Wherever the conf file is in the /etc path, can a dir named configuration and its final .d added?
for example in path
/etc/ufw/sysctlc.conf
mkdir /etc/ufw/sysctlc.conf.d/
nano /etc/ufw/sysctlc.conf.d/my.conf
Does this method true to /etc route?
for example in path
No. The program have to support it. Or if it is a bash script, you can source the files:
source /path/dir.d/*.conf
Otherwise, check the manpages:
man -k . | grep -E "[a-z_-]+\.d\s"
Thank you
