Hello everyone. My older Nvidia GT 730M apparently needs cuda-9.0 for working with hashcat. I first tried with yay and it failed (as my yay often does) so I tried in the pamac gui (which usually succeeds if yay fails). It failed as well. Cuda is huge and I’m in the US with limited hotspot so I figured I’d better ask before I run out. Each try uses over a gig of my hotspot data. I’d sure appreciate a hand with this.
Here’s my inxi…
[user@user-laptop ~]$ sudo inxi -Fmxxxz
[sudo] password for user:
System: Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: Xfce 4.16.0
tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
base: Arch Linux
Machine: Type: Laptop System: LENOVO product: 20AN009CUS v: ThinkPad T440p serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20AN009CUS v: 0B98401 PRO serial: <filter> UEFI: LENOVO
v: GLETA1WW (2.55 ) date: 04/20/2020
Battery: ID-1: BAT0 charge: 50.1 Wh (100.0%) condition: 50.1/56.2 Wh (89.3%) volts: 12.4
min: 10.8 model: LGC 45N1147 type: Li-ion serial: <filter> status: Full
Memory: RAM: total: 15.52 GiB used: 3.01 GiB (19.4%)
Array-1: capacity: 16 GiB slots: 2 EC: None max-module-size: 8 GiB note: est.
Device-1: ChannelA-DIMM0 size: 8 GiB speed: 1600 MT/s type: DDR3 detail: synchronous
bus-width: 64 bits total: 64 bits manufacturer: 1324 part-no: H641GU67G1600G
serial: N/A
Device-2: ChannelB-DIMM0 size: 8 GiB speed: 1600 MT/s type: DDR3 detail: synchronous
bus-width: 64 bits total: 64 bits manufacturer: 0000 part-no: N/A serial: N/A
CPU: Info: Quad Core model: Intel Core i7-4700MQ bits: 64 type: MT MCP arch: Haswell
rev: 3 cache: L1: 64 KiB L2: 6 MiB L3: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 38333
Speed: 2395 MHz min/max: 800/3400 MHz volts: 0.8 V ext-clock: 100 MHz
Core speeds (MHz): 1: 2395 2: 2395 3: 2395 4: 2398 5: 2395 6: 2395 7: 2395 8: 2395
Graphics: Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0416 class-ID: 0300
Device-2: NVIDIA GK208M [GeForce GT 730M] vendor: Lenovo driver: nvidia v: 390.141
bus-ID: 02:00.0 chip-ID: 10de:1290 class-ID: 0300
Device-3: Acer SunplusIT Integrated Camera type: USB driver: uvcvideo bus-ID: 2-12:6
chip-ID: 5986:0268 class-ID: 0e02
Display: server: X.Org 1.20.10 driver: loaded: modesetting,nvidia
resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: GeForce GT 730M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.141
direct render: Yes
Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
vendor: Lenovo ThinkPad T440p driver: snd_hda_intel v: kernel bus-ID: 00:03.0
chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Lenovo ThinkPad T440p driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
Sound Server-1: ALSA v: k5.9.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: no
Network: Device-1: Intel Ethernet I217-LM vendor: Lenovo ThinkPad T440p driver: e1000e
v: kernel port: 4080 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel port: 3000 bus-ID: 04:00.0
chip-ID: 8086:08b2 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-3: Qualcomm Atheros AR9271 802.11n type: USB driver: N/A bus-ID: 2-6:19
chip-ID: 0cf3:9271 class-ID: ff00 serial: <filter>
Drives: Local Storage: total: 232.89 GiB used: 112.95 GiB (48.5%)
ID-1: /dev/sda vendor: Western Digital model: WDS250G2B0A-00SM50 size: 232.89 GiB
speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 90WD scheme: GPT
Partition: ID-1: / size: 31.25 GiB used: 13.78 GiB (44.1%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 98.4 MiB used: 298 KiB (0.3%) fs: vfat dev: /dev/sda1
ID-3: /home size: 180.89 GiB used: 99.16 GiB (54.8%) fs: ext4 dev: /dev/sda4
Swap: ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3
Sensors: System Temperatures: cpu: 54.0 C mobo: 0.0 C gpu: nvidia temp: 51 C
Fan Speeds (RPM): cpu: 0
Info: Processes: 243 Uptime: 9h 23m wakeups: 1 Init: systemd v: 247 Compilers: gcc: 10.2.0
alt: 6 Packages: pacman: 1255 Shell: Bash (sudo) v: 5.1.0 running-in: xfce4-terminal
inxi: 3.3.03
With yay, it failed saying I had no C Compiler in $PATH. It gave me the option of GCC6 or GCC6-multilib and I chose the multilib simply because it sounded better. It ended like this…
==> Extracting sources...
