Headphones not being detected properly
Hi all,
I am using the default audio program (Pipewire) and I’m having issues with my wired headphones.
When I plug the headphones in, and select the headphones in Volume Control (they are listed as unplugged) I can hear sound coming through the headphones.
However, I ran a speaker test (speaker-test -c2 -l1) and got the following:
speaker-test 1.2.13
Playback device is default
Stream parameters are 48000Hz, S16_LE, 2 channels
Using 16 octaves of pink noise
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 64 to 1048576
Period size range from 32 to 524288
Periods = 4
Unable to set hw params for playback: Input/output error
Setting of hwparams failed: Input/output error
I have tried two browsers. Firefox produces no sound (when streaming). Chromium produces the following error:
Audio renderer error. Please restart your computer
I am wondering why this is. I would like the headphones to be detected (fully) by Pipewire and to be able to listen to audio regardless of application.
BTW the version of Manjaro I’m using is 25.0.0 (Zetar) and I have an XFCE desktop environment.
Any thoughts?
i believe the sounddevice with the headphone should be declared as “Analog Stereo Duplex”.
maybe thats the problem.
you can set it in pavucontrol or in my case in kde sound system settings.
Unfortunately XFCE does not seem to offer this option. Only to select from speakers OR headphones (unplugged)
Please post more information about audio cards and sinks (outputs) with headphones plugged in
pactl list cards
pactl list sinks
Sure!
pactl list cards
Card #48
	Driver: alsa
	Owner Module: n/a
	Properties:
		api.acp.auto-port = "false"
		api.alsa.card = "0"
		api.alsa.card.longname = "HDA Intel PCH at 0x6001120000 irq 134"
		api.alsa.card.name = "HDA Intel PCH"
		api.alsa.path = "hw:0"
		api.alsa.split-enable = "true"
		api.alsa.use-acp = "true"
		api.dbus.ReserveDevice1.Priority = "-20"
		device.api = "alsa"
		device.bus = "pci"
		device.description = "Built-in Audio"
		device.enum.api = "udev"
		device.icon_name = "audio-card-analog-pci"
		device.name = "alsa_card.pci-0000_00_1f.3"
		device.nick = "HDA Intel PCH"
		device.plugged.usec = "8321350"
		device.product.id = "0x4dc8"
		device.product.name = "Jasper Lake HD Audio"
		device.subsystem = "sound"
		sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
		device.vendor.id = "0x8086"
		media.class = "Audio/Device"
		spa.object.id = "2"
		factory.id = "15"
		client.id = "47"
		object.id = "48"
		object.serial = "48"
		object.path = "alsa:acp:PCH"
		alsa.card = "0"
		alsa.long_card_name = "HDA Intel PCH at 0x6001120000 irq 134"
		alsa.mixer_name = "Realtek ALC236"
		alsa.components = "HDA:10ec0236,103c88e9,00100002 HDA:8086281a,80860101,00100000"
		alsa.id = "PCH"
		device.string = "0"
	Profiles:
		off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
		output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: yes)
		output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: yes)
		output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5965, available: no)
		output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: no)
		output:hdmi-stereo-extra1+input:analog-stereo: Digital Stereo (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: no)
		output:hdmi-stereo-extra2+input:analog-stereo: Digital Stereo (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: no)
		output:hdmi-stereo-extra3+input:analog-stereo: Digital Stereo (HDMI 4) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: no)
		output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
		output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: no)
		output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (sinks: 1, sources: 0, priority: 5700, available: no)
		output:hdmi-surround+input:analog-stereo: Digital Surround 5.1 (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 865, available: no)
		output:hdmi-surround71+input:analog-stereo: Digital Surround 7.1 (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 865, available: no)
		output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
		output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
		output:hdmi-surround-extra1+input:analog-stereo: Digital Surround 5.1 (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
		output:hdmi-surround71-extra1+input:analog-stereo: Digital Surround 7.1 (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
		output:hdmi-surround-extra2+input:analog-stereo: Digital Surround 5.1 (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
		output:hdmi-surround71-extra2+input:analog-stereo: Digital Surround 7.1 (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
		output:hdmi-surround-extra3+input:analog-stereo: Digital Surround 5.1 (HDMI 4) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
		output:hdmi-surround71-extra3+input:analog-stereo: Digital Surround 7.1 (HDMI 4) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
		output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
		input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: yes)
		pro-audio: Pro Audio (sinks: 5, sources: 1, priority: 1, available: yes)
	Active Profile: output:analog-stereo+input:analog-stereo
	Ports:
		analog-input-internal-mic: Internal Microphone (type: Mic, priority: 8900, latency offset: 0 usec, availability group: Legacy 1, availability unknown)
			Properties:
				port.type = "mic"
				port.availability-group = "Legacy 1"
				card.profile.port = "0"
			Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-surround+input:analog-stereo, output:hdmi-surround71+input:analog-stereo, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1+input:analog-stereo, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2+input:analog-stereo, output:hdmi-stereo-extra3+input:analog-stereo, output:hdmi-surround-extra3+input:analog-stereo, output:hdmi-surround71-extra3+input:analog-stereo
		analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, availability group: Legacy 2, not available)
