This is my second time posting here, If I make an egregious etiquette error, please let me know, and I’ll try and update / edit my post.
Here’s the problem: My onboard audio controller doesn’t seem to be working. This is a pc I built maybe 6 ish years ago, and as far as I know it never has worked properly. I previously had windows on it (never activated), and I couldn’t really diagnose the issue. I tried taking the PC apart, but everything looked like it was wired properly. I’m hoping there’s some linux tool that can help me check for hardware faults, or something like that.
I’ve been having a slew of unrelated hardware and software issues, because I didn’t do the best job when I built this thing (I was 16 at the time), but I like to think that I know (mostly) what I’m doing now, after having worked with PC’s and Linux operating systems for a while, building my own arch and gentoo installs from scratch, etc. That said, any help / suggestions are welcome. I’m desperate here.
Here’s the output of inxi -Fazy:
Kernel: 6.6.8-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
root=UUID=6f7f115f-be6f-4f1a-adec-4a9b404807de rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop Mobo: ASRock model: X570 Phantom Gaming 4
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: P2.20
date: 11/25/2019
Info: model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64 type: MCP
arch: Zen/Zen+ note: check gen: 1 level: v3 note: check built: 2019
process: GF 12nm family: 0x17 (23) model-id: 0x18 (24) stepping: 1
microcode: 0x8108109
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2312 high: 2955 min/max: 1400/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2112 2: 2955
3: 2949 4: 1235 bogomips: 28811
Type: spec_rstack_overflow mitigation: SMT disabled
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: lanes: 16 ports: active: DVI-D-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 01:00.0 chip-ID: 1002:67df
class-ID: 0300 temp: 37.0 C
Display: x11 server: X.Org v: 21.1.10 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: DVI-D-1 model: Acer X233H serial: <filter> built: 2009
res: 1920x1080 dpi: 96 gamma: 1.2 size: 510x287mm (20.08x11.3")
diag: 585mm (23") ratio: 16:9 modes: max: 1920x1080 min: 720x400
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 580 Series (polaris10
LLVM 16.0.6 DRM 3.54 6.6.8-2-MANJARO) device-ID: 1002:67df memory: 7.81 GiB
unified: no
API: Vulkan v: 1.3.274 layers: N/A device: 0 type: discrete-gpu name: AMD
Radeon RX 580 Series (RADV POLARIS10) driver: mesa radv
v: 23.1.9-manjaro1.1 device-ID: 1002:67df surfaces: xcb,xlib
Device-1: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 08:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.6.8-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: off with: pipewire-media-session
status: active tools: pw-cli
Device-1: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
IF: enp4s0 state: down mac: <filter>
Device-2: TP-Link TL-WN722N v2/v3 [Realtek RTL8188EUS] driver: rtl8xxxu
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2
chip-ID: 2357:010c class-ID: 0000 serial: <filter>
IF: wlp5s0f1u4 state: up mac: <filter>
Local Storage: total: 931.51 GiB used: 22.29 GiB (2.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: HD103SI size: 931.51 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s tech: N/A
serial: <filter> fw-rev: 1118 scheme: MBR
ID-1: / raw-size: 441.07 GiB size: 433.08 GiB (98.19%) used: 22.29 GiB (5.1%)
fs: ext4 dev: /dev/sda4 maj-min: 8:4
System Temperatures: cpu: 48.6 C mobo: N/A gpu: amdgpu temp: 35.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1485
Processes: 266 Uptime: 1h 9m wakeups: 0 Memory: total: 8 GiB
available: 7.68 GiB used: 3.96 GiB (51.6%) Init: systemd v: 254
Packages: 1177 pm: pacman pkgs: 1164 libs: 341 tools: pamac pm: flatpak
pkgs: 13 Shell: Zsh v: 5.9 default: Bash v: 5.2.21 running-in: konsole
inxi: 3.3.31
Let me know if you have any questions, or if I can provide any additional info. Thanks!