-> Extracting libart_lgpl-2.3.21.tar.bz2 with bsdtar
==> Sources are ready.
==> Making package: libart-lgpl 2.3.21-5 (Wed 24 Mar 2021 01:53:04 AM CDT)
==> WARNING: Using existing $srcdir/ tree
==> Starting build()...
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for gcc... no
checking for cc... no
checking for cl.exe... no
configure: error: in `/home/user/.cache/yay/libart-lgpl/src/libart_lgpl-2.3.21':
configure: error: no acceptable C compiler found in $PATH
See `config.log' for more details.
==> ERROR: A failure occurred in build().
Aborting...
error making: libart-lgpl
Then, with the Pamac GUI, it ended like this…
50 73.9M 50 37.0M 0 0 2073k 0 0:00:36 0:00:18 0:00:18 1567k
51 73.9M 51 37.7M 0 0 1981k 0 0:00:38 0:00:19 0:00:19 1152k
51 73.9M 51 37.7M 0 0 1899k 0 0:00:39 0:00:20 0:00:19 743k
55 73.9M 55 40.9M 0 0 1994k 0 0:00:37 0:00:21 0:00:16 1447k
58 73.9M 58 43.5M 0 0 2021k 0 0:00:37 0:00:22 0:00:15 2023k
61 73.9M 61 45.4M 0 0 2019k 0 0:00:37 0:00:23 0:00:14 1812k
64 73.9M 64 47.8M 0 0 2038k 0 0:00:37 0:00:24 0:00:13 2283k
67 73.9M 67 50.0M 0 0 2044k 0 0:00:37 0:00:25 0:00:12 2678k
71 73.9M 71 52.5M 0 0 2066k 0 0:00:36 0:00:26 0:00:10 2372k
74 73.9M 74 54.9M 0 0 2079k 0 0:00:36 0:00:27 0:00:09 2336k
77 73.9M 77 57.5M 0 0 2101k 0 0:00:36 0:00:28 0:00:08 2477k
81 73.9M 81 59.9M 0 0 2114k 0 0:00:35 0:00:29 0:00:06 2481k
84 73.9M 84 62.5M 0 0 2133k 0 0:00:35 0:00:30 0:00:05 2576k
87 73.9M 87 64.6M 0 0 2133k 0 0:00:35 0:00:31 0:00:04 2481k
90 73.9M 90 66.8M 0 0 2137k 0 0:00:35 0:00:32 0:00:03 2448k
94 73.9M 94 69.5M 0 0 2155k 0 0:00:35 0:00:33 0:00:02 2459k
97 73.9M 97 71.9M 0 0 2162k 0 0:00:34 0:00:34 --:--:-- 2441k
100 73.9M 100 73.9M 0 0 2171k 0 0:00:34 0:00:34 --:--:-- 2413k
-> Found cuda-9.0.sh
-> Found cuda-9.0.conf
-> Found cuda-findgllib_mk.diff
==> Validating source files with sha512sums...
cuda_9.0.176_384.81_linux-run ... Passed
cuda_9.0.176.1_linux-run ... Passed
cuda_9.0.176.2_linux-run ... Passed
cuda_9.0.176.3_linux-run ... Passed
cuda_9.0.176.4_linux-run ... Passed
cuda-9.0.sh ... Passed
cuda-9.0.conf ... Passed
cuda-findgllib_mk.diff ... Passed
==> Starting prepare()...
cuda_9.0.176_384.81_linux-run: line 436: exec: -t: invalid option
exec: usage: exec [-cl] [-a name] [command [argument ...]] [redirection ...]
==> ERROR: A failure occurred in prepare().
Aborting...
Seems to me if yay can’t find the C Compiler…well I don’t know.
I still have both the terminal and Pamac GUI open if any more info is needed…
