Hello, I just managed to install Windows 10 today. I’ve been running Manjaro fine on its own on this system for about 3-4 months now. I needed Windows for Keysight engineering programs for school. I knew that Manjaro and Windows were not going to cooperate well together so I physically removed my M.2 drive containing Manjaro from my system when installing Windows. After the Windows install finished, I plugged my M.2 with Manjaro back in and tried to boot. I end up at a black screen with a message like this:
mount: /sys/firmware/efi/efivars: unknown filesystem type 'efivarfs'.
You are in emergency mode. After logging in, type "journalctl -xb" to view system logs, "systemctl reboot" to reboot, "systemcrl default" or "exit" to boot into default mode.
I’ve been trying various troubleshooting steps mentioned online. Additionally I do have a live-usb with Manjaro installed. I can run
manjarochroot -a
and all my files are still in place on the drive. I’ve ran
sudo update-grub
a few times already.
The output of this command is a bit mysterious to me:
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.15-rt-x86_64
Found initrd image: /boot/amd-ucode.img /bootinitramfs-5.13-x86_64.img
Found initrd fallback image: /boot/initramfs-5.13-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrs fallback image: /boot/amd-ucode.img /boot/initramfs-5.100x86_64-fallback,img
Its output will be used to detect bootbale binaries on them and create new boot entries.
Found Winodes Boot Manger on /dev/nvme1n1p1@/efi/Microsoft/Boot/bootmgfw.efi
Found memtest86+ image: /boot/memtest86+ image: /boot/memtest86+/memtest.bin
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
This is worrisome to me since /dev/nvme0n1 contains Manjaro on my system. It’s kinda hard to type the output of lsblk but I’ll try:
nvme0n1
→ nvme0n1p1 part /
→ nvme0n1p2 part /home
→ nvme0n1p3 part /boot/efi
nvme1n1
→ nvme1n1p1
→ nvme1n1p2
→ nvme1n1p3
→ nvme1n1p4
nvme1n1 in its entirety is a Windows 10 install. As such I think I can ignore it for troublshooting most likely.
Any help to getting my system back to operational is greatly appreciated!
It’s frustrating that manjaro-chroot -a works and gives me all the files back. I think the solution is gonna be something simple to fix in grub that I don’t know.
I should mention that I am running all these commands in the emergency mode CLI. The result of the first input is:
Installing for x86_64-efi platform.
EFI variables are not supported on this system.
grub-install: error: efibootmgr failed to register the boot entry: No such file or directory
Unfortunately, running sudo update-grub gives the exact same message as before.
What does it mean by EFI variables are unsupported? I guess this matches my original problem of unknown filesystem type ‘efivarfs’
As a sidenote --I do have access to all my files too from emergency mode surprisingly. I dropped the shell script in there. Maybe that isn’t that surprising, but I’ve used Linux for about ~2 years now so I’m still learning.
Ok I’m back on the live-usb. I’m using debug mode:
[manjaro-gnome /]# grub-install --target=x86_64-efi --efi-directory=/boot --bootloader-id=Manjaro --recheck --debug
grub-install: info: cannot open `/boot/grub/device.map': No such file or directory.
grub-install: info: /dev/nvme0n1p1 is not present.
grub-install: info: Looking for /dev/nvme0n1p1.
grub-install: info: /dev/nvme0n1 is a parent of /dev/nvme0n1p1.
grub-install: info: /dev/nvme0n1p1 starts from 2050048.
grub-install: info: opening the device hostdisk//dev/nvme0n1.
grub-install: info: drive = 0.
grub-install: info: the size of hostdisk//dev/nvme0n1 is 1953525168.
grub-install: info: Scanning for DISKFILTER devices on disk hostdisk//dev/nvme0n1.
grub-install: info: Scanning for mdraid1x devices on disk hostdisk//dev/nvme0n1.
grub-install: info: Scanning for mdraid09_be devices on disk hostdisk//dev/nvme0n1.
grub-install: info: Scanning for mdraid09 devices on disk hostdisk//dev/nvme0n1.
grub-install: info: Scanning for dmraid_nv devices on disk hostdisk//dev/nvme0n1.
grub-install: info: Scanning for ldm devices on disk hostdisk//dev/nvme0n1.
grub-install: info: scanning hostdisk//dev/nvme0n1 for LDM.
grub-install: info: no LDM signature found.
grub-install: info: Scanning for lvm devices on disk hostdisk//dev/nvme0n1.
grub-install: info: no LVM signature found.
grub-install: info: Partition 0 starts from 2050048.
grub-install: info: /dev/nvme0n1p1 is present.
grub-install: error: /boot doesn't look like an EFI partition.
I think so. That is the default I think when I boot. It always displays this at the top:
I’m debating on a reinstall from the live-usb. Making it not reformat home and only install root and /boot/efi. But that’s also risky I think and it might not solve the issue.
