I found many issues on the forum related to mine; I apologize for making one more post, but none of those threads allowed me to solve the issue.
When I plug in my (jack) headset, or my Bluetooth headset, which are both equipped with a microphone, the two options for the microphone in settings (“Headphones Stereo Microphone” and “Digital Microphones”) do not change (they’re already there when nothing is plugged in).
What’s more, I made sure that “Digital Microphone” picks up sounds from my laptops built-in mics, and “Headphones Stereo Microphones” never picks anything, no matter what is or isn’t plugged in.
Here’s the output of inxi -zv8
Kernel: 6.10.13-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
root=UUID=ccf1bd5a-96d0-48ce-b352-228bc163669c rw quiet splash apparmor=1
security=apparmor resume=UUID=f18e1fcf-8c17-46de-84fc-4c543a06dffe
udev.log_priority=3
Desktop: GNOME v: 46.5 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 46.2 Distro: Manjaro
base: Arch Linux
Type: Laptop System: ASUSTeK product: Zenbook UX3402ZA_UX3402ZA v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: UX3402ZA v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: UX3402ZA.310
date: 12/14/2022
ID-1: BAT0 charge: 53.5 Wh (71.0%) condition: 75.4/75.4 Wh (100.0%)
volts: 8.0 min: 8.0 model: ASUSTeK UX3402ZA type: Li-ion serial: <filter>
status: charging cycles: 28
System RAM: total: 16 GiB available: 15.25 GiB used: 4.34 GiB (28.4%)
Array-1: capacity: 16 GiB slots: 8 modules: 8 EC: None
max-module-size: 2 GiB note: est.
Device-1: Controller0-ChannelA type: LPDDR5 detail: synchronous
size: 2 GiB speed: spec: 6400 MT/s actual: 4800 MT/s volts: curr: 0.5
min: 0.5 max: 0.5 width (bits): data: 16 total: 16 manufacturer: SK Hynix
part-no: H9JCNNNCP3MLYR-N6E serial: N/A
Device-2: Controller0-ChannelB type: LPDDR5 detail: synchronous
Device-3: Controller0-ChannelC type: LPDDR5 detail: synchronous
Device-4: Controller0-ChannelD type: LPDDR5 detail: synchronous
Device-5: Controller1-ChannelA type: LPDDR5 detail: synchronous
Device-6: Controller1-ChannelB type: LPDDR5 detail: synchronous
Device-7: Controller1-ChannelC type: LPDDR5 detail: synchronous
Device-8: Controller1-ChannelD type: LPDDR5 detail: synchronous
Info: model: 12th Gen Intel Core i7-1260P bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x434
Topology: cpus: 1x dies: 1 clusters: 6 cores: 12 threads: 16 mt: 4 tpc: 2
st: 8 smt: enabled cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32
KiB, 8x64 KiB L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 448 min/max: 400/4700:3400 scaling: driver: intel_pstate
governor: powersave cores: 1: 448 2: 448 3: 448 4: 448 5: 448 6: 448 7: 448
8: 448 9: 448 10: 448 11: 448 12: 448 13: 448 14: 448 15: 448 16: 448
bogomips: 79888
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb
pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp
rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
xtopology xtpr
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel alternate: xe arch: Gen-12.2 process: Intel 10nm
built: 2021-22+ ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4,
HDMI-A-1 bus-ID: 0000:00:02.0 chip-ID: 8086:46a6 class-ID: 0300
Device-2: Sonix USB2.0 FHD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:3 chip-ID: 3277:0010
class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3296x2060 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: Samsung 0x4171 built: 2020 res: 3296x2060 hz: 90
dpi: 277 gamma: 1.2 chroma: red: x: 0.682 y: 0.322 green: x: 0.235 y: 0.725
blue: x: 0.137 y: 0.047 white: x: 0.314 y: 0.329
size: 302x189mm (11.89x7.44") diag: 356mm (14") ratio: 16:10
modes: 2880x1800
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.4-arch1.0.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a6 memory: 7.45 GiB unified: yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: ASUSTeK
driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel, snd_soc_avs,
snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8
class-ID: 0401
API: ALSA v: k6.10.13-3-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0033
class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 179.93 GiB (37.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 3400 MTFDKBA512TFH
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: P7MA002 temp: 38.9 C
scheme: GPT
ID-1: / raw-size: 459.87 GiB size: 451.58 GiB (98.20%)
used: 179.93 GiB (39.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: ccf1bd5a-96d0-48ce-b352-228bc163669c
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 763E-75C2
ID-1: swap-1 type: partition size: 16.78 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: f18e1fcf-8c17-46de-84fc-4c543a06dffe
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-6:2 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 04f3:0c6e class-ID: 0000
Device-2: 3-8:3 info: Sonix USB2.0 FHD UVC WebCam type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 3277:0010 class-ID: 0e02
Device-3: 3-10:4 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0033 class-ID: e001
System Temperatures: cpu: 49.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: 1739 pm: pacman pkgs: 1733 libs: 484 tools: gnome-software,pamac
pm: flatpak pkgs: 6
1: https://mirrors2.manjaro.org/stable/$repo/$arch
2: https://mirror.koddos.net/manjaro/stable/$repo/$arch
3: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
4: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
5: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
6: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
8: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
Processes:
CPU top: 5 of 377
1: cpu: 20.0% command: tracker-extract-3 pid: 57521 mem: 31.0 MiB (0.1%)
2: cpu: 11.4% command: gnome-shell pid: 1932 mem: 348.9 MiB (2.2%)
3: cpu: 9.3% command: vivaldi-bin pid: 57002 mem: 243.7 MiB (1.5%)
4: cpu: 8.5% command: Xorg pid: 1834 mem: 93.9 MiB (0.6%)
5: cpu: 7.1% command: gnome-control-center pid: 16890
mem: 245.2 MiB (1.5%)
Memory top: 5 of 377
1: mem: 361.9 MiB (2.3%) command: vivaldi-bin pid: 5261 cpu: 1.1%
2: mem: 351.0 MiB (2.2%) command: vivaldi-bin pid: 5256 cpu: 0.8%
3: mem: 348.9 MiB (2.2%) command: gnome-shell pid: 1932 cpu: 11.4%
4: mem: 340.2 MiB (2.1%) command: vivaldi-bin pid: 2841 cpu: 1.3%
5: mem: 328.0 MiB (2.1%) command: vivaldi-bin pid: 5263 cpu: 0.1%
Processes: 377 Power: uptime: 2h 30m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 6.09 GiB services: gsd-power,upowerd
Init: systemd v: 256 default: graphical tool: systemctl
Compilers: gcc: 14.2.1 alt: 13 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.36
Here are some additional outputs:
> systemctl --user status pipewire.service
● pipewire.service - PipeWire Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; enabled; preset: enabled)
Active: active (running) since Fri 2024-10-11 19:00:12 CEST; 11min ago
Invocation: 15ddf0a8b814434f9436ead4fbf424f7
TriggeredBy: ● pipewire.socket
Main PID: 56031 (pipewire)
Tasks: 3 (limit: 18696)
Memory: 8.3M (peak: 9.2M)
CPU: 10.220s
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
└─56031 /usr/bin/pipewire
oct. 11 19:00:12 take systemd[1777]: Started PipeWire Multimedia Service.
> systemctl --user status pipewire.socket
● pipewire.socket - PipeWire Multimedia System Sockets
Loaded: loaded (/usr/lib/systemd/user/pipewire.socket; enabled; preset: enabled)
Active: active (running) since Fri 2024-10-11 19:00:12 CEST; 12min ago
Invocation: c809ecafc93f43b09930e6c01ab49d8a
Triggers: ● pipewire.service
Listen: /run/user/1000/pipewire-0 (Stream)
/run/user/1000/pipewire-0-manager (Stream)
CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pipewire.socket
oct. 11 19:00:12 take systemd[1777]: Listening on PipeWire Multimedia System Sockets.
And finally I double checked that on my other Manjaro laptop, both jack and Bluetooth headset work normally (their mics are detected alright).
Both computers are equally up to date.
Thanks!
