Hello guys,
I use a laptop connected to an external display, I’m using the propriety nvidia driver 570.144 with linux kernel 6.12.28 and gnome. Whenever the laptop goes to sleep, and I use the keyboard or mouse to wake it up, the laptop’s backlight(the power button and the lights on the ports) lights up but I can’t see anything on the display, I can’t access TTY either, the only thing that works is force reboot using the power button. Previously this used to happen once in a while(usually when I disconnect the monitor in sleep), but since yesterday this is happening everytime it wakes up from sleep.
Kernel: 6.12.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=18cbda3a-2411-4046-8285-ea66e40e2d23 rw quiet splash apparmor=1
security=apparmor udev.log_priority=3 mem_sleep_default=deep
nvidia.NVreg_PreserveVideoMemoryAllocations=1
Desktop: GNOME v: 48.1 tk: GTK v: 3.24.49 wm: gnome-shell
base: Arch Linux
Type: Laptop System: LENOVO product: 82Y3 v: Legion Slim 7 16IRH8
serial: <superuser required> Chassis: type: 10 v: Legion Slim 7 16IRH8
Mobo: LENOVO model: LNVNB161216 v: SDK0T76485 WIN
serial: <superuser required> part-nu: LENOVO_MT_82Y3_BU_idea_FM_Legion Slim
7 16IRH8 uuid: <superuser required> UEFI: LENOVO v: M0CN40WW
date: 01/07/2025
ID-1: BAT1 charge: 68.0 Wh (78.9%) condition: 86.2/99.9 Wh (86.2%)
volts: 16.6 min: 15.6 model: Sunwoda L22D4PC3 type: Li-poly serial: <filter>
status: not charging cycles: 120
System RAM: total: 32 GiB available: 31.14 GiB used: 4.9 GiB (15.7%)
Device-1: Controller0-ChannelA-DIMM0 type: DDR5 detail: synchronous
size: 16 GiB speed: spec: 5600 MT/s actual: 5200 MT/s volts: curr: 1
width (bits): data: 64 total: 64 manufacturer: SK Hynix
part-no: HMCG78AGBSA092N serial: <filter>
Device-2: Controller1-ChannelA type: DDR5 detail: synchronous size: 16 GiB
speed: spec: 5600 MT/s actual: 5200 MT/s volts: curr: 1 width (bits):
data: 64 total: 64 manufacturer: Samsung part-no: M425R2GA3BB0-CWMOL
serial: N/A
Info: model: 13th Gen Intel Core i9-13900H bits: 64 type: MST AMCP
arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
process: Intel 7 (10nm) family: 6 model-id: 0xBA (186) stepping: 2
microcode: 0x4128
Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2
st: 8 smt: enabled cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32
KiB, 8x64 KiB L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB
desc: 1x24 MiB
Speed (MHz): avg: 400 min/max: 400/5200:5400:4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 bogomips: 119840
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pconfig
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand
rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
conditional; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: NVIDIA AD106M [GeForce RTX 4070 Max-Q / Mobile] vendor: Lenovo
driver: nvidia v: 570.144 alternate: nouveau,nvidia_drm
non-free: 550-570.xx+ status: current (as of 2025-04) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s ports: active: none off: eDP-1
empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2860
class-ID: 0300
Device-2: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:3 chip-ID: 30c9:00ac
Display: x11 server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
compositor: gnome-shell driver: X: loaded: nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
gpu: nvidia,nvidia-nvswitch display-ID: :1 screens: 1
Screen-1: 0 s-res: 4320x3840 s-size: <missing: xdpyinfo>
Monitor-1: DP-0.1.1 pos: right res: mode: 3840x2160 hz: 60
scale: 177% (0.5625) to: 2160x3840 dpi: 163 size: 597x336mm (23.5x13.23")
diag: 685mm (26.97") modes: N/A
Monitor-2: DP-0.8 pos: primary,left res: mode: 3840x2160 hz: 60
