Hello.
Where can I get help with downgrading an aur package? I use Nordvpn and since the last update it no longer connects. I contacted their support and they reported that “The issue seems to be caused by the different implementation of this app as it was created by the Arch Linux community and not us. In order to resolve this issue, we would recommend you to contact the Arch Linux community that created this app (…)”
I would like to try returning to the previous package.
I am pretty sure the above is only for repo packages. The aur packages are build from a pkgbuild “recipe”. So you either need the old version of the recipe and the old source files, or if it was a re-build the old version might be in your cache, if you have not clean it. I am unfortunately not sure if many older versions are kept by default or just the last one and where the buildcache was.
“If you want to see the change between newer versions just check the Github page.”
“Please DO NOT flag this package as out-of-date until there’s the official release on Github’s page.”
“Maybe the announcement is delayed, but wait for some other possible forward release, which is patching the previous one, before the actual publishing.”
Note from 3.17.3v:
Caution! This version needs heed while using it and should be avoided. I strongly advice downgrading to 3.17.2 and wait for a new version or patching. Some big problems are:
There’s DNS leak present. Your original ISP servers can be exposed, as reported already on #343 issue.
Unable to connect on nordvpn servers. Your journal might show the follow output: networker setting dns: setting dns with resolvectl: setting dns with resolvectl: Failed to set DNS configuration: Could not activate remote peer: activation request failed: unknown unit.: exit status 1
After restarting resolve with systemctl restart systemd-resolved.service you may get it working again, enough for connecting normally, as reported, but not exclusively an ARM platform issue, on #342.
I’ve never found a “proper” way to do this. The only thing I’ve been able to do was to get a list of all the files in the package, then restore them from my last backup before I upgraded it.
You can do this with the normal repos too, the question was for the aur, if that cache keep more than one version (does it respect the pamac.conf too in case of pamac as helper for example).
