Headphones not appearing
Hello,
I am having an issue where my headphones are not detected when plugged into the 3.5mm jack on Manjaro. They work perfectly on Windows, so I know the hardware is functional. I’m using Easyeffects.
 Kernel: 6.6.119-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
   root=UUID=16927a7c-d50e-4eb3-8f2c-49a49f84cd75 rw quiet splash acpi=force
   apm=power_off
 Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.21.0
 Type: Laptop System: Micro-Star product: Pulse GL66 12UGKV v: REV:1.0
 Mobo: Micro-Star model: MS-1583 v: REV:1.0 serial: <superuser required>
   part-nu: 1583.1 uuid: <superuser required> Firmware: UEFI vendor: American
   Megatrends LLC. v: E1583IMS.106 date: 01/18/2022
 ID-1: BAT1 charge: 34.6 Wh (92.5%) condition: 37.4/52 Wh (71.9%) volts: 12.1
   min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A charging:
   status: not charging cycles: N/A
 Info: model: 12th Gen Intel Core i7-12700H bits: 64 type: MST AMCP
   arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
   process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
   microcode: 0x43A
 Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2
   st: 8 smt: enabled cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32
   KiB, 8x64 KiB L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB
   desc: 1x24 MiB
 Speed (MHz): avg: 1261 min/max: 400/4600:4700:3500 scaling:
   driver: intel_pstate governor: powersave cores: 1: 1261 2: 1261 3: 1261
   4: 1261 5: 1261 6: 1261 7: 1261 8: 1261 9: 1261 10: 1261 11: 1261 12: 1261
   13: 1261 14: 1261 15: 1261 16: 1261 17: 1261 18: 1261 19: 1261 20: 1261
   bogomips: 107560
 Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
 Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
   PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
 Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: Micro-Star MSI
   driver: i915 v: kernel arch: Xe process: Intel 10nm built: 2021-22+ ports:
   active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:46a6 class-ID: 0300
 Device-2: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q]
   vendor: Micro-Star MSI driver: nvidia v: 590.48.01
   alternate: nouveau,nvidia_drm non-free: 550-580.xx+ status: current (as of
   2025-11; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
   built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4
   speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: none
   bus-ID: 01:00.0 chip-ID: 10de:249d class-ID: 0300
   compositor: kwin_wayland driver: X: loaded: modesetting,nvidia dri: iris
   gpu: i915,nvidia,nvidia-nvswitch d-rect: 3840x1080 display-ID: 0
 Monitor-1: HDMI-A-1 pos: right model: 24E6C serial: <filter> built: 2023
   res: mode: 1920x1080 hz: 120 scale: 100% (1) dpi: 93 gamma: 1.2
   size: 522x294mm (20.55x11.57") diag: 599mm (23.6") ratio: 16:9 modes:
   max: 1920x1080 min: 640x480
 Monitor-2: eDP-1 pos: primary,left model: AU Optronics 0xaf90 built: 2020
   res: mode: 1920x1080 hz: 144 scale: 100% (1) dpi: 142 gamma: 1.2
   size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
   modes: 1920x1080
   drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
   surfaceless: drv: nvidia wayland: drv: iris x11: drv: iris
   inactive: device-1
 API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.3.3-arch1.1
   glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (ADL GT2)
   device-ID: 8086:46a6 memory: 14.97 GiB unified: yes display-ID: :1.0
 API: Vulkan v: 1.4.335 layers: 8 device: 0 type: integrated-gpu name: Intel
   Iris Xe Graphics (ADL GT2) driver: mesa intel v: 25.3.3-arch1.1
   device-ID: 8086:46a6 surfaces: N/A device: 1 type: discrete-gpu name: NVIDIA
   GeForce RTX 3070 Laptop GPU driver: nvidia v: 590.48.01
   device-ID: 10de:249d surfaces: N/A
 Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Micro-Star MSI
   driver: sof-audio-pci-intel-tgl
   alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
   chip-ID: 8086:51c8 class-ID: 0401
 Device-2: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
   driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
   link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
 API: ALSA v: k6.6.119-1-MANJARO status: kernel-api with: aoss
 Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
 Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
   bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
   vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
   lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
 IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
   speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:6 chip-ID: 8087:0026
   class-ID: e001
 Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
   lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c010c
 Local Storage: total: 942.7 GiB used: 285.09 GiB (30.2%)
 ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2450 MTFDKBA512TFK
   size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
   lanes: 4 tech: SSD serial: <filter> fw-rev: V5MA010 temp: 36.9 C
   scheme: GPT
 ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD Game Drive
   size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: USB
   rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter>
   fw-rev: 3083 scheme: GPT
 ID-1: / raw-size: 334.52 GiB size: 328.2 GiB (98.11%)
   used: 285.06 GiB (86.9%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
 ID-2: /boot/efi raw-size: 300 MiB size: 296 MiB (98.67%)
   used: 31.6 MiB (10.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
 System Temperatures: cpu: 64.0 C mobo: N/A
 Fan Speeds (rpm): N/A
 Memory: total: 16 GiB note: est. available: 15.33 GiB used: 6.09 GiB (39.7%)
 Processes: 444 Power: uptime: 27m states: freeze,mem,disk suspend: s2idle
   avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
   test_resume image: 6.12 GiB services: org_kde_powerdevil,
   power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
   tool: systemctl
 Packages: 1615 pm: pacman pkgs: 1590 libs: 418 tools: pamac,yay pm: flatpak
   pkgs: 25 Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash
   v: 5.3.9 running-in: konsole inxi: 3.3.40
Any help would be appreciated.
Nvm, somehow It just showed up again.