Monitor-3: DP-2 size-res: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia platforms: device: 0
drv: nvidia device: 1 drv: nouveau device: 2 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.144
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4070 Laptop
GPU/PCIe/SSE2 memory: 7.81 GiB
Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
x11: xprop,xrandr
Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51ca class-ID: 0403
Device-2: NVIDIA AD106M High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:22bd
class-ID: 0403
API: ALSA v: k6.12.28-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8852CE PCIe 802.11ax Wireless Network vendor: Lenovo
driver: rtw89_8852ce v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
port: 3000 bus-ID: 36:00.0 chip-ID: 10ec:c852 class-ID: 0280
IF: wlp54s0 state: up mac: <filter>
Device-2: Realtek USB 10/100/1G/2.5G LAN driver: r8152 type: USB rev: 3.2
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-2.4.2:5
chip-ID: 0bda:8156 class-ID: 0000 serial: <filter>
IF: enp0s20f0u2u4u2 state: down mac: <filter>
Device-3: Realtek USB 10/100/1G/2.5G LAN driver: r8152 type: USB rev: 3.2
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-2.4.4.4.2:10
IF: eth1 state: down mac: <filter>
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:8 chip-ID: 0bda:5852
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 953.87 GiB used: 77.29 GiB (8.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS001TEJ9X115N
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 51020A12 temp: 40.9 C
scheme: GPT
ID-1: / raw-size: 125 GiB size: 122.48 GiB (97.98%) used: 77.24 GiB (63.1%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: 18cbda3a-2411-4046-8285-ea66e40e2d23
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 47.4 MiB (18.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM_DRV uuid: 288D-C40D
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 826.65 GiB fs: ntfs
label: Windows-SSD uuid: 32308E63308E2E43
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1.95 GiB fs: ntfs
label: WINRE_DRV uuid: 788A8F278A8EE14C
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Hub-4: 3-2:2 info: Fresco Logic USB2.0 Hub ports: 6 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 1d5c:5801
Hub-5: 3-2.4:5 info: Microchip (formerly SMSC) USB4206 Smart Hub ports: 5
rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0424:4206
Hub-6: 3-2.4.1:7 info: Microchip (formerly SMSC) USB4206 Smart Hub
ports: 5 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
chip-ID: 0424:4252 class-ID: 0900
Device-1: 3-2.4.1.1:10 info: Logitech Logi Bolt Receiver
type: keyboard,mouse,HID driver: hid-generic,hid-multitouch,usbhid
interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 98mA chip-ID: 046d:c548 class-ID: 0300
Device-2: 3-2.4.1.5:13 info: Microchip (formerly SMSC) USB2 Controller Hub
type: Hub driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 chip-ID: 0424:7240 class-ID: 0000
Hub-7: 3-2.4.3:9 info: Microchip (formerly SMSC) USB4216 Smart Hub
ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
chip-ID: 0424:4216 class-ID: 0900
Device-1: 3-2.4.3.4:14 info: Microchip (formerly SMSC) USB2 Controller Hub
Hub-8: 3-2.4.4:11 info: Fresco Logic USB2.0 Hub ports: 6 rev: 2.1
Hub-9: 3-2.4.4.4:15 info: Microchip (formerly SMSC) USB4206 Smart Hub
chip-ID: 0424:4206 class-ID: 0900
Hub-10: 3-2.4.4.4.1:16 info: Microchip (formerly SMSC) USB4206 Smart Hub
Device-1: 3-2.4.4.4.1.5:19 info: Microchip (formerly SMSC) USB2
Controller Hub type: Hub driver: N/A interfaces: 1 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0424:7240
class-ID: 0000
Hub-11: 3-2.4.4.4.3:17 info: Microchip (formerly SMSC) USB4216 Smart Hub
