Manjaro value to “/var/lib/faillock”.
As @Aragorn tells, this is another matter which could be discussed, if desired. My personal choice to follow this advice is not necessarily the most appropriate, for various reasons.
What I tell is just that given the recent polkit changes, the ArchWiki article should be completed. A precision like "If you choose to do so, you’ll have to relax the polkit agent helper sandbox in order to avoid it to malfunction: add the setting “ReadWritePaths=/var/lib/faillock” to the agent systemd unit “polkit-agent-helper@.service”.
Well, then you should contact the maintainers of the Arch Wiki, because we — i.e. the Manjaro community — have no control over its content or management.
Manjaro has its own Wiki, maintained by members of the Manjaro community, but Arch is a completely separate entity, and for that matter, one that generally speaking looks down on Manjaro.
Ok, I’ll do that.
Unfortunate, but I’m not surprised.