			Properties:
				port.type = "mic"
				port.availability-group = "Legacy 2"
				card.profile.port = "1"
		analog-output-speaker: Speakers (type: Speaker, priority: 10000, latency offset: 0 usec, availability group: Legacy 3, availability unknown)
			Properties:
				port.type = "speaker"
				port.availability-group = "Legacy 3"
				card.profile.port = "2"
			Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo
		analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 4, not available)
			Properties:
				port.type = "headphones"
				port.availability-group = "Legacy 4"
				card.profile.port = "3"
		hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, availability group: Legacy 5, not available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "Legacy 5"
				card.profile.port = "4"
			Part of profile(s): output:hdmi-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-surround, output:hdmi-surround+input:analog-stereo, output:hdmi-surround71, output:hdmi-surround71+input:analog-stereo
		hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, availability group: Legacy 6, not available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "Legacy 6"
				card.profile.port = "5"
			Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1, output:hdmi-surround71-extra1+input:analog-stereo
		hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, availability group: Legacy 7, not available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "Legacy 7"
				card.profile.port = "6"
			Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2, output:hdmi-surround71-extra2+input:analog-stereo
		hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, availability group: Legacy 8, not available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "Legacy 8"
				card.profile.port = "7"
			Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-stereo-extra3+input:analog-stereo, output:hdmi-surround-extra3, output:hdmi-surround-extra3+input:analog-stereo, output:hdmi-surround71-extra3, output:hdmi-surround71-extra3+input:analog-stereo
pactl list sinks
Sink #57
	State: RUNNING
	Description: Built-in Audio Analog Stereo
	Driver: PipeWire
	Sample Specification: s32le 2ch 48000Hz
	Channel Map: front-left,front-right
	Owner Module: 4294967295
	Mute: no
	Volume: front-left: 41942 /  64% / -11.63 dB,   front-right: 41942 /  64% / -11.63 dB
	        balance 0.00
	Base Volume: 65536 / 100% / 0.00 dB
	Monitor Source: alsa_output.pci-0000_00_1f.3.analog-stereo.monitor
	Latency: 0 usec, configured 0 usec
	Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
	Properties:
		alsa.card = "0"
		alsa.class = "generic"
		alsa.device = "0"
		alsa.id = "ALC236 Analog"
		alsa.name = "ALC236 Analog"
		alsa.resolution_bits = "16"
		alsa.subclass = "generic-mix"
		alsa.subdevice = "0"
		alsa.subdevice_name = "subdevice #0"
		alsa.sync.id = "00000000:00000000:00000000:00000000"
		api.alsa.path = "front:0"
		api.alsa.pcm.card = "0"
		api.alsa.pcm.stream = "playback"
		audio.channels = "2"
		audio.position = "FL,FR"
		card.profile.device = "7"
		device.api = "alsa"
		device.class = "sound"
		device.icon_name = "audio-card-analog"
		device.id = "48"
		device.profile.description = "Analog Stereo"
		device.profile.name = "analog-stereo"
		device.routes = "2"
		factory.name = "api.alsa.pcm.sink"
		media.class = "Audio/Sink"
		node.name = "alsa_output.pci-0000_00_1f.3.analog-stereo"
		node.nick = "ALC236 Analog"
		node.pause-on-idle = "false"
		object.path = "alsa:acp:PCH:7:playback"
		port.group = "playback"
		priority.driver = "1009"
		priority.session = "1009"
		factory.id = "19"
		clock.quantum-limit = "8192"
		client.id = "47"
		node.driver = "true"
		node.loop.name = "data-loop.0"
		library.name = "audioconvert/libspa-audioconvert"
		object.id = "57"
		object.serial = "57"
		node.max-latency = "16384/48000"
		api.alsa.period-size = "1024"
		api.alsa.period-num = "32"
		api.alsa.headroom = "0"
		api.alsa.card = "0"
		device.bus = "pci"
		spa.object.id = "2"
		device.string = "0"
	Ports:
		analog-output-speaker: Speakers (type: Speaker, priority: 10000, availability group: Legacy 3, availability unknown)
		analog-output-headphones: Headphones (type: Headphones, priority: 9900, availability group: Legacy 4, not available)
	Active Port: analog-output-speaker
	Formats:
		pcm
Try this
But beware I didn’t analyse your issue in depth.
Data in post #5 confirms OP system is using PipeWire
pactl list sinks
Sink #57
	State: RUNNING
	Driver: PipeWire
Yes. I really don’t want to switch to PulseAudio. Is there a way to use 3.5 mm jack headphones with Pipewire?
I believe these are installed aleady…but thanks
Headphone output port is shown as not available
Card #48
	Ports:
I suggest install alsa-tools and use hdajacksensetest to confirm jack detection for headphone output is not working
sudo hdajacksensetest -c 0
and use hdajackretask to disable headphone jack detection
Can’t select wired headphone as output device in KDE audio panel
sudo hdajackretask --card=0
Enable Advanced override and Override for the Green Headphone, Front side jack
Change Jack Detection to Not Present and click on Install boot override
Reboot system to load jack override
Thanks!!!
I can at least manually select sound output devices now. And get sound via the headphones.
Is there a way to have the machine to detect and select sound output devices (ie when a pair of 3.5 mm headphones is connected to the machine, it selects the headphones automatically and re-
selects the speakers when the headphones are disconnected)?
If the headphone jack detection is not working system cannot detect when headphones are plugged in to mute speakers automatically. The optimal solution is to replace the headphone jack to get jack detection working again.
If jack detection is disabled this command should mute or unmute ALSA mixer speaker output:
amixer -qc PCH sset 'Speaker' toggle
Command can be used with a keyboard shortcut or a custom launcher to mute or unmute speakers manually