Device-1: 3-2.4.4.4.3.1:20 info: Apple Aluminium Keyboard (ANSI)
type: keyboard,mouse driver: apple,usbhid interfaces: 2 rev: 2.0
chip-ID: 05ac:024f class-ID: 0301
Device-2: 3-2.4.4.4.3.4:21 info: Microchip (formerly SMSC) USB2
class-ID: 0000
Device-3: 3-2.4.4.4.5:18 info: Microchip (formerly SMSC) USB2 Controller
Hub type: HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0424:7260
class-ID: 0300
Device-4: 3-2.4.5:12 info: Microchip (formerly SMSC) USB2 Controller Hub
class-ID: 0300
Device-5: 3-7:3 info: Luxvisions Innotech Integrated Camera type: video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 30c9:00ac class-ID: fe01
serial: <filter>
Device-6: 3-8:4 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 04f3:0c4b class-ID: 0000
Device-7: 3-9:6 info: Integrated Express ITE Device(8258) type: keyboard
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:c987 class-ID: 0301
Device-8: 3-10:8 info: Realtek Bluetooth Radio type: bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 0bda:5852 class-ID: e001 serial: <filter>
Hub-12: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-13: 4-2:2 info: Intel USB3.0 Hub ports: 4 rev: 3.2
speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 8087:0b40
Hub-14: 4-2.4:3 info: Microchip (formerly SMSC) USB7206 Smart Hub ports: 4
rev: 3.2 speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1
chip-ID: 0424:7206 class-ID: 0900
Hub-15: 4-2.4.1:4 info: Microchip (formerly SMSC) USB7206 Smart Hub
ports: 4 rev: 3.2 speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1
chip-ID: 0424:7252 class-ID: 0900
Device-1: 4-2.4.2:5 info: Realtek USB 10/100/1G/2.5G LAN type: Network
driver: r8152 interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
mode: 3.2 gen-1x1 power: 256mA chip-ID: 0bda:8156 class-ID: 0000
serial: <filter>
Hub-16: 4-2.4.3:6 info: Microchip (formerly SMSC) USB7216 Smart Hub
ports: 3 rev: 3.2 speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1
chip-ID: 0424:7216 class-ID: 0900
Hub-17: 4-2.4.4:7 info: Intel USB3.0 Hub ports: 4 rev: 3.2
Hub-18: 4-2.4.4.4:8 info: Microchip (formerly SMSC) USB7206 Smart Hub
Hub-19: 4-2.4.4.4.1:9 info: Microchip (formerly SMSC) USB7206 Smart Hub
Device-1: 4-2.4.4.4.2:10 info: Realtek USB 10/100/1G/2.5G LAN
type: Network driver: r8152 interfaces: 1 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 256mA
Hub-20: 4-2.4.4.4.3:11 info: Microchip (formerly SMSC) USB7216 Smart Hub
System Temperatures: cpu: 41.8 C mobo: N/A gpu: nvidia temp: 45 C
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1405 libs: 351 tools: gnome-software,pamac,yay
pm: flatpak pkgs: 0
1: http://mirror.fcix.net/manjaro/stable/$repo/$arch
2: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
4: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 426
1: cpu: 21.3% command: kgx pid: 6310 mem: 177.6 MiB (0.5%)
2: cpu: 17.4% command: vivaldi-bin pid: 4129 mem: 429.0 MiB (1.3%)
3: cpu: 16.4% command: vivaldi-bin pid: 4289 mem: 555.9 MiB (1.7%)
4: cpu: 13.8% command: vivaldi-bin pid: 5745 mem: 261.9 MiB (0.8%)
5: cpu: 13.3% command: vivaldi-bin pid: 4194 mem: 504.0 MiB (1.5%)
Memory top: 5 of 426
1: mem: 555.9 MiB (1.7%) command: vivaldi-bin pid: 4289 cpu: 16.4%
2: mem: 514.8 MiB (1.6%) command: vivaldi-bin pid: 4240 cpu: 4.7%
3: mem: 504.0 MiB (1.5%) command: vivaldi-bin pid: 4194 cpu: 13.3%
4: mem: 429.0 MiB (1.3%) command: vivaldi-bin pid: 4129 cpu: 17.4%
5: mem: 416.5 MiB (1.3%) command: vivaldi-bin pid: 5993 cpu: 10.1%
Processes: 426 Power: uptime: 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.42 GiB services: gsd-power,upowerd
Compilers: gcc: 15.1.1 alt: 13/14 Shell: Bash v: 5.2.37 running-in: kgx
inxi: 3.3.38
