Hi, just rebooted my computer & ran the two diagnostic info commands, then the commands to disable auto mute, then the diagnostics again. Sound still did not work after doing this:
[jay@jay-desktop ~]$ amixer -c0
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 64
Mono: Playback 44 [69%] [-20.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 64 [100%] [0.00dB] [on]
Front Right: Playback 64 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Front',0
Mono:
Simple mixer control 'Front Mic',0
Limits: Playback 0 - 31
Mono:
Front Left: Playback 0 [0%] [-34.50dB] [off]
Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Front Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Surround',0
Mono:
Simple mixer control 'Center',0
Mono: Playback 64 [100%] [0.00dB] [on]
Simple mixer control 'LFE',0
Simple mixer control 'Side',0
Mono:
Simple mixer control 'Line',0
Mono:
Simple mixer control 'Line Boost',0
Limits: 0 - 3
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 46
Front Left: Capture 28 [61%] [12.00dB] [on]
Front Right: Capture 28 [61%] [12.00dB] [on]
Simple mixer control 'Capture',1
Front Left: Capture 0 [0%] [-16.00dB] [off]
Front Right: Capture 0 [0%] [-16.00dB] [off]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
Simple mixer control 'Input Source',0
Capabilities: cenum
Items: 'Front Mic' 'Rear Mic' 'Line'
Item0: 'Front Mic'
Simple mixer control 'Input Source',1
Capabilities: cenum
Item0: 'Front Mic'
Simple mixer control 'Loopback Mixing',0
Capabilities: enum
Item0: 'Disabled'
Simple mixer control 'Rear Mic',0
Mono:
Simple mixer control 'Rear Mic Boost',0
Limits: 0 - 3
[jay@jay-desktop ~]$ inxi -Fazy
Kernel: 5.7.17-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
root=UUID=931f69ec-d5a5-4887-99db-217e673991ea rw quiet apparmor=1
security=apparmor resume=UUID=3c0c3dce-8454-443f-a945-e85e35cd8b13
udev.log_priority=3
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Manjaro Linux
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK (MS-7C02) v: 1.0
serial: <filter> UEFI: American Megatrends v: 1.D1 date: 10/28/2019
Topology: Quad Core model: AMD Ryzen 5 2400G with Radeon Vega Graphics
bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 11 (17)
stepping: N/A microcode: 8101016 L2 cache: 2048 KiB
bogomips: 57625
Speed: 2701 MHz min/max: 1600/3600 MHz boost: enabled Core speeds (MHz):
1: 2791 2: 2993 3: 1357 4: 2762 5: 2743 6: 2925 7: 1364 8: 2778
disabled, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Sapphire Limited Nitro+ driver: amdgpu v: kernel bus ID: 10:00.0
chip ID: 1002:67df
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: amdgpu
FAILED: ati unloaded: modesetting,vesa alternate: fbdev display ID: :0
screens: 1
Screen-1: 0 s-res: 5360x1440 s-dpi: 96 s-size: 1418x381mm (55.8x15.0")
s-diag: 1468mm (57.8")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
Monitor-2: HDMI-A-1 res: 3440x1440 hz: 60 dpi: 110
size: 797x333mm (31.4x13.1") diag: 864mm (34")
OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.37.0
5.7.17-2-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.6 direct render: Yes
Device-1: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 27:00.6 chip ID: 1022:15e3
Device-2: Audio-Technica type: USB driver: hid-generic,snd-usb-audio,usbhid
bus ID: 1-1.1:4 chip ID: 0909:001c
Device-3: Microsoft LifeCam VX-700 type: USB driver: snd-usb-audio,uvcvideo
bus ID: 1-1.2:6 chip ID: 045e:0770
Sound Server: ALSA v: k5.7.17-2-MANJARO
vendor: Micro-Star MSI driver: r8169 v: kernel port: e000 bus ID: 22:00.0
chip ID: 10ec:8168
IF: enp34s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.41 TiB used: 358.51 GiB (24.8%)
ID-1: /dev/nvme0n1 vendor: Sabrent model: N/A size: 953.87 GiB block size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter>
rev: RKT303.3 scheme: GPT
ID-2: /dev/sda vendor: Crucial model: CT525MX300SSD1 size: 489.05 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: R031 scheme: GPT
ID-1: / raw size: 919.06 GiB size: 903.63 GiB (98.32%)
used: 358.51 GiB (39.7%) fs: ext4 dev: /dev/nvme0n1p2
ID-1: swap-1 type: partition size: 34.51 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3
System Temperatures: cpu: 50.6 C mobo: N/A gpu: amdgpu temp: 40 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 825
Processes: 343 Uptime: 1m Memory: 31.37 GiB used: 3.12 GiB (9.9%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1418 lib: 366
flatpak: 0 Shell: Bash v: 5.0.18 running in: yakuake inxi: 3.1.05
[jay@jay-desktop ~]$ amixer --card=0 sset 'Auto-Mute Mode' Disabled
Capabilities: enum
Item0: 'Disabled'
Mono:
Mono:
Mono:
Mono:
Limits: 0 - 3
Mono:
Mono:
Mono:
Limits: 0 - 3
Capabilities: enum
Item0: 'Disabled'
Capabilities: cenum
Item0: 'Front Mic'
Capabilities: cenum
Item0: 'Front Mic'
Capabilities: enum
Item0: 'Disabled'
Mono:
Limits: 0 - 3
[jay@jay-desktop ~]$ sudo alsactl store
[sudo] password for jay:
Here’s my amixer output after re-plugging my headphones:
Mono: Playback 60 [94%] [-4.00dB] [on]
Mono:
Mono:
Front Left: Playback 254 [100%] [-0.20dB]
Front Right: Playback 254 [100%] [-0.20dB]
Mono:
Mono:
Limits: 0 - 3
Mono:
Front Left: Playback 0 [0%] [-64.00dB] [off]
Front Right: Playback 0 [0%] [-64.00dB] [off]
Mono: Playback 0 [0%] [-64.00dB] [off]
Mono:
Mono:
Limits: 0 - 3
Capabilities: enum
Item0: 'Disabled'
Capabilities: cenum
Item0: 'Front Mic'
Capabilities: cenum
Item0: 'Front Mic'
Capabilities: enum
Item0: 'Disabled'
Mono:
Limits: 0 - 3
