I have recently my Manjaro system to 5.15.81-1-MANJARO #1 SMP PREEMPT, x86_64 GNU/Linux system. Almost immediately after the update, the sound is having problems. The laptop speaker and the headphone jack (using a heaphone) is not working, or works sometimes sporadically and then stops.
Some commands and their outputs are:
lspci | grep
00:1f.3 Multimedia audio controller: Intel Corporation Tiger Lake-LP Smart Sound Technology Audio Controller (rev 20)
inxi -A
Device-1: Intel Tiger Lake-LP Smart Sound Audio
driver: sof-audio-pci-intel-tgl
Sound API: ALSA v: k5.15.81-1-MANJARO running: yes
Sound Server-1: PulseAudio v: 16.1 running: yes
Sound Server-2: PipeWire v: 0.3.61 running: yes
pactl info | grep -i "server name"
Server Name: pulseaudio
systemctl --user restart pulseaudio
Failed to connect to bus: Operation not permitted
systemctl enable pulseaudio
Failed to enable unit: Unit file pulseaudio.service does not exist.
systemctl start pulseaudio.service
Failed to start pulseaudio.service: Unit pulseaudio.service not found.
systemctl --user status pulseaudio
● pulseaudio.service - Sound Service
Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; disabled; preset>
Active: active (running) since Tue 2022-12-06 10:54:01 CET; 14min ago
TriggeredBy: ● pulseaudio.socket
Main PID: 1247 (pulseaudio)
Tasks: 11 (limit: 18694)
Memory: 21.2M
CPU: 1.342s
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pulsea>
├─1247 /usr/bin/pulseaudio --daemonize=no --log-target=journal
└─1403 /usr/lib/pulse/gsettings-helper
Dec 06 10:54:00 arjun-lifebooku7411 systemd[1153]: Starting Sound Service...
Dec 06 10:54:01 arjun-lifebooku7411 pulseaudio[1247]: Path Capture is not a vol>
Dec 06 10:54:01 arjun-lifebooku7411 pulseaudio[1247]: stat('/etc/pulse/default.>
Dec 06 10:54:01 arjun-lifebooku7411 systemd[1153]: Started Sound Service.
Dec 06 10:54:01 arjun-lifebooku7411 pulseaudio[1247]: Could not find org.bluez.>
systemctl -l --no-pager --user status pulseaudio.{socket,service}
● pulseaudio.socket - Sound System
Loaded: loaded (/usr/lib/systemd/user/pulseaudio.socket; enabled; preset: enabled)
Active: active (running) since Tue 2022-12-06 10:53:59 CET; 15min ago
Until: Tue 2022-12-06 10:53:59 CET; 15min ago
Triggers: ● pulseaudio.service
Listen: /run/user/1000/pulse/native (Stream)
CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pulseaudio.socket
Dec 06 10:53:59 arjun-lifebooku7411 systemd[1153]: Listening on Sound System.
Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; disabled; preset: enabled)
Active: active (running) since Tue 2022-12-06 10:54:01 CET; 15min ago
Memory: 21.2M
CPU: 1.342s
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pulseaudio.service
Dec 06 10:54:01 arjun-lifebooku7411 pulseaudio[1247]: Path Capture is not a volume or mute control
Dec 06 10:54:01 arjun-lifebooku7411 pulseaudio[1247]: stat('/etc/pulse/default.pa.d'): No such file or directory
Dec 06 10:54:01 arjun-lifebooku7411 pulseaudio[1247]: Could not find org.bluez.BatteryProviderManager1.RegisterBatteryProvider(), is bluetoothd started with experimental features enabled (-E flag)?
I have switched from pulseaudio to pipewire:
sudo pacman -Rdd pulseaudio
sudo pacman -S pipewire-{jack,alsa,pulse}
systemctl --user enable --now pipewire pipewire-pulse pipewire-media-session
systemctl --user status pipewire
● pipewire.service - PipeWire Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; enabled; preset: e>
Active: active (running) since Tue 2022-12-06 11:41:08 CET; 1h 35min ago
TriggeredBy: ● pipewire.socket
Main PID: 1342 (pipewire)
Tasks: 2 (limit: 18694)
Memory: 19.2M
CPU: 565ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewi>
└─1342 /usr/bin/pipewire
Dec 06 11:41:08 arjun-lifebooku7411 systemd[1333]: Started PipeWire Multimedia >
Dec 06 11:41:08 arjun-lifebooku7411 pipewire[1342]: mod.rt: Can't find xdg-port>
Dec 06 11:41:08 arjun-lifebooku7411 pipewire[1342]: mod.rt: found session bus b>
I also tried installing “manjaro-pipewire” with:
pacman -Syu manjaro-pipeline
But still, the audio does not work as intended. What happens is say I watch a video on YouTube, and when I switch to a different video, the noise goes away and I need to run this command:
systemctl --user restart pipewire.service pipewire.socket pipewire-pulse.service pipewire-pulse.socket pipewire-media-session.service
which seems to bring back the sound temporarily. Each time I pause, the sound goes away and I need to rerun the command above. This is a horrible hack.
Any idea(s) on how to fix it?
