Help! My laptop won’t boot and it take me to gnu grub version 2.04~manjaro and I tried some from youtube but it said (hd0,gpt2)not found how can I fix this and it said load kernal first when I type boot .
Any solutions please?
Hello @NakedOctopious ![]()
Did you try something like this?
With ls it will list all partitions. Then you need to find the correct one which contains a boot folder like described in the quote above.
It’s still in the grub
Yeah I try it in my case it was in (hd0,1) but after I try normal it’s stay in grub shouldn’t it take me to somewhere else?
Any error when typing insmod normal ?
No it’s finished smoothly
Have you done a windows update or installation?
Anyway, if nothing like that helps… you will need to reinstall grub. Boot a Manjaro live disk and follow the steps here at the link:
