Hi everybody!. I have some problems with my microphones. I have my notebook connected to a monitor with an HDMI adapter, and Manjaro only recognized the notebook internal mic and no the headphones mic. The headphones are connected to the HDMI adapter with jack. Anyone know what can it be?
If the headset microphone is not visible at all in audio controls you may need an ALSA kernel patch to get the microphone connection working
Please post system information
inxi -Faz
and ALSA information
sudo alsa-info.sh --upload
inxi -Faz
System: Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/vmlinuz-5.9-x86_64
root=UUID=27e1065a-25a9-4870-92bf-fdc69de62677 rw rootflags=subvol=@ quiet apparmor=1
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Acer product: Aspire A514-52 v: V1.12 serial: <filter> Chassis:
type: 10 serial: <filter>
Mobo: WL model: Sneezy_WC v: V1.12 serial: <filter> UEFI: Insyde v: 1.12
date: 03/28/2020
Battery: ID-1: BAT0 charge: 30.5 Wh (75.1%) condition: 40.6/48.0 Wh (84.5%) volts: 11.4
min: 11.2 model: LGC KT0030G020 AP18C8K type: Li-ion serial: <filter>
status: Discharging cycles: 49
CPU: Info: Dual Core model: Intel Core i3-8145U bits: 64 type: MT MCP arch: Kaby Lake
note: check family: 6 model-id: 8E (142) stepping: C (12) microcode: DE cache:
L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18406
Speed: 700 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 700 2: 700 3: 700 4: 700
Type: srbds mitigation: TSX disabled
Graphics: Device-1: Intel UHD Graphics 620 vendor: Acer Incorporated ALI driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 1-7:3
chip-ID: 04f2:b64f class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: HDMI1 res: 1366x768 hz: 60 dpi: 85 size: 410x230mm (16.1x9.1")
diag: 470mm (18.5")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
Audio: Device-1: Intel Cannon Point-LP High Definition Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
chip-ID: 8086:9dc8 class-ID: 0403
Sound Server-1: ALSA v: k5.9.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000 bus-ID: 01:00.0
IF: enp1s0 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter vendor: Lite-On
driver: ath10k_pci v: kernel port: 3000 bus-ID: 02:00.0 chip-ID: 168c:003e
class-ID: 0280
Bluetooth: Device-1: Lite-On type: USB driver: btusb v: 0.8 bus-ID: 1-10:4 chip-ID: 04ca:3016
class-ID: e001
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0
port: 4060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: 30 class-ID: 0104
Drives: Local Storage: total: 223.57 GiB used: 97.86 GiB (43.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD
serial: <filter> rev: B1D1 scheme: GPT
Partition: ID-1: / raw-size: 38.38 GiB size: 38.38 GiB (100.00%) used: 21.49 GiB (56.0%) fs: btrfs
dev: /dev/sda6 maj-min: 8:6
ID-2: /boot raw-size: 622 MiB size: 596.2 MiB (95.85%) used: 56 MiB (9.4%) fs: ext4
dev: /dev/sda5 maj-min: 8:5
ID-3: /boot/efi raw-size: 100 MiB size: 99.2 MiB (99.21%) used: 58.1 MiB (58.5%)
fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-4: /home raw-size: 105.23 GiB size: 105.23 GiB (100.00%) used: 47.67 GiB (45.3%)
fs: btrfs dev: /dev/sda7 maj-min: 8:7
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 40.0 C mobo: N/A
Info: Processes: 244 Uptime: 1h 52m wakeups: 1 Memory: 11.43 GiB used: 3.14 GiB (27.5%)
Init: systemd v: 247 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages:
pacman: 1734 lib: 450 flatpak: 0 Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.03
!!ALSA Information Script v 0.4.65
!!Script ran on: Mon Mar 29 19:11:23 UTC 2021
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: Acer
Product Name: Aspire A514-52
Product Version: V1.12
Firmware Version: V1.12
System SKU: 0000000000000000
Board Vendor: WL
Board Name: Sneezy_WC
!!ACPI Device Status Information
/sys/bus/acpi/devices/10251229:00/status 15
/sys/bus/acpi/devices/ACPI0003:00/status 15
/sys/bus/acpi/devices/ACPI000C:00/status 15
/sys/bus/acpi/devices/INT0E0C:00/status 15
/sys/bus/acpi/devices/INT33A1:00/status 15
/sys/bus/acpi/devices/INT3400:00/status 15
/sys/bus/acpi/devices/INT3403:00/status 15
/sys/bus/acpi/devices/INT3403:01/status 15
/sys/bus/acpi/devices/INT3403:02/status 15
/sys/bus/acpi/devices/INT3403:03/status 15
/sys/bus/acpi/devices/INT3403:04/status 15
/sys/bus/acpi/devices/INT3404:00/status 15
/sys/bus/acpi/devices/INT3406:00/status 15
/sys/bus/acpi/devices/INT340E:00/status 15
/sys/bus/acpi/devices/INT34BB:00/status 15
/sys/bus/acpi/devices/INT3F0D:00/status 15
/sys/bus/acpi/devices/LNXPOWER:00/status 15
/sys/bus/acpi/devices/LNXPOWER:01/status 1
/sys/bus/acpi/devices/LNXPOWER:02/status 1
/sys/bus/acpi/devices/LNXPOWER:03/status 1
/sys/bus/acpi/devices/LNXPOWER:04/status 1
/sys/bus/acpi/devices/LNXPOWER:05/status 1
/sys/bus/acpi/devices/LNXPOWER:06/status 1
/sys/bus/acpi/devices/MSFT0001:00/status 15
/sys/bus/acpi/devices/MSFT0101:00/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0C02:00/status 3
/sys/bus/acpi/devices/PNP0C02:01/status 3
/sys/bus/acpi/devices/PNP0C02:04/status 3
/sys/bus/acpi/devices/PNP0C09:00/status 15
/sys/bus/acpi/devices/PNP0C0A:00/status 31
/sys/bus/acpi/devices/PNP0C0C:00/status 15
/sys/bus/acpi/devices/PNP0C0D:00/status 15
/sys/bus/acpi/devices/PNP0C0E:00/status 11
/sys/bus/acpi/devices/PRP00001:00/status 11
/sys/bus/acpi/devices/SYNA7DB5:00/status 15
/sys/bus/acpi/devices/device:17/status 15
/sys/bus/acpi/devices/device:24/status 15
!!Kernel Information
Kernel release: 5.9.16-1-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.9.16-1-MANJARO
Library version: 1.2.4
Utilities version: 1.2.4
!!Loaded ALSA modules
snd_aloop
snd_hda_intel
!!Sound Servers on this system
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [Loopback ]: Loopback - Loopback
Loopback 1
1 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0x914a0000 irq 130
!!PCI Soundcards installed in the system
00:1f.3 Audio device [0403]: Intel Corporation Cannon Point-LP High Definition Audio Controller [8086:9dc8] (rev 30) (prog-if 80)
Subsystem: Acer Incorporated [ALI] Device [1025:1373]
!!Modprobe options (Sound related)
snd_hda_intel: model=headset-mic
!!Loaded sound module options
!!Module: snd_aloop
enable : Y,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
pcm_notify : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
pcm_substreams : 8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8
timer_source : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
dmic_detect : Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : headset-mic,(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 1
power_save_controller : Y
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ALC256
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0256
Subsystem Id: 0x10251373
Revision Id: 0x100002
No Modem Function Group found
Default PCM:
rates [0x560]: 44100 48000 96000 192000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D1 D2 D3 D3cold CLKSTOP EPSS
Power: setting=D0, actual=D0
GPIO: io=3, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Speaker Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Amp-Out caps: ofs=0x57, nsteps=0x57, stepsize=0x02, mute=0
Amp-Out vals: [0x3c 0x3c]
Converter: stream=0, channel=0
PCM:
rates [0x60]: 44100 48000
formats [0x1]: PCM
Power states: D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Headphone Playback Volume", index=0, device=0
Device: name="ALC256 Analog", type="Audio", device=0
PCM:
formats [0x1]: PCM
Node 0x04 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x05 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x06 [Audio Output] wcaps 0x611: Stereo Digital
Digital:
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
rates [0x5e0]: 44100 48000 88200 96000 192000
formats [0x1]: PCM
Node 0x07 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Control: name="Capture Switch", index=0, device=0
Amp-In caps: ofs=0x17, nsteps=0x3f, stepsize=0x02, mute=1
Amp-In vals: [0x3d 0x3d]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x24
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Amp-In vals: [0x97 0x97]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x22
Node 0x0a [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0b [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0d [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0e [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x10 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x11 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x12 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
Control: name="Mic Boost Volume", index=0, device=0
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Amp-In vals: [0x00 0x00]
Pincap 0x00000020: IN
Pin Default 0x90a60140: [Fixed] Mic at Int N/A
Conn = Digital, Color = Unknown
DefAssociation = 0x4, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x13 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
Pin Default 0x40000000: [N/A] Line Out at Ext N/A
Conn = Unknown, Color = Unknown
DefAssociation = 0x0, Sequence = 0x0
Pin-ctls: 0x00:
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Speaker Playback Switch", index=0, device=0
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x00 0x00]
Pincap 0x00010014: OUT EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x90170110: [Fixed] Speaker at Int N/A
Conn = Analog, Color = Unknown
DefAssociation = 0x1, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Unsolicited: tag=00, enabled=0
Connection: 1
0x02
Node 0x15 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x16 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x17 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x18 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Pincap 0x00003724: IN Detect
Vref caps: HIZ 50 GRD 80 100
Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
Conn = 1/8, Color = Black
DefAssociation = 0xf, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN VREF_HIZ
Node 0x19 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Misc = NO_PRESENCE
Node 0x1a [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Misc = NO_PRESENCE
Pin-ctls: 0x00: VREF_HIZ
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Amp-Out vals: [0x80 0x80]
Pincap 0x00013734: IN OUT EAPD Detect
EAPD 0x2: EAPD
Misc = NO_PRESENCE
Connection: 2
0x02* 0x03
Node 0x1c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
Pin Default 0x40700001: [N/A] Modem Hand at Ext N/A
DefAssociation = 0x0, Sequence = 0x1
Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400781: Stereo Digital
Pincap 0x00000014: OUT Detect
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x1f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
Processing caps: benign=0, ncoeff=91
Node 0x21 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Headphone Playback Switch", index=0, device=0
Pincap 0x0001001c: OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x02211020: [Jack] HP Out at Ext Front
DefAssociation = 0x2, Sequence = 0x0
Pin-ctls: 0xc0: OUT HP
Unsolicited: tag=01, enabled=1
Connection: 2
0x02 0x03*
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 5
0x18 0x19 0x1a 0x1b 0x1d
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 6
0x18 0x19 0x1a 0x1b 0x1d 0x12
Node 0x24 [Audio Selector] wcaps 0x300101: Stereo
Connection: 2
0x12* 0x13
Codec: Intel Kabylake HDMI
Address: 2
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x8086280b
Subsystem Id: 0x80860101
Revision Id: 0x100000
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Power states: D0 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x6611: 8-Channels Digital
Converter: stream=1, channel=0
Digital: Enabled KAE
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
bits [0x1a]: 16 24 32
formats [0x5]: PCM AC3
Power states: D0 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Power: setting=D3, actual=D3
Node 0x04 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x05 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pincap 0x0b000094: OUT Detect HBR HDMI DP
Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
Pin-ctls: 0x40: OUT
Devices: 0
Connection: 3
0x02* 0x03 0x04
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x07 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x08 [Vendor Defined Widget] wcaps 0xf00000: Mono
--endcollapse--
!!ALSA Device nodes
crw-rw---- 1 root audio 116, 6 Mar 29 14:13 /dev/snd/controlC0
crw-rw---- 1 root audio 116, 16 Mar 29 14:13 /dev/snd/controlC1
crw-rw---- 1 root audio 116, 14 Mar 29 14:13 /dev/snd/hwC1D0
crw-rw---- 1 root audio 116, 15 Mar 29 14:13 /dev/snd/hwC1D2
crw-rw---- 1 root audio 116, 3 Mar 29 14:16 /dev/snd/pcmC0D0c
crw-rw---- 1 root audio 116, 2 Mar 29 14:16 /dev/snd/pcmC0D0p
crw-rw---- 1 root audio 116, 5 Mar 29 14:13 /dev/snd/pcmC0D1c
crw-rw---- 1 root audio 116, 4 Mar 29 14:13 /dev/snd/pcmC0D1p
crw-rw---- 1 root audio 116, 8 Mar 29 14:16 /dev/snd/pcmC1D0c
crw-rw---- 1 root audio 116, 7 Mar 29 14:16 /dev/snd/pcmC1D0p
crw-rw---- 1 root audio 116, 13 Mar 29 14:16 /dev/snd/pcmC1D10p
crw-rw---- 1 root audio 116, 9 Mar 29 16:08 /dev/snd/pcmC1D3p
crw-rw---- 1 root audio 116, 10 Mar 29 14:16 /dev/snd/pcmC1D7p
crw-rw---- 1 root audio 116, 11 Mar 29 14:16 /dev/snd/pcmC1D8p
crw-rw---- 1 root audio 116, 12 Mar 29 14:16 /dev/snd/pcmC1D9p
crw-rw---- 1 root audio 116, 1 Mar 29 14:13 /dev/snd/seq
crw-rw---- 1 root audio 116, 33 Mar 29 14:13 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 80 Mar 29 14:13 .
drwxr-xr-x 3 root root 400 Mar 29 14:13 ..
lrwxrwxrwx 1 root root 12 Mar 29 14:13 pci-0000:00:1f.3 -> ../controlC1
lrwxrwxrwx 1 root root 12 Mar 29 14:13 platform-snd_aloop.0 -> ../controlC0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: Loopback [Loopback], device 0: Loopback PCM [Loopback PCM]
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 0: Loopback [Loopback], device 1: Loopback PCM [Loopback PCM]
Subdevices: 8/8
card 1: PCH [HDA Intel PCH], device 0: ALC256 Analog [ALC256 Analog]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 8/8
Subdevices: 8/8
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card Loopback
Card hw:0 'Loopback'/'Loopback 1'
Mixer name : 'Loopback Mixer'
Components : ''
Controls : 97
Simple ctrls : 1
Simple mixer control 'PCM',0
Capabilities: pvolume
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
!!-------Mixer controls for card PCH
Card hw:1 'PCH'/'HDA Intel PCH at 0x914a0000 irq 130'
Mixer name : 'Realtek ALC256'
Components : 'HDA:10ec0256,10251373,00100002 HDA:8086280b,80860101,00100000'
Controls : 51
Simple ctrls : 12
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 87
Mono: Playback 60 [69%] [-20.25dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 87 [100%] [0.00dB] [on]
Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Speaker',0
Mono:
Mono:
Simple mixer control 'Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
Simple mixer control 'IEC958',4
Mono: Playback [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 61 [97%] [28.50dB] [on]
Front Right: Capture 61 [97%] [28.50dB] [on]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
!!Alsactl output
--startcollapse--
state.Loopback {
control.1 {
iface PCM
name 'PCM Rate Shift 100000'
value 100000
comment {
access 'read write'
type INTEGER
count 1
range '80000 - 120000 (step 1)'
control.2 {
iface PCM
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.3 {
iface PCM
name 'PCM Slave Active'
value false
comment {
access read
type BOOLEAN
count 1
control.4 {
iface PCM
name 'PCM Slave Format'
value 2
comment {
access read
type INTEGER
count 1
range '0 - 52 (step 1)'
control.5 {
iface PCM
name 'PCM Slave Rate'
value 48000
comment {
access read
type INTEGER
count 1
range '0 - 192000 (step 1)'
control.6 {
iface PCM
name 'PCM Slave Channels'
value 2
comment {
access read
type INTEGER
count 1
range '1 - 1024 (step 1)'
control.7 {
iface PCM
subdevice 1
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.8 {
iface PCM
subdevice 1
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.9 {
iface PCM
subdevice 1
value false
comment {
access read
type BOOLEAN
count 1
control.10 {
iface PCM
subdevice 1
value 2
comment {
access read
type INTEGER
count 1
control.11 {
iface PCM
subdevice 1
value 48000
comment {
access read
type INTEGER
count 1
control.12 {
iface PCM
subdevice 1
value 2
comment {
access read
type INTEGER
count 1
control.13 {
iface PCM
subdevice 2
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.14 {
iface PCM
subdevice 2
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.15 {
iface PCM
subdevice 2
value false
comment {
access read
type BOOLEAN
count 1
control.16 {
iface PCM
subdevice 2
value 2
comment {
access read
type INTEGER
count 1
control.17 {
iface PCM
subdevice 2
value 48000
comment {
access read
type INTEGER
count 1
control.18 {
iface PCM
subdevice 2
value 2
comment {
access read
type INTEGER
count 1
control.19 {
iface PCM
subdevice 3
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.20 {
iface PCM
subdevice 3
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.21 {
iface PCM
subdevice 3
value false
comment {
access read
type BOOLEAN
count 1
control.22 {
iface PCM
subdevice 3
value 2
comment {
access read
type INTEGER
count 1
control.23 {
iface PCM
subdevice 3
value 48000
comment {
access read
type INTEGER
count 1
control.24 {
iface PCM
subdevice 3
value 2
comment {
access read
type INTEGER
count 1
control.25 {
iface PCM
subdevice 4
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.26 {
iface PCM
subdevice 4
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.27 {
iface PCM
subdevice 4
value false
comment {
access read
type BOOLEAN
count 1
control.28 {
iface PCM
subdevice 4
value 2
comment {
access read
type INTEGER
count 1
control.29 {
iface PCM
subdevice 4
value 48000
comment {
access read
type INTEGER
count 1
control.30 {
iface PCM
subdevice 4
value 2
comment {
access read
type INTEGER
count 1
control.31 {
iface PCM
subdevice 5
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.32 {
iface PCM
subdevice 5
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.33 {
iface PCM
subdevice 5
value false
comment {
access read
type BOOLEAN
count 1
control.34 {
iface PCM
subdevice 5
value 2
comment {
access read
type INTEGER
count 1
control.35 {
iface PCM
subdevice 5
value 48000
comment {
access read
type INTEGER
count 1
control.36 {
iface PCM
subdevice 5
value 2
comment {
access read
type INTEGER
count 1
control.37 {
iface PCM
subdevice 6
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.38 {
iface PCM
subdevice 6
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.39 {
iface PCM
subdevice 6
value false
comment {
access read
type BOOLEAN
count 1
control.40 {
iface PCM
subdevice 6
value 2
comment {
access read
type INTEGER
count 1
control.41 {
iface PCM
subdevice 6
value 48000
comment {
access read
type INTEGER
count 1
control.42 {
iface PCM
subdevice 6
value 2
comment {
access read
type INTEGER
count 1
control.43 {
iface PCM
subdevice 7
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.44 {
iface PCM
subdevice 7
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.45 {
iface PCM
subdevice 7
value false
comment {
access read
type BOOLEAN
count 1
control.46 {
iface PCM
subdevice 7
value 2
comment {
access read
type INTEGER
count 1
control.47 {
iface PCM
subdevice 7
value 48000
comment {
access read
type INTEGER
count 1
control.48 {
iface PCM
subdevice 7
value 2
comment {
access read
type INTEGER
count 1
control.49 {
iface PCM
device 1
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.50 {
iface PCM
device 1
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.51 {
iface PCM
device 1
value false
comment {
access read
type BOOLEAN
count 1
control.52 {
iface PCM
device 1
value 2
comment {
access read
type INTEGER
count 1
control.53 {
iface PCM
device 1
value 44100
comment {
access read
type INTEGER
count 1
control.54 {
iface PCM
device 1
value 2
comment {
access read
type INTEGER
count 1
control.55 {
iface PCM
device 1
subdevice 1
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.56 {
iface PCM
device 1
subdevice 1
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.57 {
iface PCM
device 1
subdevice 1
value false
comment {
access read
type BOOLEAN
count 1
control.58 {
iface PCM
device 1
subdevice 1
value 2
comment {
access read
type INTEGER
count 1
control.59 {
iface PCM
device 1
subdevice 1
value 48000
comment {
access read
type INTEGER
count 1
control.60 {
iface PCM
device 1
subdevice 1
value 2
comment {
access read
type INTEGER
count 1
control.61 {
iface PCM
device 1
subdevice 2
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.62 {
iface PCM
device 1
subdevice 2
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.63 {
iface PCM
device 1
subdevice 2
value false
comment {
access read
type BOOLEAN
count 1
control.64 {
iface PCM
device 1
subdevice 2
value 2
comment {
access read
type INTEGER
count 1
control.65 {
iface PCM
device 1
subdevice 2
value 48000
comment {
access read
type INTEGER
count 1
control.66 {
iface PCM
device 1
subdevice 2
value 2
comment {
access read
type INTEGER
count 1
control.67 {
iface PCM
device 1
subdevice 3
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.68 {
iface PCM
device 1
subdevice 3
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.69 {
iface PCM
device 1
subdevice 3
value false
comment {
access read
type BOOLEAN
count 1
control.70 {
iface PCM
device 1
subdevice 3
value 2
comment {
access read
type INTEGER
count 1
control.71 {
iface PCM
device 1
subdevice 3
value 48000
comment {
access read
type INTEGER
count 1
control.72 {
iface PCM
device 1
subdevice 3
value 2
comment {
access read
type INTEGER
count 1
control.73 {
iface PCM
device 1
subdevice 4
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.74 {
iface PCM
device 1
subdevice 4
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.75 {
iface PCM
device 1
subdevice 4
value false
comment {
access read
type BOOLEAN
count 1
control.76 {
iface PCM
device 1
subdevice 4
value 2
comment {
access read
type INTEGER
count 1
control.77 {
iface PCM
device 1
subdevice 4
value 48000
comment {
access read
type INTEGER
count 1
control.78 {
iface PCM
device 1
subdevice 4
value 2
comment {
access read
type INTEGER
count 1
control.79 {
iface PCM
device 1
subdevice 5
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.80 {
iface PCM
device 1
subdevice 5
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.81 {
iface PCM
device 1
subdevice 5
value false
comment {
access read
type BOOLEAN
count 1
control.82 {
iface PCM
device 1
subdevice 5
value 2
comment {
access read
type INTEGER
count 1
control.83 {
iface PCM
device 1
subdevice 5
value 48000
comment {
access read
type INTEGER
count 1
control.84 {
iface PCM
device 1
subdevice 5
value 2
comment {
access read
type INTEGER
count 1
control.85 {
iface PCM
device 1
subdevice 6
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.86 {
iface PCM
device 1
subdevice 6
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.87 {
iface PCM
device 1
subdevice 6
value false
comment {
access read
type BOOLEAN
count 1
control.88 {
iface PCM
device 1
subdevice 6
value 2
comment {
access read
type INTEGER
count 1
control.89 {
iface PCM
device 1
subdevice 6
value 48000
comment {
access read
type INTEGER
count 1
control.90 {
iface PCM
device 1
subdevice 6
value 2
comment {
access read
type INTEGER
count 1
control.91 {
iface PCM
device 1
subdevice 7
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.92 {
iface PCM
device 1
subdevice 7
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.93 {
iface PCM
device 1
subdevice 7
value false
comment {
access read
type BOOLEAN
count 1
control.94 {
iface PCM
device 1
subdevice 7
value 2
comment {
access read
type INTEGER
count 1
control.95 {
iface PCM
device 1
subdevice 7
value 48000
comment {
access read
type INTEGER
count 1
control.96 {
iface PCM
device 1
subdevice 7
value 2
comment {
access read
type INTEGER
count 1
control.97 {
iface MIXER
name 'PCM Playback Volume'
value.0 255
value.1 255
comment {
access 'read write user'
type INTEGER
count 2
range '0 - 255'
tlv '0000000100000008ffffec1400000014'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
state.PCH {
control.1 {
iface MIXER
name 'Headphone Playback Volume'
value.0 87
value.1 87
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.2 {
iface MIXER
name 'Headphone Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.3 {
iface MIXER
name 'Speaker Playback Volume'
value.0 87
value.1 87
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.4 {
iface MIXER
name 'Speaker Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.5 {
iface MIXER
name 'Auto-Mute Mode'
value Enabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.6 {
iface MIXER
name 'Capture Volume'
value.0 61
value.1 61
comment {
access 'read write'
type INTEGER
count 2
range '0 - 63'
dbmin -1725
dbmax 3000
dbvalue.0 2850
dbvalue.1 2850
control.7 {
iface MIXER
name 'Capture Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.8 {
iface MIXER
name 'Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.9 {
iface MIXER
name 'Master Playback Volume'
value 60
comment {
access 'read write'
type INTEGER
count 1
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -2025
control.10 {
iface MIXER
name 'Master Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.11 {
iface CARD
name 'Mic Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.12 {
iface CARD
name 'Front Headphone Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.13 {
iface CARD
name 'Speaker Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.14 {
iface PCM
name 'Playback Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.15 {
iface PCM
name 'Capture Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.16 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.17 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.18 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.19 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.20 {
iface MIXER
name 'IEC958 Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.21 {
iface PCM
device 3
name ELD
value '100007006712000100000000000000004c2d340b533139443330300907070000'
comment {
access 'read volatile'
type BYTES
count 32
control.22 {
iface CARD
name 'HDMI/DP,pcm=7 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.23 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.24 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.25 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.26 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.27 {
iface PCM
device 7
name ELD
value ''
comment {
type BYTES
count 0
control.28 {
iface CARD
name 'HDMI/DP,pcm=8 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.29 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.30 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.31 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.32 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.33 {
iface PCM
device 8
name ELD
value ''
comment {
type BYTES
count 0
control.34 {
iface CARD
name 'HDMI/DP,pcm=9 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.35 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.36 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.37 {
iface MIXER
index 3
comment {
access 'read write'
type IEC958
count 1
control.38 {
iface MIXER
index 3
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.39 {
iface PCM
device 9
name ELD
value ''
comment {
type BYTES
count 0
control.40 {
iface CARD
name 'HDMI/DP,pcm=10 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.41 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.42 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.43 {
iface MIXER
index 4
comment {
access 'read write'
type IEC958
count 1
control.44 {
iface MIXER
index 4
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.45 {
iface PCM
device 10
name ELD
value ''
comment {
type BYTES
count 0
control.46 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.47 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.48 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.49 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.50 {
iface PCM
device 10
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.51 {
iface MIXER
value.0 255
value.1 255
comment {
type INTEGER
count 2
range '0 - 255'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
--endcollapse--
!!All Loaded Modules
ac
ac97_bus
acer_wireless
acer_wmi
acpi_thermal_rel
aesni_intel
af_alg
agpgart
algif_hash
algif_skcipher
ath
ath10k_core
ath10k_pci
atkbd
battery
blake2b_generic
bluetooth
bnep
btbcm
btintel
btrfs
btrtl
btusb
ccm
cec
cfg80211
cmac
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm
drm_kms_helper
ecc
ecdh_generic
ee1004
evdev
ext4
fat
fb_sys_fops
fixed_phy
fuse
ghash_clmulni_intel
glue_helper
hid
hid_generic
hid_multitouch
hidp
i2c_algo_bit
i2c_hid
i2c_i801
i2c_smbus
i8042
i915
iTCO_vendor_support
iTCO_wdt
idma64
input_leds
int3400_thermal
int3403_thermal
int3406_thermal
int340x_thermal_zone
intel_cstate
intel_gtt
intel_lpss
intel_lpss_pci
intel_pch_thermal
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_soc_dts_iosf
intel_uncore
intel_wmi_thunderbolt
ip_tables
irqbypass
jbd2
joydev
kvm
kvm_intel
ledtrig_audio
libarc4
libcrc32c
libphy
libps2
loop
mac80211
mac_hid
mbcache
mc
mdio_devres
mei
mei_hdcp
mei_me
mousedev
msr
nls_cp437
nls_iso8859_1
of_mdio
pcspkr
processor_thermal_device
r8169
raid6_pq
rapl
rc_core
realtek
rfcomm
rfkill
rng_core
serio
serio_raw
sg
snd
snd_aloop
snd_compress
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_pcm_dmaengine
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_hdac_hda
snd_soc_skl
snd_soc_sst_dsp
snd_soc_sst_ipc
snd_sof
snd_sof_intel_byt
snd_sof_intel_hda
snd_sof_intel_hda_common
snd_sof_intel_ipc
snd_sof_pci
snd_sof_xtensa_dsp
snd_timer
soundcore
sparse_keymap
squashfs
syscopyarea
sysfillrect
sysimgblt
tpm
tpm_crb
tpm_tis
tpm_tis_core
uinput
usbhid
uvcvideo
v4l2loopback_dc
vboxdrv
vboxnetadp
vboxnetflt
vfat
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xhci_hcd
xhci_pci
xor
!!Sysfs Files
/sys/class/sound/hwC1D0/init_pin_configs:
0x12 0x90a60140
0x13 0x40000000
0x14 0x90170110
0x18 0x411111f0
0x19 0x411111f0
0x1a 0x411111f0
0x1b 0x411111f0
0x1d 0x40700001
0x1e 0x411111f0
0x21 0x02211020
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
/sys/class/sound/hwC1D2/init_pin_configs:
0x05 0x18560010
0x06 0x18560010
0x07 0x18560010
/sys/class/sound/hwC1D2/driver_pin_configs:
/sys/class/sound/hwC1D2/user_pin_configs:
/sys/class/sound/hwC1D2/init_verbs:
/sys/class/sound/hwC1D2/hints:
!!ALSA/HDA dmesg
[ 0.115832] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.115832] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.115832] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 4.034114] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[ 4.075914] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
[ 4.075932] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 4.076203] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 4.144004] urandom_read: 3 callbacks suppressed
[ 4.323826] iTCO_vendor_support: vendor-support=0
[ 4.324488] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC256: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 4.324490] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 4.324491] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 4.324492] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 4.324493] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 4.324494] snd_hda_codec_realtek hdaudioC1D0: Mic=0x12
[ 4.351376] ee1004 7-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 4.397270] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 4.406941] snd_hda_codec_hdmi hdaudioC1D2: Monitor plugged-in, Failed to power up codec ret=[-13]
[ 4.437191] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1f.3/sound/card1/input15
[ 4.437277] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card1/input16
[ 4.437329] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card1/input17
[ 4.437390] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card1/input18
[ 4.437456] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card1/input19
[ 4.437522] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card1/input20
[ 4.437591] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card1/input21
[ 4.453983] input: SYNA7DB5:00 06CB:CD40 Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-SYNA7DB5:00/0018:06CB:CD40.0003/input/input22
In the future, when providing code/output, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text so that the output looks like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
instead of like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.`
(as that makes both our lives much easier)
No need to do anything right now as I’m an editor here on this site and have fixed it for you already. However, in the future I might not see your post so review my edits by pushing the orange pencil above the post I just fixed.
Data from alsa-info is only showing the internal microphone detected
!!ALSA/HDA dmesg
So the modprobe option added to folder /etc/modprobe.d/ is not working
I suggest you edit the .conf configuration file and try another model option
change - options snd_hda_intel model=headset-mic
to options snd_hda_intel model=acer-headset-mic
Thanks. I only have a file named: snd-sna-intel.conf
and there I change to:
But still not work =(
Please post ALSA information again to see if anything has changed
I also suggest you remove the ALSA Loopback virtual device that could be getting in the way of audio playback to the onboard audio
sudo modprobe -r snd_aloop
I have found 2 hardware scans for the same model laptop, but they also appear to have only the internal microphone input detected
https://linux-hardware.org/?view=computers&vendor=Acer&model=Aspire+A514-52
I am still looking for clues to show which Node connection on the audio codec should be the headset microphone
costanzo-scarella ~ # sudo modprobe -r snd_aloop
modprobe: FATAL: Module snd_aloop is in use.
!!Script ran on: Tue Mar 30 19:23:50 UTC 2021
ID_LIKE=arch
!!DMI Information
Manufacturer: Acer
Board Vendor: WL
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
snd_aloop
snd_hda_intel
Pulseaudio:
Running - Yes
Jack:
Running - No
Loopback 1
snd_hda_intel: model=acer-headset-mic
!!Module: snd_aloop
dmic_detect : Y
enable_msi : -1
model : acer-headset-mic,(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
power_save : 1
single_cmd : -1
snoop : -1
--startcollapse--
Address: 0
Default PCM:
formats [0x1]: PCM
Amp-Out vals: [0x50 0x50]
PCM:
formats [0x1]: PCM
PCM:
formats [0x1]: PCM
Digital:
PCM:
formats [0x1]: PCM
Amp-In vals: [0x29 0x29]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x24
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x23
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x22
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Pin-ctls: 0x00:
EAPD 0x2: EAPD
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x02
Misc = NO_PRESENCE
Misc = NO_PRESENCE
Misc = NO_PRESENCE
EAPD 0x2: EAPD
Misc = NO_PRESENCE
Connection: 2
0x02* 0x03
Pin-ctls: 0x20: IN
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
EAPD 0x2: EAPD
Connection: 2
0x02 0x03*
Connection: 5
Connection: 6
Connection: 2
0x12* 0x13
Address: 2
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Device: name="HDMI 0", type="HDMI", device=3
Digital: Enabled GenLevel KAE
Digital category: 0x2
PCM:
PCM:
PCM:
Pin-ctls: 0x40: OUT
Devices: 0
Connection: 3
0x02* 0x03 0x04
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Pin-ctls: 0x00:
Devices: 0
Connection: 0
--endcollapse--
!!ALSA Device nodes
crw-rw---- 1 root audio 116, 6 Mar 30 15:28 /dev/snd/controlC0
crw-rw---- 1 root audio 116, 16 Mar 30 15:28 /dev/snd/controlC1
crw-rw---- 1 root audio 116, 14 Mar 30 15:28 /dev/snd/hwC1D0
crw-rw---- 1 root audio 116, 15 Mar 30 15:28 /dev/snd/hwC1D2
crw-rw---- 1 root audio 116, 3 Mar 30 16:11 /dev/snd/pcmC0D0c
crw-rw---- 1 root audio 116, 2 Mar 30 15:35 /dev/snd/pcmC0D0p
crw-rw---- 1 root audio 116, 5 Mar 30 15:35 /dev/snd/pcmC0D1c
crw-rw---- 1 root audio 116, 4 Mar 30 15:35 /dev/snd/pcmC0D1p
crw-rw---- 1 root audio 116, 8 Mar 30 15:30 /dev/snd/pcmC1D0c
crw-rw---- 1 root audio 116, 7 Mar 30 16:07 /dev/snd/pcmC1D0p
crw-rw---- 1 root audio 116, 13 Mar 30 15:35 /dev/snd/pcmC1D10p
crw-rw---- 1 root audio 116, 9 Mar 30 16:09 /dev/snd/pcmC1D3p
crw-rw---- 1 root audio 116, 10 Mar 30 15:35 /dev/snd/pcmC1D7p
crw-rw---- 1 root audio 116, 11 Mar 30 15:35 /dev/snd/pcmC1D8p
crw-rw---- 1 root audio 116, 12 Mar 30 15:35 /dev/snd/pcmC1D9p
crw-rw---- 1 root audio 116, 1 Mar 30 15:35 /dev/snd/seq
crw-rw---- 1 root audio 116, 33 Mar 30 15:28 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 80 Mar 30 15:28 .
drwxr-xr-x 3 root root 400 Mar 30 15:28 ..
lrwxrwxrwx 1 root root 12 Mar 30 15:28 pci-0000:00:1f.3 -> ../controlC1
lrwxrwxrwx 1 root root 12 Mar 30 15:28 platform-snd_aloop.0 -> ../controlC0
APLAY
Subdevices: 8/8
Subdevices: 8/8
Subdevices: 1/1
Subdevices: 0/1
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
ARECORD
Subdevices: 8/8
Subdevices: 8/8
Subdevices: 1/1
!!Amixer output
Components : ''
Controls : 98
Simple ctrls : 2
Mono:
Simple mixer control 'Digital',0
Limits: Capture 0 - 120
Front Left: Capture 60 [50%] [0.00dB]
Front Right: Capture 60 [50%] [0.00dB]
Controls : 51
Simple ctrls : 12
Mono: Playback 80 [92%] [-5.25dB] [on]
Mono:
Front Left: Playback 0 [0%] [-65.25dB] [off]
Front Right: Playback 0 [0%] [-65.25dB] [off]
Mono:
Mono:
Limits: 0 - 3
Mono: Playback [on]
Mono: Playback [on]
Mono: Playback [on]
Mono: Playback [on]
Mono: Playback [on]
Front Left: Capture 41 [65%] [13.50dB] [on]
Front Right: Capture 41 [65%] [13.50dB] [on]
Capabilities: enum
Item0: 'Enabled'
!!Alsactl output
--startcollapse--
state.Loopback {
control.1 {
iface PCM
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.2 {
iface PCM
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.3 {
iface PCM
value false
comment {
access read
type BOOLEAN
count 1
control.4 {
iface PCM
value 2
comment {
access read
type INTEGER
count 1
control.5 {
iface PCM
value 48000
comment {
access read
type INTEGER
count 1
control.6 {
iface PCM
value 2
comment {
access read
type INTEGER
count 1
control.7 {
iface PCM
subdevice 1
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.8 {
iface PCM
subdevice 1
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.9 {
iface PCM
subdevice 1
value false
comment {
access read
type BOOLEAN
count 1
control.10 {
iface PCM
subdevice 1
value 2
comment {
access read
type INTEGER
count 1
control.11 {
iface PCM
subdevice 1
value 48000
comment {
access read
type INTEGER
count 1
control.12 {
iface PCM
subdevice 1
value 2
comment {
access read
type INTEGER
count 1
control.13 {
iface PCM
subdevice 2
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.14 {
iface PCM
subdevice 2
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.15 {
iface PCM
subdevice 2
value false
comment {
access read
type BOOLEAN
count 1
control.16 {
iface PCM
subdevice 2
value 2
comment {
access read
type INTEGER
count 1
control.17 {
iface PCM
subdevice 2
value 48000
comment {
access read
type INTEGER
count 1
control.18 {
iface PCM
subdevice 2
value 2
comment {
access read
type INTEGER
count 1
control.19 {
iface PCM
subdevice 3
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.20 {
iface PCM
subdevice 3
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.21 {
iface PCM
subdevice 3
value false
comment {
access read
type BOOLEAN
count 1
control.22 {
iface PCM
subdevice 3
value 2
comment {
access read
type INTEGER
count 1
control.23 {
iface PCM
subdevice 3
value 48000
comment {
access read
type INTEGER
count 1
control.24 {
iface PCM
subdevice 3
value 2
comment {
access read
type INTEGER
count 1
control.25 {
iface PCM
subdevice 4
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.26 {
iface PCM
subdevice 4
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.27 {
iface PCM
subdevice 4
value false
comment {
access read
type BOOLEAN
count 1
control.28 {
iface PCM
subdevice 4
value 2
comment {
access read
type INTEGER
count 1
control.29 {
iface PCM
subdevice 4
value 48000
comment {
access read
type INTEGER
count 1
control.30 {
iface PCM
subdevice 4
value 2
comment {
access read
type INTEGER
count 1
control.31 {
iface PCM
subdevice 5
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.32 {
iface PCM
subdevice 5
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.33 {
iface PCM
subdevice 5
value false
comment {
access read
type BOOLEAN
count 1
control.34 {
iface PCM
subdevice 5
value 2
comment {
access read
type INTEGER
count 1
control.35 {
iface PCM
subdevice 5
value 48000
comment {
access read
type INTEGER
count 1
control.36 {
iface PCM
subdevice 5
value 2
comment {
access read
type INTEGER
count 1
control.37 {
iface PCM
subdevice 6
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.38 {
iface PCM
subdevice 6
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.39 {
iface PCM
subdevice 6
value false
comment {
access read
type BOOLEAN
count 1
control.40 {
iface PCM
subdevice 6
value 2
comment {
access read
type INTEGER
count 1
control.41 {
iface PCM
subdevice 6
value 48000
comment {
access read
type INTEGER
count 1
control.42 {
iface PCM
subdevice 6
value 2
comment {
access read
type INTEGER
count 1
control.43 {
iface PCM
subdevice 7
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.44 {
iface PCM
subdevice 7
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.45 {
iface PCM
subdevice 7
value false
comment {
access read
type BOOLEAN
count 1
control.46 {
iface PCM
subdevice 7
value 2
comment {
access read
type INTEGER
count 1
control.47 {
iface PCM
subdevice 7
value 48000
comment {
access read
type INTEGER
count 1
control.48 {
iface PCM
subdevice 7
value 2
comment {
access read
type INTEGER
count 1
control.49 {
iface PCM
device 1
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.50 {
iface PCM
device 1
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.51 {
iface PCM
device 1
value false
comment {
access read
type BOOLEAN
count 1
control.52 {
iface PCM
device 1
value 10
comment {
access read
type INTEGER
count 1
control.53 {
iface PCM
device 1
value 48000
comment {
access read
type INTEGER
count 1
control.54 {
iface PCM
device 1
value 2
comment {
access read
type INTEGER
count 1
control.55 {
iface PCM
device 1
subdevice 1
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.56 {
iface PCM
device 1
subdevice 1
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.57 {
iface PCM
device 1
subdevice 1
value false
comment {
access read
type BOOLEAN
count 1
control.58 {
iface PCM
device 1
subdevice 1
value 2
comment {
access read
type INTEGER
count 1
control.59 {
iface PCM
device 1
subdevice 1
value 48000
comment {
access read
type INTEGER
count 1
control.60 {
iface PCM
device 1
subdevice 1
value 2
comment {
access read
type INTEGER
count 1
control.61 {
iface PCM
device 1
subdevice 2
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.62 {
iface PCM
device 1
subdevice 2
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.63 {
iface PCM
device 1
subdevice 2
value false
comment {
access read
type BOOLEAN
count 1
control.64 {
iface PCM
device 1
subdevice 2
value 2
comment {
access read
type INTEGER
count 1
control.65 {
iface PCM
device 1
subdevice 2
value 48000
comment {
access read
type INTEGER
count 1
control.66 {
iface PCM
device 1
subdevice 2
value 2
comment {
access read
type INTEGER
count 1
control.67 {
iface PCM
device 1
subdevice 3
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.68 {
iface PCM
device 1
subdevice 3
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.69 {
iface PCM
device 1
subdevice 3
value false
comment {
access read
type BOOLEAN
count 1
control.70 {
iface PCM
device 1
subdevice 3
value 2
comment {
access read
type INTEGER
count 1
control.71 {
iface PCM
device 1
subdevice 3
value 48000
comment {
access read
type INTEGER
count 1
control.72 {
iface PCM
device 1
subdevice 3
value 2
comment {
access read
type INTEGER
count 1
control.73 {
iface PCM
device 1
subdevice 4
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.74 {
iface PCM
device 1
subdevice 4
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.75 {
iface PCM
device 1
subdevice 4
value false
comment {
access read
type BOOLEAN
count 1
control.76 {
iface PCM
device 1
subdevice 4
value 2
comment {
access read
type INTEGER
count 1
control.77 {
iface PCM
device 1
subdevice 4
value 48000
comment {
access read
type INTEGER
count 1
control.78 {
iface PCM
device 1
subdevice 4
value 2
comment {
access read
type INTEGER
count 1
control.79 {
iface PCM
device 1
subdevice 5
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.80 {
iface PCM
device 1
subdevice 5
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.81 {
iface PCM
device 1
subdevice 5
value false
comment {
access read
type BOOLEAN
count 1
control.82 {
iface PCM
device 1
subdevice 5
value 2
comment {
access read
type INTEGER
count 1
control.83 {
iface PCM
device 1
subdevice 5
value 48000
comment {
access read
type INTEGER
count 1
control.84 {
iface PCM
device 1
subdevice 5
value 2
comment {
access read
type INTEGER
count 1
control.85 {
iface PCM
device 1
subdevice 6
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.86 {
iface PCM
device 1
subdevice 6
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.87 {
iface PCM
device 1
subdevice 6
value false
comment {
access read
type BOOLEAN
count 1
control.88 {
iface PCM
device 1
subdevice 6
value 2
comment {
access read
type INTEGER
count 1
control.89 {
iface PCM
device 1
subdevice 6
value 48000
comment {
access read
type INTEGER
count 1
control.90 {
iface PCM
device 1
subdevice 6
value 2
comment {
access read
type INTEGER
count 1
control.91 {
iface PCM
device 1
subdevice 7
value 100000
comment {
access 'read write'
type INTEGER
count 1
control.92 {
iface PCM
device 1
subdevice 7
name 'PCM Notify'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.93 {
iface PCM
device 1
subdevice 7
value false
comment {
access read
type BOOLEAN
count 1
control.94 {
iface PCM
device 1
subdevice 7
value 2
comment {
access read
type INTEGER
count 1
control.95 {
iface PCM
device 1
subdevice 7
value 48000
comment {
access read
type INTEGER
count 1
control.96 {
iface PCM
device 1
subdevice 7
value 2
comment {
access read
type INTEGER
count 1
control.97 {
iface MIXER
value.0 255
value.1 255
comment {
type INTEGER
count 2
range '0 - 255'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.98 {
iface MIXER
name 'Digital Capture Volume'
value.0 60
value.1 60
comment {
type INTEGER
count 2
range '0 - 120'
tlv '0000000100000008fffff44800000032'
dbmin -3000
dbmax 3000
dbvalue.0 0
dbvalue.1 0
state.PCH {
control.1 {
iface MIXER
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -6525
dbvalue.1 -6525
control.2 {
iface MIXER
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.3 {
iface MIXER
value.0 87
value.1 87
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.4 {
iface MIXER
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.5 {
iface MIXER
value Enabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.6 {
iface MIXER
value.0 41
value.1 41
comment {
access 'read write'
type INTEGER
count 2
range '0 - 63'
dbmin -1725
dbmax 3000
dbvalue.0 1350
dbvalue.1 1350
control.7 {
iface MIXER
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.8 {
iface MIXER
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.9 {
iface MIXER
value 80
comment {
access 'read write'
type INTEGER
count 1
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -525
control.10 {
iface MIXER
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.11 {
iface CARD
value true
comment {
access read
type BOOLEAN
count 1
control.12 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.13 {
iface CARD
value true
comment {
access read
type BOOLEAN
count 1
control.14 {
iface PCM
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.15 {
iface PCM
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.16 {
iface CARD
value true
comment {
access read
type BOOLEAN
count 1
control.17 {
iface MIXER
comment {
access read
type IEC958
count 1
control.18 {
iface MIXER
comment {
access read
type IEC958
count 1
control.19 {
iface MIXER
value '0482000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write locked'
type IEC958
count 1
control.20 {
iface MIXER
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.21 {
iface PCM
device 3
name ELD
comment {
type BYTES
count 32
control.22 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.23 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.24 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.25 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.26 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.27 {
iface PCM
device 7
name ELD
value ''
comment {
type BYTES
count 0
control.28 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.29 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.30 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.31 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.32 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.33 {
iface PCM
device 8
name ELD
value ''
comment {
type BYTES
count 0
control.34 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.35 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.36 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.37 {
iface MIXER
index 3
comment {
access 'read write'
type IEC958
count 1
control.38 {
iface MIXER
index 3
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.39 {
iface PCM
device 9
name ELD
value ''
comment {
type BYTES
count 0
control.40 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.41 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.42 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.43 {
iface MIXER
index 4
comment {
access 'read write'
type IEC958
count 1
control.44 {
iface MIXER
index 4
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.45 {
iface PCM
device 10
name ELD
value ''
comment {
type BYTES
count 0
control.46 {
iface PCM
device 3
value.0 3
value.1 4
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.47 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.48 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.49 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.50 {
iface PCM
device 10
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.51 {
iface MIXER
value.0 255
value.1 255
comment {
type INTEGER
count 2
range '0 - 255'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
--endcollapse--
ac
ac97_bus
acer_wireless
acer_wmi
acpi_thermal_rel
aesni_intel
af_alg
agpgart
algif_hash
algif_skcipher
ath
ath10k_core
ath10k_pci
atkbd
battery
blake2b_generic
bluetooth
bnep
btbcm
btintel
btrfs
btrtl
btusb
ccm
cec
cfg80211
cmac
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm
drm_kms_helper
ecc
ecdh_generic
ee1004
evdev
ext4
fat
fb_sys_fops
fixed_phy
fuse
ghash_clmulni_intel
glue_helper
hid
hid_generic
hid_multitouch
hidp
i2c_algo_bit
i2c_hid
i2c_i801
i2c_smbus
i8042
i915
iTCO_vendor_support
iTCO_wdt
idma64
input_leds
int3400_thermal
int3403_thermal
int3406_thermal
intel_cstate
intel_gtt
intel_lpss
intel_lpss_pci
intel_pch_thermal
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_soc_dts_iosf
intel_uncore
ip_tables
irqbypass
jbd2
joydev
kvm
kvm_intel
ledtrig_audio
libarc4
libcrc32c
libphy
libps2
loop
mac80211
mac_hid
mbcache
mc
mdio_devres
mei
mei_hdcp
mei_me
mousedev
msr
nls_cp437
nls_iso8859_1
of_mdio
pcspkr
r8169
raid6_pq
rapl
rc_core
realtek
rfcomm
rfkill
rng_core
serio
serio_raw
sg
snd
snd_aloop
snd_compress
snd_hda_codec
snd_hda_codec_hdmi
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_pcm_dmaengine
snd_seq
snd_seq_device
snd_seq_dummy
snd_soc_acpi
snd_soc_core
snd_soc_hdac_hda
snd_soc_skl
snd_soc_sst_dsp
snd_soc_sst_ipc
snd_sof
snd_sof_intel_byt
snd_sof_intel_hda
snd_sof_intel_ipc
snd_sof_pci
snd_sof_xtensa_dsp
snd_timer
soundcore
sparse_keymap
squashfs
syscopyarea
sysfillrect
sysimgblt
tpm
tpm_crb
tpm_tis
tpm_tis_core
uinput
usbhid
uvcvideo
v4l2loopback_dc
vboxdrv
vboxnetadp
vboxnetflt
vfat
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wmi
wmi_bmof
x_tables
xhci_hcd
xhci_pci
xor
!!Sysfs Files
0x12 0x90a60140
0x13 0x40000000
0x14 0x90170110
0x18 0x411111f0
0x19 0x411111f0
0x1a 0x411111f0
0x1b 0x411111f0
0x1d 0x40700001
0x1e 0x411111f0
0x21 0x02211020
0x05 0x18560010
0x06 0x18560010
0x07 0x18560010
!!ALSA/HDA dmesg
[ 0.115925] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.115925] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.115925] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 3.730435] RAPL PMU: hw unit of domain psys 2^-14 Joules
[ 3.733198] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
[ 3.733215] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 3.741566] r8169 0000:01:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 4.146561] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input13
[ 4.147280] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 4.183723] fbcon: i915drmfb (fb0) is primary device
[ 4.341406] hid-multitouch 0018:06CB:CD40.0003: input,hidraw2: I2C HID v1.00 Mouse [SYNA7DB5:00 06CB:CD40] on i2c-SYNA7DB5:00
[ 4.346954] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC256: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 4.346957] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 4.346958] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 4.346959] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 4.346960] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 4.346961] snd_hda_codec_realtek hdaudioC1D0: Mic=0x12
[ 4.365832] mousedev: PS/2 mouse device common for all mice
[ 4.419828] snd_hda_codec_hdmi hdaudioC1D2: Monitor plugged-in, Failed to power up codec ret=[-13]
[ 4.425106] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1f.3/sound/card1/input18
[ 4.425157] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card1/input19
[ 4.425195] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card1/input20
[ 4.425237] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card1/input21
[ 4.425273] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card1/input22
[ 4.425327] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card1/input23
[ 4.425361] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card1/input24
[ 4.528593] loop: module loaded```
**sudo modprobe -r snd_aloop**
(SNA was an abbreviation for Sandy Bridge New Acceleration from about 10 years ago, which does not seem to relate to this laptop at all )
If the file /etc/modprobe.d/snd-sna-intel.conf only contains the ALSA model option I suggest you delete it
If snd_aloop is in use I suspect it is very likely being used for audio playback instead of the onboard audio
I suggest you reboot system and suspend PulseAudio
pacmd suspend 1
then try the modprobe command in previous again to remove snd_aloop
and finally use this command to de-suspend PulseAudio
pacmd suspend 0
First: pacmd suspend 1
Then sudo modprobe -r snd_aloop
shows the same result as before
Then, I create a .conf in /etc/modprobe.d
with content: blacklist snd_aloop
and I reboot system
Again: sudo modprobe -r snd_aloop
Now its work.
And finally: pacmd suspend 1
pacmd suspend O
But the system only shows: Microphone (Internal) and I can’t choose another.
I checked other Acer models variants for Aspire A514 and found some with 2 microphones detected
https://linux-hardware.org/?view=computers&vendor=Acer&model=Aspire+A514+(All)
systems are showing Mic=0x19
and Internal Mic=0x12
Your ALSA data is showing that 0x19 is an input connection, but is mis-detected as a Speaker connection
To reconfigure the connection to work as a headset microphone:
Install package
alsa-tools
pamac install alsa-tools
(reinstalling is not needed if package is already installed)
Launch the tool to retask audio connections
sudo hdajackretask
Find Pin 0x19 and enable Override option and select Microphone from the list of options
Click Install boot override
close hdajackretask and reboot system to load the override
Shows:
And This:
I configure the 0x19 but system only show: Microphone (Internal, unconnected)
Internal microphone (internal)
hdajacksensetest
That is when I connected the jack directly to the notebook and no to the HDMI/VGA adapter line out.
Pavucontrol:
I tried disconnecting the headphones and system only recognize the notebook mic.
Well, I think the problem is that my computer only has an audio input, bot in VGA/HDMI adapter and computer… that explains why it does not recognize the microphone even if I connect it there.
Finally I had to buy an USB audio adapter and that fixed the problem. So this theme is solved, thanks to all!.
