Hello,
I am relatively new to Linux and am requesting a little hand-holding here.
I have a laptop with an iGPU as well as a discrete Nvidia GPU. As a result, fox external displays to function, I must run the following command:
optimus-manager --switch nvidia --no-confirm
I would like for this command to run when the machine starts. My understanding is I should do this with a systemd unit so I have attempted to create one.
I have created a script file setnvidia.sh containing the following:
#!/bin/zsh
I also created the systemd unit file setnvidia.service which contains the following:
[Unit]
Description=SetNVGPU
After=optimus-manager.service
After=sddm.service
After=display-manager.service
[Service]
Type=oneshot
ExecStart=/usr/local/bin/setnvidia.sh
[Install]
WantedBy=multi-user.target
The service appears to enable and start properly, but upon rebooting the desired effect is not achieved.
systemctl status setnvidia.service
yields:
setnvidia.service - SetNVGPU
Loaded: loaded (/etc/systemd/system/setnvidia.service; enabled; preset: disabled)
Active: failed (Result: exit-code) since Thu 2024-04-18 00:44:25 PDT; 2min 5s ago
Process: 690 ExecStart=/usr/local/bin/setnvidia.sh (code=exited, status=1/FAILURE)
Main PID: 690 (code=exited, status=1/FAILURE)
CPU: 36ms
Apr 18 00:44:25 zirconium setnvidia.sh[691]: ERROR: a GPU setup was initiated but Xorg post-start hook did not run.
Apr 18 00:44:25 zirconium setnvidia.sh[691]: Log at /var/log/optimus-manager/switch/switch-20240418T004425.log
Apr 18 00:44:25 zirconium setnvidia.sh[691]: If your login manager is GDM, make sure to follow those instructions:
Apr 18 00:44:25 zirconium setnvidia.sh[691]: https://github.com/Askannz/optimus-manager#important--gnome-and-gdm-users
Apr 18 00:44:25 zirconium setnvidia.sh[691]: If your display manager is neither GDM, SDDM nor LightDM, or if you don't use one, read the wiki:
Apr 18 00:44:25 zirconium setnvidia.sh[691]: https://github.com/Askannz/optimus-manager/wiki/FAQ,-common-issues,-troubleshooting
Apr 18 00:44:25 zirconium setnvidia.sh[691]: Cannot execute command because of previous errors.
Apr 18 00:44:25 zirconium systemd[1]: setnvidia.service: Main process exited, code=exited, status=1/FAILURE
Apr 18 00:44:25 zirconium systemd[1]: setnvidia.service: Failed with result 'exit-code'.
Apr 18 00:44:25 zirconium systemd[1]: Failed to start SetNVGPU.
var/log/optimus-manager/switch/switch-20240418T004425.log contains:
[6] INFO: # Xorg pre-start hook
[6] INFO: Previous state was: {'type': 'pending_pre_xorg_start', 'requested_mode': 'integrated', 'current_mode': None}
[6] INFO: Requested mode is: integrated
[28] INFO: Available modules: ['nouveau', 'nvidia', 'nvidia_drm', 'nvidia_modeset', 'nvidia_uvm']
[28] INFO: Unloading modules ['nvidia_drm', 'nvidia_modeset', 'nvidia_uvm', 'nvidia'] (if loaded)
[31] INFO: switching=none, nothing to do
[81] INFO: Writing to /etc/X11/xorg.conf.d/10-optimus-manager.conf
[81] INFO: Writing state {'type': 'pending_post_xorg_start', 'switch_id': '20240418T004425', 'requested_mode': 'integrated'}
[81] INFO: Xorg pre-start hook completed successfully.
[5] INFO: # Xorg post-start hook
[106] INFO: Running /etc/optimus-manager/xsetup-integrated.sh
[116] INFO: Writing state {'type': 'done', 'switch_id': '20240418T004425', 'current_mode': 'integrated'}
[117] INFO: Xorg post-start hook completed successfully.
